ASTM 2004 -Volume 02.02 Aluminum and Magnesium Alloys
3 B% i) `2 v D, `, n- t; eB0026_B0026M-03 Specification for Aluminum-Alloy Sand Castings8 X# k. B% Q4 f) D
B0037-03 Specification for Aluminum for Use in Iron and Steel Manufacture* C4 z3 P3 C- D6 K) ?& y
B0080-01E01 Specification for Magnesium-Alloy Sand Castings* |/ c( g6 u, _+ P" m& M
B0085-03 Specification for Aluminum-Alloy Die Castings
9 |/ V8 Y& {9 ` v8 Z. AB0090_B0090M-98R05 Specification for Magnesium-Alloy Sheet and Plate
$ {1 |! d: L# cB0091-97R04 Specification for Magnesium-Alloy Forgings" b( g, u) ^5 f z
B0092_B0092M-01 Specification for Unalloyed Magnesium Ingot and Stick For Remelting# o* z- O" P2 g
B0093_B0093M-04 Specification for Magnesium Alloys in Ingot Form for Sand Castings, Permanent Mold Castings, and Die Castings/ ~( ?! q; ~$ q; F& L% I8 _
B0094-05 Specification for Magnesium-Alloy Die Castings5 L( w; Y; a: S: q, D
B0107_B0107M-00 Specification for Magnesium-Alloy Extruded Bars, Rods, Profiles, Tubes, and Wire
+ y+ n6 J7 ?5 q' S# oB0108-03A Specification for Aluminum-Alloy Permanent Mold Castings. W* Y$ @$ |- w
B0179-03 Specification for Aluminum Alloys in Ingot and Molten Forms for Castings from All Casting Processes5 i) Q# O2 J- R
B0199-99R05 Specification for Magnesium-Alloy Permanent Mold Castings
5 z9 u1 S; _0 u4 DB0209-04 Specification for Aluminum and Aluminum-Alloy Sheet and Plate9 S: C* Z, P# J& e! v) J5 _+ a
B0209M-04 Specification for Aluminum and Aluminum-Alloy Sheet and Plate \[Metric\]3 L1 I5 ]/ \- D( v6 n
B0210-04 Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes) j; l+ \* S6 S T
B0210M-05 Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes \[Metric\]
% T9 N3 i, @8 Q7 o9 `* JB0211-03 Specification for Aluminum and Aluminum-Alloy Bar, Rod, and Wire
, M8 ?( F8 w5 c/ tB0211M-03 Specification for Aluminum and Aluminum-Alloy Bar, Rod, and Wire \[Metric\]% t+ S- L: T2 n N# ~& [* P
B0221-05 Specification for Aluminum and Aluminum-Alloy Extruded Bars, Rods, Wire, Profiles, and Tubes
7 [: u- z) X7 c3 x) C- SB0221M-05 Specification for Aluminum and Aluminum-Alloy Extruded Bars, Rods, Wire, Profiles, and Tubes \[Metric\]3 G" {# d6 M. x2 }( o1 q
B0234-04 Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes for Condensers and Heat Exchangers I! ^8 L2 g" n% G5 y1 L% w' i* a
B0234M-04 Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes for Condensers and Heat Exchangers \[Metric\]
1 M M$ M8 q* Z# W1 h4 }B0236-00 Specification for Aluminum Bars for Electrical Purposes (Bus Bars)
- ]4 ~4 Q# Q9 k! F4 A" kB0236M-00 Specification for Aluminum Bars for Electrical Purposes (Bus Bars) \[Metric\]1 t3 [8 |; L @: H" `% K* d
B0241_B0241M-02 Specification for Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube
4 S. D$ M- A7 v: hB0247-02A Specification for Aluminum and Aluminum-Alloy Die Forgings, Hand Forgings, and Rolled Ring Forgings
! }# I& J, u3 ?& m- UB0247M-02A Specification for Aluminum and Aluminum-Alloy Die Forgings, Hand Forgings, and Rolled Ring Forgings \[Metric\]
1 ^5 y. M/ U; u: b M1 h- lB0275-04 Practice for Codification of Certain Nonferrous Metals and Alloys, Cast and Wrought
( h4 w- S# c8 RB0296-03 Practice for Temper Designations of Magnesium Alloys, Cast and Wrought
% S) a0 [7 e( O$ h, eB0308_B0308M-02 Specification for Aluminum-Alloy 6061-T6 Standard Structural Profiles6 A; V0 ^& S; y2 H4 m3 t
B0313_B0313M-02E01 Specification for Aluminum and Aluminum-Alloy Round Welded Tubes
- @0 K/ `1 x# x. N2 v4 |( DB0316_B0316M-02 Specification for Aluminum and Aluminum-Alloy Rivet and Cold-Heading Wire and Rods
3 f& G3 g- I/ pB0317_B0317M-04 Specification for Aluminum-Alloy Extruded Bar, Rod, Tube, Pipe, and Structural Profiles for Electrical Purposes (Bus Conductor)0 i+ I3 G7 U. K( D# t
B0345_B0345M-02 Specification for Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube for Gas and Oil Transmission and Distribution Piping Systems
* C# J5 Q2 i0 S% @7 Y- ZB0361-02 Specification for Factory-Made Wrought Aluminum and Aluminum-Alloy Welding Fittings
8 Q& D) L8 S' V$ hB0373-00 Specification for Aluminum Foil for Capacitors
: I3 c! M4 H1 g/ P% p" B; DB0403-02 Specification for Magnesium-Alloy Investment Castings
7 j1 R8 d$ t! o G, m; EB0404_B0404M-02 Specification for Aluminum and Aluminum-Alloy Seamless Condenser and Heat-Exchanger Tubes with Integral Fins
! R! f! F# b6 e' }, cB0429-02 Specification for Aluminum-Alloy Extruded Structural Pipe and Tube
2 J$ I! y r6 @* f) X9 cB0479-00 Specification for Annealed Aluminum and Aluminum-Alloy Foil for Flexible Barrier, Food Contact, and Other Applications
& g4 R( ?9 z+ a# D4 ~( m0 nB0483_B0483M-03 Specification for Aluminum and Aluminum-Alloy Drawn Tube and Pipe for General Purpose Applications' o0 o% E3 j9 k9 ~: k
B0491_B0491M-00 Specification for Aluminum and Aluminum-Alloy Extruded Round Tubes for General-Purpose Applications
/ |5 v ]) s& w8 f- ?B0547_B0547M-02 Specification for Aluminum and Aluminum-Alloy Formed and Arc-Welded Round Tube
