Xem: 9251|Trả lời: 0
ASTM 2004- Volume 05.01 Petroleum Products and Lubricants (I) D 56 - D 3230
D0056-02A Test Method for Flash Point by Tag Closed Cup Tester
+ k% L" D. S- vD0061-75R04 Test Method for Softening Point of Pitches (Cube-in-Water Method)
; q+ |- J5 B' ~3 D% d- G3 X/ B9 hD0071-94R04 Test Method for Relative Density of Solid Pitch and Asphalt (Displacement Method)
: T7 o) D9 T* \: vD0086-04B Test Method for Distillation of Petroleum Products at Atmospheric Pressure
) ?% \7 y# |# n4 D& S- Q+ a  p% qD0087-04 Test Method for Melting Point of Petroleum Wax (Cooling Curve)- Z- o# ^2 S: C$ g- s
D0091-02 Test Method for Precipitation Number of Lubricating Oils2 |" Z% l; b9 d1 ], {* Q" e
D0092-02B Test Method for Flash and Fire Points by Cleveland Open Cup Tester3 i  F' t" I. }! ?
D0093-02A Test Methods for Flash Point by Pensky-Martens Closed Cup Tester$ _( T2 q) T7 W- ^) m% ^! q4 k
D0094-02 Test Methods for Saponification Number of Petroleum Products4 G! p6 Y2 F5 a, o. ^! x
D0095-99E01 Test Method for Water in Petroleum Products and Bituminous Materials by Distillation
8 Y/ K. J1 G: G) ^5 Y- s) u; lD0097-04 Test Method for Pour Point of Petroleum Products
/ T  g, ]$ y  X% i* R- @D0127-87R04 Test Method for Drop Melting Point of Petroleum Wax Including Petrolatum2 G4 K# t1 w: @# q0 C6 ~
D0128-98R03E01 Test Methods for Analysis of Lubricating Grease
# H8 f6 C. e& S: F7 K& DD0129-00 Test Method for Sulfur in Petroleum Products (General Bomb Method)9 ~" B/ p7 Y% j* |
D0130-04 Test Method for Corrosiveness to Copper from Petroleum Products by Copper Strip Test7 \5 H* t2 T: L! Y
D0156-02 Test Method for Saybolt Color of Petroleum Products (Saybolt Chromometer Method)+ C. F  `: l; _, _& b. F5 e, F
D0187-94R03E01 Test Method for Burning Quality of Kerosine
" ~9 @, N- C4 c' @" T3 E. X6 G; C2 L! mD0189-01 Test Method for Conradson Carbon Residue of Petroleum Products
5 S& a0 I4 C. f$ I2 K% FD0217-02 Test Methods for Cone Penetration of Lubricating Grease
6 j: V0 p. E+ k0 f% BD0240-02 Test Method for Heat of Combustion of Liquid Hydrocarbon Fuels by Bomb Calorimeter
- e3 [' b1 L. m$ W" F: r& ND0287-92R00E01 Test Method for API Gravity of Crude Petroleum and Petroleum Products (Hydrometer Method)
: ~) r+ |8 s8 ]# {$ r, iD0322-97R02E01 Test Method for Gasoline Diluent in Used Gasoline Engine Oils by Distillation
: c8 u9 i  o4 g4 _5 M+ m4 h3 @D0323-99A Test Method for Vapor Pressure of Petroleum Products (Reid Method)
6 y9 o: e1 L6 G% {4 t+ ND0341-03 Test Method for Viscosity-Temperature Charts for Liquid Petroleum Products
; P9 ?% R" j" o) _D0381-04 Test Method for Gum Content in Fuels by Jet Evaporation
' h* k, a. K" }D0396-04 Specification for Fuel Oils
8 r/ @( j  o3 w9 v: k( `D0445-04E01 Test Method for Kinematic Viscosity of Transparent and Opaque Liquids (and the Calculation of Dynamic Viscosity)& S( Z* }2 j4 S
D0446-04 Specifications and Operating Instructions for Glass Capillary Kinematic Viscometers- R7 ^! |& K5 D7 n
D0473-02 Test Method for Sediment in Crude Oils and Fuel Oils by the Extraction Method- O1 [! M" g% j
D0482-03 Test Method for Ash from Petroleum Products
+ t0 t- M  g3 {  R4 _D0483-00 Test Method for Unsulfonated Residue of Petroleum Plant Spray Oils
6 o4 r& l+ t5 n+ j6 jD0524-04 Test Method for Ramsbottom Carbon Residue of Petroleum Products
) B& ^1 S/ U' {$ U: W- k5 |. ZD0525-01 Test Method for Oxidation Stability of Gasoline (Induction Period Method)6 c& t; ^3 n( j7 v  L
D0565-99 Test Method for Carbonizable Substances in White Mineral Oil. g' }! h( N+ _- B+ j! c" ^
D0566-02 Test Method for Dropping Point of Lubricating Grease
$ @- h5 t7 F( C. }; J+ S8 ?% U! c$ B4 @. cD0611-04 Test Methods for Aniline Point and Mixed Aniline Point of Petroleum Products and Hydrocarbon Solvents# `% O# j' D! P- ?5 J7 l
D0612-88R04 Test Method for Carbonizable Substances in Paraffin Wax
  _4 e+ [0 y6 {2 U, R) _D0664-04E01 Test Method for Acid Number of Petroleum Products by Potentiometric Titration
. w/ }( o3 F4 B. K) ?/ `, MD0665-03 Test Method for Rust-Preventing Characteristics of Inhibited Mineral Oil in the Presence of Water
+ R1 N& w( c  l5 `4 P, Z$ nD0721-04 Test Method for Oil Content of Petroleum Waxes
& b, n5 D3 I1 W5 [2 KD0808-00 Test Method for Chlorine in New and Used Petroleum Products (Bomb Method)
$ ?3 z' {2 D! m3 J" GD0873-02 Test Method for Oxidation Stability of Aviation Fuels (Potential Residue Method)) w* f9 E6 j) H9 Y6 Q
D0874-00 Test Method for Sulfated Ash from Lubricating Oils and Additives; j: ]! e8 F0 H, g* m- D8 J8 |
D0892-03 Test Method for Foaming Characteristics of Lubricating Oils
7 p% j) M' Y3 i, Q6 G' l9 n9 xD0893-97R02E01 Test Method for Insolubles\t In\t Used\t Lubricating\t Oils
7 m& G' T8 {$ ?D0910-04A Specification for Aviation Gasolines6 F0 J0 D. A3 \, @
D0937-04 Test Method for Cone Penetration of Petrolatum
: {  O; D4 U% D' e) h2 QD0938-04 Test Method for Congealing Point of Petroleum Waxes, Including Petrolatum" t/ B! a# ?8 j/ i5 g  c0 M4 g
D0942-02 Test Method for Oxidation Stability of Lubricating Greases by the Oxygen Pressure Vessel Method% a, m6 a+ d! Y3 R, m) D) L1 M) s
D0943-04A Test Method for Oxidation Characteristics of Inhibited Mineral Oils2 k5 }! {9 @/ N, _! u
D0972-02 Test Method for Evaporation Loss of Lubricating Greases and Oils
$ l6 Q8 A  K( e5 X: HD0974-04 Test Method for Acid and Base Number by Color-Indicator Titration2 l8 A3 I, ~  H, Y  A
D0975-04C Specification for Diesel Fuel Oils
! b) o: D2 R5 A. [" RD0976-04A Test Method for Calculated Cetane Index of Distillate Fuels. [4 F& i0 {+ Y
D1015-99R04 Test Method for Freezing Points of High-Purity Hydrocarbons
# x# [' I! j  X3 Q& LD1016-99R04E01 Test Method for Purity of Hydrocarbons from Freezing Points/ m* N1 X+ a% y
D1018-00 Test Method for Hydrogen In Petroleum Fractions
) ~' b! f" U+ F- H9 }/ g8 ^& v" G/ XD1025-00R04 Test Method for Nonvolatile Residue of Polymerization-Grade Butadiene
! ~+ k- n! o' x( RD1091-00 Test Methods for Phosphorus in Lubricating Oils and Additives- ?0 j  N+ `  i( g  _& J; C
D1092-99 Test Method for Measuring Apparent Viscosity of Lubricating Greases
3 M6 Q- S+ ^% v$ p( ?  |1 j. a8 eD1093-98 Test Method for Acidity of Hydrocarbon Liquids and Their Distillation Residues4 P# V0 i; Y9 O; j
D1094-00 Test Method for Water Reaction of Aviation Fuels
9 B& q$ q- `* B, ?# t4 d, c9 rD1157-91R04 Test Method for Total Inhibitor Content (TBC) of Light Hydrocarbons$ \- @* d9 E8 B7 L$ p8 a% ?
