CẢNH BÁO và TẨY CHAY WEB filethietke ĂN CẮP files (trên DIỄN ĐÀN XD360) rồi xóa logo, xóa tác giảđăng lên web bán với giá cao. Đừng để bị mất tiền oan bởi hành vi ăn cắp của web filethietke bạn nhé!
ASTM 2004-Volume 02.01 Copper and Copper Alloys! u7 c* f1 |- M$ ]( ~& l. A
3 n+ E5 o, `1 M V! ]: GB0005-00 Specification for High Conductivity Tough-Pitch Copper Refinery Shapes 1 w) \! y7 [, w8 F. _B0016_B0016M-00 Specification for Free-Cutting Brass Rod, Bar and Shapes for Use in Screw Machines3 k" r# E! R0 i3 n5 `3 {; F
B0019-01 Specification for Cartridge Brass Sheet, Strip, Plate, Bar, and Disks - F4 n7 C$ o- U6 a* P# sB0021_B0021M-01E01 Specification for Naval Brass Rod, Bar, and Shapes : a5 E- v# D$ E) b- F% M$ L: kB0022-02 Specification for Bronze Castings for Bridges and Turntables ) m8 c; _! w1 p# b9 o/ A7 uB0030-04 Specification for Copper Alloys in Ingot Form* t7 B K; S% O# B. g* U! h
B0036_B0036M-01 Specification for Brass Plate, Sheet, Strip, And Rolled Bar: y& ^! ]/ Y7 A! h
B0042-02E01 Specification for Seamless Copper Pipe, Standard Sizes 1 ]& B4 z. |+ aB0043-98R04 Specification for Seamless Red Brass Pipe, Standard Sizes . d: M* N% d: x2 ~; [% Z: jB0049-98R04 Specification for Copper Rod Drawing Stock for Electrical Purposes* ~# e) L- l! P( O6 `
B0061-02 Specification for Steam or Valve Bronze Castings $ r+ E4 k3 B2 M* h7 t4 ZB0062-02 Specification for Composition Bronze or Ounce Metal Castings ( T. B2 a$ u$ nB0066-95R03 Specification for Bronze Castings for Steam Locomotive Wearing Parts 0 s/ o J) Z9 S: \8 {B0067 Specification for Car and Tender Journal Bearings, Lined4 t. ?0 Q) x" J" y: U, J
B0068-02 Specification for Seamless Copper Tube, Bright Annealed: U0 N, F( H) H$ _) f, k
B0068M-99 Specification for Seamless Copper Tube, Bright Annealed [Metric] & R( v8 f. O: e" s" h5 pB0075-02 Specification for Seamless Copper Tube 1 g' s" |% X. W* sB0075M-99 Specification for Seamless Copper Tube [Metric] # g% v. p; O% k$ b+ I- {0 T- v: SB0088-03 Specification for Seamless Copper Water Tube( C3 Y. G* A8 x. l4 }
B0088M-03 Specification for Seamless Copper Water Tube [Metric]/ u7 ~0 \5 B$ d& z, a) b) Z' ~9 V
B0096_B0096M-01 Specification for Copper-Silicon Alloy Plate, Sheet, Strip, and Rolled Bar for General Purposes and Pressure Vessels $ F {- v& S( S& i: KB0098_B0098M-03 Specification for Copper-Silicon Alloy Rod, Bar and Shapes / z$ _- y, _/ VB0099_B0099M-01 Specification for Copper-Silicon Alloy Wire for General Applications ; I0 e: ~; Y8 C# P8 z, C0 L. g5 E, H1 VB0100-03A Specification for Wrought Copper-Alloy Bearing and Expansion Plates and Sheets for Bridge and Other Structural Use # {" h+ @$ r5 H1 l* k$ A' EB0101-02 Specification for Lead-Coated Copper Sheet and Strip for Building Construction ! s1 @0 s& F# V9 