0 F6 O& K. ]; C/ V5 ]) P) }6 YB0548-03 Test Method for Ultrasonic Inspection of Aluminum-Alloy Plate for Pressure Vessels
9 B) Q$ I# T' M" L9 k, m+ pB0557-02A Test Methods of Tension Testing Wrought and Cast Aluminum- and Magnesium-Alloy Products" A0 i% O) q' C; F3 _( O$ M
B0557M-02A Test Methods of Tension Testing Wrought and Cast Aluminum- and Magnesium-Alloy Products \[Metric\]6 |9 ]4 _- g4 S, Q4 L1 X. K
B0565-04 Test Method for Shear Testing of Aluminum and Aluminum-Alloy Rivets and Cold-Heading Wire and Rods
( t8 n% `5 R. ^) s. SB0594-02 Practice for Ultrasonic Inspection of Aluminum-Alloy Wrought Products for Aerospace Applications: C% V3 S; ^/ Q* b; J
B0597 Practice for Heat Treatment of Aluminum Alloys0 E# X; z; L! f: P# x( w
B0618-03 Specification for Aluminum-Alloy Investment Castings
5 E: ]: I, Z/ X& ZB0632_B0632M-02 Specification for Aluminum-Alloy Rolled Tread Plate, |( Y; T# V" b$ A- L% U
B0645-02 Practice for Plane\NStrain Fracture Toughness Testing of Aluminum Alloys! Q. V8 E; Q1 H2 n# G8 V
B0646-04 Practice for Fracture Toughness Testing of Aluminum Alloys$ o5 F* {8 S: m1 ^; Y" n5 C
B0647-84R00 Test Method for Indentation Hardness of Aluminum Alloys by Means of a Webster Hardness Gage
8 L6 u; g4 Q5 P- ~) `* Q8 a! {B0648-78R00 Test Method for Indentation Hardness of Aluminum Alloys by Means of a Barcol Impressor2 M" k7 h& v( n( F. I: R2 _
B0660-02 Practices for Packaging/Packing of Aluminum and Magnesium Products& k) Z9 E" Y, ]6 X4 q, }
B0661-03 Practice for Heat Treatment of Magnesium Alloys
. y: ^5 V7 I4 n% l; @3 M( j( r$ fB0666_B0666M-01 Practice for Identification Marking of Aluminum and Magnesium Products
7 f$ q+ Y7 b6 Y7 J4 r% B6 fB0686-03 Specification for Aluminum Alloy Castings, High-Strength
; X! ^: c% K& ^. IB0724-00 Test Method for Indentation Hardness of Aluminum Alloys by Means of a Newage, Portable, Non-Caliper-Type Instrument# m8 k: J0 a7 {' ?0 ?6 D
B0736-00 Specification for Aluminum, Aluminum Alloy, and Aluminum-Clad Steel Cable Shielding Stock
0 ]1 Z/ o4 c5 P" l- H& _* j# {* MB0744_B0744M-05 Specification for Aluminum Alloy Sheet for Corrugated Aluminum Pipe" A5 p9 t% r9 L" o/ O
B0745_B0745M-97 Specification for Corrugated Aluminum Pipe for Sewers and Drains
9 k6 ]- p( [7 H1 `B0746_B0746M-02 Specification for Corrugated Aluminum Alloy Structural Plate for Field-Bolted Pipe, Pipe-Arches, and Arches4 W' x8 O5 K8 z6 B0 i
B0769-94R00 Test Method for Shear Testing of Aluminum Alloys+ w1 j& [* o" P+ E$ i/ F5 m: |: e( D3 H
B0788_B0788M-04 Practice for Installing Factory-Made Corrugated Aluminum Culverts and Storm Sewer Pipe
$ ^# a1 |, F) r) |! k# aB0789_B0789M-99R05 Practice for Installing Corrugated Aluminum Structural Plate Pipe for Culverts and Sewers+ w, } d% U4 i' h9 x7 g# E% I. @
B0790_B0790M-00 Practice for Structural Design of Corrugated Aluminum Pipe, Pipe-Arches, and Arches for Culverts, Storm Sewers, and Other Buried Conduits2 G: G! m& q }4 N! Z9 p9 K
B0807-02 Practice for Extrusion Press Solution Heat Treatment for Aluminum Alloys7 `' l5 m/ i: e6 F6 q% I+ \
B0831-05 Test Method for Shear Testing of Thin Aluminum Alloy Products, p4 V5 o* }$ \! p p& L
B0843-93R03 Specification for Magnesium Alloy Anodes for Cathodic Protection
2 {7 J3 \% N: ^+ aB0864_B0864M-00 Specification for Corrugated Aluminum Box Culverts$ [7 o! G7 _8 ]; s" R9 K
B0871-01 Test Method for Tear Testing of Aluminum Alloy Products
0 ^. X! \$ ^& t2 L h8 xB0881-98AR04 Terminology Relating to Aluminum- and Magnesium-Alloy Products
8 E- a! |5 d/ N* c' {+ A o. sB0909-00 Guide for Plane Strain Fracture Toughness Testing of Non-Stress Relieved Aluminum Products4 r z7 a" \# g$ a
B0917_B0917M-01 Practice for Heat Treatment of Aluminum-Alloy Castings from All Processes' _/ \' S& g; X6 x: S
B0918-01 Practice for Heat Treatment of Wrought Aluminum Alloys
0 h5 p @, g6 @B0926-03 Method for Pinhole Determination in Aluminum and Aluminum Alloy Plain Foil by Means of a Light Table5 _ L# _0 h- [! Q, l5 u
B0928_B0928M-04A Specification for High Magnesium Aluminum-Alloy Sheet and Plate for Marine Service and Similar Environments
# r: y6 a0 n) p2 ME0252-05 Test Method for Thickness of Thin Foil, Sheet, and Film by Mass Measurement3 G! H& G4 s; W1 E9 Y2 H; [! o
B 26 – B 26M – 01 ;QJI2LTAX.pdf
116.06 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 26 – B 26M – 02 ;QJI2L0IYNK0TUKVE.pdf
107.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 26 – B 26M – 02 ;QJI2LTAY.pdf
119.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 26 – B 26M – 03 ;QJI2L0IYNK0_.pdf
135.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 26 – B 26M – 99 ;QJI2LTK5.pdf
85.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 37 – 03 ;QJM3.pdf
34.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 37 – 96 ;QJM3LTK2.pdf
18.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 37 – 96 R01 ;QJM3LTK2UJAX.pdf
28.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 37 – 96 R01 ;QJM3LVJFRA__.pdf