D1159-01 Test Method for Bromine Numbers of Petroleum Distillates and Commercial Aliphatic Olefins by Electrometric Titration
7 U" o1 B0 e4 B! v' \D1160-03 Test Method for Distillation of Petroleum Products at Reduced Pressure" C0 F- z0 w: n3 K$ z& c" B# Z1 @
D1217-93R03E01 Test Method for Density and Relative Density (Specific Gravity) of Liquids by Bingham Pycnometer2 H* {) X1 c3 K" o' U& C7 F1 X
D1218-02 Test Method for Refractive Index and Refractive Dispersion of Hydrocarbon Liquids
# _$ S3 i) I& K$ C7 wD1250-04 Guide for Use of the Petroleum Measurement Tables. u$ M5 z. A7 e8 l1 z6 R
D1263-94R99 Test Method for Leakage Tendencies of Automotive Wheel Bearing Greases
' s( ~6 o( H& t6 F8 P9 `" wD1264-03E01 Test Method for Determining the Water Washout Characteristics of Lubricating Greases
! M% L7 f( \' Y/ xD1265-04A Practice for Sampling Liquefied Petroleum (LP) Gases, Manual Method
; @! p' Y1 T) E; X) n, a8 [D1266-98R03E01 Test Method for Sulfur in Petroleum Products (Lamp Method)$ l- f. }) v' j: M; q9 e, T4 i
D1267-02 Test Method for Gage Vapor Pressure of Liquefied Petroleum (LP) Gases (LP-Gas Method)* o+ [( n, Z9 P! d- t8 [
D1298-99E02 Test Method for Density, Relative Density (Specific Gravity), or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method
( o+ G; X, V* kD1318-00 Test Method for Sodium in Residual Fuel Oil (Flame Photometric Method)0 l6 G  l( ^1 X: u
D1319-03 Test Method for Hydrocarbon Types in Liquid Petroleum Products by Fluorescent Indicator Adsorption
) l/ j2 q( g  S% a7 D; V0 wD1321-04 Test Method for Needle Penetration of Petroleum Waxes' c; e* T( q( ]8 f
D1322-97R02E01 Test Method for Smoke Point of Kerosine and Aviation Turbine Fuel
6 I& ^: l4 A' }8 ND1367-96R01 Test Method for Lubricating Qualities of Graphites: Z- [- t8 z6 H2 @8 N. e/ W% Q0 q
D1401-02 Test Method for Water Separability of Petroleum Oils and Synthetic Fluids' n* ^' y) z5 s
D1403-02 Test Methods for Cone Penetration of Lubricating Grease Using One-Quarter and One-Half Scale Cone Equipment$ q9 B  x, {" d: N4 _
D1404_D1404M-99R03 Test Method for Estimation of Deleterious Particles in Lubricating Grease1 m6 d& l/ M) N2 q
D1405-01 Test Method for Estimation of Net Heat of Combustion of Aviation Fuels9 ^! U  D1 b3 q
D1465-04 Test Method for Blocking and Picking Points of Petroleum Wax# {1 l1 V. T* J- i( t
D1478-02 Test Method for Low-Temperature Torque of Ball Bearing Grease' \6 k3 [, I( t
D1480-02 Test Method for Density and Relative Density (Specific Gravity) of Viscous Materials by Bingham Pycnometer9 t- V3 L$ g0 q7 }  ~, l1 N) X
D1481-02 Test Method for Density and Relative Density (Specific Gravity) of Viscous Materials by Lipkin Bicapillary Pycnometer
: E, i' g0 ^8 Y9 t$ u# @D1500-04A Test Method for ASTM Color of Petroleum Products (ASTM Color Scale)
' x: X+ D* |) v8 {. I5 {D1550-94R00 ASTM Butadiene Measurement Tables' M1 b. a5 ]( N: n! K
D1552-03 Test Method for Sulfur in Petroleum Products (High-Temperature Method)
" K9 q: M3 p" F; m$ X0 ?0 rD1655-04A Specification for Aviation Turbine Fuels# s! u2 e4 o# Z* {4 \) ?* f. e
D1657-02 Test Method for Density or Relative Density of Light Hydrocarbons by Pressure Hydrometer
0 A2 J8 q8 S8 O  L  ED1662-92R02 Test Method for Active Sulfur in Cutting Oils
6 u/ F  w! c4 R8 A7 eD1740-01 Test Method for Luminometer Numbers of Aviation Turbine Fuels4 |# _8 X. q, d" Z
D1742-94R00E01 Test Method for Oil Separation from Lubricating Grease During Storage! D% K2 [0 Z9 M
D1743-01 Test Method for Determining Corrosion Preventive Properties of Lubricating Greases& C5 ]/ q8 n4 l7 v2 r" o
D1747-99R04E01 Test Method for Refractive Index of Viscous Materials4 G* c4 |& l5 I! A
D1748-02 Test Method for Rust Protection by Metal Preservatives in the Humidity Cabinet
( d+ l/ }6 m5 P# X' TD1796-97R02 Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure)
6 S  s, ~: a2 F2 [D1831-00E01 Test Method for Roll Stability of Lubricating Grease, Z+ T0 t9 Y. j0 r/ Q
D1832-04 Test Method for Peroxide Number of Petroleum Wax) J% m  i: s0 X
D1833-87R04 Test Method for Odor of Petroleum Wax2 Q8 v: b9 p. o) Z# q0 j
D1834 Test Method for 20|SD Specular Gloss of Waxed Paper& R& z& U, i8 K6 K% q8 J6 s' I- R; A
D1835-03A Specification for Liquefied Petroleum (LP) Gases, f5 i% V5 l8 W3 ?
D1837-02A Test Method for Volatility of Liquefied Petroleum (LP) Gases  f9 L% m4 P  k% Z$ S
D1838-03 Test Method for Copper Strip Corrosion by Liquefied Petroleum (LP) Gases" r( H9 W8 ^# j. y, s+ X
D1839-91R00E01 Test Method for Amyl Nitrate in Diesel Fuels; T. Q$ e+ T2 A7 C
D1840-03 Test Method for Naphthalene Hydrocarbons in Aviation Turbine Fuels by Ultraviolet Spectrophotometry
; n+ `* D; X: ^4 T$ u* U5 ND2001-92R02 Test Method for Depentanization of Gasoline and Naphthas
  T2 o' Q& l+ ~" P2 w' m- gD2007-03 Test Method for Characteristic Groups in Rubber Extender and Processing Oils and Other Petroleum-Derived Oils by the Clay-Gel Absorption Chromatographic Method
, b7 d% P. J0 eD2008-91R01 Test Method for Ultraviolet Absorbance and Absorptivity of Petroleum Products
& J  J& Z( o3 C( fD2068-04 Test Method for Filter Plugging Tendency of Distillate Fuel Oils
4 x& [( B2 O+ aD2069 Specification for Marine Fuels% v+ D7 S3 E: O, Q3 S4 V
D2070-91R01 Test Method for Thermal Stability of Hydraulic Oils4 v3 I' m; u3 E0 }: ]
D2156-94R03 Test Method for Smoke Density in Flue Gases from Burning Distillate Fuels
+ N8 S+ j7 U# J- P) e5 ]! ^# `8 p' r5 ]D2157-94R03 Test Method for Effect of Air Supply on Smoke Density in Flue Gases from Burning Distillate Fuels2 C1 V5 I' X8 Y$ y4 U
D2158-04 Test Method for Residues in Liquefied Petroleum (LP) Gases
( ]3 V$ y( a' u" c7 ~2 E  MD2161-93R99E02 Practice for Conversion of Kinematic Viscosity to Saybolt Universal Viscosity or to Saybolt Furol Viscosity
  a- ~1 t) Q& |0 {8 k: \D2162-99R04 Test Method for Basic Calibration of Master Viscometers and Viscosity Oil Standards
3 l) \9 }' V" P2 A9 MD2163-91R96 Test Method for Analysis of Liquefied Petroleum (LP) Gases and Propene Concentrates by Gas Chromatography
& W) V. g9 x$ d( `4 o# wD2265-00 Test Method for Dropping Point of Lubricating Grease Over WideTemperature RangeD2266-01 Test Method for Wear Preventive Characteristics of Lubricating Grease (Four-Ball Method)! t0 C( w/ b8 x, G1 ]0 G8 Y
D2268-93R03E01 Test Method for Analysis of High-Purity -Heptane and octane by Capillary Gas Chromatography
$ C% w8 I2 z. @6 ED2269-99 Test Method for Evaluation of White Mineral Oils by Ultraviolet Absorption  P) H, t' c5 a! v1 Y- ]
D2270-04 Practice for Calculating Viscosity Index from Kinematic Viscosity at 40 and 100|SDC
% R1 s# [; |, N) ~5 f. KD2271 Test Method for Preliminary Examination of Hydraulic Fluids (Wear Test)
3 [1 o( r* r* ?5 [- TD2272-02 Test Method for Oxidation Stability of Steam Turbine Oils by Rotating Pressure Vessel
% D/ x& @+ r: V6 o# `7 f* a  h2 GD2273-97R02E02 Test Method for Trace Sediment in Lubricating Oils
2 |; x$ O/ `; D3 g7 i8 L5 U0 zD2274-03A Test Method for Oxidation Stability of Distillate Fuel Oil (Accelerated Method)
% B2 F% R: m3 Q, a3 L. OD2276-00 Test Method for Particulate Contaminant in Aviation Fuel by Line Sampling
; B( m% a9 c4 A' U% sD2318-98R03 Test Method for Quinoline-Insoluble (QI) Content of Tar and Pitch$ P2 e: @8 p* y' z
D2319-98R03 Test Method for Softening Point of Pitch (Cube-in-Air Method)7 G' {& o' M' t4 r
D2320-98R03 Test Method for Density (Relative Density) of Solid Pitch (Pycnometer Method)  h" M; l$ I  w) \8 z8 g8 |
D2384-83R04 Test Methods for Traces of Volatile Chlorides in Butane-Butene Mixtures0 @1 x. T8 F6 A3 i, W
D2386-03 Test Method for Freezing Point of Aviation Fuels" a2 F  v, |2 r
D2392-96R01E01 Test Method for Color Of Dyed Aviation Gasolines2 A0 O/ u4 b& A1 R2 N  l. m
D2415-98R03 Test Method for Ash in Coal Tar and Pitch
* L8 E: C% r& R8 DD2416-84R04 Test Method for Coking Value of Tar and Pitch (Modified Conradson)
0 K3 H2 T" y5 MD2420-91R01 Test Method for Hydrogen Sulfide In Liquefied Petroleum (LP) Gases (Lead Acetate Method); z) @( h1 v2 E; L$ K+ \, h6 o
D2421-02 Practice for Interconversion of Analysis of C and Lighter Hydrocarbons to Gas-Volume, Liquid-Volume, or Mass Basis
, @1 T2 ~& x- y* d( ^* p  Q, ED2422-97R02 Classification of Industrial Fluid Lubricants by Viscosity System
9 ~  p1 u' J' d. s! B# r7 [D2423-90R02 Test Method for Surface Wax on Waxed Paper or Paperboard
& k6 y8 v1 c& N, ~! y9 e- xD2425-04 Test Method for Hydrocarbon Types in Middle Distillates by Mass Spectrometry7 Q5 X* C7 g. K, r( E
D2426-93R04E01 Test Method for Butadiene Dimer and Styrene in Butadiene Concentrates by Gas Chromatography
