ASTM 2004- Volume 04.13 Geosynthetics( b4 O$ |; U' y1 \
( J3 Y# U) F jD1987-95R02 Test Method for Biological Clogging of Geotextile or Soil/Geotextile Filters+ b9 V! i1 k6 U0 I6 E
D4354-99R04 Practice for Sampling of Geosynthetics for Testing
3 L* ]3 g: C% }1 _" _7 ^D4355-02 Test Method for Deterioration of Geotextiles by Exposure to Light, Moisture and Heat in a Xenon Arc Type Apparatus
) ~* y7 ]$ l" m$ {. f1 I8 \D4437-99 Practice for Determining the Integrity of Field Seams Used in Joining Flexible Polymeric Sheet Geomembranes5 w8 C9 g. n- h) G, X" i
D4439-04 Terminology for Geosynthetics
1 d5 ^" f. V! L. S6 s$ o/ U( jD4491-99AR04 Test Methods for Water Permeability of Geotextiles by Permittivity
9 j G( H# z# T7 J' O U) KD4533-04 Test Method for Trapezoid Tearing Strength of Geotextiles
2 z, Q7 a: f' @/ V$ uD4545-86R99 Practice for Determining the Integrity of Factory Seams Used in Joining Manufactured Flexible Sheet Geomembranes
: @+ @! f* C$ n7 M2 tD4594-96R03 Test Method for Effects of Temperature on Stability of Geotextiles( |4 D/ t: u( V/ \
D4595-86R01 Test Method for Tensile Properties of Geotextiles by the Wide-Width Strip Method3 S$ H6 y$ _# d+ q5 R' I8 c; N
D4632-91R03 Test Method for Grab Breaking Load and Elongation of Geotextiles/ F Q5 l! q$ `# ?
D4716-04 Test Method for Determining the (In-plane) Flow Rate per Unit Width and Hydraulic Transmissivity of a Geosynthetic Using a Constant Head
5 N4 O: o+ k. yD4751-04 Test Method for Determining Apparent Opening Size of a Geotextile8 e6 b" W0 a% n- M( L' H) n0 ]
D4759-02 Practice for Determining the Specification Conformance of Geosynthetics1 s, H; _& P2 |! j
D4833-00E01 Test Method for Index Puncture Resistance of Geotextiles, Geomembranes, and Related Products
4 Y4 y7 b9 N) }! n5 jD4873-02 Guide for Identification, Storage, and Handling of Geosynthetic Rolls and Samples8 r, M; P Z+ Y/ X) n/ S ?
D4884-96R03 Test Method for Strength of Sewn or Thermally Bonded Seams of Geotextiles
- ?# b6 ~" L ~* yD4885-01 Test Method for Determining Performance Strength of Geomembranes by the Wide Strip Tensile Method
: Z. V, x2 b5 S4 mD4886-88R02 Test Method for Abrasion Resistance of Geotextiles (Sand Paper/Sliding Block Method)3 b* l) h8 l+ h8 a* k' i
D5101-01 Test Method for Measuring the Soil-Geotextile System Clogging Potential by the Gradient Ratio
0 |3 R, d2 t8 f( D: h' p$ K aD5141-96R04 Test Method for Determining Filtering Efficiency and Flow Rate of a Geotextile for Silt Fence Application Using Site-Specific Soil( b5 s9 P8 t# [! _4 R' R
D5199-01 Test Method for Measuring the Nominal Thickness of Geosynthetics) b- L8 D) R# u
D5261-92R03 Test Method for Measuring Mass per Unit Area of Geotextiles* L' Z8 h* N6 i( m
D5262-04 Test Method for Evaluating the Unconfined Tension Creep and Creep Rupture Behavior of Geosynthetics
+ g4 x# i' |* [* ]' i \: {0 rD5321-02 Test Method for Determining the Coefficient of Soil and Geosynthetic or Geosynthetic and Geosynthetic Friction by the Direct Shear Method( u# F1 D2 a) V7 @# c" ^
D5322-98R03 Practice for Laboratory Immersion Procedures for Evaluating the Chemical Resistance of Geosynthetics to Liquids. j$ F# W3 @# t4 B4 G
D5323-92R99 Practice for Determination of 2\t\% Secant Modulus for Polyethylene Geomembranes
& t4 }7 V! h* r1 @* O, }D5397-99 Test Method for Evaluation of Stress Crack Resistance of Polyolefin Geomembranes Using Notched Constant Tensile Load Test! [/ m' `3 L0 p# S" g: E
D5493-93R03 Test Method for Permittivity of Geotextiles Under Load o7 S1 ~: ?! v6 R& o e: \. u
D5494-93R99E01 Test Method for the Determination of Pyramid Puncture Resistance of Unprotected and Protected Geomembranes5 ]) w+ u$ B* t! N0 C7 k8 ^* M
D5496-98R03 Practice for In Field Immersion Testing of Geosynthetics+ @9 @) W' i. y
D5514-94R01 Test Method for Large Scale Hydrostatic Puncture Testing of Geosynthetics
" G& g* q% U- Q: S! C9 P, Z& R6 ND5567-94R01 Test Method for Hydraulic Conductivity Ratio (HCR) Testing of Soil/Geotextile Systems
