Xem: 4357|Trả lời: 0
ASTM 2004- Volume 04.04 Roofing and Waterproofing
ASTM 2004- Volume 04.04 Roofing and Waterproofing5 n. r  B0 f. r* D9 f
& X  y8 P6 f7 S$ T; M9 ?( ~
D0004-86R04 Test Method for Bitumen Content
) L) l4 c* Q1 v8 i5 @D0006-95R00E01 Test Method for Loss on Heating of Oil and Asphaltic Compounds
- f& f' B; r* s& c; VD0036-95R00E01 Test Method for Softening Point of Bitumen (Ring-and-Ball Apparatus)1 ^" p$ p! k: g" W* Y7 g; h
D0041-05 Specification for Asphalt Primer Used in Roofing, Dampproofing, and Waterproofing
2 R* @9 c8 h/ y; T0 n0 wD0043-00 Specification for Coal Tar Primer Used in Roofing, Dampproofing, and Waterproofing
- }7 ?' I1 Y. g! w1 I' F7 sD0088-94R99 Test Method for Saybolt Viscosity
6 |; J% ~( Q, [) i4 J8 I3 FD0146-04 Test Methods for Sampling and Testing Bitumen-Saturated Felts and Woven Fabrics for Roofing and Waterproofing
; H6 {, Q2 }) m6 s7 w' G5 jD0173-03 Specification for Bitumen-Saturated Cotton Fabrics Used in Roofing and Waterproofing
+ i% L( S% C5 L7 N( c1 lD0224 Specification for Smooth-Surfaced Asphalt Roll Roofing (Organic Felt)! Y3 L/ ]1 e" P" Y# U+ i
D0225-04 Specification for Asphalt Shingles (Organic Felt) Surfaced With Mineral Granules5 N, {% U: Q& B, m% _( \* [& |
D0226-97A Specification for Asphalt-Saturated Organic Felt Used in Roofing and Waterproofing+ B. M7 B% Z$ a! K; L3 }  a8 `
D0227-03 Specification for Coal-Tar-Saturated Organic Felt Used in Roofing and Waterproofing
+ f) y% M1 m& Q/ i, f8 \) kD0228-05 Test Methods for Sampling, Testing, and Analysis of Asphalt Roll Roofing, Cap Sheets, and Shingles Used in Roofing and Waterproofing
, J4 k/ |, |0 E5 yD0249 Specification for Asphalt Roll Roofing (Organic Felt) Surfaced with Mineral Granules: m$ H( {' q1 G; K: {
D0312-00 Specification for Asphalt Used in Roofing0 f& C2 z1 ^, N
D0371 Specification for Asphalt Roll Roofing (Organic Felt) Surfaced with Mineral Granules; Wide Selvage
% z* a1 o# W- N- N0 F2 YD0449-03 Specification for Asphalt Used in Dampproofing and Waterproofing
6 i5 A' A0 U3 h& }; sD0450-96R00E01 Specification for Coal-Tar Pitch Used in Roofing, Dampproofing, and Waterproofing
1 R$ {% j9 r+ f$ j  X% u4 ]D0451-91R02 Test Method for Sieve Analysis of Granular Mineral Surfacing For Asphalt Roofing Products
6 e  x* g! A: o0 w2 TD0452-91R02 Test Method for Sieve Analysis of Surfacing for Asphalt Roofing Products
: q4 N  A1 s+ A2 `7 jD0529-04 Practice for Enclosed Carbon-Arc Exposures of Bituminous Materials
3 ~3 T$ w; o8 m* C% aD1079-05 Terminology Relating to Roofing and Waterproofing
) p( K3 U1 {" oD1187-97R02E01 Specification for Asphalt-Base Emulsions for Use as Protective Coatings for Metal. A0 D& R. m2 V: B8 d4 S: L
D1227-95R00 Specification for Emulsified Asphalt Used as a Protective Coating for Roofing/ d8 `9 J& W2 L; [( u" w0 F
D1327-04 Specification for Bitumen-Saturated Woven Burlap Fabrics Used in Roofing and Waterproofing% M* h- S& \1 c! d
D1370-00 Test Method for Contact Compatibility Between Asphaltic Materials (Oliensis Test)6 x% X& N/ b# S. \: Z% u
D1668-97A Specification for Glass Fabrics (Woven and Treated) for Roofing and Waterproofing
5 Q! T6 e2 A' nD1669-03 Practice for Preparation of Test Panels for Accelerated and Outdoor Weathering of Bituminous Coatings
+ J' |8 ]4 Z5 Y2 C: i- aD1670-04 Test Method for Failure End Point in Accelerated and Outdoor Weathering of Bituminous Materials5 d, x% b% O# x% f, `
D1863-03 Specification for Mineral Aggregate Used on Built-Up Roofs! m+ o* p0 g2 ]4 Y
D1864-89R02 Test Method for Moisture in Mineral Aggregate Used on Built-Up Roofs
' `8 o$ ]! y7 j0 [D1865-89R02 Test Method for Hardness of Mineral Aggregate Used on Built-Up Roofs7 ^& n* Z3 h( A; i
D1970-01 Specification for Self-Adhering Polymer Modified Bituminous Sheet Materials Used as Steep Roofing Underlayment for Ice Dam Protection
, c+ F' @- u* i' ND2178-04 Specification for Asphalt Glass Felt Used in Roofing and Waterproofing
3 k" _, X& X: \% e0 BD2521-76R02E01 Specification for Asphalt Used in Canal, Ditch, and Pond Lining- w. `# I6 ?" s9 b: P2 G" Q
D2523-00 Practice for Testing Load-Strain Properties of Roofing Membranes
8 G( p( V4 V0 r3 t3 wD2626-04 Specification for Asphalt-Saturated and Coated Organic Felt Base Sheet Used in Roofing1 n# N7 v' L1 g. b& z9 U  S1 n' W
D2643-04 Specification for Prefabricated Asphalt Reservoir, Pond, Canal, and Ditch Liner (Exposed Type)
3 n0 k5 j- {/ q3 SD2746-97R02E01 Test Method for Staining Tendency of Asphalt (Stain Index)
' `% n4 i. H0 \6 LD2822-91R97E01 Specification for Asphalt Roof Cement9 |  X, v: N% a& I8 s
D2823-90R97E01 Specification for Asphalt Roof Coatings: d) v4 J2 ?) U% ]
D2824-04 Specification for Aluminum-Pigmented Asphalt Roof Coatings, Nonfibered, Asbestos Fibered, and Fibered without Asbestos9 q8 U1 R1 _! E( v
D2829-04 Practice for Sampling and Analysis of Built-Up Roofs3 ?7 J( n6 O; t! m) g% @9 E
