Xem: 7453|Trả lời: 0
ASTM 2004 -Volume 03.01 Metals -- Mechanical Testing; Elevated and Low-Temperatu
ASTM 2004 -Volume 03.01 Metals -- Mechanical Testing; Elevated and Low-Temperature Tests; Metallography
/ P5 _( c( A3 N- }, N
7 L" Q2 K9 K( O* t9 q* @+ X2 ~) L* QE0003-01 Guide for Preparation of Metallographic Specimens
- X% x' V- B1 y* VE0004-03 Practices for Force Verification of Testing Machines
4 |8 z% Y2 b4 j% yE0006-03 Terminology Relating to Methods of Mechanical Testing
  A" ]  p0 C( H! U& g2 _% w: }% f6 dE0007-03 Terminology Relating to Metallography
% d% C5 ]" D: B8 R& i( mE0008-04 Test Methods for Tension Testing of Metallic Materials
& b& }" k. U" h6 ^) h% ]5 BE0008M-04 Test Methods for Tension Testing of Metallic Materials \[Metric\]1 w4 K* j& B  L6 s5 Z8 I7 t
E0009-89AR00 Test Methods of Compression Testing of Metallic Materials at Room Temperature! ]9 c/ G+ ^7 B/ n, o- T: q
E0010-01E01 Test Method for Brinell Hardness of Metallic Materials. n4 T+ I& q/ \5 C' f  u" a
E0018-05E01 Test Methods for Rockwell Hardness and Rockwell Superficial Hardness of Metallic Materials- n0 D6 o- {8 D+ l6 L
E0021-03A Test Methods for Elevated Temperature Tension Tests of Metallic Materials4 A8 M0 R( T5 p5 y
E0023-05 Test Methods for Notched Bar Impact Testing of Metallic Materials
6 s* _$ x! g# Y. U9 S" SE0045-97R02 Test Methods for Determining the Inclusion Content of Steel
9 R$ z7 Q/ s2 r# z& V: w- X) k& }2 {E0074-04 Practice of Calibration of Force-Measuring Instruments for Verifying the Force Indication of Testing Machines4 N6 s1 i+ U0 T1 l6 c" U
E0081-96R01 Test Method for Preparing Quantitative Pole Figures
. w6 g" h+ K. oE0082-91R01 Test Method for Determining the Orientation of a Metal Crystal0 k: V0 p! B" R- U/ @
E0083-02 Practice for Verification and Classification of Extensometer System
; Y0 Q& Q) o2 |7 sE0092-82R03E02 Test Method for Vickers Hardness of Metallic Materials
: v( F  e2 g3 M# c7 B* z# w" QE0103-84R02 Test Method for Rapid Indentation Hardness Testing of Metallic Materials' h+ m8 a) p+ b. }0 m. [- }+ L
E0110-82R02 Test Method for Indentation Hardness of Metallic Materials by Portable Hardness Testers  }. q! b. p( M# R' N
E0111-04 Test Method for Young's Modulus, Tangent Modulus, and Chord Modulus3 W! s8 D$ j( M1 \) x
E0112-96R04 Test Methods for Determining Average Grain Size
# S; m; a/ k7 eE0132-04 Test Method for Poisson's Ratio at Room Temperature
1 G: t5 e* S4 T! {; \+ B8 g' G+ eE0139-00E01 Test Methods for Conducting Creep, Creep-Rupture, and Stress-Rupture Tests of Metallic Materials7 j0 d$ `8 f) K6 ^, `6 X
E0140-05 Standard Hardness Conversion Tables for Metals Relationship Among Brinell Hardness, Vickers Hardness, Rockwell Hardness, Superficial Hardness, Knoop Hardness, and Scleroscope Hardness
, n0 v3 s. \. Y6 u- |7 K7 d2 bE0143-02 Test Method for Shear Modulus at Room Temperature8 s2 o3 s3 H; ]4 P( g: O
E0190-92R03 Test Method for Guided Bend Test for Ductility of Welds
4 ?) o  S! K( P" Y' S6 v3 {) SE0208-95AR00 Test Method for Conducting Drop-Weight Test to Determine Nil-Ductility Transition Temperature of Ferritic Steels6 X: A" b5 F" A1 m0 t7 e  W
E0209-00 Practice for Compression Tests of Metallic Materials at Elevated Temperatures with Conventional or Rapid Heating Rates and Strain Rates
$ q/ T% K, g) ~: z/ t+ M2 yE0238-84R02 Test Method for Pin-Type Bearing Test of Metallic Materials6 I+ K4 d" x  O) o" @
E0251-92R03 Test Methods for Performance Characteristics of Metallic Bonded Resistance Strain Gages
, N" }) m7 Z( z2 Q8 b8 d% gE0290-97AR04 Test Methods for Bend Testing of Material for Ductility1 g) j5 x% E4 W' d