! {$ s M+ _, ID5596-03 Test Method For Microscopic Evaluation of the Dispersion of Carbon Black in Polyolefin Geosynthetics* b, g1 I6 i' z0 ?" n
D5617-04 Test Method for Multi-Axial Tension Test for Geosynthetics
; n" e7 l0 o6 T( P& ?D5641-94R01E01 Practice for Geomembrane Seam Evaluation by Vacuum Chamber$ ]- M) {8 E1 |! u
D5721-95R02 Practice for Air-Oven Aging of Polyolefin Geomembranes2 k! R5 K5 q' L- C+ Y2 M. ^" |
D5747-95AR02 Practice for Tests to Evaluate the Chemical Resistance of Geomembranes to Liquids6 `4 k9 Z, O5 o D. [/ h x
D5818-95R00 Practice for Obtaining Samples of Geosynthetics from a Test Section for Assessment of Installation Damage8 s$ {4 K9 E2 a, ]5 `3 T+ [. O
D5819-99 Guide for Selecting Test Methods for Experimental Evaluation of Geosynthetic Durability
/ U ? J7 u! F0 @7 J1 CD5820-95R01E01 Practice for Pressurized Air Channel Evaluation of Dual Seamed Geomembranes
2 ~" A# X6 h: ?( u' ZD5884-04A Test Method for Determining Tearing Strength of Internally Reinforced Geomembranes4 M& {! ~; q5 B, [- o9 f) C. _
D5885-04 Test Method for Oxidative Induction Time of Polyolefin Geosynthetics by High-Pressure Differential Scanning Calorimetry/ Q+ r0 Z) ^# z' a) j
D5886-95R01 Guide for Selection of Test Methods to Determine Rate of Fluid Permeation Through Geomembranes for Specific Applications1 I# ^, u, \+ W3 z) s' z
D5887-04 Test Method for Measurement of Index Flux Through Saturated Geosynthetic Clay Liner Specimens Using a Flexible Wall Permeameter S9 J# m0 t' K% T! ]% q3 _4 ^
D5888-95R02E01 Guide for Storage and Handling of Geosynthetic Clay Liners. g6 n6 H# }3 e
D5889-97R03 Practice for Quality Control of Geosynthetic Clay Liners; [* l$ k$ Q! h0 p
D5890-02 Test Method for Swell Index of Clay Mineral Component of Geosynthetic Clay Liners1 l1 d% Z' `+ p8 n: ]" \
D5891-02 Test Method for Fluid Loss of Clay Component of Geosynthetic Clay Liners8 |$ ~, o4 d/ {2 A! j2 \
D5970-96R02 Practice for Deterioration of Geotextiles from Outdoor Exposure
/ k1 x9 T4 d$ p r$ qD5993-99R04 Test Method for Measuring Mass Per Unit of Geosynthetic Clay Liners
! L- ^. g' w3 f! u* }" KD5994-98R03 Test Method for Measuring Core Thickness of Textured Geomembrane
1 X9 e# ~. Z1 }5 J" [D6072-96R02 Guide for Obtaining Samples of Geosynthetic Clay Liners
; g' U# U. P" ~' K, aD6088-97R02 Practice for Installation of Geocomposite Pavement Drains9 s k: i# a G. `7 l+ Q
D6102-04 Guide for Installation of Geosynthetic Clay Liners$ l" t/ H) U3 \; p) q( v
D6140-00 Method to Determine Asphalt Retention of Paving Fabrics Used in Asphalt Paving for Full-Width Applications
) |" H! _3 G, N/ z0 k: oD6141-97R04 Guide for Screening Clay Portion of Geosynthetic Clay Liner (GCL) for Chemical Compatibility to Liquids' ?; m8 | v, _
D6213-97R03 Practice for Tests to Evaluate the Chemical Resistance of Geogrids to Liquids( f/ U+ U9 M- U# n& P+ u) |
D6214-98R03 Test Method for Determining the Integrity of Field Seams Used in Joining Geomembranes by Chemical Fusion Methods
) ~3 \" @4 j* ]7 HD6241-04 Test Method for the Static Puncture Strength of Geotextiles and Geotextile-Related Products Using a 50-mm Probe6 b# K, R* `! _
D6243-98 Test Method for Determining the Internal and Interface Shear Resistance of Geosynthetic Clay Liner by the Direct Shear Method
( a5 _9 l* O0 @/ v J& G! xD6244-98R04 Test Method for Vertical Compression of Geocomposite Pavement Panel Drains% P& y: Z3 Z! e; }
D6364-99R04 Test Method for Determining Short-Term Compression Behavior of Geosynthetics
/ r( X7 }& z2 V6 v/ ~8 [# hD6365-99 Practice for the Nondestructive Testing of Geomembrane Seams using the Spark Test2 D3 p0 E- _0 \' j+ i1 |
D6388-99 Practice for Tests to Evaluate the Chemical Resistance of Geonets to Liquids
1 T0 p: y- o( W3 Q: a* h, cD6389-99 Practice for Tests to Evaluate the Chemical Resistance of Geotextiles to Liquids! D: [" [. n6 L! m( V$ d! j s
