Xem: 8009|Trả lời: 0
ASTM 2004- Volume 05.02 Petroleum Products and Lubricants (II) D 3231 - D 5302
3 l1 U' H4 M- G( W  S; Z: ]
9 N7 L3 |& N) ~- {D3231-02 Test Method for Phosphorus in Gasoline. G5 k& H3 T- {) q
D3233-93R03 Test Methods for Measurement of Extreme Pressure Properties of Fluid Lubricants (Falex Pin and Vee Block Methods)
  S  [, K) E! z2 V. ZD3234 Test Method for Abrasion Resistance of Petroleum Wax Coatings
8 f- \' C7 Z( s2 t$ cD3235-04 Test Method for Solvent Extractables in Petroleum Waxes
1 H) ]# w6 ?, D! h9 {% s1 iD3236-88R04 Test Method for Apparent Viscosity of Hot Melt Adhesives and Coating Materials
9 D# o3 J2 C1 P5 CD3237-02 Test Method for Lead In Gasoline By Atomic Absorption Spectroscopy
7 B# Z3 o. C' \4 JD3238-95R00E01 Test Method for Calculation of Carbon Distribution and Structural Group Analysis of Petroleum Oils by the n-d-M Method
( [3 Q  v3 A* ~# B& U8 {: [D3239-91R01 Test Method for Aromatic Types Analysis of Gas-Oil Aromatic Fractions by High Ionizing Voltage Mass Spectrometry9 F* b. H6 A4 @& O' `5 J9 H
D3240-91R01 Test Method for Undissolved Water In Aviation Turbine Fuels( E7 E- j; B, g! H
D3241-04 Test Method for Thermal Oxidation Stability of Aviation Turbine Fuels (JFTOT Procedure)
  `4 [" b" J- _D3242-01 Test Method for Acidity in Aviation Turbine Fuel+ S. W1 k; _# N: N" R3 \
D3244-97R02 Practice for Utilization of Test Data to Determine Conformance with Specifications
, ?6 t. f/ W: Y2 F# L3 m/ R5 Z: h" R; U: }D3245-03 Test Method for Pumpability of Industrial Fuel Oils; b2 d# I, _% K) U4 C- `: d
D3246-96 Standard Test Method for Sulfur in Petroleum Gas by Oxidative Microcoulometry2 g4 T9 `5 ?* W' m
D3336-97R02E01 Test Method for Life of Lubricating Greases in Ball Bearings at Elevated Temperatures' ^/ K) F& E2 ]! C% n7 y/ s0 ~& u
D3338-04 Test Method for Estimation of Net Heat of Combustion of Aviation Fuels  F) c. ?  \) r% y
D3339-04 Test Method for Acid Number of Petroleum Products by Semi-Micro Color Indicator Titration
4 V2 B) V% I) o# CD3340-98R03 Test Method for Lithium and Sodium in Lubricating Greases by Flame Photometer
( K5 f4 N6 e  k2 d, l1 O* JD3341-00 Test Method for Lead in Gasoline\MIodine Monochloride Method
2 O/ e5 `: l! V2 z3 e" a4 zD3342-90R00E01 Test Method for Dispersion Stability of New (Unused) Rolling Oil Dispersions in Water) M( z9 p& F7 ~" [9 d
D3343-95R00 Test Method for Estimation of Hydrogen Content of Aviation Fuels% z& w. z& u5 N4 ~7 x8 W
D3344-90R00E01 Test Method for Total Wax \tContent \tof \tCorrugated \tPaperboard
6 K- i2 p7 f& v) T7 FD3348-98R03E01 Test Method for Rapid Field Test for Trace Lead in Unleaded Gasoline (Colorimetric Method)
+ O; I" o: [% c% I. c- U2 BD3427-03 Test Method for Air Release Properties of Petroleum Oils# \" c) `2 |# `- Z" m
D3429-93R02E01 Test Method for Solubility of Fixed Gases in Low-Boiling Liquids+ z0 u7 Z2 i; o2 z
D3461-97R02 Test Method for Softening Point of Asphalt and Pitch (Mettler Cup-and-Ball Method)
# g. n9 o6 {" N3 @D3519-88R02 Test Method for Foam in Aqueous Media (Blender Test)
  h6 k' O% U! L6 w; I5 w4 A* }7 ?D3520-04 Test Method for Quenching Time of Heat-Treating Fluids (Magnetic Quenchometer Method)+ }% x1 A7 v6 E: h% m. E
D3521-86R02 Test Method for Surface Wax Coating On Corrugated Board
6 u# l8 I0 \8 @% p3 v$ M* K; [D3522-86R02E01 Test Method for Applied Coating Wax and Impregnating (Saturating) Wax in Corrugated Board Facing
* E0 D4 u( C- \) k7 G, vD3523-92R02 Test Method for Spontaneous Heating Values of Liquids and Solids (Differential Mackey Test)
' J$ w% D6 Q% U( h/ z& u: c4 CD3524-04 Test Method for Diesel Fuel Diluent in Used Diesel Engine Oils by Gas Chromatography
6 X3 r; r* f. b0 G# I1 B4 dD3525-04 Test Method for Gasoline Diluent in Used Gasoline Engine Oils by Gas Chromatography
+ O  n# U' g! {+ \% TD3527-02 Test Method for Life Performance of Automotive Wheel Bearing Grease
" Q7 R! W0 {5 R& CD3601-88R02E01 Test Method for Foam In Aqueous Media (Bottle Test): |& u, x* w" w. B% U# N9 r
D3603-93R02 Test Method for Rust-Preventing Characteristics of Steam Turbine Oil in the Presence of Water (Horizontal Disk Method)
