ASTM 2004-Volume 02.04 Nonferrous Metals, Precious, Reactive, Refractory Metals and Alloys;others" U* [, S0 x! k. g, T0 [
( y- z t# G& [6 ?$ A4 _! l
B0006-03 Specification for Zinc
2 Y# K% N: v1 J. hB0023-00 Specification for White Metal Bearing Alloys (Known Commercially as |P`Babbitt Metal|P'); O" j5 @9 F1 ~( ^, u+ R' ?
B0029-03 Specification for Refined Lead$ h, r( i- H! e
B0032-04 Specification for Solder Metal, H" g. j. p/ c
B0039-79R04 Specification for Nickel" s" U8 j' r* L+ [
B0063-90R01 Test Method for Resistivity of Metallically Conducting Resistance and Contact Materials( X* R. O2 |1 f% p' z5 i+ X7 l
B0069-01A Specification for Rolled Zinc
t$ ]. z# G/ K$ q- \B0070-90R01 Test Method for Change of Resistance With Temperature of Metallic Materials for Electrical Heating' t6 j+ f; s) Q7 y z$ W8 a$ ~
B0076-90R01 Test Method for Accelerated Life of Nickel-Chromium and Nickel-Chromium-Iron Alloys for Electrical Heating" ^. E" [5 q9 Y0 e. X' R
B0077-81R01 Test Method for Thermoelectric Power of Electrical-Resistance Alloys
9 w8 t( ~5 Q5 e+ M8 _1 G" x/ S$ |B0078-90R01 Test Method of Accelerated Life of Iron-Chromium-Aluminum Alloys for Electrical Heating
W2 K9 Z) U: H+ h* f% w, d2 V) bB0084-90R01 Test Method for Temperature-Resistance Constants of Alloy Wires for Precision Resistors
, }2 L g w5 T7 AB0086-04E01 Specification for Zinc and Zinc-Aluminum (ZA) Alloy Foundry and Die Castings
; y) q! e \1 I' oB0102-00 Specification for Lead- and Tin-Alloy Die Castings
6 @2 g4 R- `1 D0 r; `2 XB0106-96R02E01 Test Methods for Flexivity of Thermostat Metals0 ^4 N+ O7 U4 v' g9 O/ b
B0114-90R01 Test Method for Temperature-Resistance Constants of Sheet Materials for Shunts and Precision Resistors
# O% y9 H0 q4 v2 m$ @8 ZB0127-98 Specification for Nickel-Copper Alloy (UNS N04400) Plate, Sheet, and Strip
5 L& f( n4 {/ PB0160-99 Specification for Nickel Rod and Bar
, ?' y2 a3 I9 n$ ]B0161-03 Specification for Nickel Seamless Pipe and Tube
. ` E# U f3 T; kB0162-99 Specification for Nickel Plate, Sheet, and Strip
2 U3 a& a. S& G' r, gB0163-04 Specification for Seamless Nickel and Nickel Alloy Condenser and Heat-Exchanger Tubes
; x! _1 w/ N4 CB0164-03 Specification for Nickel-Copper Alloy Rod, Bar, and Wire
! z/ o1 Z# f8 ]. m* U- _. lB0165-93R03E01 Specification of Nickel-Copper Alloy (UNS N04400)* Seamless Pipe and Tube
( W% k3 x# a5 m; OB0166-04 Specification for Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045)* and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Rod, Bar, and Wire. l3 D1 k4 Q, S% C; I0 Q
B0167-01 Specification for Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045)* and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Seamless Pipe and Tube" n: z& u8 m$ W2 D: \3 Y
B0168-01 Specification Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045) and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Plate, Sheet, and Strip4 C3 N6 R L, C0 H5 @0 Y6 c3 O
B0223-03 Test Method for Modulus of Elasticity of Thermostat Metals (Cantilever Beam Method)6 C: m, L2 V: e* d( J2 g$ v+ |1 H- F
B0237-01 Specification for Refined Antimony2 A! u" i6 D+ D
B0240-04 Specification for Zinc and Zinc-Aluminum (ZA) Alloys in Ingot Form for Foundry and Die Castings
$ J4 e/ }2 J! Q# OB0265-05 Specification for Titanium and Titanium Alloy Strip, Sheet, and Plate
1 Y# s0 g6 {, o8 \B0267-90R01 Specification for Wire for Use In Wire-Wound Resistors) K6 a" n5 s% ~% M' \
B0277-95R01 Test Method for Hardness of Electrical Contact Materials& x$ C3 s0 @4 g* J
B0299-01 Specification for Titanium Sponge
* `' R+ G# v% n5 [ hB0327-01E02 Specification for Master Alloys Used in Making Zinc Die Casting Alloys
1 Z: \' f2 n+ IB0333-03 Specification for Nickel-Molybdenum Alloy Plate, Sheet, and Strip/ L$ o: r% Y( Y+ B% H& c
B0335-03 Specification for Nickel-Molybdenum Alloy Rod, y- I" E, \: f/ N1 s( S2 c
B0338-05A Specification for Seamless and Welded Titanium and Titanium Alloy Tubes for Condensers and Heat Exchangers
6 ]; z. _* m- b+ `* O$ tB0339-00 Specification for Pig Tin9 W4 v8 {2 J2 @% t4 n4 ~ A
B0344-01 Specification for Drawn or Rolled Nickel-Chromium and Nickel-Chromium-Iron Alloys for Electrical Heating Elements
9 z' O9 R; M9 G6 s6 lB0348-05 Specification for Titanium and Titanium Alloy Bars and Billets4 e2 _9 [& q q% Z1 s% n0 \1 U
B0349_B0349M-03 Specification for Zirconium Sponge and Other Forms of Virgin Metal for Nuclear Application
8 q* R. g5 h* `) u" U. BB0350_B0350M-02 Specification for Zirconium and Zirconium Alloy Ingots for Nuclear Application& D! i. e- ?- s
B0351_B0351M-02 Specification for Hot-Rolled and Cold-Finished Zirconium and Zirconium Alloy Bars, Rod, and Wire for Nuclear Application
1 E) t* s6 F+ kB0352_B0352M-02 Specification for Zirconium and Zirconium Alloy Sheet, Strip, and Plate for Nuclear Application0 r. W: N( J) ~$ x0 k' O3 Y- [6 ^7 l1 X& Z
B0353-02 Specification for Wrought Zirconium and Zirconium Alloy Seamless and Welded Tubes for Nuclear Service (Except Nuclear Fuel Cladding)
4 R. _1 g3 x5 \. g" `) |/ vB0362-91R03 Test Method for Mechanical Torque Rate of Spiral Coils of Thermostat Metal# {+ W+ h: a" e+ a4 y) u X
B0363-04 Specification for Seamless and Welded Unalloyed Titanium and Titanium Alloy Welding Fittings3 O6 j% ^8 g7 T
B0364-96R02 Specification for Tantalum and Tantalum Alloy Ingots5 C- @7 u2 P& X9 {- V
B0365-98R04 Specification for Tantalum and Tantalum Alloy Rod and Wire6 H+ P; f% s; k. p6 L4 n
B0366-04B Specification for Factory-Made Wrought Nickel and Nickel Alloy Fittings
& u4 w, W+ N. z" V. z! t% YB0367-93R04 Specification for Titanium and Titanium Alloy Castings
7 `( D" [. f1 @1 R4 H0 x7 eB0381-05 Specification for Titanium and Titanium Alloy Forgings& {$ j; m N& ?
B0386-03 Specification for Molybdenum and Molybdenum Alloy Plate,Sheet, Strip, and Foil
. i. A) m+ [6 r/ cB0387-90R01 Specification for Molybdenum and Molybdenum Alloy Bar, Rod, and Wire
$ `3 e+ P& A* r/ y+ d& ZB0388-00 Specification for Thermostat Metal Sheet and Strip2 c6 N9 k" Z- v+ e
B0389-81R04 Test Method for Thermal Deflection Rate of Spiral and Helical Coils of Thermostat Metal R" H/ c) `* \0 G! v
B0391-03 Specification for Niobium and Niobium Alloy Ingots1 _8 Q6 U) r: c9 p8 M3 d
B0392-03 Specification for Niobium and Niobium Alloy Bar, Rod, and Wire g, D$ ]! c0 i: R5 w, ^* d
B0393-03 Specification for Niobium and Niobium Alloy Strip, Sheet, and Plate8 a/ k8 s3 |, o
B0394-03 Specification for Niobium and Niobium Alloy Seamless and Welded Tubes; `- e6 O! u% w6 i5 s& @, t
B0407-04 Specification for Nickel-Iron-Chromium Alloy Seamless Pipe and Tube
% u, h: c" x( J" `& m/ V$ @5 n8 {B0408-01 Specification for Nickel-Iron-Chromium Alloy Rod and Bar
2 i& L7 J4 P$ d$ Z( w, F! }" c' I4 UB0409-01 Specification for Nickel-Iron-Chromium Alloy Plate, Sheet, and Strip
/ V5 \& W$ O- ~' cB0413-97AR03 Specification for Refined Silver; h) J: Z& G$ C" u
B0418-01 Specification for Cast and Wrought Galvanic Zinc Anodes
' F! E. X( W$ L. dB0423-03 Specification for Nickel-Iron-Chromium-Molybdenum-Copper Alloy (UNS N08825 and N08221)* Seamless Pipe and Tube
6 F; E+ O" B2 V* R& @B0424-98A Specification for Ni-Fe-Cr-Mo-Cu Alloy (UNS N08825 and UNS N08221)* Plate, Sheet, and Strip, j3 V4 r! e! g
B0425-99 Specification for Ni-Fe-Cr-Mo-Cu Alloy (UNS N08825 and UNS N08221)* Rod and Bar
: i0 {/ G; E) a3 @B0434-00 Specification for Nickel-Molybdenum-Chromium-Iron Alloys (UNS N10003, UNS N10242)* Plate, Sheet, and Strip
% F6 ^$ J4 t5 Z& s! y3 LB0435-03 Specification for UNS N06002, UNS N06230, UNS N12160, and UNS R30556 Plate, Sheet, and Strip/ t) m9 ^/ x9 \8 A
B0440-00 Specification for Cadmium8 f- \* y. X9 X4 C
B0443-00E01 Specification for Nickel-Chromium-Molybdenum-Columbium Alloy (UNSN06625) and Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219)* Plate, Sheet, and Strip
' i0 z* g' F% e/ g {B0444-04 Specification for Nickel-Chromium-Molybdenum-Columbium Alloys (UNS N06625 and UNS N06852) and Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219) Pipe and Tube2 d1 @% {2 N* N
B0446-03 Specification for Nickel-Chromium-Molybdenum-Columbium Alloy (UNS N06625), Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219), and Nickel-Chromium-Molybdenum-Tungsten Alloy (UNS N06650)* Rod and Bar7 g% R/ Z! O0 J, ]/ K" h8 W" l
B0462-04 Specification for Forged or Rolled UNS N06030, UNS N06022, UNS N06035, UNS N06200, UNS N06059, UNS N06686, UNS N08020, UNS N08024, UNS N08026, UNS N08367, UNS N10276, UNS N10665, UNS N10675, # ?2 l" l. X+ P: a6 i
UNS N10629, UNS N08031, UNS N06045, UNS N06025, and UNS
6 x! z' L3 E6 I; \% L w, }; rB0463-04 Specification for UNS N08020, UNS N08026, and UNS N08024 Alloy Plate, Sheet, and Strip* ~0 R) ]% k. m5 \0 D J
B0464-04 Specification for Welded UNS N08020, N08024, and N08026 Alloy Pipe
P/ `2 W1 M, D- {# |( BB0468-04 Specification for Welded UNS N08020, N08024, and N08026 Alloy Tubes2 n# K2 I9 y3 j4 k. D! i
B0472-04A Specification for Nickel Alloy Billets and Bars for Reforging8 ]* H0 |. B5 x4 K4 |1 [7 ?