f, f/ ]6 k; F0 tB0103_B0103M-04 Specification for Phosphor Bronze Plate, Sheet, Strip, and Rolled Bar 2 n/ p& L0 H, I, l1 hB0111_B0111M-04 Specification for Copper and Copper-Alloy Seamless Condenser Tubes and Ferrule Stock + X B8 c2 s; H9 @6 aB0111M Specification for Copper and Copper-Alloy Seamless Condenser Tubes and Ferrule Stock [Metric] 8 h% r, o! R& NB0115-00R04 Specification for Electrolytic Copper Cathode . E4 @9 d( c6 J, Q% b, RB0121_B0121M-01 Specification for Leaded Brass Plate, Sheet, Strip, and Rolled Bar% ]5 m0 q( m% m! {0 _/ ]
B0122_B0122M-01 Specification for Copper-Nickel-Tin Alloy, Copper-Nickel-Zinc Alloy (Nickel Silver), and Copper-Nickel Alloy Plate, Sheet, Strip, and Rolled Bar 8 j7 G0 i0 N b. ^. E# v1 s0 cB0124_B0124M-04 Specification for Copper and Copper Alloy Forging Rod, Bar, and Shapes' E# P" \6 D/ M4 k3 F$ x
B0129-02 Specification for Cartridge Brass Cartridge Case Cups 5 h, q! i+ a( ^2 jB0130-02 Specification for Commercial Bronze Strip for Bullet Jackets+ w! H6 f( s& c; h0 G$ g
B0131-02 Specification for Copper Alloy Bullet Jacket Cups ! U9 I4 j d0 V; ?$ Y8 XB0134_B0134M-01 Specification for Brass Wire * y' _1 j2 C2 e7 n% l3 J: nB0135-02 Specification for Seamless Brass Tube" t: c' M: L, g$ k5 Y
B0135M-00E01 Specification for Seamless Brass Tube [Metric] $ ^3 M# X& e3 `. d8 OB0138_B0138M-01 Specification for Manganese Bronze Rod, Bar, and Shapes) n; [9 a x. w, W5 @$ r6 ^/ g
B0139_B0139M-01 Specification for Phosphor Bronze Rod, Bar, and Shapes/ s. T: K# e9 O- D
B0140_B0140M-01 Specification for Copper-Zinc-Lead (Red Brass or Hardware Bronze) Rod, Bar, and Shapes . G6 z' j, i3 K. MB0148-97R03E01 Specification for Aluminum-Bronze Sand Castings ' g$ L9 Q# g1 J6 u# zB0150_B0150M-03 Specification for Aluminum Bronze Rod, Bar, and Shapes' q7 m' G2 Q! c
B0150M Specification for Aluminum Bronze, Rod, Bar, and Shapes [Metric]7 W4 y% Q, @: U) F* {
B0151_B0151M-00 Specification for Copper-Nickel-Zinc Alloy (Nickel Silver) and Copper-Nickel Rod and Bar' r( \2 D }7 U8 O! g9 f
B0152_B0152M-00 Specification for Copper Sheet, Strip, Plate, and Rolled Bar 8 e- a* [6 U" @, w3 }% R, t! MB0153-91R03E01 Test Method for Expansion (Pin Test) of Copper and Copper-Alloy Pipe and Tubing ' p! d+ n u8 H. s+ kB0154-01 Test Method for Mercurous Nitrate Test for Copper and Copper Alloys x# C. N9 F0 J- c: T
B0159_B0159M-01 Specification for Phosphor Bronze Wire ; C0 ^( y5 V- s- }- R1 s0 nB0169_B0169M-01 Specification for Aluminum Bronze Sheet, Strip, and Rolled Bar2 h0 H* b1 ] q* M3 Q6 c0 c
B0170-99R04 Specification for Oxygen-Free Electrolytic Copper\MRefinery Shapes- U7 e5 |2 ~. X
B0171_B0171M-04E01 Specification for Copper-Alloy Plate and Sheet for Pressure Vessels, Condensers, and Heat Exchangers 7 @7 B$ c% V5 w6 j) h/ b7 aB0176-04 Specification for Copper-Alloy Die Castings: P% z- @3 Q( w/ N
