Xem: 4269|Trả lời: 0
ASTM 2004- Volume 03.06 Molecular Spectroscopy; Surface Analysis
ASTM 2004- Volume 03.06 Molecular Spectroscopy; Surface Analysis% Y0 A, o7 J) K0 k: z2 V
' q% z! s7 ~) C0 G4 T% RE0131-02 Terminology Relating to Molecular Spectroscopy6 d6 ]" a+ ~; L# v
E0168-99R04 Practices for General Techniques of Infrared Quantitative Analysis
4 D; L, R1 h/ E# a- Y2 I' cE0169-04 Practices for General Techniques of Ultraviolet-Visible Quantitative Analysis1 A1 S8 c  S% `0 g# \2 p9 l6 m
E0204-98R02 Practices for Identification of Material by Infrared Absorption Spectroscopy, Using the ASTM Coded Band and Chemical Classification Index5 M* r. N3 d( v7 [: i$ P8 X
E0250-98R02 Practice for Use of CODEN
( Z! Y0 Q; L  dE0260-96R01 Practice for Packed Column Gas Chromatography
6 o" h) r* E, y" GE0275-01 Practice for Describing and Measuring Performance of Ultraviolet, Visible, and Near-Infrared Spectrophotometers
. f9 H9 Y1 `7 f. \7 w3 zE0334-01 Practice for General Techniques of Infrared Microanalysis
% g4 x5 W" c, I% _: C. O% VE0355-96R01 Practice for Gas Chromatography Terms and Relationships
/ X' h5 n6 s1 k3 T- y6 M( LE0386-90R04 Practice for Data Presentation Relating to High-Resolution Nuclear Magnetic Resonance (NMR) Spectroscopy# G+ @% z  ^! r9 y2 |
E0387-04 Test Method for Estimating Stray Radiant Power Ratio of Dispersive Spectrophotometers by the Opaque Filter Method+ \5 E3 X2 \! F6 N7 `7 D* l
E0388-04 Test Method for Wavelength Accuracy of Spectral Bandwidth of Fluorescence Spectrometers7 ?% B6 Y/ p) d/ f& j+ O
E0516-95AR00 Practice for Testing Thermal Conductivity Detectors Used in Gas Chromatography: g0 w) e( b0 E
E0573-01 Practices for Internal Reflection Spectroscopy
5 t  i" W! L& K4 aE0578-01 Test Method for Linearity of Fluorescence Measuring Systems- ~/ e: f: M' p# C
E0579-04 Test Method for Limit of Detection of Fluorescence of Quinine Sulfate in Solution* t/ `1 A& ~+ D8 U5 y, E5 i
E0594-96R01 Practice for Testing Flame Ionization Detectors Used in Gas or Supercritical Fluid Chromatography
0 [7 `0 z5 b" n% q9 a# j; w8 n5 ?E0682-92R00 Practice for Liquid Chromatography Terms and Relationships
. w/ J, o" ]  z1 x& p# |1 E5 R! sE0685-93R00 Practice for Testing Fixed-Wavelength Photometric Detectors Used in Liquid Chromatography& F2 ?6 P6 E2 F' _  t
E0697-96R01 Practice for Use of Electron-Capture Detectors in Gas Chromatography
% N1 p; K. j4 v+ t+ yE0840-95R00 Practice for Using Flame Photometric Detectors in Gas Chromatography& e! v6 `& x5 Y4 W: s# e
E0924 Guide for Quality Assurance of Laboratories Using Molecular Spectroscopy
7 t$ M4 @9 G9 ^4 qE0925-02 Practice for Monitoring the Calibration of Ultraviolet-Visible Spectrophotometers whose Spectral Slit Width does not Exceed 2 nm; p/ M7 U2 Y6 m& n$ w# K
E0932-89R02 Practice for Describing and Measuring Performance of Dispersive Infrared Spectrometers
2 C( ~0 q7 U, vE0958-93R05 Practice for Measuring Practical Spectral Bandwidth of Ultraviolet-Visible Spectrophotometers* F0 S* Y9 Z6 ?% h/ x/ B
E1140-95R05 Practice for Testing Nitrogen/Phosphorus Thermionic Ionization Detectors for Use In Gas Chromatography
* I3 U' B' |  yE1151-93R00 Practice for Ion Chromatography Terms and Relationships
: e3 G4 ]( a0 }0 l) C. b- _* bE1252-98R02 Practice for General Techniques for Obtaining Infrared Spectra for Qualitative Analysis/ ]' O; C2 ]2 B# j
E1303-95R05 Practice for Refractive Index Detectors Used in Liquid Chromatography; O, e; g) A  g# S9 Y
E1421-99R04 Practice for Describing and Measuring Performance of Fourier Transform Mid-Infrared (FT-MIR) Spectrometers: Level Zero and Level One Tests
' ]4 ^/ F4 m& W; N: bE1449-92R00 Guide for Supercritical Fluid Chromatography Terms and Relationships
$ B% a$ h; v7 |9 SE1510-95R05 Practice for Installing Fused Silica Open Tubular Capillary Columns in Gas Chromatographs% L$ }% D- K# u- q
E1511-93R05 Practice for Testing Conductivity Detectors Used in Liquid and Ion Chromatography9 z) U) h5 X) r- S0 K% {
E1578-93R99 Guide for Laboratory Information Management Systems (LIMS)4 _( r+ ?6 H; p, `4 s: h  Z