B0473-96R02E01 Specification for UNS N08020, UNS N08024, and UNS N08026 Nickel Alloy Bar and Wire5 b3 w! R: z$ f8 U1 B
B0474-03 Specification for Electric Fusion Welded Nickel and Nickel Alloy Pipe
% r/ F: t: ~/ v) FB0475-96R02E01 Specification for UNS N08020, UNS N08024, and UNS N08026 Nickel Alloy Round Weaving Wire- _* X. z- J/ e2 Z- |+ O8 j8 ~6 N
B0476-01 Specification for General Requirements for Wrought Precious Metal Electrical Contact Materials
2 P- A8 X2 l: w! o& C, EB0477-97R02 Specification for Gold-Silver-Nickel Electrical Contact Alloy J! }! x+ G# ^% N9 I6 m
B0478-85R03 Test Method for Cross\t Curvature\t of\t Thermostat\t Metals& }0 }4 d' ~- M
B0493-01R03 Specification for Zirconium and Zirconium Alloy Forgings
% H+ @+ w' ^' V6 k2 OB0494_B0494M-03 Specification for Primary Zirconium
# ^( h8 d6 t' l T) iB0495-01 Specification for Zirconium and Zirconium Alloy Ingots
- s! |! Q2 }9 u7 k3 IB0497-00 Guide for Measuring Voltage Drop on Closed Arcing Contacts
4 h' b6 Y# c& aB0511-01 Specification for Nickel-Iron-Chromium-Silicon Alloy Bars and Shapes. h' p' A3 ]6 _8 x0 [1 B7 W
B0512-04 Specification for Nickel-Chromium-Silicon Alloy (UNS N08330) Billets and Bars
( {4 U2 w7 W& y. x* V& \ xB0514-95R02E01 Specification for Welded Nickel-Iron-Chromium Alloy Pipe% M8 i s' |; Y9 r2 V8 G* x
B0515-95R02 Specification for Welded UNS N08120, UNS N08800, UNS N08810, and UNS N08811 Alloy Tubes
/ _& ]% H# F. s. Q, BB0516-03 Specification for Welded Nickel-Chromium-Iron Alloy (UNS N06600, UNS N06603, UNS N06025, and UNS N06045) Tubes
, N! V* N7 R: RB0517-03 Specification for Welded Nickel-Chromium-Iron-Alloy (UNS N06600, UNS N06603, UNS N06025, and UNS N06045) Pipe! A# N" w8 G+ I( y5 M
B0521-98R04 Specification for Tantalum and Tantalum Alloy Seamless and Welded Tubes/ Y9 v$ n. x: z
B0522-01 Specification for Gold-Silver-Platinum Electrical Contact Alloy
7 P( A1 }4 o+ r$ `B0523_B0523M-02 Specification for Seamless and Welded Zirconium and Zirconium Alloy Tubes+ [/ A1 s5 v# Y, k8 H" Q
B0535-04 Specification for Nickel-Iron-Chromium-Silicon Alloys (UNS N08330 and N08332) Seamless Pipe and Tube
2 {8 R4 H/ Q ^4 a; N `B0536-02 Specification for Nickel-Iron-Chromium-Silicon Alloys (UNS N08330 and N08332) Plate, Sheet, and Strip; i& _ X- O( r3 _- Y6 h/ D9 ^
B0539-02E01 Test Methods for Measuring Resistance of Electrical Connections (Static Contacts). U9 h0 D* C+ x( W; g
B0540-97R02 Specification for Palladium Electrical Contact Alloy, W4 H& H$ d# d& D, R
B0541-01 Specification for Gold Electrical Contact Alloy" C% J: F$ c. _+ d: E* G; L
B0542-04 Terminology Relating to Electrical Contacts and Their Use+ E8 H9 T, {- d
B0546-04 Specification for Electric Fusion-Welded Ni-Cr-Co-Mo Alloy (UNS N06617), Ni-Fe-Cr-Si Alloys (UNS N08330 and UNS N08332), Ni-Cr-Fe-Al Alloy (UNS N06603), Ni-Cr-Fe Alloy (UNS N06025), and Ni-Cr-Fe-Si Alloy (UNS 3 Q* K& [0 a6 F: g
N06045) Pipe
' [8 W4 `* w9 dB0550_B0550M-02 Specification for Zirconium and Zirconium Alloy Bar and Wire& Z4 P4 `% E% b& U6 m$ \
B0551_B0551M-04 Specification for Zirconium and Zirconium Alloy Strip, Sheet, and Plate! A( d: a+ b. d2 N, V+ k
B0560-00 Specification for Modern Pewter Alloys- k: g! q) R: o! t1 L- h* e$ m
B0561-94R99E01 Specification for Refined Platinum8 U. P9 T- D' b4 ^& j! I0 y& H1 W
B0562-95R99 Specification for Refined Gold
0 \( n4 M* \! Y" GB0563-01 Specification for Palladium-Silver-Copper Electrical Contact Alloy- d- X! G/ G/ ]5 B# w. D" t0 b
B0564-04 Specification for Nickel Alloy Forgings
5 q4 W ~9 E T% PB0572-03 Specification for UNS N06002, UNS N06230, UNS N12160, and UNS R30556 Rod
6 Y+ i. j3 O1 P* ], [6 KNonferrous Metals--Nickel, Cobalt, Lead, Tin, Zinc, Cadmium, Precious, Reactive, Refractory Metals and Alloys; Materials for Thermostats, Electrical Heating and Resistance Contacts, and Connectors B0573-00 Specification for Nickel-Molybdenum-Chromium-Iron Alloys (UNS N10003, N10242)* Rod/ t3 V7 }, Q7 Z) l$ s
B0574-05 Specification for Low-Carbon Nickel-Chromium-Molybdenum, Low-Carbon Nickel-Molybdenum-Chromium-Tantalum, Low-Carbon Nickel-Chromium-Molybdenum-Copper, and Low-Carbon Nickel-Chromium-Molybdenum-
0 V* V: S% Q6 b, s5 |) x3 N. O/ LTungsten Alloy Rod* r" K3 u7 |$ |
B0575-04 Specification for Low-Carbon Nickel-Chromium-Molybdenum, Low-Carbon Nickel-Chromium-Molybdenum-Copper, Low-Carbon Nickel-Chromium-Molybdenum-Tantalum, and Low-Carbon Nickel-Chromium-Molybdenum-: H( k( @9 U* H/ f
Tungsten Alloy Plate, Sheet, and Strip( s. N" e) {) z5 r. g! P; @- }5 ~0 V
B0576-94R99 Guide for Arc Erosion Testing of Electrical Contact Materials; y6 ?& _' l3 k$ K9 A0 q2 |& {
B0581-02 Specification for Nickel-Chromium-Iron-Molybdenum-Copper Alloy Rod
5 R1 b. P+ _) p6 d7 l" n$ ]B0582-02 Specification for Nickel-Chromium-Iron-Molybdenum-Copper Alloy Plate, Sheet, and Strip. Q& T2 U/ p( l M3 B/ J& |; F, j
B0589-94R99E01 Specification for Refined Palladium
3 z/ u& g& R) O+ Q+ AB0596-89R99 Specification for Gold-Copper Alloy Electrical Contact Material
; Z) r* U5 j5 i4 bB0599-92R03E01 Specification for Nickel-Iron-Chromium-Molybdenum-Columbium Stabilized Alloy (UNS N08700) Plate, Sheet, and Strip! E: x! m# D' P& T7 W& E0 C X' R
B0600-91R02 Guide for Descaling and Cleaning Titanium and Titanium Alloy Surfaces# k3 u1 P4 E8 o
B0603-90R01 Specification for Drawn or Rolled Iron-Chromium-Aluminum Alloys for Electrical Heating Elements1 F# Q$ \8 T) N1 J- w3 o7 x6 T& j
B0613-76R00 Guide for Preparing Specifications for Miniature Brushes of Composite Materials for Sliding Electric Contacts7 o) z: Z, b' S6 r8 l
B0614-95R00 Practice for Descaling and Cleaning Zirconium and Zirconium Alloy Surfaces
8 D4 M: D1 l& `' d7 RB0615-79R00 Practice for Measuring Electrical Contact Noise in Sliding Electrical Contacts
5 _- _, ^* M6 P. Y. A( [' u2 ` gB0616-96R00 Specification for Refined Rhodium2 a5 _+ a h/ L2 g- T1 [
B0617-98R04 Specification for Coin Silver Electrical Contact Alloy
1 i( d( d$ ?* nB0619-05 Specification for Welded Nickel and Nickel-Cobalt Alloy Pipe/ f; L5 Z! B% v( G
B0620-03 Specification for Nickel-Iron-Chromium-Molybdenum Alloy (UNS N08320) Plate, Sheet, and Strip
# F) {8 a* N; r* r" kB0621-02 Specification for Nickel-Iron-Chromium-Molybdenum Alloy (UNS N08320) Rod, ]; r7 D2 F$ s7 J5 z+ y
B0622-04A Specification for Seamless Nickel and Nickel-Cobalt Alloy Pipe and Tube3 k" D7 H+ O' H1 S" i: Q
B0625-04A Specification for UNS N08904, UNS N08925, UNS N08031, UNS N08932, UNS N08926, UNS N08354, and UNS R20033 Plate, Sheet, and Strip4 Q9 ~! B* K( ` p+ G. {
B0626-04 Specification for Welded Nickel and Nickel-Cobalt Alloy Tube
5 N9 V# a7 F0 OB0628-98R04 Specification for Silver-Copper Eutectic Electrical Contact Alloy# h$ S0 F1 S" a
B0631-93R04 Specification for Silver-Tungsten Electrical Contact Materials
) u8 Q$ E, Y0 yB0637-03 Specification for Precipitation-Hardening Nickel Alloy Bars, Forgings, and Forging Stock for High-Temperature Service, ^' h0 b$ E1 v$ w' P
B0639-02 Specification for Precipitation Hardening Cobalt-Containing Alloys (UNS R30155 and UNS R30816) Rod, Bar, Forgings, and Forging Stock for High-Temperature Service+ K ]1 u) T/ d8 J; V& ~
B0649-04 Specification for Ni-Fe-Cr-Mo-Cu Low-Carbon Alloy (UNS N08904), Ni-Fe-Cr-Mo-Cu-N Low-Carbon Alloys (UNS N08925, UNS N08031, UNS N08354, and UNS N08926), and Cr-Ni-Fe-N Low-Carbon Alloy (UNS R20033) 9 B/ g8 R7 l( F3 |
Bar and Wire' n! C( w+ O1 `
B0652_B0652M-04 Specification for Niobium-Hafnium Alloy Ingots1 L/ h$ v& \/ k# B" q
B0653_B0653M-02 Specification for Seamless and Welded Zirconium and Zirconium Alloy Welding Fittings
+ [& \. F7 I( Y3 a* p$ dB0654_B0654M-04 Specification for Niobium-Hafnium Alloy Foil, Sheet, Strip, and Plate, w! D6 e! h5 I! P2 s
B0655_B0655M-04 Specification for Niobium-Hafnium Alloy Bar, Rod, and Wire' P* a4 q0 B1 U6 S) l n
B0658_B0658M-02 Specification for Seamless and Welded Zirconium and Zirconium Alloy Pipe
6 @& t% P/ D+ J; r9 y6 N1 lB0662-94R00 Specification for Silver-Molybdenum Electrical Contact Material
$ i' B. y! I" N4 a* `B0663-94R00 Specification for Silver-Tungsten Carbide Electrical Contact Material$ ?$ L. M M% s+ d( j! X# F. L
B0664-90R00 Specification for 80 \% Silver-20\t\% Graphite Sliding Contact Material& U& [7 j- H# O$ R8 U: n
B0667-97R03E01 Practice for Construction and Use of a Probe for Measuring Electrical Contact Resistance
' ?+ l* ?1 j+ L. @% RB0668-00 Specification for UNS N08028 Seamless Pipe and Tube `! i& `& m( P9 _
B0670-02 Specification for Precipitation-Hardening Nickel Alloy (UNS N07718) Plate, Sheet, and Strip for High-Temperature Service
M3 x7 T4 O) g. r2 R, n# Y: v. vB0671-81R99E01 Specification for Refined Iridium( s" v1 ~' T* _( P. s' h0 j! c
B0672-02 Specification for Nickel-Iron-Chromium-Molybdenum-Columbium Stabilized Alloy (UNS N08700) Bar and Wire
" p! L$ T% l( N& S% Q0 fB0673-04 Specification for UNS N08904, UNS N08925, UNS N08354, and UNS N08926 Welded Pipe
4 T M2 ]( G e4 h$ g! g% g. GB0674-04 Specification for UNS N08904, UNS N08925, UNS N08354, and UNS N08926 Welded Tube
( B/ d( X: T. \. BB0675-02 Specification for UNS N08367 Welded Pipe1 f; _& v# D' O" H2 {: D0 {
B0676-03 Specification for UNS N08367 Welded Tube, ~/ L, \* Z# W. ^& E
B0677-04A Specification for UNS N08904, UNS N08925, UNS N08354, and UNS N08926 Seamless Pipe and Tube+ C% {+ O2 a) Z, B, {2 v
B0683-01 Specification for Pure Palladium Electrical Contact Material
- |- x6 z$ u5 [* _B0684-97R02 Specification for Platinum-Iridium Electrical Contact Materials3 K* j7 a! @( F
B0685-01 Specification for Palladium-Copper Electrical Contact Material1 D% V: w9 n9 g$ J
B0688-96R04 Specification for Chromium-Nickel-Molybdenum-Iron (UNS N08366 and UNS N08367) Plate, Sheet, and Strip) c1 Q9 i" s* a5 U. z+ X4 e# X
B0690-02 Specification for Iron-Nickel-Chromium-Molybdenum Alloys (UNS N08366 and UNS N08367) Seamless Pipe and Tube, L" [1 c" ~' s2 T, m, g( I
B0691-02 Specification for Iron-Nickel-Chromium-Molybdenum Alloys (UNS N08366 and UNS N08367) Rod, Bar, and Wire9 M9 k) ]! G& a* T4 e, j4 O
B0692-90R00 Specification for 75 \% Silver-25 \% Graphite Sliding Contact Material
* ?$ W/ ]/ y8 B$ j2 j7 Z$ UB0693-91R01 Standard\tSpecification\tfor Silver-Nickel Electrical Contact Materials* b/ Q, i( V' ~* X& s% f( D
B0702-93R04 Specification for Copper-Tungsten Electrical Contact Material! U$ u; F7 d9 h& J+ \0 p
B0704-03 Specification for Welded UNS N06625, UNS N06219 and UNS N08825 Alloy Tubes
2 a5 k1 A! b6 w% fB0705-03 Specification for Nickel-Alloy (UNS N06625, N06219 and N08825) Welded Pipe4 f8 e3 e5 l6 w/ Q
B0708-01 Specification for Tantalum and Tantalum Alloy Plate, Sheet, and Strip
6 ~$ n4 D7 k6 m, G0 EB0709-04 Specification for Iron-Nickel-Chromium-Molybdenum Alloy (UNS N08028)* Plate, Sheet, and Strip
1 a2 N: ~5 o; b/ @4 W, x# ^B0710-04 Specification for Nickel-Iron-Chromium-Silicon Alloy Welded Pipe
& ?$ u0 T1 V% h }' G/ YB0712-93R99 Guide for Determination of Sodium and Potassium Content For Silver-Cadmium Oxide Contact Materials* [0 z4 u- i0 C% E! o3 E: c2 ^/ G
B0717-96R00 Specification for Refined Ruthenium1 d5 n0 I4 r1 C6 N/ I M; d
B0718-00 Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Plate, Sheet, and Strip" M5 z, e. g" N0 f V
B0719-00 Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Bar, l- b, Q& J4 V4 C0 C- z" a
B0722-02 Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Seamless Pipe and Tube( E ?' P) i7 N' R6 `0 ~
B0723-00 Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Welded Pipe
# ^7 K) _6 y6 T7 RB0725-93R03E01 Specification for Welded Nickel (UNS N02200/UNS N02201) and Nickel Copper Alloy (UNS N04400) Pipe
. _- u3 [9 _" X% J; zB0726-02 Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Welded Tube# i* m5 o3 E# e7 |# o O
B0729-00 Specification for Seamless UNS N08020, UNS N08026, and UNS N08024 Nickel-Alloy Pipe and Tube
: L( r( t, W! s( xB0730 Specification for Welded Nickel (UNS N02200/UNS N02201) and Nickel Copper Alloy (UNS N04400) Tube: [/ d# j2 w% m
B0731-96R01 Specification for 60 \%\t Palladium-40\t\% Silver Electrical Contact Material\t
/ u, y% l! ]' D8 M" RB0735-95R00 Test Method for Porosity in Gold Coatings on Metal Substrates by Nitric Acid Vapor
: K) f6 \( ^$ z' J2 lB0737-01 Specification for Hot-Rolled and/or Cold-Finished Hafnium Rod and Wire
! m3 W4 |+ E8 E. B& h( TB0739-03 Specification for Nickel-Iron-Chromium-Silicon Alloy Welded Tube
4 s+ o2 ~5 g! eB0741-95R00 Test Method for Porosity In Gold Coatings On Metal Substrates By Paper Electrography$ N' g w1 M) o$ k9 T$ }! r& \
B0742-90R00 Specification for Fine Silver Electrical Contact Fabricated Material# |4 Q( q" M( z+ _, B
B0749-03 Specification for Lead and Lead Alloy Strip, Sheet, and Plate Products
" e% h; E6 k1 v rB0750-03 Specification for GALFAN (Zinc-5 \% Aluminum-Mischmetal) Alloy in Ingot Form for Hot-Dip Coatings
# T( z; v: V6 QB0751-03 Specification for General Requirements for Nickel and Nickel Alloy Welded Tube5 L6 p2 a, O. [9 M3 b. W0 \. {
B0752-01 Specification for Castings, Zirconium-Base, Corrosion Resistant, for General Application
" H2 v8 E% [' N& U6 DB0753-01 Specification for Thermostat Component Alloys% s2 r$ _& ?) g0 I9 z
B0755-00 Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Plate, Sheet, and Strip1 w8 F" @2 A+ j: B% S! l* n6 }, [
B0756-00 Specification for Nickel-Chromium-Molybdenum-Tungsten Alloy (UNS N06110) Rod and Bar
4 x/ r( Z+ C% S. w" W% ^2 J* v0 SB0757-00 Specification for Nickel-Chromium-Molybdenum-Tungsten-Alloys (UNS N06110) Welded Pipe u# O, H. Q1 z% e
B0758-00 Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Welded Tube3 d6 s! A( d$ j/ k
B0759-00 Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Pipe and Tube
. v) `5 G/ V* Q2 T ]! d' FB0760-86R99 Specification for Tungsten Plate, Sheet,\t and\t Foil) G' ~5 ]$ g9 f. u8 @) H: g
B0772-97R03 Guide for Specifying the Chemical Compositions for Electrical Contact Materials (Arcing and Nonarcing)
, l$ d2 s' Z* m/ e+ q) u/ DB0773-96R02E01 Guide for Ultrasonic C-Scan Bond Evaluation of Brazed or Welded Electrical Contact Assemblies
: t) d/ b7 w0 J/ ^5 o# [B0774-00 Specification for Low Melting Point Alloys
* m3 y: A# ?/ JB0775-02 Specification for General Requirements for Nickel and Nickel Alloy Welded Pipe/ E/ v; s4 t$ a& v5 i( I! d