# A% b) ]: K9 G: N+ I* ?/ `6 z0 _! ID3605-00 Test Method for Trace Metals in Gas Turbine Fuels by Atomic Absorption and Flame Emission Spectroscopy6 t4 H- M0 k# K, Q, i0 {- u
D3606-04A Test Method for Determination of Benzene and Toluene in Finished Motor and Aviation Gasoline by Gas Chromatography
8 u& Q8 f1 C8 ]2 X+ y0 r" UD3607-97R02E01 Test Method for Removing Volatile Contaminants from Used Engine Oils by Stripping
- J. q4 ~" c0 K9 K! ]) K0 e+ f( GD3699-04 Specification for Kerosine
3 ~" D# j  h& YD3700-01 Practice for Obtaining LPG Samples Using a Floating Piston Cylinder, U* \) L( ~* e' g$ a
D3701-01 Test Method for Hydrogen Content of Aviation Turbine Fuels by Low Resolution Nuclear Magnetic Resonance Spectrometry6 l, ^, r6 n9 j! e2 S7 x
D3702-94R04 Test Method for Wear Rate and Coefficient of Friction of Materials in Self-Lubricated Rubbing Contact Using a Thrust Washer Testing Machine8 {! ~- u3 M, T! j' c
D3703-99R04 Test Method for Peroxide Number of Aviation Turbine Fuels
  V! {3 U, |  C) i, k3 Z( _5 ^& d' kD3704-96R01 Test Method for Wear Preventive Properties of Lubricating Greases Using the (Falex) Block on Ring Test Machine in Oscillating Motion3 b0 g9 a- M& ^  S) ?
D3705-86R03E01 Test Method for Misting Properties of Lubricating Fluids6 c- o' S/ J3 m% M/ b# f
D3706 Test Method for Hot Tack of Wax-Polymer Blends by the Flat Spring Test5 A, V) e  v/ l& I
D3707-89R99 Test Method for Storage Stability of Water-in-Oil Emulsions by the Oven Test Method
% p/ D  A3 J' ~) R4 S0 ?( _) ]) zD3708-88R00 Test Method for Weight of Wax Applied During Curtain Coating Operation
4 N' ~; M0 ~; |D3709-89R99 Test Method for Stability of Water-in-Oil Emulsions Under Low to Ambient Temperature Cycling Conditions4 G& n3 E( b1 H9 e' |( s2 V* u
D3710-95R04 Test Method for Boiling Range Distribution of Gasoline and Gasoline Fractions by Gas Chromatography- C4 ]1 R/ f; h% b
D3711-95R00E01 Test Method for Deposition Tendencies of Liquids in Thin Films and Vapors* `6 v) C7 p1 ~
D3712-91R00E01 Test Method of Analysis of Oil-Soluble Petroleum Sulfonates by Liquid Chromatography! Y. Z! R4 }( R# w
D3764-01 Practice for Validation of Process Stream Analyzer Systems  o' y' Y" p2 t3 w6 E
D3825-90R00 Test Method for Dynamic Surface Tension by the Fast-Bubble Technique" q% U3 d" ^2 ~
D3827-92R02 Test Method for Estimation of Solubility of Gases in Petroleum and Other Organic Liquids7 N' B1 P) e9 A, h0 q! r( j  i
D3828-02 Test Methods for Flash Point by Small Scale Closed Cup Tester( h. J/ m5 m. A& M5 w1 d1 v
D3829-02 Test Method for Predicting the Borderline Pumping Temperature of Engine Oil
9 R0 q9 T9 _6 Z* w& N( D  i% VD3831-01 Test Method for Manganese in Gasoline By Atomic Absorption Spectroscopy& i) s/ p- z2 a$ f5 h" a
D3944-88R00 Test Method for Solidification Point of Petroleum Wax
; q" k0 ~* Z+ r' ^D3948-04 Test Method for Determining Water Separation Characteristics of Aviation Turbine Fuels by Portable Separometer/ R( C/ F! V! k8 C) h; F1 R' t
D4006-81R00E01 Test Method for Water in Crude Oil by Distillation
1 d" x0 j% K( k3 vD4007-02 Test Method for Water and Sediment in Crude Oil by the Centrifuge Method (Laboratory Procedure)+ k- f* J  L$ _5 J4 g
D4042-93R03E01 Test Method for Sampling and Testing for Ash and Total Iron in Steel Mill Dispersions of Rolling Oils
0 b; z/ W  m# X( T# N3 ED4045-04 Test Method for Sulfur in Petroleum Products by Hydrogenolysis and Rateometric Colorimetry
. D) T' }0 d) @" B3 M/ cD4046-91R00E01 Test Method for Alkyl Nitrate in Diesel Fuels by Spectrophotometry
& c& y3 e0 [) x/ b1 r$ z2 h7 |D4047-00 Test Method for Phosphorus in Lubricating Oils and Additives by Quinoline Phosphomolybdate Method
6 K2 o! a; m) Y1 C0 {; [/ W8 lD4048-02 Test Method for Detection of Copper Corrosion from Lubricating Grease
: w5 W6 C9 e% o; N" C* S5 @. QD4049-99R04 Test Method for Determining the Resistance of Lubricating Grease to Water Spray' y  p( U9 l6 q" ~
D4051-99R04 Practice for Preparation of Low-Pressure Gas Blends
. I. N4 U: H! L2 qD4052-96R02E01 Test Method for Density and Relative Density of Liquids by Digital Density Meter
: ?& h( ~0 v3 t( h, r' r- t9 hD4053-04 Test Method for Benzene in Motor and Aviation Gasoline by Infrared Spectroscopy0 J7 E  q* w) n" E+ `9 _
D4054-93R03 Practice for Evaluating the Compatibility of Additives with Aviation-Turbine Fuels and Aircraft Fuel System Materials+ w+ z; d+ }: a! T# j4 c