E1614-94R04 Guide for Procedure for Measuring Ionizing Radiation-Induced Attenuation in Silica-Based Optical Fibers and Cables for Use in Remote Fiber-Optic Spectroscopy andBroadband Systems
0 V) p! \: v2 O" \5 z, cE1642-00 Practice for General Techniques of Gas Chromatography Infrared (GC/IR) Analysis) n% W5 [1 Z: k, y8 H1 v
E1653-94R04 Guide for Specifying Dynamic Characteristics of Optical Radiation Transmitting Fiber Waveguides  H# n# R. ]: z& k
E1654-94R04 Guide for Measuring Ionizing Radiation-Induced Spectral Changes in Optical Fibers and Cables for Use in Remote Raman FiberOptic Spectroscopy
0 J  v# j& b4 d$ Z( ^- D/ D! bE1655-05 Practices for Infrared Multivariate Quantitative Analysis* G* Z$ i# B; @$ L0 e
E1657-98R01 Practice for Testing Variable-Wavelength Photometric Detectors Used in Liquid Chromatography8 A2 P, V& X# Y$ `- B# @
E1683-02 Practice for Testing the Performance of Scanning Raman Spectrometers
5 b# n; C3 u8 BE1698-95R00 Practice for Testing Electrolytic Conductivity Detectors (ELCD) Used in Gas Chromatography: O& G" E# l1 p( x* b
E1747-95R00 Guide for Purity of Carbon Dioxide Used in Supercritical Fluid Applications
# b  h* E) g' m: TE1790-04 Practice for Near Infrared Qualitative Analysis$ p6 A2 S3 {% K: ~7 Y) q8 C
E1791-96R00 Practice for Transfer Standards for Reflectance Factor for Near-Infrared Instruments Using Hemispherical Geometry5 O# a! x. c, y' I( T5 ?7 K
E1840-96R02 Guide for Raman Shift Standards for Spectrometer Calibration5 |/ W1 K( `" a- e8 V
E1865-97R02 Guide for Open-Path Fourier Transform Infrared (OP/FT-IR) Monitoring of Gases and Vapors in Air
2 `, s% ~9 E- i& HE1866-97R02 Guide for Establishing Spectrophotometer Performance Tests
5 w9 h) q5 @& c2 E! F' V7 k7 uE1944-98R02 Practice for Describing and Measuring Performance of Laboratory Fourier Transform Near-Infrared (FT-NIR) Spectrometers: Level Zero and Level One Tests
) {% C- V! f" w- E( p5 UE1947-98R04 Specification for Analytical Data Interchange Protocol for Chromatographic Data5 k3 D7 y4 ], ?, m+ V
E1948-98R04 Guide for Analytical Data Interchange Protocol for Chromatographic Data
; u2 [# G1 s7 B6 j; cE1982-98R02 Practice for Open-Path Fourier Transform Infrared (OP/FT-IR) Monitoring of Gases and Vapors in Air5 H1 H$ D/ ~7 s& s0 X0 r$ o8 g
E1989-98R04 Specification for Laboratory Equipment Control Interface (LECIS)
; }1 [& x8 J" d8 XE2056-04 Practice for Qualifying Spectrometers and Spectrophotometers for Use in Multivariate Analyses, Calibrated Using Surrogate Mixtures
( R" U  Z# J( L0 r6 X  ?( wE2066-00 Guide for Validation of Laboratory Information Management Systems; y/ E" y8 q$ G. z$ T+ q$ [- f
E2077-00 Specification for Analytical Data Interchange Protocol for Mass Spectrometric Data
) ]+ n0 b4 j$ o  t$ ^2 g) x' E$ W# z- r# p% yE2078-00 Guide for Analytical Data Interchange Protocol for Mass Spectrometric Data
# z2 l- u% M" @9 A6 YE2105-00 Practice for General Techniques of Thermogravimetric Analysis (TGA) Coupled With Infrared Analysis (TGA/IR): X$ D3 b2 C3 |9 f- S! G
E2106-00 Practice for General Techniques of Liquid Chromatography-Infrared (LC/IR) and Size Exclusion Chromatography-Infrared (SEC/IR) Analyses
' R. ~) U& g( x$ @% w$ z+ BE2143-01 Practice for Using Field-Portable Fiber Optics Synchronous Fluorescence Spectrometer for Quantification of Field Samples for Aromatic and Polycyclic Aromatic Hydrocarbons
; o9 X; X. ^6 j5 Q& sE2310-04 Guide for Use of Spectral Searching by Curve Matching Algorithms with Data Recorded Using Mid-infrared Spectroscopy
# o9 Y3 L4 B9 [3 n7 lE2412-04 Practice for Condition Monitoring of Used Lubricants by Trend Analysis Using Fourier Transform Infrared (FT-IR) Spectrometry" D2 K" e7 n1 g8 U" s
E0673-03 Terminology Relating to Surface Analysis
% J$ g  w& H, A! ]; HE0684-04 Practice for Approximate Determination of Current Density of Large-Diameter Ion Beams for Sputter Depth Profiling of Solid Surfaces' l1 c# [/ a6 S+ _5 X9 K
E0827-02 Practice for Indentifying Elements by the Peaks in Auger Electron Spectroscopy2 Y$ Y$ t: W! Y9 U- M# w% w. m0 o) V