D2939-03 Test Methods for Emulsified Bitumens Used as Protective Coatings
3 t8 r/ P) }! L2 K5 QD3018-03 Specification for Class A Asphalt Shingles Surfaced with Mineral Granules3 ], Y7 O% h' l5 q2 o
D3019-94R00E01 Specification for Lap Cement Used with Asphalt Roll Roofing, Non Fibered, Asbestos Fibered, and Non Asbestos Fibered
8 J' p+ G: U- x  _D3105-99 Index of Methods for Testing Elastomeric and Plastomeric Roofing and Waterproofing Materials
# h, ~! d) w' r$ {9 L: S% KD3161-03B Test Method for Wind-Resistance of Asphalt Shingles (Fan-Induced Method)
9 _5 \$ Q5 F! [; iD3320-00R04E01 Specification for Emulsified Coal-Tar Pitch (Mineral Colloid Type)& e; P9 H, B" k' t' a+ W
D3409-93R02E01 Test Method for Adhesion of Asphalt-Roof Cement to Damp, Wet, or Underwater Surfaces
7 N3 A' u0 L" i* l3 |; m% TD3423-84R03 Practice for Application of Emulsified Coal-Tar Pitch(Mineral Colloid Type)
+ k3 J" A! B; l; R1 v( b4 V# oD3462-04 Specification for Asphalt Shingles Made from Glass Felt and Surfaced with Mineral Granules
( ?# A2 e" {3 m2 T: w# n  ?8 pD3468-99 Specification for Liquid-Applied Neoprene and Chlorosulfonated Polyethylene Used in Roofing and Waterproofing
$ s$ Y( ?% C# Y0 j  JD3617-02 Practice for Sampling and Analysis of New Built-Up Roof Membranes
! z) c1 I/ z2 }D3745-95R00E01 Practice for Installation of Prefabricated Asphalt Reservoir, Pond, Canal, and Ditch Liner (Exposed Type)
# Q3 I0 g+ q; Y. DD3746-85R02 Test Method for Impact Resistance of Bituminous Roofing Systems
, f7 D' ?3 Z2 L. K: C2 x5 i& T) iD3747-79R00E01 Specification for Emulsified Asphalt Adhesive for Adhering Roof Insulation
& G  V" V" Q4 G. @5 U) UD3791-04 Practice for Evaluating the Effects of Heat on Asphalts
7 H3 c6 Q1 O& Q' C, S4 r: QD3805-97R03E01 Guide for Application of Aluminum-Pigmented Asphalt Roof Coatings
  P& p6 l+ e" Q- H' U8 aD3909-97BR04E01 Specification for Asphalt Roll Roofing (Glass Felt) Surfaced With Mineral Granules
+ `0 U" [* T2 M# cD4022-94R00E01 Specification for Coal Tar Roof Cement, Asbestos Containing  c$ ~; i0 ?$ ]1 h# J3 d; M
D4073-94R03 Test Method for Tensile-Tear Strength of Bituminous Roofing Membranes0 Q2 Y- e) o  F4 R8 w0 o6 h
D4074-91R04 Test Method for Bitumen and Aggregate Content of Bitumen-Aggregate Mixtures From Roofing Samples3 l. H% ~$ Q) v' a9 ]+ v
D4402-02 Test Method for Viscosity Determination of Asphalt at Elevated Temperatures Using a Rotational Viscometer$ H' y+ q$ `# f. D/ G& P1 V
D4434-04 Specification for Poly(Vinyl Chloride) Sheet Roofing+ ?# M. T( Q4 F% Y8 ~0 d: b" x  x
D4479-00 Specification for Asphalt Roof Coatings \N Asbestos-Free
# P4 j2 o9 _# qD4586-00 Specfication for Asphalt Roof Cement, Asbestos-Free+ }" J0 \6 Y0 K0 S; J) z
D4601-04 Specification for Asphalt-Coated Glass Fiber Base Sheet Used in Roofing
5 l: d0 E% ^# `" ]0 P' oD4637-04 Specification for EPDM Sheet Used In Single-Ply Roof Membrane% n! Y- Q- H) G# f: d
D4798-04 Practice for Accelerated Weathering Test Conditions and Procedures for Bituminous Materials (Xenon-Arc Method), ~- B: v+ d- n
D4799-03 Practice for Accelerated Weathering Test Conditions and Procedures for Bituminous Materials (Fluorescent UV, Water Spray, and Condensation Method)
8 V$ i6 ]5 s. x; {* eD4811-04 Specification for Nonvulcanized (Uncured) Rubber Sheet Used as Roof Flashing0 u5 H# c6 D& B+ l# W
D4830-98 Test Methods for Characterizing Thermoplastic Fabrics Used in Roofing and Waterproofing
( z, B3 u; J8 E0 y4 F' tD4866-88R03E01 Performance Specification for Coal Tar Pitch Emulsion Pavement Sealer Mix Formulations Containing Mineral Aggregates and Optional Polymeric Admixtures/ e% A0 G2 F, v- @+ V5 T
D4869-05 Specification for Asphalt-Saturated Organic Felt Underlayment Used in Steep Slope Roofing
+ v3 F7 R7 @# b3 WD4897-01 Specification for Asphalt-Coated Glass-Fiber Venting Base Sheet Used in Roofing4 ?7 t1 `5 w6 g! g
D4932-89R00E01 Test Method for Fastener Rupture and Tear Resistance of Roofing and Waterproofing Sheets, Roll Roofing, and Shingles
5 K6 ]& }* S. k1 c* j- YD4977-03 Test Method for Granule Adhesion to Mineral Surfaced Roofing by Abrasion
* ~5 r# o( B4 X4 C( W' SD4989-90AR04 Test Method for Apparent Viscosity (Flow) of Roofing Bitumens Using the Parallel Plate Plastometer: ~- `0 Q# U( z5 D+ F* \
D4990-97AR05E01 Specification for Coal Tar Glass Felt Used in Roofing and Waterproofing
1 S% F" r( ~$ z0 |5 j0 aD5019-96E01 Specification for Reinforced Non-Vulcanized Polymeric Sheet Used in Roofing Membrane. _1 r* z) W: t
D5036-99 Practice for Application of Adhered Poly(Vinyl Chloride) Sheet Roofing
1 D9 \) Q1 o2 c# A8 W7 cD5076-90R00E01 Test Method for Measuring Voids in Roofing and Waterproofing Membranes
, g- b+ g, P9 gD5081-90R99E01 Test Method for Aggregate Layer Hiding Power) T0 W  z6 n6 {: c1 x4 V+ E
D5082-99 Practice for Application of Mechanically Attached Poly(Vinyl Chloride) Sheet Roofing
% u$ h" v9 D: T( v3 c7 GD5100-95AR04 Test Method for Adhesion of Mineral Aggregate to Hot Bitumen" V- M4 l' O% [4 Z( G3 W