B0776-01A Specification for Hafnium and Hafnium Alloy Strip, Sheet, and Plate+ P% _- @! a# s A6 ^
B0777-99 Specification for Tungsten Base, High-Density Metal
, M) ~/ \7 M; [0 k1 xB0780-98R04 Specification for 75 \% Silver, 24.5 \% Copper, 0.5 \% Nickel Electrical Contact Alloy
8 N8 e3 w/ N4 ^: i% t LB0781-93AR99 Guide for Silver-Cadmium Oxide Contact Material
8 Z! O7 i5 s% r8 @' C/ S8 ZB0792-01E01 Specification for Zinc Alloys in Ingot Form for Slush Casting& F% y; w+ M. d r8 P ]; [% }( J G) G
B0793-03 Specification for Zinc Casting Alloy Ingot for Sheet Metal Forming Dies and Plastic Injection Molds
1 h- W+ g/ {" F& [! @- JB0794-97R03 Test Method for Durability Wear Testing of Separable Electrical Connector Systems Using Electrical Resistance Measurements
7 W' y6 G4 i, s+ v# b) c4 [B0798-95R00 Test Method for Porosity in Gold or Palladium Coatings on Metal Substrates by Gel-Bulk Electrography
! z! h, I9 M% W+ e% w7 U- PB0799-95R00 Test Method for Porosity in Gold and Palladium Coatings by Sulfurous Acid/Sulfur-Dioxide Vapor; e3 `+ C8 m- f/ k$ f' U- W
B0804-02 Specification for UNS N08367 and UNS N08926 Welded Pipe$ e2 ~7 P F; h3 D% H1 O$ B' c$ ~
B0805-02 Specification for Precipitation Hardening Nickel Alloys UNS N07716, N07725, N07773, N07776, and N09777, Bar and Wire
: f# X4 O# v& R- oB0808-97R03 Test Method for Monitoring of Atmospheric Corrosion Chambers by Quartz Crystal Microbalances
) S$ p5 `& [* j( hB0810-01A Test Method for Calibration of Atmospheric Corrosion Test Chambers by Change in Mass of Copper Coupons n4 B2 E8 e! b) b( p
B0811-02 Specification for Wrought Zirconium Alloy Seamless Tubes for Nuclear Reactor Fuel Cladding
- W8 R& K0 X5 E; \B0812-96R02E01 Test Method for Resistance to Environmental Degradation of Electrical Pressure Connections Involving Aluminum and Intended for Residential Applications
& P1 }) ~" y$ E0 S8 p! X C, LB0814-02 Specification for Nickel-Chromium-Iron-Molybdenum-Tungsten Alloy (UNS N06920) Plate, Sheet, and Strip% V: o" I; w; T. Y2 b$ u- n
B0815-02 Specification for Cobalt-Chromium-Nickel-Molybdenum-Tungsten Alloy (UNS R31233) Rod
1 C. G! V/ p* y- yB0818-03 Specification for Cobalt-Chromium-Nickel-Molybdenum-Tungsten Alloy (UNS R31233) Plate, Sheet and Strip
/ K( F) K+ t' R( _( ]B0825-02 Test Method for Coulometric Reduction of Surface Films on Metallic Test Samples
! S' F, c9 Z; A7 s" \% }B0826-03 Test Method for Monitoring Atmospheric Corrosion Tests by Electrical Resistance Probes3 e! j6 ~( m' Y/ [; N) ~, @ K
B0827-97R03 Practice for Conducting Mixed Flowing Gas (MFG) Environmental Tests
( }( b# [) o& X4 I/ ]9 O p8 xB0829-04A Specification for General Requirements for Nickel and Nickel Alloys Seamless Pipe and Tube
0 u& n2 j+ D8 K; m$ q3 g4 uB0833-01A Specification for Zinc and Zinc Alloy Wire for Thermal Spraying (Metallizing)
' a# l7 c* \; m: X0 q* CB0834-95R03 Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel-Chromium-Molybdenum (UNS N08367) and Nickel-Chromium-Molybdenum-Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, % g9 j4 Q8 J, g' H
and Parts# [ n1 e% M" |0 q/ u4 `' d% O
B0844-98R04 Guide for Silver-Tin Oxide Contact Material- W1 @: k* K% h
B0845-97R03 Guide for Mixed Flowing Gas (MFG) Tests for Electrical Contacts- Z, `/ D' k N
B0852-01 Specification for Continuous Galvanizing Grade (CGG) Zinc Alloys for Hot-Dip Galvanizing of Sheet Steel
' \8 f! {1 K, m3 nB0854-98R04 Guide for Measuring Electrical Contact Intermittences6 g2 r8 y" ^+ a2 E# F7 B, c) z
B0860-02 Specification for Zinc Master Alloys for Use in Hot Dip GalvanizingB0861-05 Specification for Titanium and Titanium Alloy Seamless Pipe3 D4 L1 K& d, r3 l u) m
B0862-05 Specification for Titanium and Titanium Alloy Welded Pipe( I a: ^% Y# i e) k- R
B0863-05 Specification for Titanium and Titanium Alloy Wire+ Z$ g7 A; R% S% ?
B0865-04 Specification for Precipitation Hardening Nickel-Copper-Aluminum Alloy (UNS N05500) Bar, Rod, Wire, Forgings, and Forging Stock
8 Q6 R! W. N( {8 ^2 E8 I0 DB0868-96R02E02 Practice for Contact Performance Classification of Electrical Connection Systems( z7 K% g# @3 n" V7 \$ y+ M5 F
B0872-96R03 Specification for Precipitation-Hardening Nickel-Iron-Chromium-Columbium (Nb)-Titanium-Aluminum Alloy (UNS N09908) Plate, Sheet, and Strip
) e# ~4 Q- ~ B3 JB0878-97R03 Test Method for Nanosecond Event Detection for Electrical Contacts and Connectors
( r. t0 |' O( c( k5 u: q3 L _" E1 bB0880-03 Specification for General Requirements for Chemical Check Analysis Limits for Nickel, Nickel Alloys and Cobalt Alloys' A! P6 g) Z' Y, p% m( |$ v
B0884-01 Specification for Niobium-Titanium Alloy Billets, Bar, and Rod for Superconducting Applications. L- P% Z" ]0 t
B0885-97R03 Test Method for Presence of Foreign Matter on Printed Wiring Board Contacts% V* R# g/ d( s J: Y0 r
B0891-98R04 Specification for Seamless and Welded Titanium and Titanium Alloy Condenser and Heat Exchanger Tubes With Integral Fins" h5 ^ F5 j4 b7 K3 A% ]
B0892-03 Specification for ACuZinc5 (Zinc-Copper-Aluminum) Alloy in Ingot Form for Die Castings
) U+ H |% ^ K! s- O7 ^B0894-03 Specification for ACuZinc5 (Zinc-Copper-Aluminum) Alloy Die Castings9 b m+ Z( w! a9 X+ K1 D: B
B0896-99 Test Methods for Evaluating Connectability Characteristics of Electrical Conductor Materials" s& d& T/ q, ?/ Q( I/ f, f
B0897-03 Specification for the Configuration of Zinc and Zinc Alloy Jumbo and Block Ingot9 _/ A/ {9 {/ P2 n$ v
B0898-99 Specification for Reactive and Refractory Metal Clad Plate
w3 P& Q) G7 ?! ~. ?B0899-04 Terminology Relating to Non-ferrous Metals and Alloys
# b6 M2 H7 S" p& k4 r1 XB0906-02 Specification for General Requirements for Flat-Rolled Nickel and Nickel Alloys Plate, Sheet, and Strip
7 o6 P% C* g7 e. ^! z* \$ QB0907-04 Specification for Zinc, Tin and Cadmium Base Alloys Used as Solders and for Thermal Spraying6 J+ A9 G2 ]( H: t
B0908-03 Practice for the Use of Color Codes for Zinc Casting Alloy Ingot
4 z2 X! M: G$ F+ Q; wB0913-00E01 Test Method for Evaluation of Crimped Electrical Connections to 16-Gauge and Smaller Diameter Stranded and Solid Conductors
, m$ o' {! C; X+ A: @3 O5 ?! H2 LB0914-03E01 Practice for Color Codes on Zinc and Zinc Alloy Ingot for Use in Hot-Dip Galvanizing of Steel
/ o7 O+ u# w, Z3 d- yB0920-01 Practice for Porosity in Gold and Palladium Alloy Coatings on Metal Substrates by Vapors of Sodium Hypochlorite Solution0 e/ p) Y! S1 d( }& \
B0924-02 Specification for Seamless and Welded Nickel Alloy Condenser and Heat Exchanger Tubes With Integral Fins5 I; {6 P/ w& C% I( O; _, F5 A
B0932-04 Specification for Low-Carbon Nickel-Chromium-Molybdenum-Gadolinium Alloy Plate, Sheet, and Strip
& ^) I' `" d+ j |
A 181 – A 181M – 01 ;QTE4MS9BMTGXTQ__.pdf
30.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 182 – A 182M – 00 ;QTE4MI0WMEM_.pdf
65.93 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 182 – A 182M – 01 ;QTE4MI0WMQ__.pdf
67.06 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 182 – A 182M – 02 ;QTE4MI0WMG__.pdf
100.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 182 – A 182M – 02 ;QTE4MI9BMTGYTS1SRUQ_.pdf
91.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 182 – A 182M – 04 ;QTE4MI9BMTGYTQ__.pdf
102.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 192 – A 192M – 02 ;QTE5MI9BMTKYTQ__.pdf
27.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 192 – A 192M – 91 R01 ;QTE5MI05MVIWMQ__.pdf
27.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 192 – A 192M – 91 R01 ;QTE5MI9BMTKYTS1SRUQ_.pdf
20.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 192 – A 192M – 91 R96 ;QTE5MI05MVI5NKUX.pdf
18.87 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 00 ;QTE5MY0WMEE_.pdf
62.08 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 00 ;QTE5MY0WMEI_.pdf
59.57 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 01 ;QTE5MY0WMQ__.pdf
62.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 01 ;QTE5MY0WMUE_.pdf
59.5 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 01 ;QTE5MY0WMUI_.pdf
95.64 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 03 ;QTE5MY0WMW__.pdf
90.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 03 ;QTE5MY9BMTKZTS1SRUQ_.pdf
62.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 193 – A 193M – 04 ;QTE5MY9BMTKZTQ__.pdf
85.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 00 ;QTE5NC0WMEE_.pdf
65.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 00 ;QTE5NC0WMEI_.pdf
64.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 01 ;QTE5NC0WMQ__.pdf
64.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 01 ;QTE5NC0WMUE_.pdf
84.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 03 ;QTE5NC0WMW__.pdf
113.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 03 ;QTE5NC9BMTK0TQ__.pdf
94.16 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 194 – A 194M – 03 ;QTE5NC9BMTK0TS1SRUQ_.pdf
107.94 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 209 – A 209M – 03 ;QTIWOS9BMJA5TQ__.pdf
32.97 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 209 – A 209M – 98 ;QTIWOS05OA__.pdf
34.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 209 – A 209M – 98 ;QTIWOS9BMJA5TS1SRUQ_.pdf
34.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 210 – A 210M – 02 ;QTIXMC9BMJEWTQ__.pdf
33.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 210 – A 210M – 96 ;QTIXMC05NG__.pdf
21.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 210 – A 210M – 96 R01 ;QTIXMC05NLIWMQ__.pdf
34.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 210 – A 210M – 96 R01 ;QTIXMC9BMJEWTS1SRUQ_.pdf
31.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 01 ;QTIXMY0WMQ__.pdf
42.86 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 01 ;QTIXMY0WMUE_.pdf
77.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 03 ;QTIXMY0WM0E_.pdf
88.28 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 03 ;QTIXMY0WM0I_.pdf
90.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 03 ;QTIXMY0WM0M_.pdf
84.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 03 ;QTIXMY0WMW__.pdf
88.02 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 03 ;QTIXMY9BMJEZTS1SRUQ_.pdf
57.24 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 213 – A 213M – 04 ;QTIXMY9BMJEZTQ__.pdf
85.16 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
A 214 – A 214M – 96 ;QTIXNC05NG__.pdf
16.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 214 – A 214M – 96 R01 ;QTIXNC9BMJE0TQ__.pdf
25.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 00 ;QTIZNC0WMA__.pdf
45.18 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 00 ;QTIZNC0WMEE_.pdf
38.16 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 01 ;QTIZNC0WMQ__.pdf
40.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 02 ;QTIZNC0WMG__.pdf
62.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 03 ;QTIZNC0WMW__.pdf
58.99 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 03 ;QTIZNC9BMJM0TS1SRUQ_.pdf
43.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 234 – A 234M – 04 ;QTIZNC9BMJM0TQ__.pdf
59.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 01 ;QTI0OS0WMQ__.pdf
40.51 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 01 ;QTI0OS0WMUE_.pdf
44.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 03 ;QTI0OS0WM0E_.pdf
73.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 03 ;QTI0OS0WMW__.pdf
64.31 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 03 ;QTI0OS9BMJQ5TS1SRUQ_.pdf
51.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 04 ;QTI0OS9BMJQ5TQ__.pdf
74.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 249 – A 249M – 98 ;QTI0OS05OEUX.pdf
42.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 250 – A 250M – 04 ;QTI1MC9BMJUWTQ__.pdf
37 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 250 – A 250M – 95 ;QTI1MC05NQ__.pdf
23.22 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 250 – A 250M – 95 R01 ;QTI1MC05NVIWMQ__.pdf
36.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 250 – A 250M – 95 R01 ;QTI1MC9BMJUWTS1SRUQ_.pdf
36.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 252 – 98 ;QTI1MI05OEUX.pdf
60.16 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 252 – 98 R02 ;QTI1MG__.pdf
50.65 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 254 – 97 ;QTI1NC05NW__.pdf
30.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 254 – 97 R02 ;QTI1NA__.pdf
42.88 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 268 – A 268M – 00 ;QTI2OC0WMEE_.pdf
33.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 268 – A 268M – 01 ;QTI2OC0WMQ__.pdf
56.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 268 – A 268M – 01 ;QTI2OC9BMJY4TS1SRUQ_.pdf
A 268 – A 268M – 03 ;QTI2OC0WMW__.pdf
54.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 268 – A 268M – 04 ;QTI2OC9BMJY4TQ__.pdf
54.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 269 – 00 ;QTI2OS0WMA__.pdf
31.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 269 – 02 ;QTI2OS0WMG__.pdf
51.5 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 269 – 02 ;QTI2OS0WMKE_.pdf
51.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 269 – 02 ;QTI2OS1SRUQ_.pdf
38.71 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 269 – 04 ;QTI2OQ__.pdf
50.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 01 ;QTI3MC0WMQ__.pdf
27.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 02 ;QTI3MC0WMG__.pdf
45.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 02 ;QTI3MC0WMKE_.pdf
44.34 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 03 ;QTI3MA__.pdf
46.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 03 ;QTI3MC0WMW__.pdf
45.81 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 270 – 03 ;QTI3MC1SRUQ_.pdf
41.22 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 00 ;QTMXMI0WMEM_.pdf
53.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 01 ;QTMXMI0WMQ__.pdf
52.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 01 ;QTMXMI0WMUE_.pdf
90.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 02 ;QTMXMI0WMG__.pdf
93.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 03 ;QTMXMI0WMW__.pdf
87.7 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 04 ;QTMXMI0WNA__.pdf
89.11 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 04 ;QTMXMI9BMZEYTQ__.pdf
89.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 312 – A 312M – 04 ;QTMXMI9BMZEYTS1SRUQ_.pdf