39.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 80 – 01 ;QJGW.pdf
117.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 80 – 01 ;QJGWLTAX.pdf
111.15 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
B 80 – 97 ;QJGWLTK3.pdf
83.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 85 – 02 ;QJG1LTAY.pdf
62.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 85 – 02 ;QJG1LVJFRA__.pdf
86.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 85 – 03 ;QJG1.pdf
65.51 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 85 – 99 ;QJG1LTK5.pdf
38.8 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 90 – B 90M – 98 ;QJKWL0I5ME0_.pdf
65.21 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 91 – 97 ;QJKXLTK3.pdf
40.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 91 – 97 R04 ;QJKX.pdf
39.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 92 – B92M – 89 R94 ;QJKYL0I5MK0TUKVE.pdf
23.53 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 92 – B92M – 89 R94 ;QJKYLTG5UJK0RTE_.pdf
19.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 92 – B 92M – 01 ;QJKYL0I5MK0_.pdf
25.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 93 – B 93M – 00 ;QJKZL0I5M00TUKVE.pdf
32.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 93 – B 93M – 00 ;QJKZLTAW.pdf
37.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 93 – B 93M – 03 ;QJKZL0I5M00_.pdf
35.56 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 94 – 94 R00 ;QJK0.pdf
46.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 107 – B 107M – 00 ;QJEWNY9CMTA3TQ__.pdf
148.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 107 – B 107M – 94 ;QJEWNY05NA__.pdf
115.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 107 – B 107M – 94 ;QJEWNY9CMTA3TS1SRUQ_.pdf
138.3 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 01 ;QJEWOC0WMQ__.pdf
94.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 01 ;QJEWOC0WMUE_.pdf
124.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 02 ;QJEWOC0WMG__.pdf
178.86 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 03 ;QJEWOA__.pdf
179.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 03 ;QJEWOC0WMW__.pdf
187.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 03 ;QJEWOC1SRUQ_.pdf
151.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 108 – 99 ;QJEWOC05OQ__.pdf
91.77 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 179 – 03 ;QJE3OQ__.pdf
73.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 179 – 96 ;QJE3OS1SRUQ_.pdf
39.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 179 – 96 ;QJE3OS05NG__.pdf
57.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 199 – 99 ;QJE5OQ__.pdf
49.3 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 00 ;QJIWOS0WMA__.pdf
111.38 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 209 – 01 ;QJIWOS0WMQ__.pdf
108.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 02 ;QJIWOS0WMG__.pdf
191.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 02 ;QJIWOS0WMKE_.pdf
180.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 02 ;QJIWOS0WMKUX.pdf
204.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 02 ;QJIWOS1SRUQ_.pdf
135.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209 – 04 ;QJIWOQ__.pdf
177.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209M – 02 ;QJIWOU0TMDI_.pdf
233.2 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 209M – 02 ;QJIWOU0TMDJFMQ__.pdf
242.93 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209M – 03 ;QJIWOU0TMDM_.pdf
221 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209M – 03 ;QJIWOU0TUKVE.pdf
204.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 209M – 04 ;QJIWOU0_.pdf
227.02 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 210 – 00 ;QJIXMC0WMA__.pdf
95.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 210 – 00 ;QJIXMC1SRUQ_.pdf
70.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 210 – 02 ;QJIXMA__.pdf
93.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 210M – 00 ;QJIXME0TMDA_.pdf
99.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 210M – 00 ;QJIXME0TUKVE.pdf
74.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 210M – 02 ;QJIXME0_.pdf
97.5 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 211 – 00 ;QJIXMS0WMA__.pdf
79.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211 – 02 ;QJIXMS0WMG__.pdf
82.38 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211 – 02 ;QJIXMS1SRUQ_.pdf
60.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211 – 03 ;QJIXMQ__.pdf
74.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211M – 01 ;QJIXMU0TMDE_.pdf
89.31 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 211M – 02 ;QJIXMU0TMDI_.pdf
92.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211M – 02 ;QJIXMU0TUKVE.pdf
64.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 211M – 03 ;QJIXMU0_.pdf
84.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 221 – 00 ;QJIYMS0WMA__.pdf
193.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 221 – 00 ;QJIYMS1SRUQ_.pdf