E0292-01 Test Methods for Conducting Time-for-Rupture Notch Tension Tests of Materials! d3 g& t* {7 @) a
E0328-02 Test Methods for Stress Relaxation for Materials and Structures
; |% s- c' v" |- u8 {$ Q- uE0338-03 Test Method of Sharp-Notch Tension Testing of High-Strength Sheet Materials, Q; J5 \# t/ c
E0340-00E01 Test Method for Macroetching Metals and Alloys4 C- @# @3 K# _% z& g. \; Z' O
E0345-93R02 Test Methods of Tension Testing of Metallic Foil' r' h; Q$ v/ s) k% }2 r5 T, Y
E0381-01 Method of Macroetch Testing Steel Bars, Billets, Blooms, and Forgings2 @+ R- |7 D9 d7 d+ O0 z
E0384-99E01 Test Method for Microindentation Hardness of Materials5 C9 z8 v+ g- ^" w0 y
E0399-90R97 Test Method for Plane-Strain Fracture Toughness of Metallic Materials# W; Q. q1 P4 H: R  a; o
E0407-99 Practice for Microetching Metals and Alloys
" A/ a1 K2 R+ V- R" |* s( l; ~( p. dE0436-03 Test Method for Drop-Weight Tear Tests of Ferritic Steels: [: Z( Q7 A) H1 a
E0448-82R02E01 Practice for Scleroscope Hardness Testing of Metallic Materials
3 F& J! U" q) k: c) UE0466-96R02E01 Practice for Conducting Force Controlled Constant Amplitude Axial Fatigue Tests of Metallic Materials
) B/ H; E% R1 V3 [5 a. c% T# kE0467-98AR04 Practice for Verification of Constant Amplitude Dynamic Forces in an Axial Fatigue Testing System
# U6 O# y/ ~2 K6 k; ]9 W5 k4 NE0468-90R04E01 Practice for Presentation of Constant Amplitude Fatigue Test Results for Metallic Materials
3 ?' b% U0 J5 b0 h7 Y8 i9 q! {4 WE0517-00 Test Method for Plastic Strain Ratio r for Sheet Metal- ^/ F1 [; n, E1 P3 c, Z
E0561-98 Practice for R-Curve Determination
6 K. [- y. L7 f& F' y: Q: p/ b" SE0562-02 Test Method for Determining Volume Fraction by Systematic Manual Point Count
: r. R) P; C; \; N4 S1 d0 M  P( @8 {E0602-03 Test Method for Sharp-Notch Tension Testing with Cylindrical Specimens1 E" M$ K6 x5 k, w7 e" ~
E0604-83R02 Test Method for Dynamic Tear Testing of Metallic Materials/ \2 T/ M; e- P# q+ o, E
E0606-04 Practice for Strain-Controlled Fatigue Testing
4 e( c% `* s1 t% }& [E0633-00R05 Guide for Use of Thermocouples in Creep and Stress-Rupture Testing to 1800|SDF (1000|SDC) in Air
1 ?* N1 W% y9 e" ?E0643-84R00 Test Method for Ball Punch Deformation of Metallic Sheet Material
& B0 U$ Y7 ~$ Z6 }E0646-00 Test Method for Tensile Strain-Hardening Exponents (n -Values) of Metallic Sheet Materials, m# h; c1 M  C# Z
E0647-00 Test Method for Measurement of Fatigue Crack Growth Rates% I, v3 B7 N* T9 }6 J1 ]  m
E0739-91R04 Practice for Statistical Analysis of Linear or Linearized Stress-Life () and Strain-Life (|ge-) Fatigue Data) @+ v9 W9 d: U- \; i
E0740-03 Practice for Fracture Testing with Surface-Crack Tension Specimens- l$ Y5 N' @* j8 F
E0766-98R03 Practice for Calibrating the Magnification of a Scanning Electron Microscope. s* K( \$ ?- t( t0 X. ]
E0768-99R05 Guide for Preparing and Evaluating Specimens for Automatic Inclusion Assessment of Steel7 J! i+ q3 n8 h6 J# \
E0796-94R00 Test Method for Ductility Testing of Metallic Foil
$ l7 B8 h% ]5 ?" q5 ]5 c6 Y7 `E0812 Test Method for Crack Strength of Slow-Bend Precracked Charpy Specimens of High-Strength Metallic Materials. c+ d" }% J) A! g5 H' p
E0837-01E01 Test Method for Determining Residual Stresses by the Hole-Drilling Strain-Gage Method* d, K4 Z7 @5 H% g# C
E0855-90R00 Test Methods for Bend Testing of Metallic Flat Materials for Spring Applications Involving Static Loading
9 z1 O0 b7 _' r$ t' cE0883-02 Guide for Reflected\NLight Photomicrography+ N7 c: D5 [' m/ t9 ^8 [& ?