D5147-02AE01 Test Methods for Sampling and Testing Modified Bituminous Sheet Material- y2 v) y- J3 x( _; {
D5295-00 Guide for Preparation of Concrete Surfaces for Adhered (Bonded) Membrane Waterproofing Systems
: e( ^0 y% u2 a  ~D5385-93R00E01 Test Method for Hydrostatic Pressure Resistance of Waterproofing Membranes! K4 g  D1 f: l1 g) d" f
D5405-98R04 Test Method for Conducting Time-to-Failure (Creep-Rupture) Tests of Joints Fabricated from Nonbituminous Organic Roof Membrane Material7 d- Y# f7 }5 D9 s+ \
D5469-00 Guide for Application of New Spray Applied Polyurethane Foam and Coated Roofing Systems
3 {1 U2 v' m& `" y3 [9 @D5601 Test Method for Tearing Resistance of Roofing and Waterproofing Materials and Membranes0 M4 d5 z1 L+ ]4 c+ ], L
D5602-98 Test Method for Static Puncture Resistance of Roofing Membrane Specimens
. h$ J4 a+ _6 Y/ ?+ JD5635-04A Test Method for Dynamic Puncture Resistance of Roofing Membrane Specimens' J# l8 p9 p9 t; J
D5636-94R99E01 Test Method for Low Temperature Unrolling of Felt or Sheet Roofing and Waterproofing Materials
3 _0 S! I! _; o/ }5 t0 J9 `9 ]3 Y  XD5643-94R00E01 Specification for Coal Tar Roof Cement, Asbestos Free0 W" }* K. z9 i3 e
D5665-99A Specification for Thermoplastic Fabrics Used in Cold-Applied Roofing and Waterproofing
2 `7 c! H% s$ ?, S  \D5683-95R99E01 Test Method for Flexibility of Roofing and Waterproofing Materials and Membranes+ q: Y4 Z2 B  ?! @+ F  c
D5726-98 Specification for Thermoplastic Fabrics Used in Hot-Applied Roofing and Waterproofing
! g6 Z( ^/ ~  o1 V3 HD5727-00R04E01 Specification for Emulsified Refined Coal Tar (Mineral Colloid Type)
  Q" H- ]% ]9 T& I5 r0 WD5843-95R00E01 Guide for Application of Fully Adhered Vulcanized Rubber Sheets Used in Waterproofing4 P& Q, Z0 p" Q- b
D5849-95R00E01 Test Method for Evaluating Resistance of Modified, Bituminous Roofing Membranes to Cyclic Joint Displacement
- ^. J4 Q( R3 I, ^" {* u0 nD5869-04A Practice for Dark Oven Heat Exposure of Bituminous Materials# R% a# Y" W2 T. s$ D3 h/ s
D5898-96 Guide for Standard Details for Adhered Sheet Waterproofing
  B* `- f- u1 g" O. n! G4 dD5957-98 Guide for Flood Testing Horizontal Waterproofing Installations
. z4 B. M: x, O7 d, |. W! N4 XD6083-05 Specification for Liquid Applied Acrylic Coating Used in Roofing3 m2 p6 m( T1 @
D6134-97 Specification for Vulcanized Rubber Sheets Used in Waterproofing Systems; Z. O, S1 E* n0 Q. C" s
D6135-97 Practice for Application of Self-Adhering Modified Bituminous Waterproofing: n" Z' T+ Z8 Z2 e9 r
D6136-97R04E01 Test Method for Kerosine Number of Unsaturated (Dry) Felt by Vacuum Method$ e; Y* F. Y; z! ^
D6152-99 Specification for SEBS-Modified Mopping Asphalt Used in Roofing
, A" f3 W7 e. Z7 ?- KD6162-00A Specification for Styrene Butadiene Styrene (SBS) Modified Bituminous Sheet Materials Using a Combination of Polyester and Glass Fiber Reinforcements
  n' c' D/ N4 AD6163-00E01 Specification for Styrene Butadiene Styrene (SBS) Modified Bituminous Sheet Materials Using Glass Fiber Reinforcements
- Z5 v' i& b6 H" P. mD6164-00 Specification for Styrene Butadiene Styrene (SBS) Modified Bituminous Sheet Materials Using Polyester Reinforcements
1 y1 G1 a+ Y: K6 E( E& s4 KD6221-00 Specification for Reinforced Bituminous Flashing Sheets for Roofing and Waterproofing( d2 K& }6 `  i% u6 [+ Q' G' B* X
D6222-02 Specification for Atactic Polypropylene (APP) Modified Bituminous Sheet Materials Using Polyester Reinforcements
) z- T4 G6 x! M4 k  ID6223-02 Specification for Atactic Polypropylene (APP) Modified Bituminous Sheet Materials Using a Combination of Polyester and Glass Fiber Reinforcements0 U/ ~- l. h  a- c% h9 ^  ~% l" O  O
D6225-98R04 Test Method for Granule Cover of Mineral Surfaced Roofing: Y, Y6 |9 R% n# E$ }' i
D6294-98R03 Test Method for Corrosion Resistance of Ferrous Metal Fastener Assemblies Used in Roofing and Waterproofing
& _& C( s9 z9 DD6298-00 Specification for Fiberglass Reinforced Styrene-Butadiene-Styrene (SBS) Modified Bituminous Sheets with a Factory Applied Metal Surface
8 `( h$ E" N2 U% p- lD6356-98R04 Test Method for Hydrogen Gas Generation of Aluminum Emulsified Asphalt Used as a Protective Coating for Roofing
2 t: O. c. B  |5 d; I+ F8 `D6369-99 Guide for Design of Standard Flashing Details for EPDM Roof Membranes8 \9 y7 \& N* W
D6380-03 Specification for Asphalt Roll Roofing (Organic Felt)D6381-03B Test Method for Measurement of Asphalt Shingle Mechanical Uplift Resistance
1 i; `1 Z0 `# uD6382-99 Practice for Dynamic Mechanical Analysis and Thermogravimetry of Roofing and Waterproofing Membrane Material- x8 P: c* V" m3 n
D6383-99E01 Practice for Time-to-Failure (Creep-Rupture) of Adhesive Joints Fabricated from EPDM Roof Membrane Material
( Y; J' o" q( u5 W) C; r, K" e! {4 YD6451-99 Guide for Application of Asphalt Based Protection Board