2 K: N, B* X  U- X- `: A4 d9 Z: eD2427-92R01 Test Method for Determination of C through C Hydrocarbons in Gasolines by Gas Chromatography& e$ b7 P) q8 w
D2500-02E01 Test Method for Cloud Point of Petroleum Products, Z4 {2 `8 y& `
D2501-91R00 Test Method for Calculation of Viscosity-Gravity Constant (VGC) of Petroleum Oils
3 S! W$ M$ x' Z' E" J7 B, t% ^: ]D2502-04 Test Method for Estimation of Mean Relative Molecular Mass of Petroleum Oils from Viscosity Measurements
$ [2 c6 Y1 k' p( Y1 o/ MD2503-92R02E01 Test Method for Relative Molecular Mass (Molecular Weight) of Hydrocarbons by Thermoelectric Measurement of Vapor Pressure* a# s$ j8 }9 u# N; R" ~1 w
D2504-88R04E01 Test Method for Noncondensable Gases in C and Lighter Hydrocarbon Products by Gas Chromatography# @& W! b0 F! {) {, v% T
D2505-88R04E01 Test Method for Ethylene, Other Hydrocarbons, and Carbon Dioxide in High-Purity Ethylene by Gas Chromatography& x! ?" m, v0 H% W8 w0 F7 p
D2509-03 Test Method for Measurement of Load-Carrying Capacity of Lubricating Grease (Timken Method)
/ A5 ?! r7 \/ C0 n2 Y8 ~1 f  X6 S5 ]D2510-94R98 Test Method for Adhesion of Solid Film Lubricants" ?( b- ~: |8 R  h1 ^* s: |+ O
D2511-93R03 Test Method for Thermal Shock Sensitivity of Solid Film Lubricants
' ^0 X  F, m1 u8 z5 e1 ^D2532-03 Test Method for Viscosity and Viscosity Change After Standing at Low Temperature of Aircraft Turbine Lubricants
0 G6 P) m- O: K0 O& w& s" i1 ]D2533-99 Test Method for Vapor-Liquid Ratio of Spark-Ignition Engine Fuels
1 Y' m! M4 i, c$ aD2534-88R04 Test Method for Coefficient of Kinetic Friction for Wax Coatings# ?2 X5 x* y# l4 f2 R# }/ {3 S
D2549-02 Test Method for Separation of Representative Aromatics and Nonaromatics Fractions of High-Boiling Oils by Elution Chromatography
" O( R6 Q. U1 Z2 Z/ P: L( P7 {  OD2569-97R02 Test Method for Distillation of Pitch( l/ G4 j+ p3 x$ [. X
D2593-93R04E01 Test Method for Butadiene Purity and Hydrocarbon Impurities by Gas Chromatography
% D- u8 w" F0 U# f  H. k) \+ ^D2595-96R02E01 Test Method for Evaporation Loss of Lubricating Greases Over Wide-Temperature Range# Q7 Y: u% C! N- l/ v
D2596-97R02E01 Test Method for Measurement of Extreme-Pressure Properties of Lubricating Grease (Four-Ball Method)/ X) ?4 Q% V, T
D2597-94R04 Test Method for Analysis of Demethanized Hydrocarbon Liquid Mixtures Containing Nitrogen and Carbon Dioxide by Gas Chromatography
) g" A3 x  N- }2 `, H4 }D2598-02 Practice for Calculation of Certain Physical Properties of Liquefied Petroleum (LP) Gases from Compositional Analysis
; ~3 z/ i" x& Y) s' B( _" mD2603-01 Test Method for Sonic Shear Stability of Polymer-Containing Oils
9 C# R1 `* C( @6 H' x' s; N; P! ED2619-95R02E01 Test Method for Hydrolytic Stability of Hydraulic Fluids (Beverage Bottle Method); r2 m  u$ x% g4 e' l
D2622-03 Test Method for Sulfur in Petroleum Products by Wavelength Dispersive X-ray Fluorescence Spectrometry" I; a4 k/ s" \2 @" b+ p8 l
D2624-02 Test Methods for Electrical Conductivity of Aviation and Distillate Fuels9 N5 y7 [$ E/ j
D2625-94R03 Test Method for Endurance (Wear) Life and Load-Carrying Capacity of Solid Film Lubricants (Falex Pin and Vee Method)6 `* g  c0 z8 ^! G
D2638-91R02 Test Method for Real Density of Calcined Petroleum Coke by Helium Pycnometer1 L0 N# j) A# r4 E
D2649-04 Test Method for Corrosion Characteristics of Solid Film Lubricants
: o: n4 }: g. @( }+ r& s1 [9 JD2650-04 Test Method for Chemical Composition of Gases By Mass Spectrometry
$ D0 c( R8 ^1 W3 l2 UD2669 Test Method for Apparent Viscosity of Petroleum Waxes Compounded with Additives (Hot Melts)
; p7 H( W4 a; S9 o2 ?D2670-95R04 Test Method for Measuring Wear Properties of Fluid Lubricants (Falex Pin and Vee Block Method)2 {. l4 N" D, J/ c
D2709-96R01E01 Test Method for Water and Sediment in Middle Distillate Fuels by Centrifuge
1 I4 l1 x0 P% G$ N- }D2710-99R04E01 Test Method for Bromine Index of Petroleum Hydrocarbons by Electrometric Titration
, x4 S9 ]. D( J; u# W# e, CD2711-01A Test Method for Demulsibility Characteristics of Lubricating Oils, ^0 c% E4 _  Y( `3 C1 L
D2712-91R03E01 Test Method for Hydrocarbon Traces in Propylene Concentrates by Gas Chromatography
* a% T2 `/ M- W5 F( Y  O8 X2 S3 ]D2713-91R01 Test Method for Dryness of Propane (Valve Freeze Method)
+ A" N" |( _1 h; O. Y6 WD2714-94R03 Test Method for Calibration and Operation of the Falex Block-on-Ring Friction and Wear Testing Machine
* I" f  t6 A/ S" q/ Q+ x0 D- @D2715-92R02 Test Method for Volatilization Rates of Lubricants in Vacuum
" A  `  \! Q* W$ bD2717-95R00 Test Method for Thermal Conductivity of Liquids+ u2 h8 s) [+ \* U- C; K
D2764-99R04E01 Test Method for Dimethylformamide-Insoluble (DMF-I) Content of Tar and Pitch2 m; d  A/ ~0 Y% n" D1 Z
D2766-95R00 Test Method for Specific Heat of Liquids and Solids; b, N9 Q; z3 |* A+ q, {
D2779-92R02 Test Method for Estimation of Solubility of Gases in Petroleum Liquids4 E- {. k2 @% H4 @9 ^
D2780-92R02E01 Test Method for Solubility of Fixed Gases in Liquids6 E; j$ ^, E+ _; S& F
D2782-02 Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Timken Method)4 S% n4 w0 J  V! m: L/ k
D2783-03 Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Four-Ball Method)
; o; r) g7 w0 R% y  A( j: @( PD2784-98R03E01 Test Method for Sulfur in Liquefied Petroleum Gases (Oxy-Hydrogen Burner or Lamp)
% W/ v: u  \+ U6 UD2786-91R01E01 Test Method for Hydrocarbon Types Analysis of Gas-Oil Saturates Fractions by High Ionizing Voltage Mass Spectrometry+ h7 O. v/ U: C( X2 v1 V
D2789-95R00E01 Test Method for Hydrocarbon Types in Low Olefinic Gasoline by Mass Spectrometry6 M2 D6 D3 d% ^! S
D2878-95R00E01 Test Method for Estimating Apparent Vapor Pressures and Molecular Weights of Lubricating Oils- u+ s* Q0 M* c' H0 g' W
D2879-97R02E01 Test Method for Vapor Pressure-Temperature Relationship and Initial Decomposition Temperature of Liquids by Isoteniscope' c1 `  s' `" W( V2 k2 D8 F
D2880-03 Specification for Gas Turbine Fuel Oils
$ t! o4 t5 ?, @5 f/ d% yD2881-03 Classification for Metal Working Fluids and Related Materials
( i, ?) h2 }6 u! \2 QD2882 Test Method for Indicating Wear Characteristics of Petroleum and Non-Petroleum Hydraulic Fluids in Constant Volume Vane Pump
! h- K) j+ j/ J7 s# jD2883-95R00E01 Test Method for Reaction Threshold Temperature of Liquid and Solid Materials
. I, P6 b1 e" I" S% o& T1 PD2884-93R02 Test Method for Yield Stress of Heterogeneous Propellants by Cone Penetration Method: ]) B1 y& h3 s/ h" D" A
! u* w6 H. [; |7 n5 a' }' G" C, \5 `6 A
, ^/ k( y/ i* l! E+ `( ^3 V( ZD2887-04A Test Method for Boiling Range Distribution of Petroleum Fractions by Gas Chromatography. r/ z! @8 l1 r: P' I, F1 _/ V
D2889-95R00 Test Method for Calculation of True Vapor Pressures of Petroleum Distillate Fuels8 i9 \( i- {# U! f) q8 N2 }
D2890-92R03 Test Method for Calculation of Liquid Heat Capacity of Petroleum Distillate Fuels7 I3 J. m; Q9 `
D2892-03A Test Method for Distillation of Crude Petroleum (15-Theoretical Plate Column)
7 a  @4 e5 G/ B! _" P# ID2893-04 Test Methods for Oxidation Characteristics of Extreme-Pressure Lubrication Oils
+ p8 Z0 `8 |9 [" ]% H8 m( ?3 @% kD2895 Test Method for Gloss Retention of Waxed Paper and Paperboard After Storage at 40|SDC (104|SDF)
$ O1 G- U; V9 p& m$ w$ ?D2896-03 Test Method for Base Number of Petroleum Products by Potentiometric Perchloric Acid Titration
' l' R6 I3 k: r3 v) F: `D2962-97R02 Test Method for Calculating Volume-Temperature Correction For Coal-Tar Pitches
/ Z9 e$ U" ~! l3 w, _% ?D2981-94R03 Test Method for Wear Life of Solid Film Lubricants in Oscillating Motion
/ n. u* X4 @/ m( u$ MD2982-98E01 Test Methods for Detecting Glycol-Base Antifreeze in Used Lubricating Oils
( T* m2 e* \! k& V6 r( E9 P) xD2983-04A Test Method for Low-Temperature Viscosity of Lubricants Measured by Brookfield Viscometer, |/ c+ ?( \% v; q' Y+ U
D3104-99 Test Method for Softening Point of Pitches (Mettler Softening Point Method). n$ X' z$ _1 |" u- Z4 U6 U* q
D3115-95R00 Test Method for Explosive Reactivity of Lubricants with Aerospace Alloys Under High Shear
$ c& Q1 B$ u! P3 O$ @' vD3117-03 Test Method for Wax Appearance Point of Distillate Fuels  j( q" G- T) {" W8 s
D3120-03A Test Method for Trace Quantities of Sulfur in Light Liquid Petroleum Hydrocarbons by Oxidative Microcoulometry. k* T6 _) C' |% Q/ g; P+ Q2 T; ]: y
D3227-04A Test Method for (Thiol Mercaptan) Sulfur in Gasoline, Kerosine, Aviation Turbine, and Distillate Fuels (Potentiometric Method)
6 G. E  \8 |8 D/ `D3228-03 Test Method for Total Nitrogen in Lubricating Oils and Fuel Oils by Modified Kjeldahl Method