D6392-99 Test Method for Determining the Integrity of Nonreinforced Geomembrane Seams Produced Using Thermo-Fusion Methods8 @- Q1 Q( w' f2 ^2 Z
D6434-04 Guide for the Selection of Test Methods for Flexible Polypropylene (fPP) Geomembranes; `3 f6 k, b0 }9 t( u5 A. w( A* O
D6454-99 Test Method for Determining the Short-Term Compression Behavior of Turf Reinforcement Mats (TRMs)
" p4 _* b2 x( m8 LD6455-99 Guide for the Selection of Test Methods for Prefabricated Bituminous Geomembranes (PBGM)
; K- \& Y; J8 dD6495-02 Guide for Acceptance Testing Requirements for Geosynthetic Clay Liners
0 Q/ z# N" z6 Q6 b. A( T; | |, @D6496-04A Test Method for Determining Average Bonding Peel Strength Between Top and Bottom Layers of Needle-Punched Geosynthetic Clay Liners7 w. l$ N, W- `, }6 S( X9 K' G+ `
D6497-02 Guide for Mechanical Attachment of Geomembrane to Penetrations or Structures
" s6 K% t- x- ~* b+ q" i0 x! `D6523-00 Guide for Evaluation and Selection of Alternative Daily Covers (ADCs) for Sanitary Landfills! N1 N% I$ f& F5 o5 D8 \1 |
D6524-00 Test Method for Measuring the Resiliency of Turf Reinforcement Mats (TRMs)" P1 `& O; u7 e7 J7 w$ ?4 A+ J
D6525-00 Test Method for Measuring Nominal Thickness of Permanent Rolled Erosion Control Products
9 b/ N' @4 U; X4 @. m& XD6566-00 Test Method for Measuring Mass per Unit Area of Turf Reinforcement Mats
* m; M, ~$ l. B8 T/ n# E. kD6567-00 Test Method for Measuring the Light Penetration of a Turf Reinforcement Mat (TRM)
/ m# @9 q: \0 \0 bD6574-00 Test Method for Determining the (In-Plane) Hydraulic Transmissivity of a Geosynthetic by Radial Flow% n! C/ t. ?! L& Z0 T
D6575-00 Test Method for Determining Stiffness of Geosynthetics Used as Turf Reinforcement Mats (TRM's)
' U# E+ @2 K: ~& RD6636-01 Test Method for Determination of Ply Adhesion Strength of Reinforced Geomembranes
$ ]! V$ f9 J* g! l {D6637-01 Test Method for Determining Tensile Properties of Geogrids by the Single or Multi-Rib Tensile Method
0 O( v# @ y' E% \D6638-01 Test Method for Determining Connection Strength Between Geosynthetic Reinforcement and Segmental Concrete Units (Modular Concrete Blocks). Z" Y# }+ @. l. w, Q7 q! h
D6693-04 Test Method for Determining Tensile Properties of Nonreinforced Polyethylene and Nonreinforced Flexible Polypropylene Geomembranes# s" O$ _- W: b: v9 h% \' z
D6706-01 Test Method for Measuring Geosynthetic Pullout Resistance in Soil
5 b' o4 a' G' G* |( |- x$ ~* GD6707-01 Specification for Circular-Knit Geotextile for Use in Subsurface Drainage Applications H7 ?; V5 T7 R' K2 C v* }
D6747-04 Guide for Selection of Techniques for Electrical Detection of Potential Leak Paths in Geomembranes
6 `1 f$ h( z& X# N% RD6766-02 Test Method for Evaluation of Hydraulic Properties of Geosynthetic Clay Liners Permeated with Potentially Incompatible Liquids5 K7 V: O/ @, a b$ b# j
D6767-02 Test Method for Pore Size Characteristics of Geotextiles by Capillary Flow Test( @/ H( ?1 ?! S0 b6 g& ~$ [
D6768-04 Test Method for Tensile Strength of Geosynthetic Clay Liners
( z1 b# s+ z/ ?1 `D6817-04 Specification for Rigid Cellular Polystyrene Geofoam
3 P7 U, M" k8 I4 fD6818-02 Test Method for Ultimate Tensile Properties of Turf Reinforcement Mats
; f5 j( M2 r8 ND6826-02A Specification for Sprayed Slurries, Foams and Indigenous Materials Used As Alternative Daily Cover for Municipal Solid Waste Landfills% k5 e7 L+ s5 [% m9 C
D6916-03 Test Method for Determining the Shear Strength Between Segmental Concrete Units (Modular Concrete Blocks)9 N2 d3 t y+ b( r& ?
D6917-03 Guide for Selection of Test Methods for Prefabricated Vertical Drains (PVD)
* i6 g! F9 Y1 ^# c$ X6 B$ c+ mD6918-03 Test Method for Testing Vertical Strip Drains in the Crimped Condition$ x) q6 h% t- N8 j
D6992-03 Test Method for Accelerated Tensile Creep and Creep-Rupture of Geosynthetic Materials Based on Time-Temperature Superposition Using the Stepped Isothermal Method