D4055-04 Test Method for Pentane Insolubles by Membrane Filtration
+ _6 f- S3 j* f. w$ K+ F8 `) kD4056-01 Test Method for Estimation of Solubility of Water in Hydrocarbon and Aliphatic Ester Lubricants8 y  l; `. U! N$ Y
D4057-95R00 Practice for Manual Sampling of Petroleum and Petroleum Products$ K/ B8 V) o% ^
D4072-98R03E01 Test Method for Toluene-Insoluble (TI) Content of Tar and Pitch
" Z- \5 U3 r. ?D4170-97R02E01 Test Method for Fretting Wear Protection by Lubricating Greases4 q& Q2 C% a$ k8 J# _
D4171-03 Specification for Fuel System Icing Inhibitors
, L' ~" k3 i: A) k+ bD4172-94R04 Test Method for Wear Preventive Characteristics of Lubricating Fluid (Four-Ball Method)
+ d" E: K3 Y2 L1 w% AD4174-89R99 Practice for Cleaning, Flushing, and Purification of Petroleum Fluid Hydraulic Systems
) B4 ?1 O1 x0 ^2 x2 CD4175-02AE02 Terminology Relating to Petroleum, Petroleum Products, and Lubricants
, \3 h2 ^8 b. k$ G, OD4176-04 Test Method for Free Water and Particulate Contamination in Distillate Fuels (Visual Inspection Procedures)- L/ ^2 E) ~! H( d8 k1 K4 V+ t: G6 R
D4177-95R00 Practice for Automatic Sampling of Petroleum and Petroleum Products; U1 l6 N, U; @- q6 {% K- a. `' G  F* G
D4178-82R99 Practice for Calibrating Moisture Analyzers9 A7 Z) C4 s. k5 l7 t4 r
D4241-98R03 Practice for Design of Gas Turbine Generator Lubricating Oil Systems
1 E% L! }4 R* }5 G1 f+ kD4248-98R03 Practice for Design of Steam Turbine Generator Oil Systems0 T: t/ b$ m- {# ]/ I$ Y* }
D4289-03 Test Method for Elastomer Compatibility of Lubricating Greases and Fluids
6 v+ F' K7 \/ Y6 J- sD4290-02 Test Method for Determining the Leakage Tendencies of Automotive Wheel Bearing Grease Under Accelerated Conditions* ^6 N+ t- a5 T; ?+ W' ?. c
D4291-04 Test Method for Trace Ethylene Glycol in Used Engine Oil
, ?, Y, e" P& QD4292-92R02E01 Test Method for Determination of Vibrated Bulk Density of Calcined Petroleum Coke  R; M; c4 |5 l
D4293-83R03 Specification for Phosphate Ester Based Fluids for Turbine Lubrication
5 I+ J$ J* q" z% x) kD4294-03 Test Method for Sulfur in Petroleum and Petroleum Products by Energy-Dispersive X-ray Fluorescence Spectrometry7 `4 ~0 `! n- M
D4296-83R04 Practice for Sampling Pitch  u- s  q0 g" H" i7 l4 P
D4304-00 Specification for Mineral Lubricating Oil Used in Steam or Gas Turbines
" P6 K# i9 p" T* c% M% f' {D4305-98AR04E01 Test Method for Filter Flow of Aviation Fuels at Low Temperatures
3 `- F& E4 t% y# v$ c/ t9 z0 j* yD4306-01 Practice for Aviation Fuel Sample Containers for Tests Affected by Trace Contamination
) E( s! I& [$ Q) h# s8 YD4307-99R04 Practice for Preparation of Liquid Blends for Use as Analytical Standards  l. H! i+ c5 _5 j- t5 ]+ z& h5 V
D4308-95R00E01 Test Method for Electrical Conductivity of Liquid Hydrocarbons by Precision Meter
+ j" N$ ?6 y7 g2 lD4310-03 Test Method for Determination of the Sludging and Corrosion Tendencies of Inhibited Mineral Oils9 T" Y7 z' d0 Q/ g0 N
D4312-95AR00E01 Test Method for Toluene-Insoluble (TI) Content of Tar and Pitch (Short Method); O. p! Z9 ~# ?7 ~% y$ p- i
D4377-00E01 Test Method for Water in Crude Oils by Potentiometric Karl Fischer Titration
6 h+ I& [, |& C1 c  c. Y( C1 lD4378-03 Practice for In-Service Monitoring of Mineral Turbine Oils for Steam and Gas Turbines; h3 R! E8 D' Q1 i# y" x2 j2 n
D4418-00 Practice for Receipt, Storage, and Handling of Fuels for Gas Turbines/ g- |) Y8 [: h0 X& W
D4419-90R00 Test Method for Measurement of Transition Temperatures of Petroleum Waxes by Differential Scanning Calorimetry (DSC)
( D# I0 g  \" k8 m  ]" k) dD4420 Test Method for Determination of Aromatics in Finished Gasoline by Gas Chromatography
  `) q: z% @7 i7 h8 C) }, qD4421 Test Method for Volatile Matter in Petroleum Coke
( c1 j- K& j: c. q* V' P+ }D4422-03 Test Method for Ash in Analysis of Petroleum Coke: Y% l6 m2 v, D& r6 S: M
D4423-00 Test Method for Determination of Carbonyls In C Hydrocarbons
. I( @* o! F8 \7 j3 `D4424-90R01E01 Test Method for Butylene Analysis by Gas Chromatography6 q" o/ n6 a8 V: G5 K7 S
D4425-97R02 Test Method for Oil Separation from Lubricating Grease by Centrifuging (Koppers Method)0 O% f0 Y5 O  S- k! |, [7 K9 D
D4485-04 Specification for Performance of Engine Oils" L& o9 ~& L- Q) E4 c8 }
D4486-91R01 Test Method for Kinematic Viscosity of Volatile and Reactive Liquids