E0915-96R02 Test Method for Verifying the Alignment of X-Ray Diffraction Instrumentation for Residual Stress Measurement
$ E: Z' ]0 a+ i, T  C. @6 e- vE0930-99 Test Methods for Estimating the Largest Grain Observed in a Metallographic Section (ALA Grain Size)
/ N6 P1 I( ~5 ^! z& ^  e* cE0963-95R04 Practice for Electrolytic Extraction of Phases from Ni and Ni-Fe Base Superalloys Using a Hydrochloric-Methanol Electrolyte( H3 {/ r- r9 W, R+ U' K
E0975-03 Practice for X-Ray Determination of Retained Austenite in Steel with Near Random Crystallographic Orientation
! v. p- z: l3 t# v! {+ UE0986-04 Practice for Scanning Electron Microscope Beam Size Characterization* G& U5 j$ M$ j0 q% N! i- n
E1012-99 Practice for Verification of Specimen Alignment Under Tensile Loading; |9 o& n7 t4 ]% u$ u  C3 a
E1049-85R97 Practices for Cycle Counting in Fatigue Analysis
" i  ?4 \8 g$ K& YE1077-01R05 Test Methods for Estimating the Depth of Decarburization of Steel Specimens$ Y' |1 p; V- X% @- }
E1122-96R02 Practice for Obtaining JK Inclusion Ratings Using Automatic Image Analysis
* @% e7 w: @' b) S- W( LE1180-03E01 Practice for Preparing Sulfur Prints for Macrostructural Examination9 Q* W9 i! b# b3 E$ c4 t9 ]
E1181-02 Test Methods for Characterizing Duplex Grain Sizes
5 V# Z7 `3 L/ f% E$ j% FE1182 Test Method for Measurement of Surface Layer Thickness by Radial Sectioning2 P8 S4 I. E6 j
E1221-96R02 Test Method for Determining Plane-Strain Crack-Arrest Fracture Toughness, , of Ferritic Steels% v- j$ G- X4 @- u% l7 I4 ?& ?
E1236-91R97 Practice for Qualifying Charpy Impact Machines as Reference Machines
1 E5 n7 U7 z. R2 G# BE1237-93R03 Guide for Installing Bonded Resistance Strain Gages
2 w" u. {1 ^9 j" O/ wE1245-03 Practice for Determining the Inclusion or Second-Phase Constituent Content of Metals by Automatic Image Analysis5 l* z' [2 m5 E
E1268-01 Practice for Assessing the Degree of Banding or Orientation of Microstructures
+ `: r1 @) _+ s0 Y% N1 A7 @5 EE1271 Practice for Qualifying Charpy Verification Specimens of Heat-Treated Steel
! ]) F& i3 G7 B0 M; h7 U! _! q/ IE1290-02E01 Test Method for Crack-Tip Opening Displacement (CTOD) Fracture Toughness Measurement3 b8 l) _: ]& F, a# M3 r
E1304-97R02 Test Method for Plane-Strain (Chevron-Notch) Fracture Toughness of Metallic Materials
# W3 z" G1 H( N( CE1319-98R03 Guide for High-Temperature Static Strain Measurement6 k: U, h9 I+ k. l0 j* r
E1351-01 Practice for Production and Evaluation of Field Metallographic Replicas) H: n7 _1 z, z3 d% J. s4 c9 W: \
E1382-97R04 Test Methods for Determining Average Grain Size Using Semiautomatic and Automatic Image Analysis
5 Q1 C: t+ a) PE1426-98R03 Test Method for Determining the Effective Elastic Parameter for X-Ray Diffraction Measurements of Residual Stress  e* Y. r- S$ ^
E1450-03 Test Method for Tension Testing of Structural Alloys in Liquid Helium
4 \0 ^. S; T$ o: _) JE1457-00 Test Method for Measurement of Creep Crack Growth Rates in Metals
; b% \  H" i  H9 a- l  w& iE1508-98R03 Guide for Quantitative Analysis by Energy-Dispersive Spectroscopy, y( Q6 X& t) K' Q% e
E1544-99R04E01 Practice for Construction of a Stepped Block and Its Use to Estimate Errors Produced by Speed-of-Sound Measurement Systems for Use on Solids
1 d% y" t4 n8 F4 J6 M  y4 LE1558-99R04 Guide for Electrolytic Polishing of Metallographic Specimens
  ]4 N* G4 ~% j1 Y' \E1561-93R03 Practice for Analysis of Strain Gage Rosette Data2 ^3 d% F- v( i& v
E1595 Practice for Evaluating the Performance of Mechanical Testing Laboratories
1 ?3 S3 L( @1 a3 \E1681-03 Test Method for Determining Threshold Stress Intensity Factor for Environment-Assisted Cracking of Metallic Materials2 J5 }; z& ^8 d6 e6 W) K' {. w; g
E1685-00 Practice for Measuring the Change in Length of Fasteners Using the Ultrasonic Pulse-Echo Technique( Z- N+ G, Q# t5 g# C2 _
E1761-95R99 Guide for Recommended Formats for Data Records Used in Computerization of Fatigue and Fracture Data of Metals/ P. m2 ?& C, ]4 K/ I0 s5 D& U
E1820-01 Test Method for Measurement of Fracture Toughness" b( H4 h  G- k
E1823-96R02 Terminology Relating to Fatigue and Fracture Testing
  L# b7 _: h$ N8 b4 N2 `7 [E1842 Test Method for Macro-Rockwell Hardness Testing of Metallic Materials
$ Y0 S$ k6 ^: g3 F# dE1856-97R02 Guide for Evaluating Computerized Data Acquisition Systems Used to Acquire Data from Universal Testing Machines5 }* Q; _! t+ p4 U
E1875-00E01 Test Method for Dynamic Young's Modulus, Shear Modulus, and Poisson's Ratio by Sonic Resonance" |$ m: e0 I* n8 i6 P
E1876-01 Test Method for Dynamic Young's Modulus, Shear Modulus, and Poisson's Ratio by Impulse Excitation of Vibration
4 Q' i1 M0 f2 m' TE1920-03 Guide for Metallographic Preparation of Thermal Sprayed Coatings; `2 s! w" h, q" O( j6 c
E1921-05 Test Method for Determination of Reference Temperature, , for Ferritic Steels in the Transition Range