B0187_B0187M-03 Specification for Copper, Bus Bar, Rod, and Shapes and General Purpose Rod, Bar, and Shapes 8 w1 T; V. j, t* F5 c' h _1 iB0187M Specification for Copper Bar, Bus Bar, Rod and Shapes [Metric] + M& k6 p% M: ^2 A2 O9 N
B0188-02 Specification for Seamless Copper Bus Pipe and Tube * P; Q, w1 z" F% ~# b. pB0194-01E01 Specification for Copper-Beryllium Alloy Plate, Sheet, Strip, and Rolled Bar 3 T2 w8 ?0 o" }+ k1 u" {B0196_B0196M-03 Specification for Copper-Beryllium Alloy Rod and Bar# e& ]2 z0 w" q' P, K9 c, D
B0197_B0197M-01 Specification for Copper-Beryllium Alloy Wire+ y* U+ S5 `& j" I# c) K9 c/ ?
B0206_B0206M-97R02 Specification for Copper-Nickel-Zinc (Nickel Silver) Wire and Copper-Nickel Alloy Wire5 M# W! l7 G# _9 k4 n6 M' ]
B0208-04 Practice for Preparing Tension Test Specimens for Copper Alloy Sand, Permanent Mold, Centrifugal, and Continuous Castings - Q( |& ~$ h o: P) m2 W+ D; rB0216-97R03 Specification for Tough-Pitch Fire-Refined Copper\MRefinery Shapes, D% f* D$ }3 ~. I+ K( |3 D g
B0224-04 Classification of Coppers / a8 N/ W% F ]# VB0248-01E01 Specification for General Requirements for Wrought Copper and Copper-Alloy Plate, Sheet, Strip, and Rolled Bar - A* D6 Y ~& H7 gB0248M-01E01 Specification for General Requirements for Wrought Copper and Copper-Alloy Plate, Sheet, Strip, and Rolled Bar [Metric]1 o$ I) Q& y9 f ?2 C7 Y) e
B0249_B0249M-04 Specification for General Requirements for Wrought Copper and Copper-Alloy Rod, Bar, Shapes and Forgings 5 |: c4 r2 I, iB0250_B0250M-01 Specification for General Requirements for Wrought Copper Alloy Wire & |) n+ l* q: Q1 \# V4 wB0251-02E01 Specification for General Requirements for Wrought Seamless Copper and Copper-Alloy Tube . V6 }* I* h- M9 W# m& ]. }0 z: xB0251M-97R03 Specification for General Requirements for Wrought Seamless Copper and Copper-Alloy Tube [Metric]& R: t9 `% z. B a) Q
B0271-96R03 Specification for Copper-Base Alloy Centrifugal Castings. f- O! K5 \, w( z5 O, T
B0272-02 Specification for Copper Flat Products with Finished (Rolled or Drawn) Edges (Flat Wire and Strip) 1 x, U: d+ O- l7 ^0 x, [B0280-03 Specification for Seamless Copper Tube for Air Conditioning and Refrigeration Field Service8 Q; r5 q; Q/ o2 s0 c1 l# {+ c
B0283-04 Specification for Copper and Copper-Alloy Die Forgings (Hot-Pressed)+ x: ]4 c( m: F% D/ L- Z
B0301_B0301M-04 Specification for Free-Cutting Copper Rod, Bar, Wire, and Shapes6 i' B: z) k& X+ Z4 v9 A- ~) c