' |; z% `0 P5 u! w1 ZD4529-01 Test Method for Estimation of Net Heat of Combustion of Aviation Fuels3 A& J  Y% U: T. D. b7 e
D4530-03 Test Method for Determination of Carbon Residue (Micro Method)
; T* e0 r- ]1 l( vD4539-03E01 Test Method for Filterability of Diesel Fuels by Low-Temperature Flow Test (LTFT)$ ]8 Z# E3 L; P8 l! e
D4616-95R00 Test Method for Microscopical Analysis by Reflected Light and Determination of Mesophase in a Pitch
/ h1 s% N' y. e( F  |* nD4624 Test Method for Measuring Apparent Viscosity by Capillary Viscometer at High-Temperature and High-Shear Rates
# e* V, c) F: t- T# y8 u3 MD4625-04 Test Method for Middle Distillate Fuel Storage Stability at 43|SDC (110|SDF)7 O6 ~' U" r6 j; R* R" n* s8 T
D4626-95R00 Practice for Calculation of Gas Chromatographic Response Factors: I7 l. @7 }: H( C
D4627-92R02 Test Method for Iron Chip Corrosion for Water\NDilutable Metalworking Fluids
) n, M( A  j- q4 s" C# r7 t4 ^D4628-02 Test Method for Analysis of Barium, Calcium, Magnesium, and Zinc in Unused Lubricating Oils by Atomic Absorption SpectrometryD4629-02 Test Method for Trace Nitrogen in Liquid Petroleum Hydrocarbons by Syringe/Inlet Oxidative Combustion and Chemiluminescence Detection
9 j8 L7 ?0 J6 Z- ^: ~2 ^D4636-99R04E01 Test Method for Corrosiveness and Oxidation Stability of Hydraulic Oils, Aircraft Turbine Engine Lubricants, and Other Highly Refined Oils
* J8 `! X5 J- t$ w* Z0 V$ f; hD4682-87R02 Specification for Miscibility with Gasoline and Fluidity of Two-Stroke-Cycle Gasoline Engine Lubricants
5 }# h2 a: h( V/ O" Y% \, t" V+ CD4683-04 Test Method for Measuring Viscosity at High Shear Rate and High Temperature by Tapered Bearing Simulator4 w$ z  r7 W$ h1 M
D4684-02A Test Method for Determination of Yield Stress and Apparent Viscosity of Engine Oils at Low Temperature
8 A- r+ t4 b# O( K7 A$ qD4693-03 Test Method for Low-Temperature Torque of Grease-Lubricated Wheel Bearings
+ ]; l+ \, |1 j- k$ D8 SD4715-98R03 Test Method for Coking Value of Tar and Pitch (Alcan)5 ~0 `: M: O+ r8 H3 C. `  ]
D4737-03 Test Method for Calculated Cetane Index by Four Variable Equation( Z+ l" G4 D- B
D4739-02 Test Method for Base Number Determination by Potentiometric Titration
1 q, S! d3 ?! N5 r5 x6 WD4740-04 Test Method for Cleanliness and Compatibility of Residual Fuels by Spot Test
! ?, O, A. A' ZD4741-00 Test Method for Measuring Viscosity at High Temperature and High Shear Rate by Tapered-Plug Viscometer
; u) W8 `) d1 K4 C, i3 p, SD4742-02A Test Method for Oxidation Stability of Gasoline Automotive Engine Oils by Thin-Film Oxygen Uptake (TFOUT)% _7 `0 Y) ]5 \' H6 x
D4746-98R03E01 Test Method for Determination of Quinoline Insolubles (QI) in Tar and Pitch by Pressure Filtration3 G4 D' O% ~6 h* Q- W" ^/ [$ s
D4806-04A Specification for Denatured Fuel Ethanol for Blending with Gasolines for Use as Automotive Spark-Ignition Engine Fuel- y9 a; o' |( ]; p  P
D4807-88R99 Test Method for Sediment in Crude Oil by Membrane Filtration7 w5 e% r" N, i7 O3 J
D4808-01 Test Methods for Hydrogen Content of Light Distillates, Middle Distillates, Gas Oils, and Residua by Low-Resolution Nuclear Magnetic Resonance Spectroscopy( H* I: U$ [; w9 Y
D4809-00 Test Method for Heat of Combustion of Liquid Hydrocarbon Fuels by Bomb Calorimeter (Precision Method)
* Y$ {$ m" M6 j" z+ W9 KD4814-04A Specification for Automotive Spark-Ignition Engine Fuel
( U8 {6 I& v; `7 x6 G0 o* Q# ZD4815-03 Test Method for Determination of MTBE, ETBE, TAME, DIPE, tertiary-Amyl Alcohol and C to C Alcohols in Gasoline by Gas Chromatography8 C/ M& S& H+ x% C& g$ y
D4857-03 Test Method for Determination of the Ability of Lubricants to Minimize Ring Sticking and Piston Deposits in Two-Stroke-Cycle Gasoline Engines Other Than Outboards4 H; g. {3 [4 x. `- U9 h  T9 E
D4858-02 Test Method for Determination of the Tendency of Lubricants to Promote Preignition in Two-Stroke-Cycle Gasoline Engines5 L4 `. r  C0 T6 I) C& |
D4859-97R03 Specification for Lubricants for Two-Stroke-Cycle Spark-Ignition Gasoline Engines-TC# X- L' }$ A" I0 r7 P% O2 l4 L6 w
D4860-91R00E01 Test Method for Free Water and Particulate Contamination in Mid-Distillate Fuels (Clear and Bright Numerical Rating)5 y7 w9 a3 Q' @% `1 _