& V0 d' R9 S! D: k; c  Z" K3 W2 ME1922-04 Test Method for Translaminar Fracture Toughness of Laminated and Pultruded Polymer Matrix Composite Materials
! `0 C& [* o) }& Z5 n4 mE1928-99 Practice for Estimating the Approximate Residual Circumferential Stress in Straight Thin-walled Tubing5 l& O- b1 r' E
E1942-98R04 Guide for Evaluating Data Acquisition Systems Used in Cyclic Fatigue and Fracture Mechanics Testing
: H7 C9 O0 Y$ Q& q0 SE1949-03 Test Method for Ambient Temperature Fatigue Life of Metallic Bonded Resistance Strain Gages0 v0 x  C1 ?+ j, D$ \9 I9 @2 I
E1951-02 Guide for Calibrating Reticles and Light Microscope Magnifications* C8 I1 w8 Y* p; k3 Y3 X
E2014-99 Guide on Metallographic Laboratory Safety
* ^2 u9 G- V: VE2015-04 Guide for Preparation of Plastics and Polymeric Specimens for Microstructural Examination" m6 Q2 D% e, ?, {, x
E2109-01 Test Methods for Determining Area Percentage Porosity in Thermal Sprayed Coatings
6 b+ W& E) l+ o- {  RE2142-01 Test Methods for Rating and Classifying Inclusions in Steel Using the Scanning Electron Microscope
- Z' i" f$ @; k, hE2207-02 Practice for Strain-Controlled Axial-Torsional Fatigue Testing with Thin-Walled Tubular Specimens* k" a! y  `6 |9 t8 L# A
E2208-02 Guide for Evaluating Non-Contacting Optical Strain Measurement Systems5 h; M1 S3 Y3 a" _6 }( P7 U7 _
E2218-02 Test Method for Determining Forming Limit Curves
) i% U0 d/ z/ u* }( N) hE2244-02 Test Method for In-Plane Length Measurements of Thin, Reflecting Films Using an Optical Interferometer
  I; P* k6 Z& \' P; m$ |E2245-02 Test Method for Residual Strain Measurements of Thin, Reflecting Films Using an Optical Interferometer, t: k" T& Y  B9 t1 D, k7 y2 c
E2246-02 Test Method for Strain Gradient Measurements of Thin, Reflecting Films Using an Optical InterferometerE2283-03 Practice for Extreme Value Analysis of Nonmetallic Inclusions in Steel and Other Microstructural Features
* C* r* p# ]4 v5 ~E2309-05 Practices for Verification of Displacement Measuring Systems and Devices Used in Material Testing Machines
0 ]- W) ]: I; s) [, vE2368-04E01 Practice for Strain Controlled Thermomechanical Fatigue Testing
& A  D4 J* U5 @. [+ ]% @
E 3 – 01 ;RTM_.pdf
99.81 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
E 3 – 95 ;RTMTOTU_.pdf
52.6 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 3 – 95 ;RTMTUKVE.pdf
109.38 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 4 – 01 ;RTQTMDE_.pdf
54.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 4 – 02 ;RTQTMDI_.pdf
80.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 4 – 02 ;RTQTUKVE.pdf
56.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 4 – 03 ;RTQ_.pdf
83.22 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 4 – 99 ;RTQTOTK_.pdf
49.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 6 – 02 ;RTYTMDI_.pdf
92.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 6 – 02 ;RTYTMDJB.pdf
138.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 6 – 02 ;RTYTUKVE.pdf
84.31 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 6 – 03 ;RTY_.pdf
109.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 6 – 99 ;RTYTOTLFMQ__.pdf
77.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 7 – 00 ;RTCTMDA_.pdf
173.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 7 – 01 ;RTCTMDE_.pdf
269.3 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 7 – 01 ;RTCTUKVE.pdf
177.38 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 7 – 03 ;RTC_.pdf
257.22 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
E 8 – 00 ;RTGTMDBC.pdf
214.77 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 8 – 01 ;RTGTMDE_.pdf
231.25 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 8 – 01 ;RTGTMDFFMG__.pdf
303.36 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 8 – 03 ;RTGTMDM_.pdf
293.06 KB, Lượt tải về: 15, Tải điểm: Thưởng -2 điểm
E 8 – 03 ;RTGTUKVE.pdf
246.82 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 8 – 04 ;RTG_.pdf
303.09 KB, Lượt tải về: 27, Tải điểm: Thưởng -2 điểm
E 8M – 00 ;RTHNLTAWQG__.pdf
213.26 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 8M – 00 ;RTHNLTAWQQ__.pdf
213.19 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 8M – 01 ;RTHNLTAX.pdf
228.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 8M – 03 ;RTHNLTAZ.pdf
287.58 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 8M – 03 ;RTHNLVJFRA__.pdf
244.93 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 8M – 04 ;RTHN.pdf
295.44 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 9 – 89a R00 ;RTK_.pdf
128.76 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
E 10 – 00 ;RTEWLTAW.pdf
56.75 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 10 – 00 ;RTEWLTAWQQ__.pdf
57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 10 – 01 ;RTEW.pdf
97.88 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 18 – 00 ;RTE4LTAW.pdf
153.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 18 – 02 ;RTE4LTAY.pdf
211.45 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 18 – 03 ;RTE4.pdf