61.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 320 – A 320M – 00 ;QTMYMC0WMEI_.pdf
40.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 320 – A 320M – 01 ;QTMYMC0WMQ__.pdf
40.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 320 – A 320M – 02 ;QTMYMC0WMG__.pdf
66.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 320 – A 320M – 02 ;QTMYMC9BMZIWTS1SRUQ_.pdf
45.64 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 320 – A 320M – 03 ;QTMYMC9BMZIWTQ__.pdf
62.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 333 – A 333M – 04 ;QTMZMY0WNA__.pdf
61.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 333 – A 333M – 04 ;QTMZMY9BMZMZTQ__.pdf
61.3 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 333 – A 333M – 99 ;QTMZMY05OQ__.pdf
73.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 333 – A 333M – 99 ;QTMZMY9BMZMZTS1SRUQ_.pdf
63.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 334 – A 334M – 04 ;QTMZNC0WNA__.pdf
51.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 334 – A 334M – 04 ;QTMZNC9BMZM0TQ__.pdf
51.8 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 334 – A 334M – 04 ;QTMZNC9BMZM0TS1SRUQ_.pdf
40.36 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 334 – A 334M – 99 ;QTMZNC05OQ__.pdf
51.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 335 – A 335M – 00 ;QTMZNS0WMA__.pdf
46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 335 – A 335M – 02 ;QTMZNS0WMG__.pdf
73.11 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 335 – A 335M – 02 ;QTMZNS9BMZM1TS1SRUQ_.pdf
53.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 335 – A 335M – 03 ;QTMZNS9BMZM1TQ__.pdf
69.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 00 ;QTM1MC0WMEI_.pdf
58.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 00 ;QTM1MC0WMEM_.pdf
50.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 02 ;QTM1MC0WMG__.pdf
79.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 02 ;QTM1MC0WMKE_.pdf
83.37 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 02 ;QTM1MC0WMKI_.pdf
80.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 02 ;QTM1MC9BMZUWTS1SRUQ_.pdf
55.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 350 – A 350M – 04 ;QTM1MC9BMZUWTQ__.pdf
80.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 358 – A 358M – 00 ;QTM1OC0WMA__.pdf
37.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 358 – A 358M – 01 ;QTM1OC0WMQ__.pdf
62.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 358 – A 358M – 01 ;QTM1OC9BMZU4TS1SRUQ_.pdf
49.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 358 – A 358M – 04 ;QTM1OC9BMZU4TQ__.pdf
66.01 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 369 – A 369M – 00 ;QTM2OS0WMA__.pdf
25.65 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 369 – A 369M – 01 ;QTM2OS0WMQ__.pdf
25.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 369 – A 369M – 01 ;QTM2OS9BMZY5TS1SRUQ_.pdf
31.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 369 – A 369M – 02 ;QTM2OS9BMZY5TQ__.pdf
38.56 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 370 – 01 ;QTM3MC0WMQ__.pdf
450.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 370 – 02 ;QTM3MC0WMKUX.pdf
892.47 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 370 – 03 ;QTM3MA__.pdf
537.17 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 370 – 03 ;QTM3MC0WMW__.pdf
883.57 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 370 – 03 ;QTM3MC1SRUQ_.pdf
721.53 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 00 ;QTM3NI0WMEE_.pdf
42.45 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 01 ;QTM3NI0WMQ__.pdf
43.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 01 ;QTM3NI0WMUE_.pdf
45.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 02 ;QTM3NI0WMG__.pdf
76.44 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 02 ;QTM3NI9BMZC2TQ__.pdf
76.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 376 – A 376M – 02 ;QTM3NI9BMZC2TS1SRUQ_.pdf
46.48 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 381 – 96 ;QTM4MS05NG__.pdf
43.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 381 – 96 R01 ;QTM4MQ__.pdf
59.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 403 – A 403M – 00 ;QTQWMY0WMEI_.pdf
41.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 403 – A 403M – 02 ;QTQWMY0WMG__.pdf
63.3 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 403 – A 403M – 03 ;QTQWMY0WM0E_.pdf
61.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 403 – A 403M – 03 ;QTQWMY0WMW__.pdf
A 403 – A 403M – 03 ;QTQWMY9BNDAZTS1SRUQ_.pdf
44.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 403 – A 403M – 04 ;QTQWMY9BNDAZTQ__.pdf
60.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 409 – A409M – 95 ;QTQWOS05NUFFMQ__.pdf
60.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 409 – A 409M – 01 ;QTQWOS9BNDA5TQ__.pdf
68.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 409 – A 409M – 95 ;QTQWOS9BNDA5TS1SRUQ_.pdf
56.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 00 ;QTQYMC0WMEE_.pdf
36.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 00 ;QTQYMC0WMEI_.pdf
36.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 01 ;QTQYMC0WMQ__.pdf
37.85 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 02 ;QTQYMC0WMG__.pdf
56.32 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 03 ;QTQYMC0WMW__.pdf
54.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 03 ;QTQYMC9BNDIWTS1SRUQ_.pdf
41.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 420 – A 420M – 04 ;QTQYMC9BNDIWTQ__.pdf
53.88 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 423 – A 423M – 95 R00 ;QTQYMY9BNDIZTQ__.pdf
31.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 426 – 92 R02 ;QTQYNI05MLIWMG__.pdf
41.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
A 426 – 92 R02 ;QTQYNI9BNDI2TS1SRUQ_.pdf
31.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 426 – A 426M – 02 ;QTQYNI9BNDI2TQ__.pdf
41.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 437 – A 437M – 00 ;QTQZNY0WMEE_.pdf
23.04 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 437 – A 437M – 01 ;QTQZNY0WMQ__.pdf
24.1 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 437 – A 437M – 01 ;QTQZNY9BNDM3TQ__.pdf
36.09 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 437 – A 437M – 01 ;QTQZNY9BNDM3TS1SRUQ_.pdf
26.75 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 450 – A 450M – 02 ;QTQ1MC0WMG__.pdf
84 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 450 – A 450M – 03 ;QTQ1MC0WMW__.pdf
85.36 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 450 – A 450M – 03 ;QTQ1MC9BNDUWTS1SRUQ_.pdf
66.72 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 450 – A 450M – 04 ;QTQ1MC9BNDUWTQ__.pdf
84.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 450 – A 450M – 96 ;QTQ1MC05NKE_.pdf
57.65 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 451 – 9 R97 ;QTQ1MS05M1I5NW__.pdf
25.23 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 451 – 93 R02 ;QTQ1MS9BNDUXTS1SRUQ_.pdf
31.29 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 451 – A 451M – 02 ;QTQ1MS9BNDUXTQ__.pdf
39.85 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 453 – A 453M – 00 ;QTQ1MY0WMA__.pdf
34.56 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 453 – A 453M – 00 ;QTQ1MY0WMEUX.pdf
A 453 – A 453M – 02 ;QTQ1MY0WMG__.pdf
54.51 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 453 – A 453M – 02 ;QTQ1MY9BNDUZTS1SRUQ_.pdf
41.45 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 453 – A 453M – 03 ;QTQ1MY9BNDUZTQ__.pdf
52.1 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 498 – 04 ;QTQ5OA__.pdf
34.11 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 498 – 98 ;QTQ5OC1SRUQ_.pdf
27.33 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 498 – 98 ;QTQ5OC05OA__.pdf
34.03 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 01 ;QTUWMC0WMQ__.pdf
33.45 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 01 ;QTUWMC0WMUE_.pdf
52.72 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 03 ;QTUWMA__.pdf
51.15 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 03 ;QTUWMC0WMW__.pdf
53.83 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 03 ;QTUWMC1SRUQ_.pdf
37.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 500 – 99 ;QTUWMC05OQ__.pdf
33.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 501 – 01 ;QTUWMQ__.pdf
53.54 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 501 – 99 ;QTUWMS1SRUQ_.pdf
44.89 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 501 – 99 ;QTUWMS05OQ__.pdf
36.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 511 – 04 ;QTUXMQ__.pdf
72.81 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 511 – 96 ;QTUXMS1SRUQ_.pdf
51.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 511 – 96 ;QTUXMS05NG__.pdf
72.23 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 512 – 96 ;QTUXMI05NG__.pdf
39 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 512 – 96 R01 ;QTUXMG__.pdf
61.5 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 513 – 00 ;QTUXMW__.pdf
125.03 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 513 – 98 ;QTUXMY1SRUQ_.pdf
88.91 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 519 – 03 ;QTUXOQ__.pdf
96.42 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 519 – 96 ;QTUXOS05NG__.pdf
59.91 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 519 – 96 R01 ;QTUXOS1SRUQ_.pdf
69.87 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 519 – 96 R01 ;QTUXOS05NLIWMQ__.pdf
104.59 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 522 – A522M – 95 ;QTUYMI05NUI_.pdf
26.36 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 522 – A 522M – 01 ;QTUYMI9BNTIYTQ__.pdf
37.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 522 – A 522M – 95b R01 ;QTUYMI05NUJSMDE_.pdf
26.28 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
A 522 – A 522M – 95b R01 ;QTUYMI9BNTIYTS1SRUQ_.pdf
37.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 523 – 96 ;QTUYMY05NG__.pdf
34.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 523 – 96 R01 ;QTUYMW__.pdf
51.76 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 524 – 96 ;QTUYNC05NG__.pdf
38.04 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 524 – 96 R01 ;QTUYNA__.pdf
59.19 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 530 – A 530M – 02 ;QTUZMC0WMG__.pdf
71.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 530 – A 530M – 03 ;QTUZMC0WMW__.pdf
68.93 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 530 – A 530M – 03 ;QTUZMC9BNTMWTS1SRUQ_.pdf
51.98 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 530 – A 530M – 04 ;QTUZMC9BNTMWTQ__.pdf
69.86 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 539 – 99 ;QTUZOQ__.pdf
25.72 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 540 – A 540M – 00 ;QTU0MC0WMA__.pdf
68.53 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 540 – A 540M – 00 ;QTU0MC9BNTQWTS1SRUQ_.pdf
49.34 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 540 – A 540M – 04 ;QTU0MC9BNTQWTQ__.pdf
68.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 554 – 03 ;QTU1NA__.pdf
53.08 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 554 – 98 ;QTU1NC1SRUQ_.pdf
40.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 554 – 98 ;QTU1NC05OEUX.pdf
63.18 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 556 – A 556M – 96 ;QTU1NI05NG__.pdf
37.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 556 – A 556M – 96 R01 ;QTU1NI9BNTU2TQ__.pdf
52.74 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 587 – 96 ;QTU4NY05NG__.pdf
33.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 587 – 96 R01 ;QTU4NW__.pdf
50.91 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
A 589 – 96 ;QTU4OS05NG__.pdf
104.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 589 – 96 R01 ;QTU4OQ__.pdf
134.68 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 595 – 04 ;QTU5NQ__.pdf
32.35 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 595 – 98 ;QTU5NS05OA__.pdf
32.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 595 – 98 R02 ;QTU5NS1SRUQ_.pdf
26.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 595 – 98 R02 ;QTU5NS05OFIWMG__.pdf
31.95 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 608 – 91a R98 ;QTYWOC05MUFSOTG_.pdf
34.99 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 608 – 91a R98 ;QTYWOC9BNJA4TS1SRUQ_.pdf
50.23 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 608 – A 608M – 02 ;QTYWOC9BNJA4TQ__.pdf
49.57 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 618 – 01 ;QTYXOC9BNJE4TQ__.pdf
44.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 618 – 99 ;QTYXOC05OQ__.pdf
29.49 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 618 – A 618M – 01 ;QTYXOC9BNJE4TS1SRUQ_.pdf
40.35 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 01 ;QTYZMI0WMQ__.pdf
26.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 02 ;QTYZMI0WMG__.pdf
26.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 02 ;QTYZMI0WMKE_.pdf
38.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 02 ;QTYZMI1SRUQ_.pdf
28.78 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 04 ;QTYZMG__.pdf
39.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 632 – 98 ;QTYZMI05OA__.pdf
26.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 660 – 96 ;QTY2MC05NG__.pdf
24.77 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 660 – 96 R01 ;QTY2MA__.pdf
37.69 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 671 – 04 ;QTY3MQ__.pdf
60.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 671 – 96 ;QTY3MS05NG__.pdf
38.77 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 671 – 96 R01 ;QTY3MS1SRUQ_.pdf
45.83 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 671 – 96 R01 ;QTY3MS05NLIWMQ__.pdf
60.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 672 – 96 R01 ;QTY3MG__.pdf
56.8 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 688 – A 688M – 00 ;QTY4OC0WMA__.pdf
54.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 688 – A 688M – 01 ;QTY4OC0WMQ__.pdf
56.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 688 – A 688M – 02 ;QTY4OC0WMG__.pdf
120.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 688 – A 688M – 02 ;QTY4OC9BNJG4TS1SRUQ_.pdf
79.75 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 688 – A 688M – 03 ;QTY4OC9BNJG4TQ__.pdf