- V  h& i! Q& G/ F& _+ _- R2 BD6506-01 Specification for Asphalt Based Protection Board for Below-Grade Waterproofing
' n. Z( \% @9 B3 f* O! A. t- CD6509-00 Specification for Atactic Polypropylene (APP) Modified Bituminous Base Sheet Materials Using Glass Fiber Reinforcement
( Q8 R; Y; B/ S- k0 v7 N  @D6510-00 Guide for Selection of Asphalt Used in Built-Up Roofing Systems
9 E. h* z1 J9 y% YD6511-00 Test Methods for Solvent Bearing Bituminous Compounds
& o* ?; W& Y) r- [1 `! d) b+ ~: G  s* |D6622-01 Guide for Application of Fully Adhered Hot-Applied Reinforced Waterproofing Systems
4 g) u" N5 h2 xD6630-01 Guide for Low Slope Insulated Roof Membrane Assembly Performance
" |& H( \5 C* Y1 F: PD6694-01 Specification for Liquid-Applied Silicone Coating Used in Spray Polyurethane Foam Roofing3 E" B, C7 R- a/ |* t
D6705-04 Guide for Repair and Recoat of Spray Polyurethane Foam Roofing Systems/ H5 a% P2 ^8 [% R
D6753-02 Specification for Coal Tar Adhesive% K1 N: l% \( x0 g: C4 E3 F+ x3 A- |
D6754-02 Specification for Ketone Ethylene Ester Based Sheet Roofing
" M0 {- o" @$ GD6757-05 Specification for Underlayment Felt Containing Inorganic Fibers Used in Steep-Slope Roofing# w. s" b- G' Q, Q& k, v
D6769-02 Guide for Application of Fully Adhered, Cold-Applied, Prefabricated Reinforced Modified Bituminous Membrane Waterproofing Systems  ]2 ^( m" J  f, J, X2 z
D6805-02 Practice for Infrared (IR) Procedure for Determination of Aromatic/ Aliphatic Ratio of Bituminous Emulsions/ U1 X0 O" _" L! p8 X. P2 }5 p- H
D6848-02 Specification for Aluminum Pigmented Emulsified Asphalt Used as a Protective Coating for Roofing
/ j5 V, s& F0 K+ K5 z  f, Q/ XD6878-03 Specification for Thermoplastic Polyolefin Based Sheet Roofing
9 z- m* j3 q! h! Z* S# FD6945-03 Specification for Emulsified Refined Coal-Tar (Ready to Use, Commercial Grade)
! c* h- H% O% [* Y* L: tD6946-03 Specification for Emulsified Refined Coal-Tar (Driveway Sealer, Ready to Use, Primarily Residential Grade): o: I7 s( _- b: Y) S* a
D6948-03 Practice for Application of Refined Coal Tar (Ready to Use, Commercial Grade)
, \1 s/ M; J7 S* k/ W8 D$ kD6950-04 Practice for Application of Heat Weldable Atactic Polypropylene (APP) Modified Bituminous Waterproofing Membranes Systems for New Building Decks
7 Q# n7 Q! q8 O9 n0 cE0102-93R03E01 Test Method for Saybolt Furol Viscosity of Bituminous Materials at High Temperatures
% _; _5 b( r6 oE0907-96R04 Test Method for Field Testing Uplift Resistance of Adhered Membrane Roofing Systems9 K- ], X' g$ o  ?. l7 ~
D 4 – 86 R98 ;RDQ_.pdf
49.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6 – 95 R00 ;RDY_.pdf
32.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 36 – 95 R00 ;RDM2.pdf
47.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 41 – 94 ;RDQX.pdf
17.01 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 43 – 00 ;RDQZ.pdf
23.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 43 – 94 R00 ;RDQZLVJFRA__.pdf
20.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 88 – 94 R99 ;RDG4.pdf
92.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 146 – 03 ;RDE0NG__.pdf
91.97 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 146 – 97 ;RDE0NI1SRUQ_.pdf
83.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 146 – 97 ;RDE0NI05N0UX.pdf
103.56 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 146 – 97 ;RDE0NI05NW__.pdf
79.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 173 – 03 ;RDE3MW__.pdf
27.53 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 173 – 97 ;RDE3MY1SRUQ_.pdf
23.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 173 – 97 ;RDE3MY05N0I_.pdf
28.44 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 225 – 02 ;RDIYNS1SRUQ_.pdf
22.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 225 – 03 ;RDIYNQ__.pdf
30.64 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 226 – 97 ;RDIYNG__.pdf
32.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 227 – 03 ;RDIYNW__.pdf
25.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 227 – 97 ;RDIYNY1SRUQ_.pdf
20.21 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 227 – 97 ;RDIYNY05N0E_.pdf
26.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 228 – 00 ;RDIYOC0WMEI_.pdf
102.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 228 – 02 ;RDIYOC0WMG__.pdf
230.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 228 – 03 ;RDIYOA__.pdf
225.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 228 – 03 ;RDIYOC0WMW__.pdf
138.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 228 – 03 ;RDIYOC1SRUQ_.pdf
171.79 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 312 – 00 ;RDMXMG__.pdf
23.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 312 – 95 ;RDMXMI1SRUQ_.pdf
20.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 449 – 03 ;RDQ0OQ__.pdf
25.76 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 449 – 89 R99 ;RDQ0OS1SRUQ_.pdf
23.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 449 – 89 R99 ;RDQ0OS04OVI5OUUX.pdf