8 `+ N8 m4 A8 J( y( oD3230-99R04 Test Method for Salts in Crude Oil (Electrometric Method( S+ U6 E5 I6 a6 l, [
D 1015 – 99 ;RDEWMTUTOTK_.pdf
158.71 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 1015 – 99 R04 ;RDEWMTU_.pdf
156.89 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1016 – 99 ;RDEWMTYTOTK_.pdf
140.56 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 1016 – 99 R04 ;RDEWMTY_.pdf
150.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1018 – 00 ;RDEWMTG_.pdf
63.21 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1018 – 91 R95 ;RDEWMTGTUKVE.pdf
57.77 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1025 – 00 ;RDEWMJU_.pdf
25.9 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1025 – 96 ;RDEWMJUTOTY_.pdf
16.76 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1025 – 96 ;RDEWMJUTUKVE.pdf
20.06 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1091 – 00 ;RDEWOTE_.pdf
130.06 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1091 – 91 R95 ;RDEWOTETUKVE.pdf
121.41 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1092 – 99 ;RDEWOTI_.pdf
114.38 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1093 – 98 ;RDEWOTM_.pdf
27.73 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1094 – 00 ;RDEWOTQTUKVE.pdf
24.39 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1094 – 99 ;RDEWOTQ_.pdf
34.75 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1094 – 99 ;RDEWOTQTOTK_.pdf
22.9 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1157 – 91 R00 ;RDEXNTC_.pdf
39.37 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1159 – 01 ;RDEXNTK_.pdf
80.99 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1159 – 98 ;RDEXNTKTOTG_.pdf
57.19 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1159 – 98 ;RDEXNTKTUKVE.pdf
66.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1160 – 02 ;RDEXNJATMDJB.pdf
560.77 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 1160 – 02 ;RDEXNJATUKVE.pdf
478.18 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 1160 – 03 ;RDEXNJA_.pdf
288.79 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 1160 – 99 ;RDEXNJATOTK_.pdf
164.38 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 1217 – 93 R03 ;RDEYMTC_.pdf
90.99 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1217 – 93 R98 ;RDEYMTCTOTNSOTG_.pdf
83.51 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 1218 – 02 ;RDEYMTG_.pdf
59.41 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1218 – 99 ;RDEYMTGTUKVE.pdf
76.53 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1250 – 04 ;RDEYNTA_.pdf
64.79 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 1250 – 80 R02 ;RDEYNTATODBSMDI_.pdf
30.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1250 – 80 R02 ;RDEYNTATUKVE.pdf
57.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1250 – 80 R97 ;RDEYNTATODBSOTDFMQ__.pdf
23.27 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 1263 – 94 R99 ;RDEYNJM_.pdf
151.26 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1264 – 00 ;RDEYNJQTMDA_.pdf
56.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1264 – 03 ;RDEYNJQ_.pdf
62.1 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1264 – 03 ;RDEYNJQTMDM_.pdf
56.53 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1264 – 03 ;RDEYNJQTUKVE.pdf
46.44 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1264 – 96 ;RDEYNJQTOTY_.pdf
41.7 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1265 – 04 ;RDEYNJU_.pdf
51.28 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1265 – 97 ;RDEYNJUTOTC_.pdf
39.5 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1266 – 98 ;RDEYNJYTOTG_.pdf
142.98 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1266 – 98 R03 ;RDEYNJY_.pdf
146.46 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1267 – 02 ;RDEYNJC_.pdf
51.95 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1267 – 95 ;RDEYNJCTOTU_.pdf
36.43 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1267 – 95 R01 ;RDEYNJCTOTVSMDFFMQ__.pdf
38.45 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1267 – 95 R01 ;RDEYNJCTUKVE.pdf
43.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1298 – 99 ;RDEYOTG_.pdf
80.57 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1298 – 99 ;RDEYOTGTOTK_.pdf
99.51 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1298 – 99 ;RDEYOTGTOTLFMQ__.pdf
128.55 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 1318 – 00 ;RDEZMTG_.pdf
35.73 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1319 – 02 ;RDEZMTKTMDJB.pdf
104.92 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1319 – 02 ;RDEZMTKTUKVE.pdf
85.48 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1319 – 03 ;RDEZMTK_.pdf
106.49 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1319 – 99 ;RDEZMTKTOTK_.pdf
69.25 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1321 – 02 ;RDEZMJE_.pdf
47.32 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1321 – 02 ;RDEZMJETMDI_.pdf
49.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1321 – 02 ;RDEZMJETUKVE.pdf
36.95 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1322 – 97 ;RDEZMJITOTC_.pdf
117.67 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1322 – 97 R02 ;RDEZMJI_.pdf
104.21 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1367 – 96 ;RDEZNJCTOTY_.pdf
49.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1367 – 96 R01 ;RDEZNJC_.pdf
59.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1401 – 02 ;RDE0MDE_.pdf
51.01 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1401 – 98 ;RDE0MDETOTG_.pdf
48.34 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1401 – 98 ;RDE0MDETUKVE.pdf
41.59 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1403 – 02 ;RDE0MDM_.pdf
96.24 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1403 – 97 ;RDE0MDMTOTC_.pdf
82.54 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1403 – 97 ;RDE0MDMTUKVE.pdf
85.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1404 – 99 ;RDE0MDQTOTK_.pdf
160.83 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1404 – D 1404M – 99 R03 ;RDE0MDQVRDE0MDRN.pdf
64.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1405 – 01 ;RDE0MDU_.pdf
63.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1405 – 95 ;RDE0MDUTOTVB.pdf
36.53 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1405 – 95 ;RDE0MDUTUKVE.pdf
50.88 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 1465 – 90 R00 ;RDE0NJU_.pdf
93.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1465 – 90 R95 ;RDE0NJUTOTBSOTVFMQ__.pdf
83.46 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1478 – 02 ;RDE0NZG_.pdf
220.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 1478 – 91 R97 ;RDE0NZGTOTFSOTC_.pdf
205.6 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1478 – 91 R97 ;RDE0NZGTUKVE.pdf
214.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 1480 – 02 ;RDE0ODA_.pdf
96.61 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 1480 – 93 R97 ;RDE0ODATOTNSOTC_.pdf
97.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 1480 – 93 R97 ;RDE0ODATUKVE.pdf
88.93 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 1481 – 02 ;RDE0ODE_.pdf
88.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 1481 – 93 R97 ;RDE0ODETOTNSOTC_.pdf
89.36 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 1481 – 93 R97 ;RDE0ODETUKVE.pdf
191.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 1500 – 02 ;RDE1MDATMDI_.pdf
53.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 1500 – 03 ;RDE1MDA_.pdf
50.24 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 1500 – 98 ;RDE1MDATOTG_.pdf
49.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1500 – 98 ;RDE1MDATUKVE.pdf
43.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1550 – 94 R00 ;RDE1NTA_.pdf
66.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1552 – 00 ;RDE1NTITMDA_.pdf
58.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1552 – 01 ;RDE1NTITMDE_.pdf
66.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1552 – 01 ;RDE1NTITUKVE.pdf
71.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1552 – 03 ;RDE1NTI_.pdf
81.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 00 ;RDE2NTUTMDBB.pdf
133.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 00 ;RDE2NTUTMDBC.pdf
123.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 01 ;RDE2NTUTMDE_.pdf
131.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 02 ;RDE2NTUTMDI_.pdf
239.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 03 ;RDE2NTU_.pdf
151.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 03 ;RDE2NTUTMDM_.pdf