279.82 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
E 21 – 03 ;RTIX.pdf
71.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 21 – 03 ;RTIXLTAZ.pdf
75.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 21 – 03 ;RTIXLVJFRA__.pdf
E 21 – 92 R98 ;RTIXLTKYUJK4.pdf
51.53 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 21 – 92 R98 ;RTIXLTKYUJK4RTE_.pdf
84.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 23 – 00 ;RTIZLTAW.pdf
292.55 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 23 – 01 ;RTIZLTAX.pdf
373.39 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 23 – 01 ;RTIZLTAXQQ__.pdf
384.58 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
E 23 – 02 ;RTIZ.pdf
429.24 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
E 23 – 02 ;RTIZLVJFRA__.pdf
388.89 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 45 – 97 R02 ;RTQ1.pdf
211.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 74 – 00 ;RTC0LTAWQQ__.pdf
78.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 74 – 01 ;RTC0LTAX.pdf
81.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 74 – 01 ;RTC0LVJFRA__.pdf
82.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 74 – 02 ;RTC0.pdf
114.71 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 81 – 96 ;RTGXLTK2.pdf
70.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 81 – 96 R01 ;RTGX.pdf
108.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 82 – 91 R01 ;RTGY.pdf
453.17 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 82 – 91 R96 ;RTGYLTKXUJK2.pdf
253.37 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
E 83 – 00 ;RTGZLTAW.pdf
169.45 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 83 – 00 ;RTGZLVJFRA__.pdf
180.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 83 – 02 ;RTGZ.pdf
193.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 92 – 82 R03 ;RTKY.pdf
84.12 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 92 – 82 R97 ;RTKYLTGYUJK3RTM_.pdf
87.64 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
E 103 – 84 R02 ;RTEWMW__.pdf
36.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 110 – 82 R02 ;RTEXMA__.pdf
27.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 110 – 82 R97 ;RTEXMC04MLI5N0UY.pdf
35.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 111 – 97 ;RTEXMQ__.pdf
82.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 112 – 96 ;RTEXMG__.pdf
340.88 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 112 – 96 ;RTEXMI05NKUY.pdf
340.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 132 – 04 ;RTEZMG__.pdf
39.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 132 – 97 ;RTEZMI1SRUQ_.pdf
34.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 132 – 97 ;RTEZMI05NW__.pdf
39.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 139 – 00 ;RTEZOQ__.pdf
117.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 139 – 00 ;RTEZOS0WMA__.pdf
113.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 140 – 02 ;RTE0MA__.pdf
124.26 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 140 – 97 ;RTE0MC1SRUQ_.pdf
88.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 140 – 97 ;RTE0MC05N0UY.pdf
79.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 140 – 97 ;RTE0MC05N0UZ.pdf
78.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 143 – 01 ;RTE0MY0WMQ__.pdf
55.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 143 – 01 ;RTE0MY1SRUQ_.pdf
40.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 143 – 02 ;RTE0MW__.pdf
52.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 143 – 87 R98 ;RTE0MY04N1I5OA__.pdf
36.53 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 190 – 92 R03 ;RTE5MA__.pdf
53.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 190 – 92 R97 ;RTE5MC05MLI5NW__.pdf
55.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 208 – 95 ;RTIWOC05NUE_.pdf
254.1 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 208 – 95a R00 ;RTIWOA__.pdf
286.8 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 209 – 00 ;RTIWOQ__.pdf
68.53 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 209 – 65 R93 ;RTIWOS1SRUQ_.pdf
58.9 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 238 – 84 R02 ;RTIZOA__.pdf
79.84 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 251 – 92 R03 ;RTI1MQ__.pdf
294.77 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 251 – 92 R98 ;RTI1MS05MLI5OA__.pdf
303.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 290 – 97 ;RTI5MA__.pdf
80.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 292 – 01 ;RTI5MG__.pdf
100.33 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 292 – 83 R96 ;RTI5MI1SRUQ_.pdf
85.77 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 292 – 83 R96 ;RTI5MI04M1I5NKUX.pdf
74.53 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 328 – 02 ;RTMYOA__.pdf
170.86 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 328 – 86 R96 ;RTMYOC1SRUQ_.pdf
161.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 328 – 86 R96 ;RTMYOC04NLI5NKUX.pdf