E0902-05 Practice for Checking the Operating Characteristics of X-Ray Photoelectron Spectrometers! b4 j9 t  t. ^5 F1 d# v2 T
E0983-05 Guide for Minimizing Unwanted Electron Beam Effects in Auger Electron Spectroscopy  e+ @- w& w; ~
E0984-95R01 Guide for Identifying Chemical Effects and Matrix Effects in Auger Electron Spectroscopy
2 a* _6 u  r7 g# a+ oE0995-04 Guide for Background Subtraction Techniques in Auger Electron Spectroscopy and X-ray Photoelectron Spectroscopy# z7 M, N/ h  y. [5 V
E0996-04 Practice for Reporting Data in Auger Electron Spectroscopy and X-ray Photoelectron Spectroscopy0 P; z( ?& j, K- x1 Y
E1016-96R02 Guide for Literature Describing Properties of Electrostatic Electron Spectrometers
& L  `) `1 S- N' u1 OE1078-02 Guide for Specimen Preparation and Mounting in Surface Analysis
/ A% A9 D" C/ D% FE1127-03 Guide for Depth Profiling in Auger Electron Spectroscopy
' q9 o0 m) w' ~" @E1162-87R01 Practice for Reporting Sputter Depth Profile Data in Secondary Ion Mass Spectrometry (SIMS)- c* ]: H- O$ h; d9 I
E1217-00 Practice for Determination of the Specimen Area Contributing to the Detected Signal in Auger Electron Spectrometers and Some X-Ray Photoelectron Spectrometers
+ k$ S! o3 ^6 e4 y8 j. K* i" \& VE1438-91R01 Guide for Measuring Widths of Interfaces in Sputter Depth Profiling Using SIMS! M/ `. f& p) G( W' P* O3 W
E1504-92R01 Practice for Reporting Mass Spectral Data in Secondary Ion Mass Spectrometry (SIMS)
0 E- Q$ g, r: vE1505-92R01 Guide for Determining SIMS Relative Sensitivity Factors from Ion Implanted External Standards
" s3 Y& Z' V2 u9 k4 @! ~E1523-03 Guide to Charge Control and Charge Referencing Techniques in X-Ray Photoelectron Spectroscopy* N1 G! `0 d+ y- }* |; a, ~2 f
E1577-04 Guide for Reporting of Ion Beam Parameters Used in Surface Analysis
0 W  x% g( J7 rE1634-02 Guide for Performing Sputter Crater Depth Measurements; [; ?, e* F3 ?* Z3 [% w
E1635-95R00 Practice for Reporting Imaging Data in Secondary Ion Mass Spectrometry (SIMS)
$ ?) l: v& P* ^' J8 I9 @( s  t6 hE1636-04 Practice for Analytically Describing Sputter-Depth-Profile Interface Data by an Extended Logistic Function; y2 ~; Y( b& [9 x) x
E1813-96R02 Practice for Measuring and Reporting Probe Tip Shape in Scanning Probe Microscopy
7 S6 H! ~1 U4 t5 N0 n( @* oE1829-02 Guide for Handling Specimens Prior to Surface Analysis+ u+ S7 x8 Q0 J
E1880-97R02 Practice for Tissue Cryosection Analysis with SIMS
+ n1 B5 S. G0 X& M% E" kE1881-97R02 Guide for Cell Culture Analysis with SIMS3 K% ~5 c' b$ _( t
E2108-00 Practice for Calibration of the Electron Binding-Energy Scale of an X-Ray Photoelectron Spectrometer
1 w) L# Q  y  V, v; S" A9 |E2382-04 Guide to Scanner and Tip Related Artifacts in Scanning Tunneling Microscopy and Atomic Force Microscopy
' \. y8 |% S* x2 R% u
E 131 – 00 ;RTEZMS0WMEE_.pdf
125.97 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 131 – 02 ;RTEZMQ__.pdf
124.81 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
E 168 – 99 ;RTE2OC05OQ__.pdf
187.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 168 – 99 R04 ;RTE2OA__.pdf
188.91 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
E 169 – 99 ;RTE2OQ__.pdf
52.46 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
E 204 – 98 ;RTIWNC05OA__.pdf
237.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 204 – 98 R02 ;RTIWNA__.pdf
230.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 250 – 98 ;RTI1MC05OA__.pdf
36.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 250 – 98 R02 ;RTI1MA__.pdf
35.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 260 – 96 ;RTI2MC05NG__.pdf
119.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 260 – 96 R01 ;RTI2MA__.pdf
160.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 275 – 01 ;RTI3NQ__.pdf
123.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 275 – 93 ;RTI3NS1SRUQ_.pdf
108.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 275 – 93 ;RTI3NS05MW__.pdf
101.16 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 334 – 01 ;RTMZNA__.pdf
115.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 334 – 96 ;RTMZNC1SRUQ_.pdf
103.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 334 – 96 ;RTMZNC05NG__.pdf