80.62 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 691 – 98 ;QTY5MS05OA__.pdf
53.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 691 – 98 R02 ;QTY5MQ__.pdf
52.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 694 – A 694M – 00 ;QTY5NC0WMA__.pdf
34.93 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 694 – A 694M – 00 ;QTY5NC9BNJK0TS1SRUQ_.pdf
26.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 694 – A 694M – 03 ;QTY5NC9BNJK0TQ__.pdf
33.23 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 707 – A 707M – 00 ;QTCWNY9BNZA3TS1SRUQ_.pdf
42.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 707 – A 707M – 02 ;QTCWNY9BNZA3TQ__.pdf
47.4 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 714 – 99 ;QTCXNC05OQ__.pdf
70.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 714 – 99 R03 ;QTCXNA__.pdf
65.8 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 727 – A 727M – 00 ;QTCYNY9BNZI3TS1SRUQ_.pdf
30.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 727 – A 727M – 02 ;QTCYNY9BNZI3TQ__.pdf
39.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 733 – 01 ;QTCZMY0WMQ__.pdf
61.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
A 733 – 01 ;QTCZMY1SRUQ_.pdf
43.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 733 – 03 ;QTCZMW__.pdf
50.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 733 – 99 ;QTCZMY05OQ__.pdf
35.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 751 – 01 ;QTC1MQ__.pdf
47.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 751 – 96 ;QTC1MS1SRUQ_.pdf
40.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 751 – 96 ;QTC1MS05NG__.pdf
32.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 758 – A 758M – 00 ;QTC1OC9BNZU4TQ__.pdf
44.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 758 – A 758M – 98 ;QTC1OC9BNZU4TS1SRUQ_.pdf
A 771 – A 771M – 95 ;QTC3MS05NQ__.pdf
34.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 771 – A 771M – 95 R01 ;QTC3MS9BNZCXTQ__.pdf
50.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 774 – A 774M – 00 ;QTC3NC0WMA__.pdf
32.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 774 – A 774M – 00 ;QTC3NC9BNZC0TS1SRUQ_.pdf
32.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 774 – A 774M – 02 ;QTC3NC9BNZC0TQ__.pdf
39.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 778 – 00 ;QTC3OC0WMA__.pdf
26.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 778 – 00 ;QTC3OC1SRUQ_.pdf
33.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 778 – 01 ;QTC3OA__.pdf
39.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 787 – 00 ;QTC4NY0WMA__.pdf
40.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 787 – 00 ;QTC4NY1SRUQ_.pdf
62.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 787 – 01 ;QTC4NW__.pdf
63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 00 ;QTC4OS0WMEI_.pdf
26.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 01 ;QTC4OS0WMQ__.pdf
26.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 02 ;QTC4OS0WMG__.pdf
43.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 02 ;QTC4OS0WMKE_.pdf
41.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 02 ;QTC4OS9BNZG5TS1SRUQ_.pdf
32.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 789 – A 789M – 04 ;QTC4OS9BNZG5TQ__.pdf
41.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 790 – A 790M – 00 ;QTC5MC0WMEE_.pdf
38.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 790 – A 790M – 01 ;QTC5MC0WMQ__.pdf
59.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 790 – A 790M – 02 ;QTC5MC0WMG__.pdf
63.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
A 790 – A 790M – 02 ;QTC5MC0WMKE_.pdf
63.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 616 – 96 R00 ;QJYXNG__.pdf
23.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 617 – 98 ;QJYXNY05OA__.pdf
37.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 617 – 98 R04 ;QJYXNW__.pdf
29.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 619 – 00 ;QJYXOS0WMA__.pdf
42.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 619 – 00 ;QJYXOS1SRUQ_.pdf
43.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 619 – 04 ;QJYXOQ__.pdf
44.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 620 – 03 ;QJYYMA__.pdf
27.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 620 – 98 ;QJYYMC1SRUQ_.pdf
31.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 621 – 02 ;QJYYMQ__.pdf
34.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 621 – 95 ;QJYYMS1SRUQ_.pdf
31.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 621 – 95 ;QJYYMS05NUE_.pdf
35.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 622 – 00 ;QJYYMI0WMA__.pdf
52.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 622 – 00 ;QJYYMI1SRUQ_.pdf
49.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 622 – 04 ;QJYYMG__.pdf
52.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 625 – 04 ;QJYYNQ__.pdf
25.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 625 – 99 ;QJYYNS1SRUQ_.pdf
37.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 625 – 99 ;QJYYNS05OQ__.pdf
86.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 626 – 00 ;QJYYNI0WMA__.pdf
35.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 626 – 01 ;QJYYNI0WMQ__.pdf
40.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 626 – 03 ;QJYYNI0WMW__.pdf
38.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 626 – 03 ;QJYYNI1SRUQ_.pdf
31.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 626 – 04 ;QJYYNG__.pdf
39.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 628 – 98 ;QJYYOC05OA__.pdf
37.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 628 – 98 R04 ;QJYYOA__.pdf
29.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 631 – 93 R04 ;QJYZMQ__.pdf
38.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 631 – 93 R98 ;QJYZMS05M1I5OA__.pdf
39.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 637 – 03 ;QJYZNW__.pdf
49.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 637 – 98 ;QJYZNY1SRUQ_.pdf
39.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 637 – 98 ;QJYZNY05OA__.pdf
52.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 639 – 02 ;QJYZOQ__.pdf
39.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 639 – 97 ;QJYZOS1SRUQ_.pdf
31.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 639 – 97 ;QJYZOS05NW__.pdf
41.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 649 – 02 ;QJY0OQ__.pdf
60.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 649 – 95 ;QJY0OS1SRUQ_.pdf
51.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 652 – B 652M – 04 ;QJY1MI9CNJUYTQ__.pdf
25.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 652 – B 652M – 96 R99 ;QJY1MI05NLI5OQ__.pdf
25.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 652 – B 652M – 96 R99 ;QJY1MI9CNJUYTS1SRUQ_.pdf
23.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 653 – B 653M – 01 ;QJY1MY0WMQ__.pdf
34.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 653 – B 653M – 01 ;QJY1MY9CNJUZTS1SRUQ_.pdf
25.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 653 – B 653M – 02 ;QJY1MY9CNJUZTQ__.pdf
32.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 654 – 92 R99 ;QJY1NC05MLI5OQ__.pdf
48.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 654 – B 654M – 03 ;QJY1NC9CNJU0TS1SRUQ_.pdf
59.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 654 – B 654M – 04 ;QJY1NC9CNJU0TQ__.pdf
50.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 655 – B 655M – 04 ;QJY1NS9CNJU1TQ__.pdf
36.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 655 – B 655M – 96 R99 ;QJY1NS05NLI5OQ__.pdf
36.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 655 – B 655M – 96 R99 ;QJY1NS9CNJU1TS1SRUQ_.pdf
34.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 658 – B 658M – 01 ;QJY1OC0WMQ__.pdf
41.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 658 – B 658M – 01 ;QJY1OC9CNJU4TS1SRUQ_.pdf
37.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 658 – B 658M – 02 ;QJY1OC9CNJU4TQ__.pdf
B 662 – 94 R00 ;QJY2MG__.pdf
31.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 663 – 94 R00 ;QJY2MW__.pdf
32.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 664 – 90 R00 ;QJY2NA__.pdf
31.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 667 – 97 ;QJY2NY05NW__.pdf
50.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 667 – 97 R03 ;QJY2NW__.pdf
57.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 667 – 97 R03 ;QJY2NY1SRUQ_.pdf
39.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 668 – 00 ;QJY2OA__.pdf
23.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 668 – 99 ;QJY2OC1SRUQ_.pdf
18.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 670 – 02 ;QJY3MA__.pdf
74.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 670 – 95 ;QJY3MC1SRUQ_.pdf
55.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 671 – 81 R99 ;QJY3MQ__.pdf
30.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 672 – 02 ;QJY3MG__.pdf
46.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 672 – 95 ;QJY3MI1SRUQ_.pdf
56.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 672 – 95 ;QJY3MI05NQ__.pdf
50.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 673 – 96 ;QJY3MY05NG__.pdf
19.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 673 – 96 R02 ;QJY3MW__.pdf
38.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 674 – 96 ;QJY3NC05NG__.pdf
15.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 674 – 96 R02 ;QJY3NA__.pdf
33.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 675 – 02 ;QJY3NQ__.pdf
33.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 675 – 96 ;QJY3NS1SRUQ_.pdf
26.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 675 – 96 ;QJY3NS05NKUX.pdf
41.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 676 – 02 ;QJY3NI0WMG__.pdf
35.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 676 – 02 ;QJY3NI1SRUQ_.pdf
23.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 676 – 03 ;QJY3NG__.pdf
36.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 676 – 97 ;QJY3NI05NW__.pdf
34.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 677 – 04 ;QJY3NW__.pdf
29.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 677 – 99 ;QJY3NY1SRUQ_.pdf
35.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 677 – 99 ;QJY3NY05OQ__.pdf
45.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 683 – 01 ;QJY4MW__.pdf
B 683 – 90 R95 ;QJY4MY1SRUQ_.pdf
21.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 683 – 90 R95 ;QJY4MY05MFI5NUUX.pdf
18.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 684 – 97 ;QJY4NC05NW__.pdf
29.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 684 – 97 R02 ;QJY4NA__.pdf
28.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 685 – 01 ;QJY4NQ__.pdf
24.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 685 – 90 R95 ;QJY4NS1SRUQ_.pdf
20.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 685 – 90 R95 ;QJY4NS05MFI5NUUX.pdf
17.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 688 – 96 ;QJY4OC05NG__.pdf
75.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 688 – 96 R04 ;QJY4OA__.pdf
74.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 690 – 02 ;QJY5MA__.pdf
46.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 690 – 96 ;QJY5MC1SRUQ_.pdf
36.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 690 – 96 ;QJY5MC05NG__.pdf
55.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 691 – 02 ;QJY5MQ__.pdf
58.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 691 – 95 ;QJY5MS1SRUQ_.pdf
42.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 691 – 95 ;QJY5MS05NQ__.pdf
38.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 692 – 90 R00 ;QJY5MG__.pdf
31.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 693 – 91 R01 ;QJY5MW__.pdf
29.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 693 – 91 R96 ;QJY5MY05MVI5NKUX.pdf
20.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 702 – 93 R04 ;QJCWMG__.pdf
30.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 6 – 00 ;QJYTMDA_.pdf
34.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 6 – 00 ;QJYTUKVE.pdf
26.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 6 – 03 ;QJY_.pdf
33.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 23 – 00 ;QJIZ.pdf
40.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 23 – 94 ;QJIZLVJFRA__.pdf
32.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 29 – 03 ;QJI5.pdf
41.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 29 – 92 R97 ;QJI5LTKYUJK3.pdf
43.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 29 – 92 R97 ;QJI5LVJFRA__.pdf
38.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 32 – 00 ;QJMYLTAW.pdf
84.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 32 – 00 ;QJMYLTAWRTE_.pdf
93.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 32 – 00 ;QJMYLVJFRA__.pdf
61.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 32 – 03 ;QJMY.pdf
81.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 39 – 79 R04 ;QJM5.pdf
28.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 39 – 79 R99 ;QJM5LTC5UJK5.pdf
27.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 63 – 90 R01 ;QJYZ.pdf
53.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 63 – 90 R95 ;QJYZLTKWUJK1RTE_.pdf
42.31 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
B 69 – 01 ;QJY5.pdf
44.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 69 – 01 ;QJY5LTAX.pdf
24.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 69 – 01 ;QJY5LTAXRTE_.pdf
25.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 69 – 01 ;QJY5LVJFRA__.pdf
28.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 69 – 98 ;QJY5LTK4QUUY.pdf
25.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 70 – 90 R01 ;QJCW.pdf
27.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 70 – 90 R95 ;QJCWLTKWUJK1RTE_.pdf
19.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 76 – 90 R01 ;QJC2.pdf
99.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 76 – 90 R95 ;QJC2LTKWUJK1RTE_.pdf
89.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 77 – 81 R01 ;QJC3.pdf
33.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 77 – 81 R94 ;QJC3LTGXUJK0RTE_.pdf
20.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 78 – 90 R01 ;QJC4.pdf
78.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 78 – 90 R95 ;QJC4LTKWUJK1RTE_.pdf