165.96 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 338 – 03 ;RTMZOA__.pdf
84.69 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 338 – 91 R97 ;RTMZOC1SRUQ_.pdf
76.09 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 338 – 91 R97 ;RTMZOC05MVI5NW__.pdf
85.96 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 340 – 00 ;RTM0MA__.pdf
95.33 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 345 – 93 R02 ;RTM0NQ__.pdf
60.51 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 345 – 93 R98 ;RTM0NS05M1I5OA__.pdf
62.99 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 381 – 01 ;RTM4MQ__.pdf
32.22 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 381 – 98 ;RTM4MS1SRUQ_.pdf
32.93 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 381 – 98 ;RTM4MS05OA__.pdf
31.24 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 384 – 99 ;RTM4NA__.pdf
239.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 384 – 99 ;RTM4NC05OQ__.pdf
158.99 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 399 – 90 R97 ;RTM5OQ__.pdf
443.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 407 – 99 ;RTQWNW__.pdf
77.68 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 436 – 03 ;RTQZNG__.pdf
85.41 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 436 – 91 R97 ;RTQZNI1SRUQ_.pdf
79.46 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 436 – 91 R97 ;RTQZNI05MVI5NW__.pdf
153.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 448 – 82 R02 ;RTQ0OA__.pdf
53.64 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 448 – 82 R97 ;RTQ0OC04MLI5N0UX.pdf
35.74 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 448 – 82 R97 ;RTQ0OC04MLI5N0UY.pdf
55.83 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 466 – 96 R02 ;RTQ2NG__.pdf
59.82 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 467 – 98 ;RTQ2NY05OEE_.pdf
144.32 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 467 – 98a R04 ;RTQ2NW__.pdf
144.1 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 468 – 90 R04 ;RTQ2OA__.pdf
84.29 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 468 – 90 R98 ;RTQ2OC05MFI5OA__.pdf
85.54 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 517 – 00 ;RTUXNW__.pdf
88.62 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 517 – 98 ;RTUXNY1SRUQ_.pdf
64.23 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 561 – 98 ;RTU2MQ__.pdf
210.06 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 562 – 01 ;RTU2MI0WMQ__.pdf
47.52 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 562 – 01 ;RTU2MI1SRUQ_.pdf
48.66 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 562 – 02 ;RTU2MG__.pdf
70.43 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 602 – 03 ;RTYWMG__.pdf
78.73 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 602 – 91 R97 ;RTYWMI1SRUQ_.pdf
64.21 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 602 – 91 R97 ;RTYWMI05MVI5NW__.pdf
80.17 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 604 – 83 R02 ;RTYWNA__.pdf
97.42 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 606 – 92 R98 ;RTYWNG__.pdf
214.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 633 – 00 ;RTYZMW__.pdf
83.93 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 633 – 95 ;RTYZMY1SRUQ_.pdf
77.58 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 643 – 84 R00 ;RTY0MW__.pdf
51.92 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 643 – 84 R95 ;RTY0MY04NFI5NQ__.pdf
40.96 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 646 – 00 ;RTY0NG__.pdf
91.41 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 646 – 98 ;RTY0NI1SRUQ_.pdf
69.93 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 647 – 00 ;RTY0NW__.pdf
867.18 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 647 – 99 ;RTY0NY05OQ__.pdf
423.12 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 739 – 91 R04 ;RTCZOQ__.pdf
106.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 739 – 91 R98 ;RTCZOS05MVI5OA__.pdf
106.43 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 740 – 03 ;RTC0MA__.pdf
95.09 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 740 – 88 R95 ;RTC0MC1SRUQ_.pdf
76.8 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 740 – 88 R95 ;RTC0MC04OFI5NUUX.pdf
104.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 766 – 98 ;RTC2NI05OA__.pdf
94.79 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 766 – 98 R03 ;RTC2NG__.pdf
94.03 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 768 – 99 ;RTC2OA__.pdf
28.94 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 796 – 94 ;RTC5NI05NA__.pdf
45.26 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 796 – 94 R00 ;RTC5NG__.pdf
71.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 812 – 91 R97 ;RTGXMG__.pdf
48.43 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 837 – 01 ;RTGZNW__.pdf
153.54 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 837 – 01 ;RTGZNY0WMQ__.pdf