D4863-02 Test Method for Determination of Lubricity of Two-Stroke-Cycle Gasoline Engine Lubricants: v7 w2 @. Z5 w. i+ }, [# F9 u  K1 R
D4864-90R00E01 Test Method for Determination of Traces of Methanol in Propylene Concentrates by Gas Chromatography0 {' c, y( l6 g& {( c4 B- h
D4865-98R03E01 Guide for Generation and Dissipation of Static Electricity in Petroleum Fuel Systems+ _; P4 A. A  H$ U. t, f1 ~- h! N# N
D4868-00 Test Method for Estimation of Net and Gross Heat of Combustion of Burner and Diesel Fuels
6 ?# [& B8 K: p6 GD4870-04 Test Method for Determination of Total Sediment in Residual Fuels
( q1 g9 d7 Z. ?$ L, J" gD4871-00 Guide for Universal Oxidation/Thermal Stability Test Apparatus$ Z9 K' t2 x" J6 ^3 [4 ^
D4892-89R04 Test Method for Density of Solid Pitch (Helium Pycnometer Method)3 R4 K9 b( G% U
D4893-94R04 Test Method for Determination of Pitch Volatility: U& a/ O' O9 w! T* w/ E( T$ t  A. \
D4898-90R00E01 Test Method for Insoluble Contamination of Hydraulic Fluids by Gravimetric Analysis
# L8 M" O" E1 s5 l* v* ?. {D4927-02 Test Methods for Elemental Analysis of Lubricant and Additive Components\MBarium, Calcium, Phosphorus, Sulfur, and Zinc by Wavelength-Dispersive X-Ray Fluorescence Spectroscopy, b( W4 t- U; P
D4928-00E01 Test Methods for Water in Crude Oils by Coulometric Karl Fischer Titration9 v: u8 J9 c' `4 Q
D4929-04 Test Methods for Determination of Organic Chloride Content in Crude Oil$ B- H2 H2 [" _6 q4 x- Z4 b0 T
D4930-94R04E01 Test Method for Dust Control Material on Calcined Petroleum Coke
' ]  [5 X+ m; W( Y. o, k/ t! z$ p+ |3 BD4931-92R02 Test Method for Gross Moisture in Green Petroleum Coke
  ~4 _& d% l/ Q, b" ^D4950-01R04E01 Classification and Specification for Automotive Service Greases- r/ z2 N7 e1 k- X' N- c6 L) n
D4951-02 Test Method for Determination of Additive Elements in Lubricating Oils by Inductively Coupled Plasma Atomic Emission Spectrometry
5 _7 D. k! T; E# Q  jD4952-02 Test Method for Qualitative Analysis for Active Sulfur Species in Fuels and Solvents (Doctor Test)
  t; O% q, t5 }3 k+ X; k$ u. s0 bD4953-99A Test Method for Vapor Pressure of Gasoline and Gasoline-Oxygenate Blends (Dry Method)
  v" ^, k" s% B) r+ gD4998-95R03E01 Test Method for Evaluating Wear Characteristics of Tractor Hydraulic Fluids: a( U2 `2 z  f
D5000-89R00 Practice for Evaluating Activity of Clay Elements Using a Side-Stream Sensor
0 [) j4 a( m2 M* y# _( `. vD5001-03 Test Method for Measurement of Lubricity of Aviation Turbine Fuels by the Ball-on-Cylinder Lubricity Evaluator (BOCLE)) Y" @" q# B' Q( `) S3 d" @3 A% i# A
D5002-99 Test Method for Density and Relative Density of Crude Oils by Digital Density Analyzer
5 }' X) ~; I) z6 H% M0 uD5003-95R00E01 Test Method for The Hardgrove Grindability Index (HGI) of Petroleum Coke
, T" f1 z1 }* A: D# K% e8 t6 N+ [D5004-89R04E01 Test Method for Real Density of Calcined Petroleum Coke by Xylene Displacement
( A. d9 M% ^  RD5006-03 Test Method for Measurement of Fuel System Icing Inhibitors (Ether Type) in Aviation Fuels3 ]8 n. j: @7 {& A* b  T/ \
D5018-89R04 Test Method for Shear Viscosity of Coal-Tar and Petroleum Pitches
  j, ]5 ]( J/ A! XD5056-04 Test Method for Trace Metals in Petroleum Coke by Atomic Absorption3 R" `8 r# w" k- I/ n1 {
D5059-98R03E01 Test Methods for Lead in Gasoline by X-Ray Spectroscopy  _1 ~  H* a8 J/ Z
D5119 Test Method for Evaluation of Automotive Engine Oils in the CRC L-38 Spark-Ignition Engine
  L" t" A, S1 a& }D5133-01 Test Method for Low Temperature, Low Shear Rate, Viscosity/Temperature Dependence of Lubricating Oils Using a Temperature-Scanning Technique$ H0 p! p, q' W$ H+ {3 C' S+ k) U
D5134-98R03 Test Method for Detailed Analysis of Petroleum Naphthas through n-Nonane by Capillary Gas Chromatography
/ ~( l8 `6 }4 z  q% U3 f8 fD5182-97R02E01 Test Method for Evaluating the Scuffing Load Capacity of Oils (FZG Visual Method)8 u0 H5 \$ g/ }0 z/ h2 k$ b/ k
D5183-95R99E01 Test Method for Determination of the Coefficient of Friction of Lubricants Using the Four-Ball Wear Test Machine. R( ]- u: p8 H1 i& ~) v  I' V5 ]! H; m
D5184-01 Test Methods for Determination of Aluminum and Silicon in Fuel Oils by Ashing, Fusion, Inductively Coupled Plasma Atomic Emission Spectrometry, and Atomic Absorption Spectrometry+ P+ [& W, R1 Y0 f9 {1 Z5 E4 h' n