- P2 c" l0 Q/ gD7001-04 Specification for Geocomposites for Pavement Edge Drains and Other High-Flow Applications' ?' M7 U5 ~2 d! l' \; u' [
D7002-03 Practice for Leak Location on Exposed Geomembranes Using the Water Puddle System
( ]( B/ S2 t' H+ A$ tD7003-03 Test Method for Strip Tensile Properties of Reinforced Geomembranes- ]; w" G$ e5 `
D7004-03 Test Method for Grab Tensile Properties of Reinforced Geomembranes
; Z5 J* @; r% ^! I& f1 ]- a& a6 k( ID7005-03 Test Method for Determining the Bond Strength (Ply Adhesion) of Geocomposites4 J; B3 O2 d b' c. L) u) w
D7006-03 Practice for Ultrasonic Testing of Geomembranes
! T) _# z( {' J8 P% G4 `7 X2 xD7007-03 Practices for Electrical Methods for Locating Leaks in Geomembranes Covered with Water or Earth Materials
) r i* v, r% |6 e6 xD7008-03 Specification for Geosynthetic Alternate Daily Covers
' D( B. P( K: c# A" K, l' FD7056-04 Test Method for Determining the Tensile Shear Strength of Pre-Fabricated Bituminous Geomembrane Seams
7 o; V' D: a# D$ P6 k: Q0 u v4 q8 D) G |
D 1987 – 95 ;RDE5ODCTOTU_.pdf
58.02 KB, Lượt tải về: 12, Tải điểm: Thưởng -2 điểm
D 1987 – 95 R02 ;RDE5ODC_.pdf
72.87 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4354 – 99 ;RDQZNTQ_.pdf
36.12 KB, Lượt tải về: 20, Tải điểm: Thưởng -2 điểm
D 4355 – 02 ;RDQZNTU_.pdf
42.82 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4355 – 99 ;RDQZNTUTUKVE.pdf
39.14 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
D 4437 – 99 ;RDQ0MZC_.pdf
20.97 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
D 4439 – 00 ;RDQ0MZKTMDA_.pdf
34.71 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 4439 – 01 ;RDQ0MZKTMDE_.pdf
60.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4439 – 01 ;RDQ0MZKTUKVE.pdf
36.74 KB, Lượt tải về: 14, Tải điểm: Thưởng -2 điểm
D 4439 – 02 ;RDQ0MZK_.pdf
58.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4491 – 99 ;RDQ0OTE_.pdf
83.34 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
D 4533 – 91 R96 ;RDQ1MZM_.pdf
44.88 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 4545 – 86 R99 ;RDQ1NDU_.pdf
32.28 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 4594 – 96 ;RDQ1OTQTOTY_.pdf
34.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4594 – 96 R03 ;RDQ1OTQ_.pdf
33.36 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4595 – 86 R01 ;RDQ1OTU_.pdf
117.44 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 4595 – 86 R94 ;RDQ1OTUTODZSOTQ_.pdf
90.01 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4632 – 91 R03 ;RDQ2MZI_.pdf
41.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4632 – 91 R96 ;RDQ2MZITOTFSOTY_.pdf
43.51 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4716 – 00 ;RDQ3MTYTMDA_.pdf
74.46 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4716 – 01 ;RDQ3MTYTMDE_.pdf
254.35 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 4716 – 02 ;RDQ3MTYTUKVE.pdf
88.26 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 4716 – 03 ;RDQ3MTY_.pdf
252.14 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 4751 – 99 ;RDQ3NTE_.pdf
126.29 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4759 – 02 ;RDQ3NTK_.pdf
28.98 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 4759 – 88 R96 ;RDQ3NTKTUKVE.pdf
25.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4833 – 00 ;RDQ4MZM_.pdf
113.69 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 4833 – 00 ;RDQ4MZMTMDA_.pdf
48.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4873 – 01 ;RDQ4NZMTMDE_.pdf
18.71 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4873 – 01 ;RDQ4NZMTUKVE.pdf
19.79 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4873 – 02 ;RDQ4NZM_.pdf
26.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4873 – 97 ;RDQ4NZMTOTC_.pdf
16.75 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4884 – 96 ;RDQ4ODQTOTY_.pdf
95.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4884 – 96 R03 ;RDQ4ODQ_.pdf
92.55 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