70 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 221 – 02 ;QJIYMQ__.pdf
B 221M – 00 ;QJIYMU0TMDA_.pdf
190.44 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 221M – 00 ;QJIYMU0TUKVE.pdf
96.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 221M – 02 ;QJIYMU0_.pdf
105.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234 – 00 ;QJIZNC0WMA__.pdf
64.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234 – 00 ;QJIZNC1SRUQ_.pdf
43.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234 – 02 ;QJIZNA__.pdf
64.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234M – 00 ;QJIZNE0TMDA_.pdf
55.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234M – 00 ;QJIZNE0TUKVE.pdf
41.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 234M – 02 ;QJIZNE0_.pdf
56.31 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 236 – 00 ;QJIZNG__.pdf
60.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 236 – 95 ;QJIZNI1SRUQ_.pdf
41.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 236M – 00 ;QJIZNK0_.pdf
59.36 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 236M – 95 ;QJIZNK0TUKVE.pdf
41.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 241 – B 241M – 00 ;QJI0MS0WMA__.pdf
289.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 241 – B 241M – 00 ;QJI0MS9CMJQXTS1SRUQ_.pdf
482 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
B 241 – B 241M – 02 ;QJI0MS9CMJQXTQ__.pdf
124.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247 – 02 ;QJI0NW__.pdf
90.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247 – 02 ;QJI0NY0WMG__.pdf
97.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247 – 02 ;QJI0NY1SRUQ_.pdf
62.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247M – 02 ;QJI0N00_.pdf
100.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247M – 02 ;QJI0N00TMDI_.pdf
107.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 247M – 02 ;QJI0N00TUKVE.pdf
67.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 275 – 02 ;QJI3NS0WMG__.pdf
51.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 275 – 02 ;QJI3NS0WMKUX.pdf
56.86 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 275 – 02 ;QJI3NS1SRUQ_.pdf
39.93 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 275 – 04 ;QJI3NQ__.pdf
41.77 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 275 – 96 ;QJI3NS05NG__.pdf
31.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 296 – 03 ;QJI5NG__.pdf
35.48 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 296 – 96 ;QJI5NI05NG__.pdf
37.02 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 308 – B 308M – 00 ;QJMWOC0WMA__.pdf
35.56 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 308 – B 308M – 00 ;QJMWOC9CMZA4TS1SRUQ_.pdf
41.14 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 308 – B 308M – 02 ;QJMWOC9CMZA4TQ__.pdf
52.32 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 313 – B 313M – 00 ;QJMXMY0WMA__.pdf
48.12 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 313 – B 313M – 02 ;QJMXMY0WMG__.pdf
68.66 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 313 – B 313M – 02 ;QJMXMY9CMZEZTQ__.pdf
77.97 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 313 – B 313M – 02 ;QJMXMY9CMZEZTS1SRUQ_.pdf
52.79 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 316 – B 316M – 00 ;QJMXNI0WMA__.pdf
63.75 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 316 – B 316M – 00 ;QJMXNI9CMZE2TS1SRUQ_.pdf
45.24 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 316 – B 316M – 02 ;QJMXNI9CMZE2TQ__.pdf
60.93 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 317 – 00 ;QJMXNY0WMA__.pdf
71.5 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 317 – 00 ;QJMXNY1SRUQ_.pdf
47.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
B 317 – 02 ;QJMXNW__.pdf
B 345 – B 345M – 00 ;QJM0NS0WMA__.pdf
56.81 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 345 – B 345M – 00 ;QJM0NS9CMZQ1TS1SRUQ_.pdf
58.02 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 345 – B 345M – 02 ;QJM0NS9CMZQ1TQ__.pdf
85.12 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
116.06 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
107.33 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
119.99 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
135.26 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
85.85 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 37 – 03 ;QJM3.pdf
34.29 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
18.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
28.85 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
39.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 80 – 01 ;QJGW.pdf
117.52 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
111.15 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
83.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
62.59 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
86.43 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 85 – 03 ;QJG1.pdf
65.51 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