34.07 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 450 – 96 R00 ;RDQ1MA__.pdf
32.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 451 – 91 R02 ;RDQ1MQ__.pdf
D 451 – 91 R96 ;RDQ1MS05MVI5NKUX.pdf
18.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 452 – 91 R02 ;RDQ1MG__.pdf
26.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 452 – 91 R97 ;RDQ1MI05MVI5N0UX.pdf
35.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 529 – 00 ;RDUYOQ__.pdf
21.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1079 – 00 ;RDEWNZKTMDBB.pdf
107.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1079 – 01 ;RDEWNZKTUKVE.pdf
109.12 KB, Lượt tải về: 12, Tải điểm: Thưởng -2 điểm
D 1079 – 02 ;RDEWNZK_.pdf
129.2 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 1187 – 97 ;RDEXODCTOTC_.pdf
16.88 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1187 – 97 R02 ;RDEXODC_.pdf
33.93 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1227 – 95 R00 ;RDEYMJC_.pdf
25.52 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 1327 – 04 ;RDEZMJC_.pdf
30.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1327 – 97 ;RDEZMJCTOTDB.pdf
31.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1327 – 97 ;RDEZMJCTUKVE.pdf
24.57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1370 – 00 ;RDEZNZA_.pdf
16.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1668 – 97 ;RDE2NJG_.pdf
33.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1669 – 01 ;RDE2NJKTMDE_.pdf
35.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1669 – 01 ;RDE2NJKTUKVE.pdf
26.99 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1669 – 03 ;RDE2NJK_.pdf
35.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1669 – 89 R94 ;RDE2NJKTODLSOTRFMQ__.pdf
25.23 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1670 – 04 ;RDE2NZA_.pdf
59.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1670 – 98 ;RDE2NZATOTG_.pdf
56.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1670 – 98 R03 ;RDE2NZATOTHSMDM_.pdf
54.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1670 – 98 R03 ;RDE2NZATUKVE.pdf
58.73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1863 – 03 ;RDE4NJM_.pdf
25.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1863 – 93 R03 ;RDE4NJMTOTNSMDM_.pdf
26.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1863 – 93 R03 ;RDE4NJMTUKVE.pdf
20.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1864 – 89 R02 ;RDE4NJQ_.pdf
23.75 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1864 – 89 R99 ;RDE4NJQTODLSOTLFMQ__.pdf
18.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1865 – 89 R02 ;RDE4NJU_.pdf
26.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1865 – 89 R99 ;RDE4NJUTODLSOTLFMQ__.pdf
34.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1970 – 00 ;RDE5NZATMDA_.pdf
33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1970 – 00 ;RDE5NZATUKVE.pdf
41.54 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 1970 – 01 ;RDE5NZA_.pdf
45.86 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 2178 – 97 ;RDIXNZG_.pdf
29.66 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2521 – 76 R02 ;RDI1MJE_.pdf
31.17 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2521 – 76 R02 ;RDI1MJETNZZSMDI_.pdf
15.58 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2521 – 76 R97 ;RDI1MJETNZZSOTC_.pdf
14.83 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2523 – 00 ;RDI1MJM_.pdf
31.8 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2523 – 78 R95 ;RDI1MJMTUKVE.pdf
29.58 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2626 – 97 ;RDI2MJY_.pdf
28.34 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2643 – 98 ;RDI2NDM_.pdf
36.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2746 – 97 ;RDI3NDYTOTC_.pdf
21.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2746 – 97 R02 ;RDI3NDY_.pdf
39.8 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2746 – 97 R02 ;RDI3NDYTOTDSMDI_.pdf
22.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2822 – 91 R97 ;RDI4MJI_.pdf
38.5 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 2823 – 90 R97 ;RDI4MJM_.pdf
31.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2824 – 02 ;RDI4MJQTMDI_.pdf
25.15 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2824 – 04 ;RDI4MJQ_.pdf
24.47 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2824 – 94 ;RDI4MJQTOTQ_.pdf
34.57 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2824 – 94 ;RDI4MJQTUKVE.pdf
30.87 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2829 – 04 ;RDI4MJK_.pdf
49.7 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 2939 – 03 ;RDI5MZK_.pdf
64.59 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 2939 – 98 ;RDI5MZKTOTG_.pdf
65.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2939 – 98 ;RDI5MZKTUKVE.pdf
47.97 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3018 – 00 ;RDMWMTGTMDA_.pdf