89.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 355 – 96 ;RTM1NS05NG__.pdf
49.64 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 355 – 96 R01 ;RTM1NQ__.pdf
50.71 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 386 – 90 R99 ;RTM4NG__.pdf
110.48 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 387 – 04 ;RTM4NW__.pdf
85.65 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 387 – 84 R95 ;RTM4NY1SRUQ_.pdf
126.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 387 – 84 R95 ;RTM4NY04NFI5NUUX.pdf
127.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 388 – 72 R98 ;RTM4OA__.pdf
25.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 516 – 95 ;RTUXNI05NUE_.pdf
77.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 516 – 95a R00 ;RTUXNG__.pdf
97.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 573 – 01 ;RTU3MW__.pdf
273.87 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 573 – 96 ;RTU3MY1SRUQ_.pdf
210.56 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 573 – 96 ;RTU3MY05NG__.pdf
194.57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 578 – 01 ;RTU3OA__.pdf
32.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 578 – 83 R98 ;RTU3OC1SRUQ_.pdf
27.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 578 – 83 R98 ;RTU3OC04M1I5OA__.pdf
19.5 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 579 – 04 ;RTU3OQ__.pdf
36.22 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 594 – 96 ;RTU5NC05NG__.pdf
51.94 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 594 – 96 R01 ;RTU5NA__.pdf
68.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 01 ;RTY3MY0WMG__.pdf
96.38 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 01 ;RTY3MY0WMQ__.pdf
101.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 02 ;RTY3MY0WMKE_.pdf
101.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 02 ;RTY3MY1SRUQ_.pdf
65.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 03 ;RTY3MW__.pdf
97.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 673 – 98 ;RTY3MY05OEUX.pdf
65.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 682 – 92 ;RTY4MI05MG__.pdf
63.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 682 – 92 R00 ;RTY4MG__.pdf
99.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 684 – 95 R00 ;RTY4NA__.pdf
15.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 685 – 93 ;RTY4NS05MW__.pdf
64.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 685 – 93 R00 ;RTY4NQ__.pdf
79.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 697 – 96 ;RTY5NY05NG__.pdf
99.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 697 – 96 R01 ;RTY5NW__.pdf
141.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 827 – 02 ;RTGYNW__.pdf
34.23 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 827 – 95 ;RTGYNY1SRUQ_.pdf
26.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 827 – 95 ;RTGYNY05NQ__.pdf
21.23 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 840 – 95 ;RTG0MC05NQ__.pdf
90.81 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 840 – 95 R00 ;RTG0MA__.pdf
131.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 902 – 94 R99 ;RTKWMG__.pdf
49.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 925 – 02 ;RTKYNQ__.pdf
70.32 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 925 – 83 R94 ;RTKYNS1SRUQ_.pdf
E 925 – 83 R94 ;RTKYNS04M1I5NEUX.pdf
34.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 932 – 89 R02 ;RTKZMG__.pdf
78.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 932 – 89 R97 ;RTKZMI04OVI5NW__.pdf
57.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 958 – 93 R99 ;RTK1OA__.pdf
54.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 983 – 94 R99 ;RTK4MW__.pdf
42.87 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 984 – 95 ;RTK4NC05NQ__.pdf
40.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 984 – 95 R01 ;RTK4NA__.pdf
52.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 995 – 97 ;RTK5NQ__.pdf
42.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 996 – 94 R99 ;RTK5NG__.pdf