38.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
65.21 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
40.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
39.29 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
23.53 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
19.14 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
25.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
32.7 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
37.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
35.56 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
46.98 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
148.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
115.15 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
138.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
94.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
124.19 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
178.86 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
179.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
187.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
151.68 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
91.77 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
73.24 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
39.67 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
57.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
49.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
111.38 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
108.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
191.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
180.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
204.67 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
135.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
177.46 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
233.2 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
242.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
221 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
204.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
227.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
95.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
70.15 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
93.19 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
99.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
74.73 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
97.5 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
79.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
82.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
60.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
74.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
89.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
92.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
64.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
84.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
193.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
70 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
99.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
190.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
96.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
105.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
64.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
43.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
64.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
55.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
41.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
56.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
60.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
41.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
59.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
41.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
289.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
482 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
124.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
90.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
97.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
62.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
100.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
107.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
67.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
51.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
56.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
39.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
41.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
31.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
35.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
37.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
35.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
41.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
52.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
48.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
68.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
77.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
52.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
63.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
45.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
60.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
71.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
47.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
56.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
58.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
85.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 361 – 02 ;QJM2MQ__.pdf
46.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 361 – 95 ;QJM2MS1SRUQ_.pdf
40.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 373 – 00 ;QJM3MW__.pdf
50.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 373 – 95 ;QJM3MY1SRUQ_.pdf
38.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 403 – 02 ;QJQWMW__.pdf
37.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 403 – 96 ;QJQWMY1SRUQ_.pdf
29.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 403 – 96 ;QJQWMY05NG__.pdf
23.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 404 – B 404M – 00 ;QJQWNC0WMA__.pdf
48.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 404 – B 404M – 00 ;QJQWNC9CNDA0TS1SRUQ_.pdf
48.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 404 – B 404M – 02 ;QJQWNC9CNDA0TQ__.pdf
66.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 429 – 00 ;QJQYOS0WMA__.pdf
42.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 429 – 00 ;QJQYOS1SRUQ_.pdf
43.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 429 – 02 ;QJQYOQ__.pdf
64.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 479 – 00 ;QJQ3OQ__.pdf
65.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 479 – 97 ;QJQ3OS1SRUQ_.pdf
53.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 483 – B 483M – 00 ;QJQ4MY0WMA__.pdf
47.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 483 – B 483M – 02 ;QJQ4MY0WMG__.pdf
71.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 483 – B 483M – 02 ;QJQ4MY9CNDGZTS1SRUQ_.pdf
80.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 483 – B 483M – 03 ;QJQ4MY9CNDGZTQ__.pdf
74.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 491 – B 491M – 00 ;QJQ5MS9CNDKXTQ__.pdf
38.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 491 – B 491M – 95 ;QJQ5MS9CNDKXTS1SRUQ_.pdf
50.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 547 – B 547M – 00 ;QJU0NY0WMA__.pdf
58.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 547 – B 547M – 00 ;QJU0NY9CNTQ3TS1SRUQ_.pdf
58.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 547 – B 547M – 02 ;QJU0NY9CNTQ3TQ__.pdf
82.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 548 – 03 ;QJU0OA__.pdf
51.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 548 – 90 R97 ;QJU0OC1SRUQ_.pdf
42.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 548 – 90 R97 ;QJU0OC05MFI5NW__.pdf
54.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 557 – 02 ;QJU1NW__.pdf
196.49 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 557 – 02 ;QJU1NY0WMG__.pdf
204.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 557 – 02 ;QJU1NY1SRUQ_.pdf
161.27 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
B 557M – 02 ;QJU1N00_.pdf
190.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 557M – 02 ;QJU1N00TMDI_.pdf
200.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 557M – 02 ;QJU1N00TUKVE.pdf
161.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 565 – 04 ;QJU2NQ__.pdf
41.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 565 – 94 R00 ;QJU2NS1SRUQ_.pdf
38.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 565 – 94 R00 ;QJU2NS05NFIWMA__.pdf
41.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 594 – 02 ;QJU5NA__.pdf
99.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 594 – 97 ;QJU5NC1SRUQ_.pdf
95.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 594 – 97 ;QJU5NC05NW__.pdf
70.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 618 – 01 ;QJYXOC0WMQ__.pdf
70.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 618 – 02 ;QJYXOC0WMG__.pdf
77.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 618 – 03 ;QJYXOA__.pdf
78.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 618 – 99 ;QJYXOC05OQ__.pdf
45.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 632 – B 632M – 00 ;QJYZMI0WMA__.pdf
44.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 632 – B 632M – 01 ;QJYZMI0WMQ__.pdf
67.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 632 – B 632M – 01 ;QJYZMI9CNJMYTS1SRUQ_.pdf
49.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 632 – B 632M – 02 ;QJYZMI9CNJMYTQ__.pdf
65.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 645 – 02 ;QJY0NQ__.pdf
42.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 645 – 98 ;QJY0NS1SRUQ_.pdf