26.21 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3018 – 00 ;RDMWMTGTUKVE.pdf
19.06 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3018 – 03 ;RDMWMTG_.pdf
25.27 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3019 – 94 R00 ;RDMWMTK_.pdf
18.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3105 – 99 ;RDMXMDU_.pdf
29.24 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3161 – 03 ;RDMXNJE_.pdf
30.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3161 – 03 ;RDMXNJETMDM_.pdf
31.57 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3161 – 03 ;RDMXNJETMDNB.pdf
31.48 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3161 – 03 ;RDMXNJETUKVE.pdf
21.5 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3161 – 99 ;RDMXNJETOTLB.pdf
21.75 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3320 – 00 ;RDMZMJA_.pdf
20.63 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3320 – 90 R98 ;RDMZMJATUKVE.pdf
25.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3409 – 93 ;RDM0MDKTOTM_.pdf
14.94 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3409 – 93 R02 ;RDM0MDK_.pdf
31.41 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3409 – 93 R02 ;RDM0MDKTOTNSMDI_.pdf
16.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3423 – 84 R03 ;RDM0MJM_.pdf
26.72 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3423 – 84 R98 ;RDM0MJMTODRSOTHFMQ__.pdf
35.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3462 – 00 ;RDM0NJITMDA_.pdf
45.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3462 – 01 ;RDM0NJITMDE_.pdf
47.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3462 – 01 ;RDM0NJITMDFFMQ__.pdf
50.31 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3462 – 02 ;RDM0NJITMDI_.pdf
64.41 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3462 – 03 ;RDM0NJI_.pdf
62.5 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3462 – 03 ;RDM0NJITMDM_.pdf
65.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3462 – 03 ;RDM0NJITUKVE.pdf
48.14 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3468 – 99 ;RDM0NJG_.pdf
35.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3617 – 02 ;RDM2MTC_.pdf
27.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3617 – 83 R94 ;RDM2MTCTODNSOTRFMQ__.pdf
27.77 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3617 – 83 R94 ;RDM2MTCTUKVE.pdf
35.49 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 3745 – 95 R00 ;RDM3NDU_.pdf
22.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3746 – 85 R02 ;RDM3NDY_.pdf
42.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3746 – 85 R96 ;RDM3NDYTODVSOTZFMQ__.pdf
51.79 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3747 – 79 R00 ;RDM3NDC_.pdf
35 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3791 – 04 ;RDM3OTE_.pdf
25.72 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3791 – 96 ;RDM3OTETOTY_.pdf
26.84 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3805 – 97 ;RDM4MDUTOTC_.pdf
32.13 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3805 – 97 R03 ;RDM4MDU_.pdf
38.53 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 3909 – 97 ;RDM5MDK_.pdf
26.35 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4022 – 94 R00 ;RDQWMJI_.pdf
17.56 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4073 – 94 R03 ;RDQWNZM_.pdf
34.96 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 4073 – 94 R98 ;RDQWNZMTOTRSOTHFMQ__.pdf
41.84 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4074 – 91 R96 ;RDQWNZQ_.pdf
36.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4402 – 02 ;RDQ0MDI_.pdf
D 4402 – 87 R00 ;RDQ0MDITUKVE.pdf
35.25 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 4434 – 96 ;RDQ0MZQ_.pdf
34.98 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 4479 – 00 ;RDQ0NZK_.pdf
23.86 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4479 – 93 ;RDQ0NZKTUKVE.pdf
31.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4586 – 00 ;RDQ1ODY_.pdf
23.68 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4586 – 93 ;RDQ1ODYTUKVE.pdf
24.14 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4601 – 98 ;RDQ2MDE_.pdf
26.53 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4637 – 03 ;RDQ2MZC_.pdf
41.08 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4637 – 96 ;RDQ2MZCTOTY_.pdf
42.7 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4637 – 96 ;RDQ2MZCTUKVE.pdf
40.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4798 – 00 ;RDQ3OTGTMDA_.pdf
18.64 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4798 – 00 ;RDQ3OTGTUKVE.pdf
22.59 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4798 – 01 ;RDQ3OTG_.pdf
29.44 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4799 – 00 ;RDQ3OTKTMDA_.pdf
17.53 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4799 – 00 ;RDQ3OTKTUKVE.pdf
21.54 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4799 – 03 ;RDQ3OTK_.pdf
27.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4811 – 04 ;RDQ4MTE_.pdf