D 4885 – 01 ;RDQ4ODU_.pdf
98.92 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 4885 – 88 R95 ;RDQ4ODUTODHSOTU_.pdf
78.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4885 – 88 R95 ;RDQ4ODUTUKVE.pdf
83.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4886 – 88 R02 ;RDQ4ODY_.pdf
35.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4886 – 88 R95 ;RDQ4ODYTODHSOTVFMQ__.pdf
25.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5101 – 01 ;RDUXMDE_.pdf
118.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5101 – 99 ;RDUXMDETOTK_.pdf
100.48 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5101 – 99 ;RDUXMDETUKVE.pdf
107.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5141 – 96 ;RDUXNDE_.pdf
74.73 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 5199 – 01 ;RDUXOTK_.pdf
41.1 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5199 – 99 ;RDUXOTKTUKVE.pdf
32.22 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5261 – 92 R03 ;RDUYNJE_.pdf
28.01 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5261 – 92 R96 ;RDUYNJETOTJSOTY_.pdf
29.48 KB, Lượt tải về: 10, Tải điểm: Thưởng -2 điểm
D 5262 – 02 ;RDUYNJI_.pdf
86.64 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5262 – 97 ;RDUYNJITOTC_.pdf
87.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5262 – 97 ;RDUYNJITUKVE.pdf
73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5321 – 02 ;RDUZMJE_.pdf
64.33 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5321 – 92 R97 ;RDUZMJETOTJSOTC_.pdf
39.7 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 5321 – 92 R97 ;RDUZMJETUKVE.pdf
64.54 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 5322 – 98 ;RDUZMJITOTG_.pdf
36.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5322 – 98 R03 ;RDUZMJI_.pdf
35.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5323 – 92 R99 ;RDUZMJM_.pdf
40.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5397 – 99 ;RDUZOTC_.pdf
81.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5397 – 99 ;RDUZOTCTOTK_.pdf
84.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5493 – 93 R03 ;RDU0OTM_.pdf
63.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5493 – 93 R98 ;RDU0OTMTOTNSOTG_.pdf
66.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5494 – 93 R99 ;RDU0OTQ_.pdf
78.29 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5496 – 98 ;RDU0OTYTOTG_.pdf
35.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5496 – 98 R03 ;RDU0OTY_.pdf
33.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5514 – 94 ;RDU1MTQTOTQ_.pdf
26.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5514 – 94 R01 ;RDU1MTQ_.pdf
38.79 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5567 – 94 R01 ;RDU1NJC_.pdf
119.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5567 – 94 R99 ;RDU1NJCTOTRSOTK_.pdf
85.94 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5596 – 03 ;RDU1OTY_.pdf
73.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5596 – 94 ;RDU1OTYTOTQ_.pdf
169.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5596 – 94 ;RDU1OTYTUKVE.pdf
61.53 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5617 – 99 ;RDU2MTC_.pdf
50.32 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5641 – 94 ;RDU2NDETOTRFMQ__.pdf
46.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5641 – 94 R01 ;RDU2NDE_.pdf
62.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5721 – 95 ;RDU3MJETOTU_.pdf
28.85 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5721 – 95 R02 ;RDU3MJE_.pdf
28.37 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5747 – 95 ;RDU3NDCTOTVB.pdf
63.51 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5747 – 95a R02 ;RDU3NDC_.pdf
44.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5818 – 95 R00 ;RDU4MTG_.pdf
36.51 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5819 – 99 ;RDU4MTK_.pdf
81.13 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5820 – 95 ;RDU4MJATOTU_.pdf