33.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 1016 – 96 ;RTEWMTYTOTY_.pdf
26.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 1016 – 96 R02 ;RTEWMTY_.pdf
40.44 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 1078 – 02 ;RTEWNZG_.pdf
81.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 1078 – 97 ;RTEWNZGTUKVE.pdf
85.72 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1127 – 03 ;RTEXMJC_.pdf
59.93 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1127 – 91 R97 ;RTEXMJCTOTFSOTC_.pdf
61.47 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1127 – 91 R97 ;RTEXMJCTUKVE.pdf
43.03 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1140 – 95 ;RTEXNDATOTU_.pdf
39.84 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1140 – 95 R00 ;RTEXNDA_.pdf
40.91 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1151 – 93 ;RTEXNTE_.pdf
79.21 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1162 – 87 R01 ;RTEXNJI_.pdf
37.98 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1162 – 87 R96 ;RTEXNJITODDSOTY_.pdf
28.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
E 1217 – 00 ;RTEYMTC_.pdf
109.39 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1217 – 87 R92 ;RTEYMTCTUKVE.pdf
110.33 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1252 – 98 ;RTEYNTITOTG_.pdf
121.23 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1252 – 98 R02 ;RTEYNTI_.pdf
118.4 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1303 – 95 ;RTEZMDMTOTU_.pdf
104.67 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1303 – 95 R00 ;RTEZMDM_.pdf
128.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1421 – 99 ;RTE0MJETOTK_.pdf
182.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1421 – 99 R04 ;RTE0MJE_.pdf
182.5 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
E 1438 – 91 R01 ;RTE0MZG_.pdf
36.8 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1438 – 91 R96 ;RTE0MZGTOTFSOTY_.pdf
22.15 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1449 – 92 ;RTE0NDKTOTI_.pdf
52.34 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1449 – 92 R00 ;RTE0NDK_.pdf
53.5 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1504 – 92 R01 ;RTE1MDQ_.pdf
33.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1504 – 92 R96 ;RTE1MDQTOTJSOTY_.pdf
25.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1505 – 92 R01 ;RTE1MDU_.pdf
37.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1505 – 92 R96 ;RTE1MDUTOTJSOTY_.pdf
26.26 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1510 – 95 ;RTE1MTA_.pdf
136.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1510 – 95 ;RTE1MTATOTU_.pdf
137.03 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1511 – 93 ;RTE1MTETOTM_.pdf
48.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1511 – 93 R00 ;RTE1MTE_.pdf
63 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1523 – 03 ;RTE1MJM_.pdf
59.76 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1523 – 97 ;RTE1MJMTOTC_.pdf
45.12 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1523 – 97 ;RTE1MJMTUKVE.pdf
49.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1577 – 95 R00 ;RTE1NZC_.pdf
18.8 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1578 – 93 R99 ;RTE1NZG_.pdf
495.42 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1614 – 94 R99 ;RTE2MTQ_.pdf
77.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1634 – 02 ;RTE2MZQ_.pdf
43.69 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1634 – 94 R99 ;RTE2MZQTOTRSOTK_.pdf
19.13 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1634 – 94 R99 ;RTE2MZQTUKVE.pdf
39.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1635 – 95 R00 ;RTE2MZU_.pdf
26.26 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1636 – 94 R99 ;RTE2MZY_.pdf
73.66 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1642 – 00 ;RTE2NDI_.pdf
57.48 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1653 – 94 R99 ;RTE2NTM_.pdf
38.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1654 – 94 R99 ;RTE2NTQ_.pdf
64.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1655 – 00 ;RTE2NTU_.pdf
271.7 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1655 – 99 ;RTE2NTUTUKVE.pdf