D5185-02E02 Test Method for Determination of Additive Elements, Wear Metals, and Contaminants in Used Lubricating Oils and Determination of Selected Elements in Base Oils by Inductively Coupled Plasma Atomic Emission & O2 D! @1 c% f4 H% T; p$ G
Spectrometry (ICP-AES)
0 F. a% B/ H# o; a! Y" Q0 dD5186-03 Test Method for Determination of the Aromatic Content and Polynuclear Aromatic Content of Diesel Fuels and Aviation Turbine Fuels By Supercritical Fluid Chromatography/ K' B! z/ w. i: `  `
D5187-91R02 Test Method for Determination of Crystallite Size (L of Calcined Petroleum Coke by X-Ray Diffraction9 ^# r( K$ X% N% ^
D5188-04A Test Method for Vapor-Liquid Ratio Temperature Determination of Fuels (Evacuated Chamber Method)7 h3 u) G; O2 Y" k, ?( ?: c; j( B. f
D5190-01 Test Method for Vapor Pressure of Petroleum Products (Automatic Method)" P4 V. j9 x) W3 t: T
D5191-04A Test Method for Vapor Pressure of Petroleum Products (Mini Method)- ?: t' V# s, ?; T3 b! }
D5234-92R02 Guide for Analysis of Ethylene Product8 s& g) R. k9 j3 p
D5236-03 Test Method for Distillation of Heavy Hydrocarbon Mixtures (Vacuum Potstill Method)
7 K( ~: p5 u( G" e* \8 UD5273-92R02 Guide for Analysis of Propylene Concentrates
8 C2 m7 C2 L0 H0 ]$ Z$ z! PD5274-00 Guide for Analysis of 1,3\NButadiene Product. a; ?4 X; Z. Z  g& Y' f9 K$ x1 e
D5275-03 Test Method for Fuel Injector Shear Stability Test (FISST) for Polymer Containing Fluids9 y% a4 P3 y; e$ K8 B9 m, n
D5291-02 Test Methods for Instrumental Determination of Carbon, Hydrogen, and Nitrogen in Petroleum Products and Lubricants( l9 i, q% c8 X
D5292-99R04 Test Method for Aromatic Carbon Contents of Hydrocarbon Oils by High Resolution Nuclear Magnetic Resonance Spectroscopy8 U- Y, y$ c' o! k$ z  ?, M/ n5 M% L7 U
D5293-04 Test Method for Apparent Viscosity of Engine Oils Between \-5 and \-35|SDC Using the Cold-Cranking Simulator+ o8 l+ h* r2 f2 C: R# X5 U6 b
D5302 Test Method for Evaluation of Automotive Engine Oils for Inhibition of Deposit Formation and Wear in a Spark-Ignition Internal Combustion Engine Fueled with Gasoline and Operated Under Low-Temperature, Light-Duty " _* N# v/ C  s9 e' _3 {, F* [
Conditions: B3 C% E! I, T2 Y2 z) }
D 3231 – 02 ;RDMYMZE_.pdf
46.09 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3231 – 99 ;RDMYMZETOTK_.pdf
46.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3231 – 99 ;RDMYMZETUKVE.pdf
36.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3233 – 93 R03 ;RDMYMZM_.pdf
223.79 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3233 – 93 R98 ;RDMYMZMTOTNSOTG_.pdf
227.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3234 – 88 R99 ;RDMYMZQ_.pdf
38.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3235 – 02 ;RDMYMZU_.pdf
96.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3235 – 97 ;RDMYMZUTOTC_.pdf
98.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3235 – 97 ;RDMYMZUTUKVE.pdf
86.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3236 – 88 R04 ;RDMYMZY_.pdf
272.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3236 – 88 R99 ;RDMYMZYTODHSOTK_.pdf
271.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3237 – 02 ;RDMYMZC_.pdf
36.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3237 – 97 ;RDMYMZCTOTC_.pdf
31.93 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3237 – 97 ;RDMYMZCTUKVE.pdf
28.79 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3238 – 95 R00 ;RDMYMZG_.pdf
40.07 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3238 – 95 R00 ;RDMYMZGTOTVSMDA_.pdf
20.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3239 – 91 R01 ;RDMYMZK_.pdf
359.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3239 – 91 R96 ;RDMYMZKTOTFSOTY_.pdf
350.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3240 – 91 R01 ;RDMYNDA_.pdf
34.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3240 – 91 R96 ;RDMYNDATOTFSOTY_.pdf
23.37 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3241 – 01 ;RDMYNDETMDE_.pdf
131.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3241 – 01 ;RDMYNDETMDFFMQ__.pdf
136.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3241 – 02 ;RDMYNDE_.pdf
166.74 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3241 – 02 ;RDMYNDETMDI_.pdf
162.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3241 – 02 ;RDMYNDETMDJB.pdf