75.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 646 – 03 ;QJY0NI0WMW__.pdf
61.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 646 – 03 ;QJY0NI1SRUQ_.pdf
90.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 646 – 04 ;QJY0NG__.pdf
86.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 646 – 97 ;QJY0NI05NW__.pdf
61.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 647 – 84 R00 ;QJY0NW__.pdf
68.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 648 – 78 R00 ;QJY0OA__.pdf
48.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 660 – 02 ;QJY2MA__.pdf
490.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 660 – 96 ;QJY2MC05NG__.pdf
447.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 660 – 96 R02 ;QJY2MC1SRUQ_.pdf
493.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 660 – 96 R02 ;QJY2MC05NLIWMG__.pdf
501.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 661 – 03 ;QJY2MQ__.pdf
58.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 661 – 99 ;QJY2MS1SRUQ_.pdf
40.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 661 – 99 ;QJY2MS05OQ__.pdf
60.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 666 – B666M – 01 ;QJY2NI9CNJY2TQ__.pdf
89.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 666 – B666M – 96 ;QJY2NI05NKUX.pdf
76.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 666 – B666M – 96 ;QJY2NI9CNJY2TS1SRUQ_.pdf
90.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 686 – 02 ;QJY4NI0WMG__.pdf
73.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 686 – 02 ;QJY4NI0WMKE_.pdf
73.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 686 – 02 ;QJY4NI1SRUQ_.pdf
51.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 686 – 03 ;QJY4NG__.pdf
69.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 686 – 99 ;QJY4NI05OQ__.pdf
46.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 724 – 00 ;QJCYNA__.pdf
41.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 724 – 83 R91 ;QJCYNC1SRUQ_.pdf
54.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 736 – 00 ;QJCZNG__.pdf
66.41 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
B 736 – 95 ;QJCZNI1SRUQ_.pdf
52.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 744 – B 744M – 99 ;QJC0NC9CNZQ0TQ__.pdf
31.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 745 – B 745M – 97 ;QJC0NS9CNZQ1TQ__.pdf
B 746 – B 746M – 01 ;QJC0NI0WMQ__.pdf
33.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 746 – B 746M – 01 ;QJC0NI9CNZQ2TS1SRUQ_.pdf
34.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 746 – B 746M – 02 ;QJC0NI9CNZQ2TQ__.pdf
45.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 746 – B 746M – 95 R00 ;QJC0NI05NVIWMA__.pdf
30.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 769 – 94 R00 ;QJC2OQ__.pdf
55.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 788 – B 788M – 00 ;QJC4OC9CNZG4TQ__.pdf
97.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 788 – B 788M – 99 ;QJC4OC9CNZG4TS1SRUQ_.pdf
142.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 789 – B 789M – 99 ;QJC4OS9CNZG5TQ__.pdf
100.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 790 – B 790M – 00 ;QJC5MC9CNZKWTQ__.pdf
73.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 790 – B 790M – 99 ;QJC5MC9CNZKWTS1SRUQ_.pdf
81.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 807 – 02 ;QJGWNW__.pdf
38.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 807 – 95 ;QJGWNY1SRUQ_.pdf
27.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 807 – 95 ;QJGWNY05NQ__.pdf
39.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 831 – 93 R98 ;QJGZMQ__.pdf
42.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 843 – 93 R03 ;QJG0MW__.pdf
23.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 843 – 93 R98 ;QJG0MY05M1I5OA__.pdf
24.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 864 – B 864M – 00 ;QJG2NC9CODY0TQ__.pdf
54.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 871 – 01 ;QJG3MQ__.pdf
92.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 871 – 96 ;QJG3MS1SRUQ_.pdf
121.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 871 – 96 ;QJG3MS05NG__.pdf
84.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 881 – 98 ;QJG4MS05OEE_.pdf
45.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 881 – 98a R04 ;QJG4MQ__.pdf
44.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 909 – 00 ;QJKWOQ__.pdf
46.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 917 – B 917M – 01 ;QJKXNY9COTE3TQ__.pdf
106.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 918 – 01 ;QJKXOA__.pdf
69.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 926 – 03 ;QJKYNG__.pdf
24.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 928 – 03 ;QJKYOC0WMW__.pdf
189.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 928 – 03 ;QJKYOC1SRUQ_.pdf
179.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 928 – 04 ;QJKYOA__.pdf
184.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
E 252 – 84 R99 ;RTI1MG__.pdf
39.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