121.3 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 837 – 99 ;RTGZNY05OQ__.pdf
118.6 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 855 – 90 R00 ;RTG1NQ__.pdf
86.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 855 – 90 R95 ;RTG1NS05MFI5NQ__.pdf
66.35 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 883 – 02 ;RTG4MW__.pdf
203.34 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 883 – 99 ;RTG4MY1SRUQ_.pdf
197.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 883 – 99 ;RTG4MY05OQ__.pdf
169.54 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 915 – 96 R02 ;RTKXNQ__.pdf
42.05 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 930 – 99 ;RTKZMA__.pdf
447.37 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 963 – 95 ;RTK2MY05NQ__.pdf
30.17 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 963 – 95 R00 ;RTK2MW__.pdf
42.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 975 – 00 ;RTK3NS0WMA__.pdf
118.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 975 – 00 ;RTK3NS1SRUQ_.pdf
95.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 975 – 03 ;RTK3NQ__.pdf
153.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 986 – 97 ;RTK4NG__.pdf
52.51 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1012 – 99 ;RTEWMTI_.pdf
94.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1049 – 85 R97 ;RTEWNDK_.pdf
138.62 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1077 – 01 ;RTEWNZC_.pdf
269.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1077 – 01 ;RTEWNZCTMDE_.pdf
242.92 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1077 – 91 R97 ;RTEWNZCTOTFSOTC_.pdf
242.27 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1122 – 96 R02 ;RTEXMJI_.pdf
142.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1180 – 03 ;RTEXODA_.pdf
47.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1180 – 03 ;RTEXODATMDM_.pdf
41.62 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1180 – 94 R98 ;RTEXODATOTRSOTG_.pdf
34.89 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1181 – 02 ;RTEXODE_.pdf
450.77 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1181 – 87 R98 ;RTEXODETODDSOTHFMQ__.pdf
428.58 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1181 – 87 R98 ;RTEXODETUKVE.pdf
436.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1182 – 93 R98 ;RTEXODITOTNSOTG_.pdf
67.6 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1221 – 96 ;RTEYMJETOTY_.pdf
271.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1221 – 96 R02 ;RTEYMJE_.pdf
323.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1236 – 91 R97 ;RTEYMZY_.pdf
63.79 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1237 – 93 R03 ;RTEYMZC_.pdf
43.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1237 – 93 R98 ;RTEYMZCTOTNSOTG_.pdf
45.4 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1245 – 00 ;RTEYNDUTMDA_.pdf
82.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1245 – 00 ;RTEYNDUTUKVE.pdf
55.9 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1245 – 03 ;RTEYNDU_.pdf
82.35 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1245 – 95 ;RTEYNDUTOTU_.pdf
53.31 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1268 – 01 ;RTEYNJG_.pdf
567.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1268 – 99 ;RTEYNJGTOTK_.pdf
560.87 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1268 – 99 ;RTEYNJGTUKVE.pdf
569.81 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1290 – 02 ;RTEYOTA_.pdf
222.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1290 – 99 ;RTEYOTATOTK_.pdf
213.5 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1290 – 99 ;RTEYOTATUKVE.pdf
184.75 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1304 – 97 ;RTEZMDQTOTC_.pdf
162.34 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1304 – 97 R02 ;RTEZMDQ_.pdf
207.27 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1319 – 98 ;RTEZMTKTOTG_.pdf
137.53 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1319 – 98 R03 ;RTEZMTK_.pdf
133.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1351 – 01 ;RTEZNTE_.pdf
606.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1351 – 96 ;RTEZNTETOTY_.pdf
158.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1351 – 96 ;RTEZNTETUKVE.pdf
161.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1382 – 97 ;RTEZODI_.pdf
398.6 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1426 – 98 ;RTE0MJYTOTG_.pdf
56.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1426 – 98 R03 ;RTE0MJY_.pdf
54.15 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1450 – 03 ;RTE0NTA_.pdf
105.57 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1450 – 92 R98 ;RTE0NTATOTJSOTHFMQ__.pdf
117.06 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1450 – 92 R98 ;RTE0NTATUKVE.pdf
91.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1457 – 00 ;RTE0NTC_.pdf
225.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1457 – 98 ;RTE0NTCTUKVE.pdf