B0302-02 Specification for Threadless Copper Pipe, Standard Sizes 4 g( O+ t3 B \* JB0306-02 Specification for Copper Drainage Tube (DWV) ' }4 ]8 X( X" OB0315-99 Specification for Seamless Copper Alloy Pipe and Tube % X8 |: D) x5 i6 x- K; Q# t5 V3 rB0359_B0359M-02 Specification for Copper and Copper-Alloy Seamless Condenser and Heat Exchanger Tubes With Integral Fins + P( }- d2 h: c3 B) ~' KB0359M Specification for Copper and Copper-Alloy Seamless Condenser and Heat Exchanger Tubes with Integral Fins [Metric]1 F% M( n0 I. Y. |6 ^; m3 Y1 S
B0360-01 Specification for Hard-Drawn Copper Capillary Tube for Restrictor Applications G/ g$ t# F5 v# x' o; bB0369-96R03 Specification for Copper-Nickel Alloy Castings : g: L( d7 m- aB0370-03 Specification for Copper Sheet and Strip for Building Construction - g! |: Z& D+ jB0371_B0371M-02 Specification for Copper-Zinc-Silicon Alloy Rod " t) ?* X# G$ p) R5 eB0372-97R03 Specification for Seamless Copper and Copper-Alloy Rectangular Waveguide Tube ' i0 {2 F* [% ]. M% WB0379-04 Specification for Phosphorized Coppers\MRefinery Shapes. K! k, H5 _: J) y H
B0395_B0395M-02 Specification for U-Bend Seamless Copper and Copper Alloy Heat Exchanger and Condenser Tubes 9 y) r" M7 w# f) C* h) zB0395M Specification for U-Bend Seamless Copper and Copper Alloy Heat Exchanger and Condenser Tubes [Metric] 5 M1 o7 v2 P; G8 ]- H4 e+ b
B0411_B0411M-01 Specification for Copper-Nickel-Silicon Alloy Rod and Bar4 x9 k, T: }- B, l/ Y+ u5 I
B0422-04 Specification for Copper-Aluminum-Silicon-Cobalt Alloy, Copper-Nickel-Silicon-Magnesium Alloy, Copper-Nickel-Silicon Alloy, Copper-Nickel-Aluminum-Magnesium Alloy, and Copper-Nickel-Tin Alloy Sheet and Strip7 S3 ~8 g" v% P8 v, M4 ]
B0427-02 Specification for Gear Bronze Alloy Castings ) p; s! W( f1 aB0428-93R04 Test Method for Angle of Twist in Rectangular and Square Copper and Copper Alloy Tube$ n- A$ d! h( m+ q
B0432-04 Specification for Copper and Copper Alloy Clad Steel Plate 3 f- s& P- L9 |. t& ]1 qB0441-04 Specification for Copper-Cobalt-Beryllium, Copper-Nickel-Beryllium, and Copper-Nickel-Lead-Beryllium Rod and Bar (UNS Nos. C17500, C17510, and C17465) 8 j6 c! y7 t q6 ^8 N$ wB0447-02 Specification for Welded Copper Tube; e( |# P. p7 t! O" w5 p6 Q
B0453_B0453M-01 Specification for Copper-Zinc-Lead Alloy (Leaded-Brass) Rod, Bar, and Shapes 5 Y: R% @+ Y0 z- n dB0455-01 Specification for Copper-Zinc-Lead Alloy (Leaded-Brass) Extruded Shapes2 E0 I1 U3 z+ i" M1 s
B0465-04 Specification for Copper-Iron Alloy Plate, Sheet, Strip, and Rolled Bar # a4 k( c5 o1 w7 yB0466_B0466M-03 Specification for Seamless Copper-Nickel Pipe and Tube) j# B8 t* E4 j6 J
B0467-88R03 Specification for Welded Copper-Nickel Pipe % a0 Q _, H F9 {; w! }B0505_B0505M-04 Specification for Copper Alloy Continuous Castings- W* S: x7 i* \! T2 f( k
B0508-97R03 Specification for Copper Alloy Strip for Flexible Metal Hose" x# P0 O3 X0 I Q, m& M& B. s
B0534-01 Specification for Copper-Cobalt-Beryllium Alloy and Copper-Nickel-Beryllium Alloy Plate, Sheet, Strip, and Rolled Bar 3 X& c) M0 e8 X& J8 @7 X