67.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 84 – 90 R01 ;QJG0.pdf
60.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 84 – 90 R95 ;QJG0LTKWUJK1RTE_.pdf
38.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 86 – 03 ;QJG2.pdf
62.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 86 – 98 ;QJG2LTK4RTE_.pdf
73.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 86 – 98 ;QJG2LVJFRA__.pdf
46.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 102 – 00 ;QJEWMG__.pdf
37.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 102 – 93 ;QJEWMI1SRUQ_.pdf
27.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 106 – 96 ;QJEWNI05NG__.pdf
51.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 106 – 96 R02 ;QJEWNG__.pdf
84.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 114 – 90 R01 ;QJEXNA__.pdf
77.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 114 – 90 R95 ;QJEXNC05MFI5NUUX.pdf
54.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 127 – 98 ;QJEYNW__.pdf
101.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 160 – 99 ;QJE2MA__.pdf
54.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 161 – 00 ;QJE2MS0WMA__.pdf
35.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 161 – 00 ;QJE2MS1SRUQ_.pdf
27.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 161 – 03 ;QJE2MQ__.pdf
36.9 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
B 162 – 99 ;QJE2MG__.pdf
93.8 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 163 – 01 ;QJE2MY0WMQ__.pdf
58.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 163 – 02 ;QJE2MY0WMG__.pdf
87.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 163 – 02 ;QJE2MY1SRUQ_.pdf
65.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 163 – 04 ;QJE2MW__.pdf
89.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 163 – 98 ;QJE2MY05OEE_.pdf
58.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 164 – 03 ;QJE2NA__.pdf
77 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 164 – 98 ;QJE2NC1SRUQ_.pdf
56.47 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 164 – 98 ;QJE2NC05OA__.pdf
80.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 165 – 93 ;QJE2NS05MW__.pdf
55.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 165 – 93 R03 ;QJE2NQ__.pdf
61.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 166 – 00 ;QJE2NI0WMA__.pdf
42.87 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
B 166 – 01 ;QJE2NI0WMQ__.pdf
69.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 166 – 01 ;QJE2NI1SRUQ_.pdf
47.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 166 – 04 ;QJE2NG__.pdf
65.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 167 – 00 ;QJE2NY0WMA__.pdf
41.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 167 – 00 ;QJE2NY1SRUQ_.pdf
60.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 167 – 01 ;QJE2NW__.pdf
63.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 168 – 00 ;QJE2OC0WMA__.pdf
58.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 168 – 00 ;QJE2OC1SRUQ_.pdf
68.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 168 – 01 ;QJE2OA__.pdf
94.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 223 – 03 ;QJIYMW__.pdf
102.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 223 – 97 ;QJIYMY1SRUQ_.pdf
92.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 223 – 97 ;QJIYMY05NW__.pdf
104.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 237 – 01 ;QJIZNW__.pdf
26.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 237 – 96 ;QJIZNY1SRUQ_.pdf
24.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 237 – 96 ;QJIZNY05NG__.pdf
16.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 240 – 01 ;QJI0MC0WMQ__.pdf
23.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 240 – 01 ;QJI0MC0WMUUX.pdf
42.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 240 – 01 ;QJI0MC1SRUQ_.pdf
27.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 240 – 03 ;QJI0MA__.pdf
34.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 240 – 98 ;QJI0MC05OEUX.pdf
22.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 265 – 02 ;QJI2NS1SRUQ_.pdf
130.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 265 – 03 ;QJI2NQ__.pdf
77.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 265 – 99 ;QJI2NS0WMG__.pdf
84.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 265 – 99 ;QJI2NS05OUUX.pdf
88.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 267 – 90 R01 ;QJI2NW__.pdf
46.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 267 – 90 R95 ;QJI2NY05MFI5NUUX.pdf
30.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 277 – 95 ;QJI3NY05NQ__.pdf
15.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 277 – 95 R01 ;QJI3NW__.pdf
24.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 299 – 01 ;QJI5OQ__.pdf
29.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 299 – 99 ;QJI5OS1SRUQ_.pdf
27.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 299 – 99 ;QJI5OS05OQ__.pdf
17.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 327 – 01 ;QJMYNW__.pdf
45.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 327 – 01 ;QJMYNY0WMUUX.pdf
B 327 – 98 ;QJMYNY05OEUX.pdf
24.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 333 – 03 ;QJMZMW__.pdf
33.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 333 – 98 ;QJMZMY1SRUQ_.pdf
34.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 333 – 98 ;QJMZMY05OA__.pdf
50.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 335 – 03 ;QJMZNQ__.pdf
38.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 335 – 98 ;QJMZNS1SRUQ_.pdf
28.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 335 – 98 ;QJMZNS05OA__.pdf
39.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 01 ;QJMZOC0WMQ__.pdf
41.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 01 ;QJMZOC0WMUE_.pdf
65.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 02 ;QJMZOC0WMG__.pdf
65.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 02 ;QJMZOC1SRUQ_.pdf
53.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 03 ;QJMZOA__.pdf
62.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 338 – 99 ;QJMZOC05OQ__.pdf
41.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 339 – 00 ;QJMZOQ__.pdf
49.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 339 – 95 ;QJMZOS1SRUQ_.pdf
B 344 – 01 ;QJM0NA__.pdf
36.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 348 – 00 ;QJM0OC0WMA__.pdf
75.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 348 – 02 ;QJM0OC0WMG__.pdf
77.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 348 – 02 ;QJM0OC1SRUQ_.pdf
48.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 348 – 03 ;QJM0OA__.pdf
73.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 349 – B 349M – 01 ;QJM0OS0WMQ__.pdf
31.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 349 – B 349M – 01 ;QJM0OS9CMZQ5TS1SRUQ_.pdf
23.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 349 – B 349M – 03 ;QJM0OS9CMZQ5TQ__.pdf
30.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 349 – B 349M – 98 ;QJM0OS05OA__.pdf
19.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 350 – B350M – 01 ;QJM1MC0WMQ__.pdf
22.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 350 – B350M – 96 ;QJM1MC05NG__.pdf
21.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 350 – B 350M – 01 ;QJM1MC9CMZUWTS1SRUQ_.pdf
27.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 350 – B 350M – 02 ;QJM1MC9CMZUWTQ__.pdf
34.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 351 – 97 ;QJM1MS05NW__.pdf
33.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 351 – B 351M – 01 ;QJM1MS9CMZUXTS1SRUQ_.pdf
42.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 351 – B 351M – 02 ;QJM1MS9CMZUXTQ__.pdf
52.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 352 – 97 ;QJM1MI05NW__.pdf
36.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 352 – B 352M – 01 ;QJM1MI9CMZUYTS1SRUQ_.pdf
42.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 352 – B 352M – 02 ;QJM1MI9CMZUYTQ__.pdf
55.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 353 – 00 ;QJM1MY0WMA__.pdf
158.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 353 – 01 ;QJM1MY0WMQ__.pdf
162.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 353 – 01 ;QJM1MY0WMUUX.pdf
218.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 353 – 01 ;QJM1MY1SRUQ_.pdf
186.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 353 – 02 ;QJM1MW__.pdf
225.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 362 – 91 R03 ;QJM2MG__.pdf
48.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 362 – 91 R97 ;QJM2MI05MVI5N0UX.pdf
57.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 363 – 00 ;QJM2MY0WMA__.pdf
36.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 363 – 02 ;QJM2MY0WMG__.pdf
37.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 363 – 03 ;QJM2MW__.pdf
35.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 363 – 03 ;QJM2MY0WMW__.pdf
37.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 363 – 03 ;QJM2MY1SRUQ_.pdf
25.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 364 – 96 ;QJM2NC05NG__.pdf
27.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 364 – 96 R02 ;QJM2NA__.pdf
26.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 365 – 98 ;QJM2NS05OA__.pdf
36.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 365 – 98 R04 ;QJM2NQ__.pdf
37.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 366 – 00 ;QJM2NI0WMA__.pdf
33.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 366 – 01 ;QJM2NI0WMQ__.pdf
33.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 366 – 01 ;QJM2NI0WMUUX.pdf
61.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 366 – 01 ;QJM2NI1SRUQ_.pdf
63.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 366 – 04 ;QJM2NG__.pdf
66.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 367 – 93 R04 ;QJM2NW__.pdf
44.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 367 – 93 R98 ;QJM2NY05M1I5OA__.pdf
44.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 381 – 00 ;QJM4MS0WMA__.pdf
41.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 381 – 02 ;QJM4MS0WMG__.pdf
66.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 381 – 02 ;QJM4MS1SRUQ_.pdf
45.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 381 – 03 ;QJM4MQ__.pdf
62.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 386 – 03 ;QJM4NG__.pdf
71.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 386 – 91 R97 ;QJM4NI1SRUQ_.pdf
72.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 386 – 91 R97 ;QJM4NI05MVI5NW__.pdf
49.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 387 – 90 R01 ;QJM4NW__.pdf
24.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 387 – 90 R95 ;QJM4NY05MFI5NUUX.pdf
26.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 388 – 00 ;QJM4OA__.pdf
54.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 388 – 96 ;QJM4OC1SRUQ_.pdf
46.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 389 – 81 R04 ;QJM4OQ__.pdf
62.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 391 – 03 ;QJM5MQ__.pdf
29.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 391 – 99 ;QJM5MS1SRUQ_.pdf
22.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 391 – 99 ;QJM5MS05OQ__.pdf
30.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 392 – 03 ;QJM5MG__.pdf
37.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 392 – 99 ;QJM5MI1SRUQ_.pdf
28.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 392 – 99 ;QJM5MI05OQ__.pdf
38.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 393 – 03 ;QJM5MW__.pdf
48.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 393 – 99 ;QJM5MY1SRUQ_.pdf
43.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 393 – 99 ;QJM5MY05OQ__.pdf
48.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 394 – 03 ;QJM5NA__.pdf
41.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 394 – 99 ;QJM5NC1SRUQ_.pdf
32.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 394 – 99 ;QJM5NC05OQ__.pdf
B 407 – 01 ;QJQWNW__.pdf
67.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 407 – 96 ;QJQWNY1SRUQ_.pdf
53.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 407 – 96 ;QJQWNY05NG__.pdf
43.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 408 – 01 ;QJQWOA__.pdf
49.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 408 – 96 ;QJQWOC1SRUQ_.pdf
43.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 408 – 96 ;QJQWOC05NG__.pdf
32.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 409 – 01 ;QJQWOQ__.pdf
82.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 409 – 96 ;QJQWOS1SRUQ_.pdf
61.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 409 – 96 ;QJQWOS05NKE_.pdf
B 413 – 97 ;QJQXMY05N0E_.pdf
31.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 413 – 97a R03 ;QJQXMW__.pdf
31.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 418 – 01 ;QJQXOA__.pdf
39.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 418 – 95a R00 ;QJQXOC1SRUQ_.pdf
27.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 418 – 95a R00 ;QJQXOC05NUFSMDBFMQ__.pdf
22.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 423 – 03 ;QJQYMW__.pdf
37.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 423 – 99 ;QJQYMY1SRUQ_.pdf
28.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 423 – 99 ;QJQYMY05OQ__.pdf
41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 424 – 98 ;QJQYNA__.pdf
75.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 425 – 99 ;QJQYNQ__.pdf
47.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 434 – 00 ;QJQZNA__.pdf
41.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 434 – 95 ;QJQZNC1SRUQ_.pdf
38.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 435 – 03 ;QJQZNQ__.pdf
B 435 – 98 ;QJQZNS1SRUQ_.pdf
35.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 435 – 98 ;QJQZNS05OEE_.pdf
45.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 440 – 00 ;QJQ0MA__.pdf
29.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 440 – 99 ;QJQ0MC1SRUQ_.pdf
31.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 443 – 00 ;QJQ0MW__.pdf
82.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 444 – 00 ;QJQ0NC0WMEUX.pdf
44.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 444 – 00 ;QJQ0NC1SRUQ_.pdf
28.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 444 – 03 ;QJQ0NA__.pdf