38.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4811 – 97 ;RDQ4MTETOTC_.pdf
40.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4811 – 97 ;RDQ4MTETUKVE.pdf
38.03 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4830 – 98 ;RDQ4MZA_.pdf
61.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4866 – 88 R03 ;RDQ4NJY_.pdf
38.17 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4866 – 88 R97 ;RDQ4NJYTODHSOTDFMQ__.pdf
38.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4866 – 88 R97 ;RDQ4NJYTUKVE.pdf
26.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4869 – 02 ;RDQ4NJKTMDI_.pdf
40.17 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4869 – 02 ;RDQ4NJKTUKVE.pdf
32.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4869 – 03 ;RDQ4NJK_.pdf
41.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4869 – 88 R93 ;RDQ4NJKTODHSOTNFMQ__.pdf
27.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4897 – 01 ;RDQ4OTC_.pdf
27.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4897 – 98 ;RDQ4OTCTOTG_.pdf
17.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4897 – 98 ;RDQ4OTCTUKVE.pdf
24.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4932 – 89 R00 ;RDQ5MZI_.pdf
39.87 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4977 – 03 ;RDQ5NZC_.pdf
56.42 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4977 – 98 ;RDQ5NZCTOTHC.pdf
57.57 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4977 – 98 ;RDQ5NZCTUKVE.pdf
49.42 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4989 – 90a R04 ;RDQ5ODK_.pdf
66.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4989 – 90a R99 ;RDQ5ODKTOTBBUJK5RTE_.pdf
74.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 4990 – 97 ;RDQ5OTA_.pdf
18.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5019 – 96 ;RDUWMTK_.pdf
46.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5036 – 99 ;RDUWMZY_.pdf
27.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5076 – 90 R00 ;RDUWNZY_.pdf
33.92 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5081 – 90 R99 ;RDUWODE_.pdf
33.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5082 – 99 ;RDUWODI_.pdf
25.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5100 – 95a R00 ;RDUXMDATOTVBUJAWRTE_.pdf
42.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5100 – 95a R04 ;RDUXMDA_.pdf
34.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5147 – 01 ;RDUXNDCTMDE_.pdf
33.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5147 – 02 ;RDUXNDC_.pdf
49.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5147 – 02 ;RDUXNDCTMDI_.pdf
51.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5147 – 02 ;RDUXNDCTUKVE.pdf
35.1 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5147 – 97 ;RDUXNDCTOTC_.pdf
31.51 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5295 – 00 ;RDUYOTU_.pdf
40.99 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5295 – 92 R98 ;RDUYOTUTUKVE.pdf
34.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5385 – 93 R00 ;RDUZODU_.pdf
75.25 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5405 – 98 ;RDU0MDU_.pdf
76.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5469 – 00 ;RDU0NJK_.pdf
169.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5469 – 93 ;RDU0NJKTUKVE.pdf
160.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5602 – 98 ;RDU2MDI_.pdf
36.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5635 – 03 ;RDU2MZUTMDM_.pdf
60.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5635 – 03 ;RDU2MZUTUKVE.pdf
48.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5635 – 04 ;RDU2MZU_.pdf
58.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5636 – 94 R99 ;RDU2MZY_.pdf
32.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5643 – 94 R00 ;RDU2NDM_.pdf
16.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5665 – 99 ;RDU2NJU_.pdf
26.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5683 – 95 R99 ;RDU2ODM_.pdf
41.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5726 – 98 ;RDU3MJY_.pdf
34.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5727 – 00 ;RDU3MJC_.pdf
15.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5727 – 95 ;RDU3MJCTUKVE.pdf
18.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5843 – 95 R00 ;RDU4NDM_.pdf
39.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5849 – 95 R00 ;RDU4NDK_.pdf
38.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5869 – 95 R00 ;RDU4NJKTOTVSMDBFMQ__.pdf
17.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5869 – 95 R02 ;RDU4NJK_.pdf
24.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5898 – 96 ;RDU4OTG_.pdf
268.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5957 – 98 ;RDU5NTC_.pdf
67.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6083 – 97 ;RDYWODM_.pdf
29.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6134 – 97 ;RDYXMZQ_.pdf
27.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6135 – 97 ;RDYXMZU_.pdf