B0543-96R03 Specification for Welded Copper and Copper-Alloy Heat Exchanger Tube% N1 ]6 c9 E) }+ ]$ a* t+ Y: g! E
B0552-98R04 Specification for Seamless and Welded Copper\NNickel Tubes for Water Desalting Plants9 I! j% J" k1 ^; R# M) ^* X2 E
B0569-04 Specification for Brass Strip in Narrow Widths and Light Gage for Heat-Exchanger Tubing ( W9 [8 f4 x9 Y1 `2 VB0570-01 Specification for Copper-Beryllium Alloy (UNS No. C17000 and C17200) Forgings and Extrusions- [" b4 ~9 B1 Q# s* C
B0577-93R04E01 Test Methods for Detection of Cuprous Oxide (Hydrogen Embrittlement Susceptibility) in Copper 0 o0 P7 a! H- V7 OB0584-04 Specification for Copper Alloy Sand Castings for General Applications8 a( b5 u: a0 |5 u" N
B0587-97R03 Specification for Welded Brass Tube2 @) j( v$ \ E3 m* N+ X
B0591-04 Specification for Copper-Zinc-Tin and Copper-Zinc-Tin-Iron-Nickel Alloys Plate, Sheet, Strip, and Rolled Bar& J8 {$ ^' {: e0 o2 o
B0592-01 Specification for Copper-Zinc-Aluminum-Cobalt Alloy, Copper-Zinc-Tin-Iron Alloy Plate, Sheet, Strip, and Rolled Bar 1 P, z$ N; m3 K6 t% k8 d. [; f5 oB0593-96R03E01 Test Method for Bending Fatigue Testing for Copper-Alloy Spring Materials' D' s) Y: P d; A6 d/ d/ c* u
B0598-98R04 Practice for Determining Offset Yield Strength in Tension for Copper Alloys 8 n$ E( c8 Y3 Q: [B0601-02 Classification for Temper Designations for Copper and Copper Alloys\MWrought and Cast 3 c5 N4 z& }" d" M- A! [3 I
B0608-02 Specification for Welded Copper-Alloy Pipe* J. [! @: E X( X. I: H' U
B0640-00 Specification for Welded Copper Tube for Air Conditioning and Refrigeration Service1 j0 W, x9 l G5 D$ C3 Q, T: P
B0643-00E01 Specification for Copper-Beryllium Alloy Seamless Tube 2 I# f: F, G3 L: ?B0644-95R03 Specification for Copper Alloy Addition Agents' B/ Q" n- s: v. t( K
B0687-99 Specification for Brass, Copper, and Chromium-Plated Pipe Nipples B0694-03 Specification for Copper, Copper-Alloy, Copper-Clad Bronze (CCB), Copper-Clad Stainless Steel (CCS), and Copper-Clad Alloy Steel (CAS) Sheet and Strip for Electrical Cable Shielding . m% j0 |; I. x; [: ?1 {B0698-02 Classification for Seamless Copper and Copper Alloy Plumbing Pipe and Tube ( X+ }) M* _( c5 N8 ?" ~( U/ GB0706-00 Specification for Seamless Copper Alloy (UNS No. C69100) Pipe and Tube l6 _, T# j3 h. t
B0740-02 Specification for Copper-Nickel-Tin Spinodal Alloy Strip 9 V) [& R4 G6 c5 c$ `B0743-00 Specification for Seamless Copper Tube in Coils - s+ ]( Q6 i+ r" O( dB0747-02 Specification for Copper-Zirconium Alloy Sheet and Strip- B4 S% U$ J5 M3 Z8 q) G: s# s* r- b
B0754-89R99E01 Test Method for Measuring and Recording the Deviations from Flatness in Copper and Copper Alloy Strip & k q7 Y6 R! x( t/ U2 D! pB0763-04 Specification for Copper Alloy Sand Castings for Valve Applications+ [4 q* ~ t: l0 n8 @& c