35.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 446 – 00 ;QJQ0NI0WMEUX.pdf
33.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 446 – 02 ;QJQ0NI0WMG__.pdf
58.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 446 – 02 ;QJQ0NI1SRUQ_.pdf
37.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 446 – 03 ;QJQ0NG__.pdf
48.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 462 – 00 ;QJQ2MI0WMEE_.pdf
40.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 462 – 02 ;QJQ2MI0WMG__.pdf
41.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 462 – 02 ;QJQ2MI1SRUQ_.pdf
38.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 462 – 04 ;QJQ2MG__.pdf
43.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 463 – 04 ;QJQ2MW__.pdf
B 463 – 99 ;QJQ2MY1SRUQ_.pdf
32.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 463 – 99 ;QJQ2MY05OQ__.pdf
B 464 – 04 ;QJQ2NA__.pdf
26.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 464 – 99 ;QJQ2NC1SRUQ_.pdf
22.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 464 – 99 ;QJQ2NC05OQ__.pdf
27.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 468 – 04 ;QJQ2OA__.pdf
26.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 468 – 99 ;QJQ2OC1SRUQ_.pdf
22.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 468 – 99 ;QJQ2OC05OQ__.pdf
27.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 472 – 00 ;QJQ3MI0WMA__.pdf
34.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 472 – 03 ;QJQ3MI0WMW__.pdf
36.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 472 – 03 ;QJQ3MI1SRUQ_.pdf
30.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 472 – 04 ;QJQ3MG__.pdf
37.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 473 – 96 ;QJQ3MY05NG__.pdf
36.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 473 – 96 R02 ;QJQ3MW__.pdf
66.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 474 – 03 ;QJQ3NA__.pdf
86.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 474 – 99 ;QJQ3NC1SRUQ_.pdf
85.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 474 – 99 ;QJQ3NC05OQ__.pdf
71.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 475 – 96 ;QJQ3NS05NG__.pdf
19.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 475 – 96 R02 ;QJQ3NQ__.pdf
39.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 476 – 01 ;QJQ3NG__.pdf
38.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 476 – 90 R95 ;QJQ3NI1SRUQ_.pdf
30.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 476 – 90 R95 ;QJQ3NI05MFI5NUUX.pdf
26.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 477 – 97 ;QJQ3NY05NW__.pdf
26.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 477 – 97 R02 ;QJQ3NW__.pdf
25.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 478 – 85 R03 ;QJQ3OA__.pdf
44.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 478 – 85 R97 ;QJQ3OC04NVI5N0UX.pdf
53.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 493 – 01 ;QJQ5MY0WMQ__.pdf
32.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 493 – 01 R03 ;QJQ5MW__.pdf
31.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 493 – 83 R98 ;QJQ5MY04M1I5OA__.pdf
19.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 494 – B 494M – 01 ;QJQ5NC0WMQ__.pdf
B 494 – B 494M – 01 ;QJQ5NC9CNDK0TS1SRUQ_.pdf
B 494 – B 494M – 03 ;QJQ5NC9CNDK0TQ__.pdf
30.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 494 – B 494M – 98 ;QJQ5NC05OA__.pdf
19.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 495 – 01 ;QJQ5NQ__.pdf
31.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 495 – 90 R00 ;QJQ5NS1SRUQ_.pdf
31.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 495 – 90 R00 ;QJQ5NS05MFIWMA__.pdf
20.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 497 – 00 ;QJQ5NW__.pdf
36.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 511 – 01 ;QJUXMQ__.pdf
52.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 511 – 98 ;QJUXMS1SRUQ_.pdf
36.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 511 – 98 ;QJUXMS05OEE_.pdf
32.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 512 – 04 ;QJUXMG__.pdf
26.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 512 – 99 ;QJUXMI1SRUQ_.pdf
20.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 512 – 99 ;QJUXMI05OQ__.pdf
27.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 514 – 95 ;QJUXNC05NQ__.pdf
16.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 514 – 95 R02 ;QJUXNA__.pdf
34.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 515 – 95 R02 ;QJUXNQ__.pdf
B 516 – 03 ;QJUXNG__.pdf
25.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 516 – 98 ;QJUXNI1SRUQ_.pdf
20.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 516 – 98 ;QJUXNI05OA__.pdf
26.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 517 – 03 ;QJUXNW__.pdf
26.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 517 – 98 ;QJUXNY1SRUQ_.pdf
22.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 517 – 98 ;QJUXNY05OA__.pdf
26.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 521 – 98 R04 ;QJUYMQ__.pdf
35.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 522 – 01 ;QJUYMG__.pdf
26.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 522 – 90 R95 ;QJUYMI1SRUQ_.pdf
23.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 522 – 90 R95 ;QJUYMI05MFI5NUUX.pdf
18.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 523 – B 523M – 01 ;QJUYMY0WMQ__.pdf
46.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 523 – B 523M – 01 ;QJUYMY9CNTIZTS1SRUQ_.pdf
33.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 523 – B 523M – 02 ;QJUYMY9CNTIZTQ__.pdf
45.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 535 – 04 ;QJUZNQ__.pdf
27.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 535 – 99 ;QJUZNS1SRUQ_.pdf
22.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 535 – 99 ;QJUZNS05OQ__.pdf
B 536 – 02 ;QJUZNG__.pdf
77.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 536 – 95 ;QJUZNI1SRUQ_.pdf
84.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 536 – 95 ;QJUZNI05NQ__.pdf
47.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 539 – 02 ;QJUZOQ__.pdf
75.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 539 – 02 ;QJUZOS0WMG__.pdf
69.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 539 – 02 ;QJUZOS1SRUQ_.pdf
56.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 539 – 96 ;QJUZOS05NG__.pdf
92.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 540 – 97 ;QJU0MC05NW__.pdf
31.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 540 – 97 R02 ;QJU0MA__.pdf
29.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 541 – 01 ;QJU0MQ__.pdf
30.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 541 – 95 ;QJU0MS1SRUQ_.pdf
22.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 541 – 95 ;QJU0MS05NQ__.pdf
18.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 542 – 00 ;QJU0MI0WMA__.pdf
B 542 – 00 ;QJU0MI1SRUQ_.pdf
33.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 542 – 04 ;QJU0MG__.pdf
42.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 546 – 04 ;QJU0NG__.pdf
37.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 546 – 98 ;QJU0NI1SRUQ_.pdf
31.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 546 – 98 ;QJU0NI05OA__.pdf
38.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 550 – B 550M – 01 ;QJU1MC0WMQ__.pdf
53.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 550 – B 550M – 01 ;QJU1MC9CNTUWTS1SRUQ_.pdf
36.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 550 – B 550M – 02 ;QJU1MC9CNTUWTQ__.pdf
51.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 551 – B 551M – 01 ;QJU1MS0WMQ__.pdf
76.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 551 – B 551M – 02 ;QJU1MS0WMG__.pdf
73.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 551 – B 551M – 02 ;QJU1MS9CNTUXTS1SRUQ_.pdf
87.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 551 – B 551M – 04 ;QJU1MS9CNTUXTQ__.pdf
73.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 560 – 00 ;QJU2MA__.pdf
32.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 560 – 94 ;QJU2MC1SRUQ_.pdf
25.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 561 – 94 R99 ;QJU2MQ__.pdf
31.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 562 – 95 R99 ;QJU2MG__.pdf
35.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 563 – 01 ;QJU2MW__.pdf
30.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 563 – 95 ;QJU2MY1SRUQ_.pdf
21.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 563 – 95 ;QJU2MY05NQ__.pdf
19.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 564 – 00 ;QJU2NC0WMEE_.pdf
65.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 564 – 00 ;QJU2NC1SRUQ_.pdf
58.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 564 – 04 ;QJU2NA__.pdf
67.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 572 – 03 ;QJU3MG__.pdf
37.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 572 – 98 ;QJU3MI1SRUQ_.pdf
27.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 572 – 98 ;QJU3MI05OEE_.pdf
B 573 – 00 ;QJU3MW__.pdf
34.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 573 – 95 ;QJU3MY1SRUQ_.pdf
29.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 574 – 04 ;QJU3NA__.pdf
38.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 574 – 99 ;QJU3NC1SRUQ_.pdf
B 574 – 99 ;QJU3NC05OUE_.pdf
38.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 575 – 04 ;QJU3NQ__.pdf
35.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 575 – 99 ;QJU3NS1SRUQ_.pdf
47.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 575 – 99 ;QJU3NS05OUE_.pdf
B 576 – 94 R99 ;QJU3NG__.pdf
24.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 581 – 02 ;QJU4MQ__.pdf
37.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 581 – 97 ;QJU4MS1SRUQ_.pdf
36.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 581 – 97 ;QJU4MS05NW__.pdf
39.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 582 – 02 ;QJU4MG__.pdf
46.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 582 – 97 ;QJU4MI1SRUQ_.pdf
55.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 582 – 97 ;QJU4MI05NW__.pdf
49.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 589 – 94 R99 ;QJU4OQ__.pdf
31.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 596 – 89 R99 ;QJU5NG__.pdf
27.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 599 – 92 R03 ;QJU5OQ__.pdf
87.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 599 – 92 R97 ;QJU5OS05MLI5NW__.pdf
84.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 600 – 91 R02 ;QJYWMA__.pdf
30.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 600 – 91 R97 ;QJYWMC05MVI5N0UX.pdf
22.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 603 – 90 R01 ;QJYWMW__.pdf
26.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 603 – 90 R95 ;QJYWMY05MFI5NUUX.pdf
18.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 613 – 76 R00 ;QJYXMW__.pdf
B 614 – 95 R00 ;QJYXNA__.pdf
18.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 615 – 79 R00 ;QJYXNQ__.pdf
33.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
18.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
B 702 – 93 R98 ;QJCWMI05M1I5OA__.pdf
30.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 704 – 00 ;QJCWNC0WMA__.pdf
25.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 704 – 00 ;QJCWNC1SRUQ_.pdf
20.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 704 – 03 ;QJCWNA__.pdf
26.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 705 – 00 ;QJCWNS0WMA__.pdf
26.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 705 – 00 ;QJCWNS1SRUQ_.pdf
23.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 705 – 03 ;QJCWNQ__.pdf
B 708 – 01 ;QJCWOA__.pdf
64.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 708 – 98 ;QJCWOC1SRUQ_.pdf
60.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 708 – 98 ;QJCWOC05OA__.pdf
32.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 709 – 04 ;QJCWOQ__.pdf
35.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 709 – 98 ;QJCWOS1SRUQ_.pdf
56.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 709 – 98 ;QJCWOS05OA__.pdf
79.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 710 – 04 ;QJCXMA__.pdf
B 710 – 99 ;QJCXMC1SRUQ_.pdf
21.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 710 – 99 ;QJCXMC05OQ__.pdf
26.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 712 – 93 R99 ;QJCXMG__.pdf
25.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 717 – 96 R00 ;QJCXNW__.pdf
23.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 718 – 00 ;QJCXOA__.pdf
63.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 718 – 95 ;QJCXOC1SRUQ_.pdf
42.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 719 – 00 ;QJCXOQ__.pdf
42.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 719 – 83 R94 ;QJCXOS1SRUQ_.pdf
36.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 722 – 02 ;QJCYMG__.pdf
25.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 722 – 95 R00 ;QJCYMI1SRUQ_.pdf
21.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 722 – 95 R00 ;QJCYMI05NVIWMA__.pdf
26.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 723 – 00 ;QJCYMW__.pdf
28.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 723 – 95 ;QJCYMY1SRUQ_.pdf
20.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 725 – 93 ;QJCYNS05MW__.pdf
50.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 725 – 93 R03 ;QJCYNQ__.pdf
56.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 726 – 01 ;QJCYNI0WMQ__.pdf
19.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 726 – 01 ;QJCYNI1SRUQ_.pdf
20.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 726 – 02 ;QJCYNG__.pdf
28.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 726 – 95 ;QJCYNI05NQ__.pdf
17.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 729 – 00 ;QJCYOQ__.pdf
B 729 – 99 ;QJCYOS1SRUQ_.pdf
20.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 731 – 96 ;QJCZMS05NG__.pdf
15.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 731 – 96 R01 ;QJCZMQ__.pdf
24.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 735 – 95 R00 ;QJCZNQ__.pdf
46.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 737 – 01 ;QJCZNW__.pdf
39.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 737 – 90 R00 ;QJCZNY05MFIWMA__.pdf
B 737 – 90 R95 ;QJCZNY1SRUQ_.pdf
30.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 739 – 03 ;QJCZOQ__.pdf