150.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1655 – 03 ;RDE2NTUTUKVE.pdf
134.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1657 – 02 ;RDE2NTC_.pdf
64.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1662 – 92 R02 ;RDE2NJI_.pdf
26.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1662 – 92 R97 ;RDE2NJITOTJSOTC_.pdf
27.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1740 – 01 ;RDE3NDA_.pdf
101.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1740 – 96 ;RDE3NDATOTY_.pdf
96.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1740 – 96 ;RDE3NDATUKVE.pdf
90.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1742 – 94 R00 ;RDE3NDI_.pdf
98.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1743 – 01 ;RDE3NDM_.pdf
147.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1743 – 94 ;RDE3NDMTOTRFMQ__.pdf
128.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1743 – 94 ;RDE3NDMTUKVE.pdf
138.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1747 – 99 ;RDE3NDCTOTK_.pdf
41.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1747 – 99 R04 ;RDE3NDC_.pdf
49.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1748 – 00 ;RDE3NDGTMDA_.pdf
146.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1748 – 00 ;RDE3NDGTUKVE.pdf
131.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1748 – 02 ;RDE3NDG_.pdf
142.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1748 – 83 R93 ;RDE3NDGTODNSOTNFMQ__.pdf
127.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1796 – 97 ;RDE3OTYTOTC_.pdf
53.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1796 – 97 ;RDE3OTYTOTDFMQ__.pdf
79.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1796 – 97 R02 ;RDE3OTY_.pdf
68.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1831 – 00 ;RDE4MZE_.pdf
55.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1831 – 00 ;RDE4MZETMDA_.pdf
36.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1831 – 94 ;RDE4MZETOTRFMQ__.pdf
37.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1832 – 87 R99 ;RDE4MZI_.pdf
30.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1833 – 87 R99 ;RDE4MZM_.pdf
31.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1834 – 90 R00 ;RDE4MZQ_.pdf
56.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1834 – 90 R95 ;RDE4MZQTOTBSOTVFMQ__.pdf
45.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1835 – 03 ;RDE4MZU_.pdf
38.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1835 – 03 ;RDE4MZUTMDM_.pdf
39.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1835 – 03 ;RDE4MZUTUKVE.pdf
32.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1835 – 97 ;RDE4MZUTOTC_.pdf
39.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1837 – 01 ;RDE4MZCTMDE_.pdf
46.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1837 – 02 ;RDE4MZC_.pdf
58.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1837 – 02 ;RDE4MZCTMDI_.pdf
59.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1837 – 02 ;RDE4MZCTUKVE.pdf
48.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1837 – 94 ;RDE4MZCTOTQ_.pdf
44.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1838 – 03 ;RDE4MZG_.pdf
45.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1838 – 91 R01 ;RDE4MZGTUKVE.pdf
43.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1838 – 91 R96 ;RDE4MZGTOTFSOTZFMG__.pdf
50.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1839 – 91 R00 ;RDE4MZK_.pdf
47.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1840 – 01 ;RDE4NDATMDE_.pdf
31.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1840 – 02 ;RDE4NDATMDI_.pdf
43.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1840 – 02 ;RDE4NDATUKVE.pdf
35.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1840 – 03 ;RDE4NDA_.pdf
45.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 1840 – 96 ;RDE4NDATOTY_.pdf
25.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2001 – 92 R02 ;RDIWMDE_.pdf
44.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2001 – 92 R97 ;RDIWMDETOTJSOTC_.pdf
44.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2007 – 01 ;RDIWMDCTMDE_.pdf
68.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2007 – 01 ;RDIWMDCTMDFB.pdf
76.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2007 – 02 ;RDIWMDCTMDI_.pdf
107.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2007 – 03 ;RDIWMDC_.pdf
89.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2007 – 98 ;RDIWMDCTOTG_.pdf
65.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2008 – 91 R01 ;RDIWMDG_.pdf
62.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2008 – 91 R96 ;RDIWMDGTOTFSOTZFMQ__.pdf
44.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2068 – 97 ;RDIWNJGTOTC_.pdf
62.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2068 – 97 R03 ;RDIWNJG_.pdf
61.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2070 – 91 R01 ;RDIWNZA_.pdf
45.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2070 – 91 R96 ;RDIWNZATOTFSOTY_.pdf
34.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2156 – 94 R03 ;RDIXNTY_.pdf
47.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2156 – 94 R99 ;RDIXNTYTOTRSOTK_.pdf
47.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2157 – 94 R03 ;RDIXNTC_.pdf
33.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2157 – 94 R99 ;RDIXNTCTOTRSOTK_.pdf
32.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2158 – 02 ;RDIXNTGTMDI_.pdf
65.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2158 – 02 ;RDIXNTGTUKVE.pdf
61.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2158 – 04 ;RDIXNTG_.pdf
67.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2158 – 97 ;RDIXNTGTOTDFMQ__.pdf
54.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2161 – 93 R99 ;RDIXNJE_.pdf
167.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2162 – 99 ;RDIXNJI_.pdf
92.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2162 – 99 ;RDIXNJITOTK_.pdf
64.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2163 – 91 R96 ;RDIXNJM_.pdf
85.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 2265 – 00 ;RDIYNJU_.pdf
91.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2265 – 94 ;RDIYNJUTOTRB.pdf
73.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2265 – 94 ;RDIYNJUTUKVE.pdf
83.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2266 – 01 ;RDIYNJY_.pdf
76.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2266 – 91 R96 ;RDIYNJYTOTFSOTY_.pdf
62.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2266 – 91 R96 ;RDIYNJYTUKVE.pdf
81.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2268 – 93 R03 ;RDIYNJG_.pdf
55.31 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2268 – 93 R98 ;RDIYNJGTOTNSOTG_.pdf
51.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2269 – 99 ;RDIYNJK_.pdf
43.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2270 – 93 R98 ;RDIYNZA_.pdf
71.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 2272 – 02 ;RDIYNZI_.pdf
231.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2272 – 98 ;RDIYNZITUKVE.pdf
221.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2273 – 97 ;RDIYNZMTOTC_.pdf
26.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2273 – 97 R02 ;RDIYNZM_.pdf
44.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 01 ;RDIYNZQTMDE_.pdf
46.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 01 ;RDIYNZQTMDFB.pdf
63.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 03 ;RDIYNZQ_.pdf
62.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 03 ;RDIYNZQTMDM_.pdf
61.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 03 ;RDIYNZQTUKVE.pdf
51.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2274 – 94 R99 ;RDIYNZQTOTRSOTLFMQ__.pdf
45.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2276 – 00 ;RDIYNZY_.pdf
131.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2276 – 99 ;RDIYNZYTUKVE.pdf
120.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2318 – 98 ;RDIZMTGTOTG_.pdf
36.49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2318 – 98 R03 ;RDIZMTG_.pdf
35.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2319 – 98 ;RDIZMTKTOTG_.pdf
34.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2319 – 98 R03 ;RDIZMTK_.pdf
33.5 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 2320 – 98 ;RDIZMJATOTG_.pdf
29.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2320 – 98 R03 ;RDIZMJA_.pdf
30.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2384 – 83 R00 ;RDIZODQ_.pdf
93.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2386 – 01 ;RDIZODYTMDE_.pdf
64.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2386 – 01 ;RDIZODYTUKVE.pdf
D 2386 – 03 ;RDIZODY_.pdf