B0768-99R04 Specification for Copper-Cobalt-Beryllium Alloy and Copper-Nickel-Beryllium Alloy Strip and Sheet v& n- [/ t s. Z) _B0770-02 Specification for Copper-Beryllium Alloy Sand Castings for General Applications % J% a1 G9 ~1 |- f, I5 v! v
B0806-04 Specification for Copper Alloy Permanent Mold Castings for General Applications / l% I) x( V( w gB0813-00E01 Specification for Liquid and Paste Fluxes for Soldering of Copper and Copper Alloy Tube 6 E% ~' [1 C+ Y p- l; kB0819-00 Specification for Seamless Copper Tube for Medical Gas Systems% a5 ?2 z6 o) @) O/ _7 V4 ^
B0820-04E01 Test Method for Bend Test for Determining the Formability of Copper and Copper Alloy Strip 4 }& i! i8 h ]/ k2 WB0824-04 Specification for General Requirements for Copper Alloy Castings) K9 U& _4 r- ^$ A
B0828-02 Practice for Making Capillary Joints by Soldering of Copper and Copper Alloy Tube and Fittings9 A* K+ V' l b! m# `! S# q
B0837-01 Specification for Seamless Copper Tube for Natural Gas and Liquified Petroleum (LP) Gas Fuel Distribution Systems - K+ a& J6 \4 ?+ U ~3 g/ b) qB0846-01E01 Terminology for Copper and Copper Alloys$ T2 ]; q5 Q. ]( `$ e% K3 Y, q3 o
B0858-01 Test Method for Ammonia Vapor Test for Determining Susceptibility to Stress Corrosion Cracking in Copper Alloys2 i4 w1 [; {4 \/ U! \6 Z& u
B0870-02 Specification for Copper-Beryllium Alloy Forgings and Extrusions Alloys (UNS Nos. C17500 and C17510). R- M/ t. x1 d/ |8 ]
B0876 Specification for Borated Dispersion Strengthened Copper Plate, Sheet, Strip, and Rolled Bar for Nuclear Application , H! |: b; S% W6 e, a2 j% @) e, mB0882-00 Specification for Pre-Patinated Copper for Architectural Applications4 o9 A' Q1 J! Z& R8 s$ G
B0888-04 Specification for Copper Alloy Strip for Use in Manufacture of Electrical Connectors or Spring Contacts - G* I. G5 O5 R2 W2 ^B0900-04 Practice for Packaging of Copper and Copper Alloy Mill Products for U.S. Government Agencies + W ^+ y5 a( a1 {. {B0903-00 Specification for Seamless Copper Heat Exchanger Tubes With Internal Enhancement3 N% E; L% n- ^4 R% C
B0919-01 Specification for Welded Copper Heat Exchanger Tubes With Internal Enhancement2 P! r( D1 p: s8 \6 Q
B0927-03 Specification for Brass Rod, Bar, and Shapes B m$ j8 M: e8 {6 w/ v8 n
B0936-04 Specification for Copper-Chrome-Iron-Titanium Alloy Plate, Sheet, Strip and Rolled Bar + Q6 F2 _1 P) C( q* dB0937-04 Specification for Copper-Beryllium Seamless Tube (UNS Nos. C17500 and C17510) 5 ^( \- a, c' LB0938-04 Specification for Copper-Beryllium Alloy Forgings and Extrusions (UNS Nos. C17500 and C17510)2 ]/ ~) O! y# k% U- o% P! b1 o( [6 I
F0068-99R04 Specification for Oxygen-Free Copper in Wrought Forms for Electron Devices . U- @! k! q7 e, U