31.07 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5820 – 95 R01 ;RDU4MJA_.pdf
48.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5884 – 01 ;RDU4ODQTMDE_.pdf
36.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5884 – 01 ;RDU4ODQTUKVE.pdf
28.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5884 – 04 ;RDU4ODQ_.pdf
36.39 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5884 – 99 ;RDU4ODQTOTK_.pdf
25.91 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5885 – 97 ;RDU4ODU_.pdf
47.87 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5886 – 95 ;RDU4ODYTOTU_.pdf
119.37 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5886 – 95 R01 ;RDU4ODY_.pdf
136.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5887 – 99 ;RDU4ODC_.pdf
69.53 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5888 – 95 ;RDU4ODGTOTU_.pdf
16.91 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5888 – 95 R02 ;RDU4ODG_.pdf
19.33 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5889 – 97 ;RDU4ODKTOTC_.pdf
28.6 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5889 – 97 R03 ;RDU4ODK_.pdf
27.58 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5890 – 01 ;RDU4OTATUKVE.pdf
21.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5890 – 02 ;RDU4OTA_.pdf
30.37 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5890 – 95 ;RDU4OTATOTU_.pdf
18.14 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5891 – 01 ;RDU4OTETUKVE.pdf
25.82 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5891 – 02 ;RDU4OTE_.pdf
35.31 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5891 – 95 ;RDU4OTETOTU_.pdf
22.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5970 – 96 ;RDU5NZATOTY_.pdf
38.38 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5970 – 96 R02 ;RDU5NZA_.pdf
36.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5993 – 99 ;RDU5OTM_.pdf
40.46 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5994 – 9 R03 ;RDU5OTQ_.pdf
40.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5994 – 98 ;RDU5OTQTOTG_.pdf
41.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6072 – 96 R02 ;RDYWNZI_.pdf
25.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6088 – 97 R02 ;RDYWODG_.pdf
151.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6102 – 97 ;RDYXMDI_.pdf
100.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6140 – 00 ;RDYXNDA_.pdf
31.74 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6140 – 97 ;RDYXNDATOTC_.pdf
20.91 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6140 – 97 ;RDYXNDATUKVE.pdf
24.78 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6141 – 97 ;RDYXNDE_.pdf
27.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6213 – 97 ;RDYYMTMTOTC_.pdf
42.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6213 – 97 R03 ;RDYYMTM_.pdf
42.5 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6214 – 98 ;RDYYMTQTOTG_.pdf
44.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6214 – 98 R03 ;RDYYMTQ_.pdf
42.76 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6214 – 98 R03 ;RDYYMTQTUKVE.pdf
32.79 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6241 – 99 ;RDYYNDE_.pdf
64.98 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6243 – 98 ;RDYYNDM_.pdf
58.97 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6244 – 98 ;RDYYNDQ_.pdf
64.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6364 – 99 ;RDYZNJQ_.pdf
62.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6365 – 99 ;RDYZNJU_.pdf
44 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6388 – 99 ;RDYZODG_.pdf
38.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6389 – 99 ;RDYZODK_.pdf
36.72 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6392 – 99 ;RDYZOTI_.pdf
82.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6434 – 99 ;RDY0MZQ_.pdf
33.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6454 – 99 ;RDY0NTQ_.pdf
42.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6455 – 99 ;RDY0NTU_.pdf