30.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6136 – 97 ;RDYXMZYTOTC_.pdf
25.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6136 – 97 R04 ;RDYXMZY_.pdf
33.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6152 – 99 ;RDYXNTI_.pdf
31.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6162 – 00 ;RDYXNJI_.pdf
19.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6162 – 00 ;RDYXNJITUKVE.pdf
22.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6163 – 00 ;RDYXNJM_.pdf
37.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6163 – 00 ;RDYXNJMTMDA_.pdf
19.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6164 – 00 ;RDYXNJQ_.pdf
29.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6164 – 98 ;RDYXNJQTUKVE.pdf
25.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6221 – 00 ;RDYYMJE_.pdf
D 6221 – 98 ;RDYYMJETUKVE.pdf
26.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6222 – 00 ;RDYYMJITMDA_.pdf
20.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6222 – 00 ;RDYYMJITUKVE.pdf
24.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6222 – 02 ;RDYYMJI_.pdf
31.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6223 – 00 ;RDYYMJMTMDA_.pdf
20.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6223 – 00 ;RDYYMJMTUKVE.pdf
25.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6223 – 02 ;RDYYMJM_.pdf
31.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6225 – 98 ;RDYYMJU_.pdf
245.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6294 – 98 ;RDYYOTQTOTG_.pdf
39.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6294 – 98 R03 ;RDYYOTQ_.pdf
38.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6298 – 00 ;RDYYOTG_.pdf
30.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6298 – 98 ;RDYYOTGTUKVE.pdf
26.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6356 – 98 ;RDYZNTY_.pdf
41.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6369 – 99 ;RDYZNJK_.pdf
188.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6380 – 00 ;RDYZODATMDA_.pdf
22.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6380 – 01 ;RDYZODATMDE_.pdf
22.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6380 – 01 ;RDYZODATMDFFMQ__.pdf
44.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6380 – 01 ;RDYZODATUKVE.pdf
28.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6380 – 03 ;RDYZODA_.pdf
34.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 00 ;RDYZODETMDA_.pdf
88.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 00 ;RDYZODETMDBB.pdf
413.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 03 ;RDYZODE_.pdf
150.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 03 ;RDYZODETMDM_.pdf
620.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 03 ;RDYZODETMDNB.pdf
620.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6381 – 03 ;RDYZODETUKVE.pdf
135.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6382 – 99 ;RDYZODI_.pdf
30.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6383 – 99 ;RDYZODM_.pdf
23.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6451 – 99 ;RDY0NTE_.pdf
25.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6506 – 00 ;RDY1MDYTUKVE.pdf
17.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6506 – 01 ;RDY1MDY_.pdf
24.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6509 – 00 ;RDY1MDK_.pdf
28.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6510 – 00 ;RDY1MTA_.pdf
28.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6511 – 00 ;RDY1MTE_.pdf
166.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6622 – 01 ;RDY2MJI_.pdf
34.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6630 – 01 ;RDY2MZA_.pdf
33.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6694 – 01 ;RDY2OTQ_.pdf
29.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6705 – 01 ;RDY3MDU_.pdf
29.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6753 – 02 ;RDY3NTM_.pdf
25.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6754 – 02 ;RDY3NTQ_.pdf
37.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6757 – 02 ;RDY3NTC_.pdf
D 6769 – 02 ;RDY3NJK_.pdf
22.57 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6805 – 02 ;RDY4MDU_.pdf
45.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6848 – 02 ;RDY4NDG_.pdf
33.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6878 – 03 ;RDY4NZG_.pdf
34.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6945 – 03 ;RDY5NDU_.pdf
30.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6946 – 03 ;RDY5NDY_.pdf
25.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6948 – 03 ;RDY5NDG_.pdf
38.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
E 102 – 93 R03 ;RTEWMG__.pdf
45.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
E 102 – 93 R97 ;RTEWMI05M1I5NW__.pdf
39.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
E 907 – 96 ;RTKWNW__.pdf
110.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
GMT+7, 6/2/2026 06:50 , Processed in 0.151684 second(s), 20 queries .