164.15 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3241 – 98 ;RDMYNDETOTG_.pdf
130.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3242 – 01 ;RDMYNDI_.pdf
53.85 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3242 – 98 ;RDMYNDITOTG_.pdf
39.17 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3242 – 98 ;RDMYNDITUKVE.pdf
44 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3244 – 97 ;RDMYNDQTOTC_.pdf
133.67 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3244 – 97 R02 ;RDMYNDQ_.pdf
131.59 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 3245 – 03 ;RDMYNDU_.pdf
67.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3245 – 96 ;RDMYNDUTOTY_.pdf
67.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3245 – 96 ;RDMYNDUTUKVE.pdf
59.58 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3246 – 96 ;RDMYNDY_.pdf
74.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3336 – 97 R02 ;RDMZMZY_.pdf
261.57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3338 – 00 ;RDMZMZG_.pdf
43.19 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3338 – 95 ;RDMZMZGTOTU_.pdf
28.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3338 – 95 ;RDMZMZGTUKVE.pdf
33.06 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3339 – 02 ;RDMZMZK_.pdf
101.71 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 3339 – 95 ;RDMZMZKTOTVFMG__.pdf
80.22 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3339 – 95 R00 ;RDMZMZKTOTVSMDBFMQ__.pdf
84.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3339 – 95 R00 ;RDMZMZKTUKVE.pdf
94.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3340 – 98 ;RDMZNDATOTG_.pdf
32.18 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3340 – 98 R03 ;RDMZNDA_.pdf
30.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3341 – 00 ;RDMZNDE_.pdf
41.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3341 – 91 R95 ;RDMZNDETUKVE.pdf
35.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3342 – 90 R00 ;RDMZNDI_.pdf
54.45 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3343 – 95 R00 ;RDMZNDM_.pdf
89.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3344 – 90 R00 ;RDMZNDQ_.pdf
40.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3344 – 90 R95 ;RDMZNDQTOTBSOTVFMQ__.pdf
22.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3348 – 98 ;RDMZNDGTOTG_.pdf
113.38 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3348 – 98 R03 ;RDMZNDG_.pdf
118.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3427 – 02 ;RDM0MJCTMDI_.pdf
87.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3427 – 02 ;RDM0MJCTUKVE.pdf
80.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3427 – 03 ;RDM0MJC_.pdf
89.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3429 – 93 R02 ;RDM0MJK_.pdf
116.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3429 – 93 R98 ;RDM0MJKTOTNSOTG_.pdf
109.31 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3461 – 97 ;RDM0NJETOTC_.pdf
98.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3461 – 97 R02 ;RDM0NJE_.pdf
111.94 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3519 – 88 R02 ;RDM1MTK_.pdf
57.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3519 – 88 R97 ;RDM1MTKTODHSOTC_.pdf
37.85 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3520 – 04 ;RDM1MJA_.pdf
80.94 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3521 – 86 R02 ;RDM1MJE_.pdf
30.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3521 – 86 R97 ;RDM1MJETODZSOTC_.pdf
29.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3522 – 86 R02 ;RDM1MJI_.pdf
50.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3522 – 86 R97 ;RDM1MJITODZSOTC_.pdf
42.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3523 – 92 R02 ;RDM1MJM_.pdf
51.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3523 – 92 R97 ;RDM1MJMTOTJSOTC_.pdf
53.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3524 – 90 R99 ;RDM1MJQ_.pdf
44.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3525 – 93 R02 ;RDM1MJU_.pdf
45.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3525 – 93 R97 ;RDM1MJUTOTNSOTC_.pdf
37.88 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3527 – 02 ;RDM1MJC_.pdf
102.23 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3527 – 95 ;RDM1MJCTOTU_.pdf