29.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6495 – 01 ;RDY0OTUTUKVE.pdf
23.57 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6495 – 02 ;RDY0OTU_.pdf
32.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6495 – 99 ;RDY0OTUTOTK_.pdf
21.32 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6496 – 03 ;RDY0OTY_.pdf
72.93 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6496 – 99 ;RDY0OTYTOTK_.pdf
43.76 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6496 – 99 ;RDY0OTYTUKVE.pdf
64.03 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6497 – 00 ;RDY0OTCTUKVE.pdf
215.4 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6497 – 02 ;RDY0OTC_.pdf
227.99 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6497 – 99 ;RDY0OTCTOTK_.pdf
194.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6523 – 00 ;RDY1MJM_.pdf
36.84 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6524 – 00 ;RDY1MJQ_.pdf
21.83 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6525 – 00 ;RDY1MJU_.pdf
20.46 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6566 – 00 ;RDY1NJY_.pdf
27.92 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6567 – 00 ;RDY1NJC_.pdf
35.43 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6574 – 00 ;RDY1NZQ_.pdf
67.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6575 – 00 ;RDY1NZU_.pdf
30.7 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6636 – 01 ;RDY2MZY_.pdf
21.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6637 – 01 ;RDY2MZC_.pdf
62.88 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6638 – 01 ;RDY2MZG_.pdf
88.59 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6693 – 01 ;RDY2OTMTUKVE.pdf
36.75 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6693 – 03 ;RDY2OTM_.pdf
53.37 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6706 – 01 ;RDY3MDY_.pdf
146.45 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6707 – 01 ;RDY3MDC_.pdf
23.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6747 – 02 ;RDY3NDC_.pdf
663.14 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6766 – 02 ;RDY3NJY_.pdf
165.17 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6767 – 02 ;RDY3NJC_.pdf
158.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6768 – 02 ;RDY3NJGTMDI_.pdf
31.83 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6768 – 02 ;RDY3NJGTUKVE.pdf
22.36 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6768 – 03 ;RDY3NJG_.pdf
30.22 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6817 – 02 ;RDY4MTC_.pdf
31.68 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6818 – 02 ;RDY4MTG_.pdf
30.39 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6826 – 02 ;RDY4MJY_.pdf
33.1 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6826 – 02 ;RDY4MJYTMDI_.pdf
34.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6826 – 02 ;RDY4MJYTUKVE.pdf
23.64 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6916 – 03 ;RDY5MTY_.pdf
71.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6917 – 03 ;RDY5MTC_.pdf
25.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6918 – 03 ;RDY5MTG_.pdf
116.92 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6992 – 03 ;RDY5OTI_.pdf
93.78 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 7001 – 04 ;RDCWMDE_.pdf
44.68 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 7002 – 03 ;RDCWMDI_.pdf
689.13 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 7003 – 03 ;RDCWMDM_.pdf
26.28 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 7004 – 03 ;RDCWMDQ_.pdf
25.91 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 7005 – 03 ;RDCWMDU_.pdf
35.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 7006 – 03 ;RDCWMDY_.pdf
531.55 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 7007 – 03 ;RDCWMDC_.pdf
129.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 7008 – 03 ;RDCWMDG_.pdf
35.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