D 2386 – 97 ;RDIZODYTOTC_.pdf
52.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2392 – 96 ;RDIZOTITOTY_.pdf
14.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2392 – 96 R01 ;RDIZOTI_.pdf
D 2415 – 98 ;RDI0MTUTOTG_.pdf
27.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2415 – 98 R03 ;RDI0MTU_.pdf
26.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2416 – 84 R99 ;RDI0MTY_.pdf
38.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2420 – 91 R01 ;RDI0MJA_.pdf
33.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2420 – 91 R96 ;RDI0MJATOTFSOTZFMQ__.pdf
26.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2421 – 01 ;RDI0MJETMDE_.pdf
21.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2421 – 01 ;RDI0MJETUKVE.pdf
26.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2421 – 02 ;RDI0MJE_.pdf
34.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2421 – 95 ;RDI0MJETOTU_.pdf
21.27 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2422 – 97 ;RDI0MJITOTC_.pdf
16.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2422 – 97 R02 ;RDI0MJI_.pdf
25.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2423 – 90 R02 ;RDI0MJM_.pdf
25.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2423 – 90 R97 ;RDI0MJMTOTBSOTC_.pdf
26.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2425 – 99 ;RDI0MJU_.pdf
60.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2426 – 93 R98 ;RDI0MJY_.pdf
32.03 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 2427 – 92 R01 ;RDI0MJC_.pdf
69.92 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2427 – 92 R96 ;RDI0MJCTOTJSOTY_.pdf
D 2500 – 02 ;RDI1MDA_.pdf
48.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2500 – 99 ;RDI1MDATUKVE.pdf
42.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2501 – 91 R00 ;RDI1MDE_.pdf
47.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2502 – 04 ;RDI1MDI_.pdf
49.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2502 – 92 R02 ;RDI1MDITOTJSMDI_.pdf
49.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2502 – 92 R02 ;RDI1MDITUKVE.pdf
69.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2502 – 92 R96 ;RDI1MDITOTJSOTY_.pdf
40.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2503 – 92 R02 ;RDI1MDM_.pdf
43.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2504 – 88 R98 ;RDI1MDQ_.pdf
48.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 2505 – 88 R98 ;RDI1MDU_.pdf
74.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2509 – 03 ;RDI1MDK_.pdf
127.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2509 – 93 R98 ;RDI1MDKTOTNSOTG_.pdf
128.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2509 – 93 R98 ;RDI1MDKTUKVE.pdf
166.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2510 – 94 R98 ;RDI1MTA_.pdf
31.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2511 – 93 R03 ;RDI1MTE_.pdf
25.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2511 – 93 R98 ;RDI1MTETOTNSOTHFMQ__.pdf
33.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2532 – 03 ;RDI1MZI_.pdf
50.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2532 – 93 R98 ;RDI1MZITOTNSOTG_.pdf
48.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2532 – 93 R98 ;RDI1MZITUKVE.pdf
45.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2533 – 99 ;RDI1MZM_.pdf
68.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2534 – 88 R04 ;RDI1MZQ_.pdf
41.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2534 – 88 R99 ;RDI1MZQTODHSOTK_.pdf
41.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2549 – 02 ;RDI1NDK_.pdf
59.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2549 – 91 R95 ;RDI1NDKTOTFSOTU_.pdf
41.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2549 – 91 R95 ;RDI1NDKTUKVE.pdf
51.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2569 – 97 ;RDI1NJKTOTC_.pdf
53.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2569 – 97 R02 ;RDI1NJK_.pdf
64.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2593 – 93 R98 ;RDI1OTM_.pdf
66.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2595 – 96 ;RDI1OTUTOTY_.pdf
54.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2595 – 96 R02 ;RDI1OTU_.pdf
74.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2596 – 97 ;RDI1OTYTOTC_.pdf
50.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2596 – 97 R02 ;RDI1OTY_.pdf
D 2597 – 94 R04 ;RDI1OTC_.pdf
194.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2597 – 94 R99 ;RDI1OTCTOTRSOTK_.pdf
193.47 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2598 – 02 ;RDI1OTG_.pdf
33.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2598 – 96 R01 ;RDI1OTGTOTZSMDE_.pdf
19.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2598 – 96 R01 ;RDI1OTGTUKVE.pdf
22.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2603 – 01 ;RDI2MDM_.pdf
40.09 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2603 – 98 ;RDI2MDMTOTG_.pdf
29.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2603 – 98 ;RDI2MDMTUKVE.pdf
30.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2619 – 95 ;RDI2MTKTOTU_.pdf
25.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2619 – 95 R02 ;RDI2MTK_.pdf
51.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2622 – 03 ;RDI2MJI_.pdf
82.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2622 – 98 ;RDI2MJITOTG_.pdf
81.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2622 – 98 ;RDI2MJITUKVE.pdf
59.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2624 – 00 ;RDI2MJQTMDA_.pdf
46.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2624 – 01 ;RDI2MJQTUKVE.pdf
55.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2624 – 02 ;RDI2MJQ_.pdf
68.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2625 – 94 R03 ;RDI2MJU_.pdf
153.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2625 – 94 R98 ;RDI2MJUTOTRSOTG_.pdf
168.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2638 – 91 R02 ;RDI2MZG_.pdf
30.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2638 – 91 R97 ;RDI2MZGTOTFSOTC_.pdf
31.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2649 – 99 ;RDI2NDK_.pdf
44.57 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 2650 – 99 ;RDI2NTA_.pdf
60.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2669 – 87 R99 ;RDI2NJK_.pdf
52.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2670 – 95 R99 ;RDI2NZA_.pdf
97.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2709 – 96 ;RDI3MDKTOTZFMG__.pdf
22.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2709 – 96 R01 ;RDI3MDK_.pdf
38.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2710 – 99 ;RDI3MTATOTK_.pdf
42.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2710 – 99 R04 ;RDI3MTA_.pdf
50.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2711 – 01 ;RDI3MTE_.pdf
139.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2711 – 01 ;RDI3MTETMDE_.pdf
126 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2711 – 01 ;RDI3MTETUKVE.pdf
128.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2711 – 99 ;RDI3MTETOTK_.pdf
124.63 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2712 – 91 R03 ;RDI3MTI_.pdf
79.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2712 – 91 R96 ;RDI3MTITOTFSOTY_.pdf
74.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2713 – 91 R01 ;RDI3MTM_.pdf
27.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2713 – 91 R95 ;RDI3MTMTOTFSOTVFMQ__.pdf
19.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2714 – 94 R03 ;RDI3MTQ_.pdf
59.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2714 – 94 R98 ;RDI3MTQTOTRSOTG_.pdf
61.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2715 – 92 R02 ;RDI3MTU_.pdf
58.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2715 – 92 R97 ;RDI3MTUTOTJSOTC_.pdf
59.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2717 – 95 ;RDI3MTCTOTU_.pdf
34.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2717 – 95 R00 ;RDI3MTC_.pdf
48.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2764 – 99 ;RDI3NJQ_.pdf
33.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2766 – 95 ;RDI3NJYTOTU_.pdf
72.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2766 – 95 R00 ;RDI3NJY_.pdf
102.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2779 – 92 R02 ;RDI3NZK_.pdf
84.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2779 – 92 R97 ;RDI3NZKTOTJSOTC_.pdf
84.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2780 – 92 R02 ;RDI3ODA_.pdf
95.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2780 – 92 R97 ;RDI3ODATOTJSOTC_.pdf
87.83 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2782 – 01 ;RDI3ODITMDE_.pdf
230.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2782 – 01 ;RDI3ODITUKVE.pdf