213.27 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1508 – 98 ;RTE1MDGTOTG_.pdf
84.18 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1508 – 98 R03 ;RTE1MDG_.pdf
82.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1544 – 99 ;RTE1NDQTOTK_.pdf
78.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1544 – 99 R04 ;RTE1NDQ_.pdf
77.81 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1558 – 99 ;RTE1NTG_.pdf
132.01 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1561 – 93 R03 ;RTE1NJE_.pdf
81.49 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1561 – 93 R98 ;RTE1NJETOTNSOTG_.pdf
83.32 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1681 – 03 ;RTE2ODE_.pdf
175.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1681 – 99 ;RTE2ODETOTLFMQ__.pdf
166.65 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1681 – 99 ;RTE2ODETUKVE.pdf
197.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1685 – 00 ;RTE2ODU_.pdf
38.92 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1685 – 95 ;RTE2ODUTUKVE.pdf
28.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1761 – 95 R99 ;RTE3NJE_.pdf
109.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1820 – 01 ;RTE4MJA_.pdf
700.25 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1820 – 99 ;RTE4MJATOTLB.pdf
454.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1820 – 99 ;RTE4MJATUKVE.pdf
597.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1823 – 96 ;RTE4MJMTOTZFMQ__.pdf
294.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1823 – 96 R02 ;RTE4MJM_.pdf
290.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1856 – 97 ;RTE4NTYTOTDFMQ__.pdf
74.51 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1856 – 97 R02 ;RTE4NTY_.pdf
63.93 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1875 – 00 ;RTE4NZU_.pdf
129.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1875 – 00 ;RTE4NZUTMDA_.pdf
80.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1876 – 00 ;RTE4NZYTMDA_.pdf
171.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1876 – 01 ;RTE4NZY_.pdf
227.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1876 – 99 ;RTE4NZYTOTK_.pdf
172.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1920 – 03 ;RTE5MJA_.pdf
45.04 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1920 – 97 ;RTE5MJATOTC_.pdf
45.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1920 – 97 ;RTE5MJATUKVE.pdf
32.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1921 – 02 ;RTE5MJETMDI_.pdf
283.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1921 – 02 ;RTE5MJETUKVE.pdf
201.04 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1921 – 03 ;RTE5MJE_.pdf
261.59 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1921 – 97 ;RTE5MJETOTC_.pdf
190.89 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1922 – 97 ;RTE5MJI_.pdf
61.21 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1928 – 99 ;RTE5MJG_.pdf
42.24 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1942 – 98 ;RTE5NDITOTHFMQ__.pdf
240.17 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1942 – 98 R04 ;RTE5NDI_.pdf
231.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1949 – 02 ;RTE5NDKTMDI_.pdf
86.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1949 – 02 ;RTE5NDKTUKVE.pdf
75.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1949 – 03 ;RTE5NDK_.pdf
85.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1951 – 01 ;RTE5NTETMDE_.pdf
116.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1951 – 01 ;RTE5NTETUKVE.pdf
115.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1951 – 02 ;RTE5NTE_.pdf
138.23 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 1951 – 98 ;RTE5NTETOTG_.pdf
108.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2014 – 99 ;RTIWMTQ_.pdf
65.79 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2015 – 99 ;RTIWMTU_.pdf
61.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2109 – 00 ;RTIXMDKTMDA_.pdf
120.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2109 – 00 ;RTIXMDKTUKVE.pdf
133.01 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2109 – 01 ;RTIXMDK_.pdf
146.54 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2142 – 01 ;RTIXNDI_.pdf
435.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2207 – 02 ;RTIYMDC_.pdf
123.74 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2208 – 02 ;RTIYMDG_.pdf
127.5 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2218 – 02 ;RTIYMTG_.pdf
167.18 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2244 – 02 ;RTIYNDQ_.pdf
435.19 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2245 – 02 ;RTIYNDU_.pdf
665.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2246 – 02 ;RTIYNDY_.pdf
608.43 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2283 – 03 ;RTIYODM_.pdf
180.83 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
E 2368 – 04 ;RTIZNJG_.pdf
103.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
GMT+7, 16/5/2026 04:29 , Processed in 0.099594 second(s), 20 queries .