199.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1657 – 98 ;RTE2NTCTOTG_.pdf
80.85 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 1657 – 98 R01 ;RTE2NTC_.pdf
97.64 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1683 – 02 ;RTE2ODM_.pdf
93.77 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1683 – 95 ;RTE2ODMTOTVB.pdf
71.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1698 – 95 ;RTE2OTGTOTU_.pdf
52.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1698 – 95 R00 ;RTE2OTG_.pdf
54.37 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1747 – 95 ;RTE3NDCTOTU_.pdf
43.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1747 – 95 R00 ;RTE3NDC_.pdf
61.87 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1790 – 00 ;RTE3OTA_.pdf
74.66 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1790 – 96 ;RTE3OTATUKVE.pdf
48.56 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1791 – 96 R00 ;RTE3OTE_.pdf
55.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1813 – 96 ;RTE4MTMTOTZFMQ__.pdf
242.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1813 – 96 R02 ;RTE4MTM_.pdf
287.99 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1829 – 02 ;RTE4MJK_.pdf
44.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1829 – 97 ;RTE4MJKTOTC_.pdf
21.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1829 – 97 ;RTE4MJKTUKVE.pdf
38.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1840 – 96 ;RTE4NDATOTY_.pdf
110.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1840 – 96 R02 ;RTE4NDA_.pdf
105.06 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1865 – 97 ;RTE4NJUTOTC_.pdf
159.71 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1865 – 97 R02 ;RTE4NJU_.pdf
205.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1866 – 97 ;RTE4NJYTOTC_.pdf
87.38 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1866 – 97 R02 ;RTE4NJY_.pdf
85.99 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1880 – 97 ;RTE4ODATOTC_.pdf
27.05 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1880 – 97 R02 ;RTE4ODA_.pdf
26.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1881 – 97 ;RTE4ODETOTC_.pdf
29.41 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1881 – 97 R02 ;RTE4ODE_.pdf
28.62 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1944 – 98 ;RTE5NDQTOTG_.pdf
52.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1944 – 98 R02 ;RTE5NDQ_.pdf
51.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1947 – 98 ;RTE5NDCTOTG_.pdf
77.63 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1947 – 98 R04 ;RTE5NDC_.pdf
77.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1948 – 98 ;RTE5NDGTOTG_.pdf
145.62 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1948 – 98 R04 ;RTE5NDG_.pdf
145.7 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1982 – 98 ;RTE5ODITOTG_.pdf
277.35 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1982 – 98 R02 ;RTE5ODI_.pdf
242.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 1989 – 98 ;RTE5ODKTOTG_.pdf
403.63 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 1989 – 98 R04 ;RTE5ODK_.pdf
403.47 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
E 2056 – 00 ;RTIWNTY_.pdf
91.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2056 – 99 ;RTIWNTYTUKVE.pdf
61.98 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2066 – 00 ;RTIWNJY_.pdf
495.48 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 2077 – 00 ;RTIWNZC_.pdf
99.71 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2078 – 00 ;RTIWNZG_.pdf
590.36 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
E 2105 – 00 ;RTIXMDU_.pdf
81.28 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2106 – 00 ;RTIXMDY_.pdf
64.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2108 – 00 ;RTIXMDG_.pdf
133.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2143 – 01 ;RTIXNDM_.pdf
92.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
E 2310 – 04 ;RTIZMTA_.pdf
147.56 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
GMT+7, 31/12/2025 17:08 , Processed in 0.088393 second(s), 21 queries .