183.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2782 – 02 ;RDI3ODI_.pdf
147.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2782 – 94 R96 ;RDI3ODITOTRSOTY_.pdf
114.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2783 – 03 ;RDI3ODM_.pdf
135.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2783 – 88 R98 ;RDI3ODMTODHSOTG_.pdf
136.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2783 – 88 R98 ;RDI3ODMTUKVE.pdf
306.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2784 – 98 ;RDI3ODQTOTG_.pdf
90.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2784 – 98 R03 ;RDI3ODQ_.pdf
94.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2786 – 91 R01 ;RDI3ODY_.pdf
66.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2786 – 91 R96 ;RDI3ODYTOTFSOTY_.pdf
36.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2789 – 95 ;RDI3ODKTOTU_.pdf
41.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2789 – 95 R00 ;RDI3ODK_.pdf
74.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2878 – 95 ;RDI4NZGTOTU_.pdf
56.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2878 – 95 R00 ;RDI4NZG_.pdf
86.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2879 – 97 ;RDI4NZKTOTC_.pdf
84.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2879 – 97 R02 ;RDI4NZK_.pdf
90.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2880 – 00 ;RDI4ODATMDA_.pdf
58.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2880 – 00 ;RDI4ODATUKVE.pdf
D 2880 – 03 ;RDI4ODA_.pdf
57.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2880 – 98 ;RDI4ODATOTG_.pdf
38.87 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2881 – 03 ;RDI4ODE_.pdf
31.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2883 – 95 ;RDI4ODMTOTU_.pdf
138.91 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2883 – 95 R00 ;RDI4ODM_.pdf
174.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2884 – 93 R02 ;RDI4ODQ_.pdf
61.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2884 – 93 R98 ;RDI4ODQTOTNSOTG_.pdf
62.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2887 – 01 ;RDI4ODCTMDE_.pdf
84.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2887 – 01 ;RDI4ODCTMDFB.pdf
93.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2887 – 02 ;RDI4ODCTMDI_.pdf
116.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2887 – 03 ;RDI4ODCTMDM_.pdf
119.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2887 – 03 ;RDI4ODCTUKVE.pdf
91.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2887 – 04 ;RDI4ODC_.pdf
119.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2887 – 99 ;RDI4ODCTOTK_.pdf
83.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2889 – 95 R00 ;RDI4ODK_.pdf
155.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2890 – 92 R03 ;RDI4OTA_.pdf
95.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2890 – 92 R96 ;RDI4OTATOTJSOTY_.pdf
88.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2892 – 01 ;RDI4OTITMDE_.pdf
650.57 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 2892 – 03 ;RDI4OTI_.pdf
627.35 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 2892 – 03 ;RDI4OTITMDM_.pdf
634.89 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2892 – 03 ;RDI4OTITUKVE.pdf
572.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2892 – 99 ;RDI4OTITOTLB.pdf
647.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2893 – 03 ;RDI4OTMTMDM_.pdf
39.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2893 – 03 ;RDI4OTMTUKVE.pdf
32.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2893 – 04 ;RDI4OTM_.pdf
D 2893 – 99 ;RDI4OTMTOTK_.pdf
38.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2895 – 88 R99 ;RDI4OTU_.pdf
24.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2896 – 01 ;RDI4OTYTMDE_.pdf
54.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2896 – 01 ;RDI4OTYTMDFFMQ__.pdf
89.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2896 – 01 ;RDI4OTYTUKVE.pdf
60.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2896 – 03 ;RDI4OTY_.pdf
82.37 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2896 – 98 ;RDI4OTYTOTG_.pdf
50.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2962 – 97 ;RDI5NJITOTC_.pdf
15.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2962 – 97 ;RDI5NJITUKVE.pdf
15.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2962 – 97 R02 ;RDI5NJI_.pdf
22.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2981 – 94 R03 ;RDI5ODE_.pdf
38.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2981 – 94 R98 ;RDI5ODETOTRSOTG_.pdf
D 2982 – 98 ;RDI5ODI_.pdf
56.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2982 – 98 ;RDI5ODITOTG_.pdf
33.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2983 – 02 ;RDI5ODMTMDJB.pdf
103.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2983 – 02 ;RDI5ODMTMDJC.pdf
102.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2983 – 03 ;RDI5ODMTMDM_.pdf
100.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2983 – 04 ;RDI5ODM_.pdf
107.19 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2983 – 04 ;RDI5ODMTMDQ_.pdf
107.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 2983 – 04 ;RDI5ODMTUKVE.pdf
87.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 2983 – 87 R93 ;RDI5ODMTODDSOTM_.pdf
77.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3104 – 99 ;RDMXMDQ_.pdf
107.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3115 – 95 ;RDMXMTUTOTU_.pdf
26.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3115 – 95 R00 ;RDMXMTU_.pdf
37.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3117 – 03 ;RDMXMTC_.pdf
323.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3117 – 96 ;RDMXMTCTOTZFMQ__.pdf
333.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3117 – 96 ;RDMXMTCTUKVE.pdf
322.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3120 – 03 ;RDMXMJA_.pdf
96.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3120 – 03 ;RDMXMJATMDM_.pdf
99.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3120 – 03 ;RDMXMJATUKVE.pdf
77.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3120 – 96 ;RDMXMJATOTY_.pdf
65.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3227 – 00 ;RDMYMJCTMDA_.pdf
53.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3227 – 02 ;RDMYMJCTMDI_.pdf
77.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3227 – 02 ;RDMYMJCTMDJB.pdf
80.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3227 – 02 ;RDMYMJCTUKVE.pdf
56.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3227 – 04 ;RDMYMJC_.pdf
80.57 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3228 – 01 ;RDMYMJGTMDE_.pdf
44.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3228 – 01 ;RDMYMJGTUKVE.pdf
36.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3228 – 03 ;RDMYMJG_.pdf
47.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3228 – 96 ;RDMYMJGTOTY_.pdf
27.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3230 – 99 ;RDMYMZATOTK_.pdf
72.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 3230 – 99 R04 ;RDMYMZA_.pdf
71.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 56 – 00 ;RDU2LTAW.pdf
107.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 56 – 02 ;RDU2.pdf
129.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 56 – 02 ;RDU2LTAY.pdf
185.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 56 – 02 ;RDU2LVJFRA__.pdf
156.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 61 – 75 R99 ;RDYX.pdf
39.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 71 – 94 R99 ;RDCX.pdf
26.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 86 – 00 ;RDG2LTAWQQ__.pdf
282.78 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 86 – 01 ;RDG2LTAX.pdf
283.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 86 – 01 ;RDG2LTAXRTE_.pdf
717.64 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 86 – 02 ;RDG2LTAY.pdf
709.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 86 – 03 ;RDG2LTAZ.pdf
342.51 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 86 – 04 ;RDG2.pdf
356.99 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 86 – 04 ;RDG2LTA0.pdf
340.49 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 86 – 04 ;RDG2LTA0QQ__.pdf
342.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 86 – 04 ;RDG2LVJFRA__.pdf
304.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 87 – 87 R99 ;RDG3.pdf
39.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 91 – 02 ;RDKX.pdf
33.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 91 – 97 ;RDKXLVJFRA__.pdf
28.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 92 – 02 ;RDKY.pdf
110.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 92 – 02 ;RDKYLTAY.pdf