23.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 739 – 98 ;QJCZOS1SRUQ_.pdf
18.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 739 – 98 ;QJCZOS05OA__.pdf
26.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 741 – 95 R00 ;QJC0MQ__.pdf
66.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 742 – 90 R00 ;QJC0MG__.pdf
34.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 749 – 03 ;QJC0OQ__.pdf
37.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 749 – 97 ;QJC0OS1SRUQ_.pdf
28.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 749 – 97 ;QJC0OS05NW__.pdf
B 750 – 03 ;QJC1MA__.pdf
33.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 750 – 99 ;QJC1MC1SRUQ_.pdf
30.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 750 – 99 ;QJC1MC05OUUX.pdf
42.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 751 – 01 ;QJC1MS0WMQ__.pdf
46.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 751 – 02 ;QJC1MS0WMG__.pdf
57.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 751 – 02 ;QJC1MS1SRUQ_.pdf
38.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 751 – 03 ;QJC1MQ__.pdf
54.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 751 – 99 ;QJC1MS05OQ__.pdf
B 752 – 01 ;QJC1MG__.pdf
39.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 752 – 97 ;QJC1MI1SRUQ_.pdf
33.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 752 – 97 ;QJC1MI05NW__.pdf
25.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 753 – 01 ;QJC1MW__.pdf
B 753 – 86 R98 ;QJC1MY1SRUQ_.pdf
32.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 753 – 86 R98 ;QJC1MY04NLI5OA__.pdf
22.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 755 – 00 ;QJC1NQ__.pdf
70.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 755 – 98 ;QJC1NS1SRUQ_.pdf
47.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 756 – 00 ;QJC1NG__.pdf
44.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 756 – 98 ;QJC1NI1SRUQ_.pdf
33.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 757 – 00 ;QJC1NW__.pdf
B 757 – 99 ;QJC1NY1SRUQ_.pdf
34.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 758 – 00 ;QJC1OA__.pdf
43.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 758 – 99 ;QJC1OC1SRUQ_.pdf
32.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 759 – 00 ;QJC1OQ__.pdf
29.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 759 – 86 R94 ;QJC1OS1SRUQ_.pdf
43.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 760 – 86 R99 ;QJC2MA__.pdf
34.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 772 – 97 ;QJC3MI05NW__.pdf
25.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 772 – 97 R03 ;QJC3MG__.pdf
24.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 773 – 96 ;QJC3MY05NG__.pdf
21.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 773 – 96 R02 ;QJC3MW__.pdf
40.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 774 – 00 ;QJC3NA__.pdf
B 774 – 95 ;QJC3NC1SRUQ_.pdf
31.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 775 – 00 ;QJC3NS0WMA__.pdf
32.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 775 – 01 ;QJC3NS0WMQ__.pdf
50.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 775 – 01 ;QJC3NS1SRUQ_.pdf
37.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 775 – 02 ;QJC3NQ__.pdf
51.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 776 – 01 ;QJC3NG__.pdf
48.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 776 – 01 ;QJC3NI0WMQ__.pdf
32.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 776 – 01 ;QJC3NI1SRUQ_.pdf
37.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 776 – 91 R95 ;QJC3NI05MVI5NQ__.pdf
30.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 777 – 99 ;QJC3NW__.pdf
20.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 780 – 98 ;QJC4MC05OA__.pdf
25.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 780 – 98 R04 ;QJC4MA__.pdf
26.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 781 – 93a R99 ;QJC4MQ__.pdf
39.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 792 – 01 ;QJC5MG__.pdf
37.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 792 – 01 ;QJC5MI0WMQ__.pdf
20.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 792 – 98 ;QJC5MI05OEUX.pdf
19.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 793 – 01 ;QJC5MY0WMQ__.pdf
20.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 793 – 01 ;QJC5MY0WMUUX.pdf
38.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 793 – 01 ;QJC5MY1SRUQ_.pdf
24.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 793 – 03 ;QJC5MW__.pdf
B 793 – 98 ;QJC5MY05OEUX.pdf
19.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 794 – 97 ;QJC5NC05NW__.pdf
78.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 794 – 97 R03 ;QJC5NA__.pdf
75.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 798 – 95 R00 ;QJC5OA__.pdf
63.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 799 – 95 R00 ;QJC5OQ__.pdf
53.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 804 – 02 ;QJGWNA__.pdf
79.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 804 – 96 ;QJGWNC1SRUQ_.pdf
65.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 804 – 96 ;QJGWNC05NG__.pdf
81.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 805 – 02 ;QJGWNQ__.pdf
57.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 805 – 95 ;QJGWNS1SRUQ_.pdf
97.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 805 – 95 ;QJGWNS05NQ__.pdf
61.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 808 – 97 ;QJGWOC05NW__.pdf
37.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 808 – 97 R03 ;QJGWOA__.pdf
36.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 810 – 00 ;QJGXMC0WMA__.pdf
B 810 – 01 ;QJGXMA__.pdf
42.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 810 – 01 ;QJGXMC0WMQ__.pdf
29.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 810 – 01 ;QJGXMC1SRUQ_.pdf
35.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 811 – 01 ;QJGXMS0WMQ__.pdf
179.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 811 – 01 ;QJGXMS1SRUQ_.pdf
186.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 811 – 02 ;QJGXMQ__.pdf
171.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 811 – 97 ;QJGXMS05NW__.pdf
131.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 812 – 96 ;QJGXMI05NG__.pdf
118 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 812 – 96 R02 ;QJGXMG__.pdf
148.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 814 – 02 ;QJGXNA__.pdf
43.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 814 – 95 ;QJGXNC1SRUQ_.pdf
B 815 – 02 ;QJGXNQ__.pdf
34.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 815 – 97 ;QJGXNS1SRUQ_.pdf
31.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 815 – 97 ;QJGXNS05NW__.pdf
35.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 818 – 03 ;QJGXOA__.pdf
26.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 818 – 98 ;QJGXOC1SRUQ_.pdf
31.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 818 – 98 ;QJGXOC05OEE_.pdf
42.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 825 – 02 ;QJGYNQ__.pdf
94.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 825 – 97 ;QJGYNS1SRUQ_.pdf
79.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 825 – 97 ;QJGYNS05NW__.pdf
98.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 826 – 03 ;QJGYNG__.pdf
45.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 826 – 97 ;QJGYNI1SRUQ_.pdf
B 826 – 97 ;QJGYNI05NW__.pdf
47.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 827 – 97 ;QJGYNY05NW__.pdf
108.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 827 – 97 R03 ;QJGYNW__.pdf
103.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 829 – 04 ;QJGYOQ__.pdf
B 829 – 99 ;QJGYOS1SRUQ_.pdf
58.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 829 – 99 ;QJGYOS05OQ__.pdf
54.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 833 – 00 ;QJGZMY0WMA__.pdf
23.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 833 – 01 ;QJGZMW__.pdf
43.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 833 – 01 ;QJGZMY0WMQ__.pdf
24.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 833 – 01 ;QJGZMY0WMUUX.pdf
B 833 – 01 ;QJGZMY1SRUQ_.pdf
31.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 834 – 95 ;QJGZNC05NQ__.pdf
38.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 834 – 95 R03 ;QJGZNA__.pdf
B 844 – 98 ;QJG0NC05OA__.pdf
31.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 844 – 98 R04 ;QJG0NA__.pdf
31.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 845 – 97 ;QJG0NS05NW__.pdf
120.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 845 – 97 R03 ;QJG0NQ__.pdf
115.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 852 – 00 ;QJG1MI0WMEE_.pdf
22.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 852 – 00 ;QJG1MI1SRUQ_.pdf
B 852 – 01 ;QJG1MG__.pdf
34.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 854 – 98 ;QJG1NC05OA__.pdf
49.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 854 – 98 R04 ;QJG1NA__.pdf
49.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 860 – 00 ;QJG2MC0WMA__.pdf
18.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 860 – 01 ;QJG2MC0WMQ__.pdf
21.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 860 – 01 ;QJG2MC0WMUUX.pdf
B 860 – 01 ;QJG2MC1SRUQ_.pdf
24.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 860 – 02 ;QJG2MA__.pdf
37.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 861 – 00 ;QJG2MS0WMA__.pdf
38.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 861 – 01 ;QJG2MS0WMQ__.pdf
71.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 861 – 02 ;QJG2MS0WMG__.pdf
71.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 861 – 02 ;QJG2MS1SRUQ_.pdf
58.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 861 – 03 ;QJG2MQ__.pdf
69.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 862 – 01 ;QJG2MI0WMQ__.pdf
B 862 – 01 ;QJG2MI1SRUQ_.pdf
B 862 – 02 ;QJG2MG__.pdf
71.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 862 – 99 ;QJG2MI05OQ__.pdf
45.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 863 – 02 ;QJG2MY0WMG__.pdf
B 863 – 02 ;QJG2MY1SRUQ_.pdf
49.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 863 – 03 ;QJG2MW__.pdf
46.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 863 – 99 ;QJG2MY05OUE_.pdf
B 865 – 04 ;QJG2NQ__.pdf
59.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 865 – 96 ;QJG2NS1SRUQ_.pdf
53.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 865 – 96 ;QJG2NS05NKE_.pdf
79.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 868 – 96 ;QJG2OC05NG__.pdf
41.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 868 – 96 R02 ;QJG2OA__.pdf
69.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 872 – 96 ;QJG3MI05NG__.pdf
75.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 872 – 96 R03 ;QJG3MG__.pdf
73.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 878 – 97 ;QJG3OC05NW__.pdf
60.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 878 – 97 R03 ;QJG3OA__.pdf
59.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 880 – 03 ;QJG4MA__.pdf
31.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 880 – 98 ;QJG4MC1SRUQ_.pdf
22.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 880 – 98 ;QJG4MC05OA__.pdf
32.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 884 – 01 ;QJG4NA__.pdf
57.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 884 – 97 ;QJG4NC1SRUQ_.pdf
37.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 884 – 97 ;QJG4NC05NW__.pdf
34.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 885 – 97 ;QJG4NS05NW__.pdf
57.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 885 – 97 R03 ;QJG4NQ__.pdf
56.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 891 – 98 R04 ;QJG5MQ__.pdf
63.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 892 – 01 ;QJG5MI0WMQ__.pdf
20.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 892 – 01 ;QJG5MI1SRUQ_.pdf
B 892 – 03 ;QJG5MG__.pdf
29.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 892 – 98 ;QJG5MI05OEUZ.pdf
19.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 894 – 03 ;QJG5NA__.pdf
B 894 – 99 ;QJG5NC1SRUQ_.pdf
35.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 894 – 99 ;QJG5NC05OUUX.pdf
49.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 896 – 99 ;QJG5NG__.pdf
74.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 897 – 03 ;QJG5NW__.pdf
55.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 897 – 99 ;QJG5NY1SRUQ_.pdf
129.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 897 – 99 ;QJG5NY05OUFFMQ__.pdf
67.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 898 – 99 ;QJG5OA__.pdf
63.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 01 ;QJG5OS0WMQ__.pdf
B 899 – 01 ;QJG5OS0WMUUX.pdf
47.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 02 ;QJG5OS0WMG__.pdf
40.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 03 ;QJG5OS0WM0E_.pdf
B 899 – 03 ;QJG5OS0WMW__.pdf
40.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 03 ;QJG5OS1SRUQ_.pdf
30.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 04 ;QJG5OQ__.pdf
37.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 899 – 99 ;QJG5OS05OUE_.pdf
17.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 906 – 00 ;QJKWNI0WMA__.pdf
137.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 906 – 00 ;QJKWNI1SRUQ_.pdf
92.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 906 – 02 ;QJKWNG__.pdf
133.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 907 – 00 ;QJKWNY0WMEE_.pdf
32.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 907 – 01 ;QJKWNW__.pdf
57.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 907 – 01 ;QJKWNY0WMQ__.pdf
B 908 – 00 ;QJKWOC0WMA__.pdf
26.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 908 – 00 ;QJKWOC1SRUQ_.pdf
21.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 908 – 03 ;QJKWOA__.pdf
25.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 913 – 00 ;QJKXMW__.pdf
46.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 913 – 00 ;QJKXMY0WMA__.pdf
40.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 914 – 00 ;QJKXNC0WMA__.pdf
25.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 914 – 03 ;QJKXNA__.pdf
B 914 – 03 ;QJKXNC0WMW__.pdf
B 920 – 01 ;QJKYMA__.pdf
60.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 924 – 02 ;QJKYNA__.pdf
49.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
B 932 – 04 ;QJKZMG__.pdf