149.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 92 – 02 ;RDKYLTAYQQ__.pdf
151.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 92 – 02 ;RDKYLVJFRA__.pdf
131.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 92 – 98 ;RDKYLTK4QQ__.pdf
70 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 93 – 02 ;RDKZ.pdf
193.62 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 93 – 02 ;RDKZLTAY.pdf
202.93 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 93 – 02 ;RDKZLVJFRA__.pdf
186.23 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 94 – 00 ;RDK0LVJFRA__.pdf
105.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 94 – 02 ;RDK0.pdf
105.59 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 95 – 99 ;RDK1.pdf
74.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 95 – 99 ;RDK1LTK5.pdf
66.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 97 – 02 ;RDK3LTAY.pdf
133.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 97 – 02 ;RDK3LVJFRA__.pdf
123.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 97 – 04 ;RDK3.pdf
132.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 97 – 96 ;RDK3LTK2QQ__.pdf
118.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 127 – 87 R99 ;RDEYNW__.pdf
D 128 – 98 ;RDEYOC05OA__.pdf
131.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 128 – 98 R03 ;RDEYOA__.pdf
135.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 128 – 98 R03 ;RDEYOC1SRUQ_.pdf
112.28 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 129 – 00 ;RDEYOQ__.pdf
45.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 130 – 04 ;RDEZMA__.pdf
201.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 130 – 94 R00 ;RDEZMC05NFIWMEUX.pdf
91.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 156 – 00 ;RDE1NI0WMA__.pdf
67.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 156 – 00 ;RDE1NI1SRUQ_.pdf
96.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 156 – 02 ;RDE1NG__.pdf
80.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 187 – 94 R03 ;RDE4NW__.pdf
60.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 187 – 94 R99 ;RDE4NY05NFI5OQ__.pdf
55.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 189 – 01 ;RDE4OQ__.pdf
116.27 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 189 – 97 ;RDE4OS1SRUQ_.pdf
105.19 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 189 – 97 ;RDE4OS05NW__.pdf
101.29 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 217 – 02 ;RDIXNW__.pdf
240.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 217 – 97 ;RDIXNY1SRUQ_.pdf
474.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 217 – 97 ;RDIXNY05NW__.pdf
209.35 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 240 – 00 ;RDI0MC1SRUQ_.pdf
65.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 240 – 02 ;RDI0MA__.pdf
D 240 – 92 R97 ;RDI0MC05MLI5N0UY.pdf
56.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 287 – 92 R00 ;RDI4NW__.pdf
41.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 322 – 97 ;RDMYMI05NW__.pdf
42.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 322 – 97 R02 ;RDMYMG__.pdf
59.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 323 – 99 ;RDMYMW__.pdf
115.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 341 – 03 ;RDM0MQ__.pdf
252.67 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 341 – 93 R98 ;RDM0MS05M1I5OA__.pdf
307.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 381 – 00 ;RDM4MS0WMA__.pdf
56.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 381 – 01 ;RDM4MS0WMQ__.pdf
80.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 381 – 01 ;RDM4MS1SRUQ_.pdf
66.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 381 – 03 ;RDM4MQ__.pdf
81.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 396 – 02 ;RDM5NG__.pdf
50.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 396 – 02 ;RDM5NI0WMG__.pdf
50.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 396 – 02 ;RDM5NI1SRUQ_.pdf
37.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 396 – 98 ;RDM5NI05OA__.pdf
30.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 445 – 01 ;RDQ0NS0WMQ__.pdf
84.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 445 – 03 ;RDQ0NS0WMW__.pdf
97.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 445 – 04 ;RDQ0NQ__.pdf
89.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 445 – 97 ;RDQ0NS05NW__.pdf
57.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 446 – 00 ;RDQ0NI1SRUQ_.pdf
185.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 446 – 04 ;RDQ0NG__.pdf
217.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 446 – 97 ;RDQ0NI05N0UX.pdf
179.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 473 – 02 ;RDQ3MW__.pdf
72.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 473 – 81 R95 ;RDQ3MY1SRUQ_.pdf
109.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 482 – 00 ;RDQ4MI0WMEE_.pdf
26.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 482 – 00 ;RDQ4MI0WMEFFMQ__.pdf
48.52 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 482 – 02 ;RDQ4MI0WMG__.pdf
41.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 482 – 02 ;RDQ4MI1SRUQ_.pdf
31.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 482 – 03 ;RDQ4MG__.pdf
39.23 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 483 – 00 ;RDQ4MW__.pdf
66.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 483 – 97 ;RDQ4MY1SRUQ_.pdf
94.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 524 – 00 ;RDUYNC0WMA__.pdf
124.59 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 524 – 00 ;RDUYNC0WMEUX.pdf
226.77 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 524 – 00 ;RDUYNC1SRUQ_.pdf
195.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 524 – 03 ;RDUYNA__.pdf
145.19 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 525 – 00 ;RDUYNS0WMA__.pdf
61.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 525 – 00 ;RDUYNS1SRUQ_.pdf
64.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 525 – 01 ;RDUYNQ__.pdf
82.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 565 – 99 ;RDU2NQ__.pdf
49.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 566 – 02 ;RDU2NG__.pdf
61.32 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 566 – 97 ;RDU2NI1SRUQ_.pdf
59.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 566 – 97 ;RDU2NI05N0UX.pdf
49.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 566 – 97 ;RDU2NI05NW__.pdf
D 611 – 01 ;RDYXMS0WMQ__.pdf
75.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 611 – 01 ;RDYXMS0WMUE_.pdf
69.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 611 – 01 ;RDYXMS0WMUI_.pdf
84.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 611 – 01 ;RDYXMS1SRUQ_.pdf
74.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 611 – 04 ;RDYXMQ__.pdf
83.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 611 – 82 R98 ;RDYXMS04MLI5OA__.pdf
71.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 612 – 88 R99 ;RDYXMG__.pdf
52.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 664 – 01 ;RDY2NC0WMQ__.pdf
79.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 664 – 01 ;RDY2NC1SRUQ_.pdf
82.82 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 664 – 04 ;RDY2NA__.pdf
73.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 664 – 95 ;RDY2NC05NQ__.pdf
56.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 665 – 02 ;RDY2NS0WMG__.pdf
112.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 665 – 02 ;RDY2NS1SRUQ_.pdf
97.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 665 – 03 ;RDY2NQ__.pdf
111.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 665 – 99 ;RDY2NS05OQ__.pdf
96.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 721 – 02 ;RDCYMQ__.pdf
97.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 721 – 02 ;RDCYMS0WMG__.pdf
98.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 721 – 02 ;RDCYMS1SRUQ_.pdf
85.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 721 – 97 ;RDCYMS05NW__.pdf
83.59 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 808 – 00 ;RDGWOA__.pdf
42.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 873 – 02 ;RDG3MW__.pdf
50.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 873 – 99 ;RDG3MY1SRUQ_.pdf
36.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 873 – 99 ;RDG3MY05OUE_.pdf
31.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 874 – 00 ;RDG3NA__.pdf
45.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
Số người tham gia 1Uy tín +2 Thanked +1 Thu lại Lý do
taimienphix + 2 + 1 Cảm ơn chia sẻ của bạn nhiều!
GMT+7, 17/11/2026 12:23 , Processed in 0.167053 second(s), 22 queries .