105.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3527 – 95 ;RDM1MJCTUKVE.pdf
94.75 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3601 – 88 R02 ;RDM2MDE_.pdf
71.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3601 – 88 R97 ;RDM2MDETODHSOTC_.pdf
44.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3603 – 93 R02 ;RDM2MDM_.pdf
89.23 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3603 – 93 R97 ;RDM2MDMTOTNSOTC_.pdf
89.57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3605 – 00 ;RDM2MDU_.pdf
48.63 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3605 – 91 R95 ;RDM2MDUTUKVE.pdf
34.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3606 – 04 ;RDM2MDY_.pdf
101.46 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3606 – 99 ;RDM2MDYTOTK_.pdf
100.6 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3606 – 99 ;RDM2MDYTUKVE.pdf
90.56 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3607 – 97 ;RDM2MDCTOTC_.pdf
46.31 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3607 – 97 R02 ;RDM2MDC_.pdf
55.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3699 – 01 ;RDM2OTKTMDE_.pdf
33.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3699 – 02 ;RDM2OTKTMDI_.pdf
34.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3699 – 02 ;RDM2OTKTUKVE.pdf
27.44 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3699 – 03 ;RDM2OTK_.pdf
36.47 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3699 – 98 ;RDM2OTKTOTG_.pdf
21.3 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3700 – 01 ;RDM3MDA_.pdf
137.06 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3700 – 94 ;RDM3MDATOTQ_.pdf
58.45 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3700 – 94 ;RDM3MDATUKVE.pdf
152.32 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3701 – 01 ;RDM3MDE_.pdf
51.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3701 – 99 ;RDM3MDETOTLB.pdf
38.59 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3701 – 99 ;RDM3MDETUKVE.pdf
42.32 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3702 – 94 R99 ;RDM3MDI_.pdf
78.61 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3703 – 99 ;RDM3MDM_.pdf
36.23 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3704 – 96 ;RDM3MDQTOTY_.pdf
123.24 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3704 – 96 R01 ;RDM3MDQ_.pdf
86.03 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3705 – 86 R03 ;RDM3MDU_.pdf
88.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3705 – 86 R98 ;RDM3MDUTUKVE.pdf
72.78 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3706 – 88 R00 ;RDM3MDY_.pdf
42.74 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3706 – 88 R93 ;RDM3MDYTODHSOTNFMQ__.pdf
27.74 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3707 – 89 R99 ;RDM3MDC_.pdf
29.89 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3708 – 88 R00 ;RDM3MDG_.pdf
27.73 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3708 – 88 R93 ;RDM3MDGTODHSOTNFMQ__.pdf
20.2 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3709 – 89 R99 ;RDM3MDK_.pdf
29.18 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3710 – 95 R99 ;RDM3MTA_.pdf
124.39 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3711 – 95 ;RDM3MTETOTU_.pdf
46.98 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3711 – 95 R00 ;RDM3MTE_.pdf
75.81 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3712 – 91 R00 ;RDM3MTI_.pdf
82.14 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3764 – 01 ;RDM3NJQ_.pdf
98.87 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3764 – 92 R98 ;RDM3NJQTOTJSOTG_.pdf
131.99 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3764 – 92 R98 ;RDM3NJQTUKVE.pdf
138.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3825 – 90 R00 ;RDM4MJU_.pdf
61.81 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3825 – 90 R95 ;RDM4MJUTOTBSOTU_.pdf
40.93 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3827 – 92 R02 ;RDM4MJC_.pdf
42.01 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3827 – 92 R97 ;RDM4MJCTOTJSOTC_.pdf
43.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3828 – 02 ;RDM4MJG_.pdf
95.04 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3828 – 98 ;RDM4MJGTOTG_.pdf
93.1 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3828 – 98 ;RDM4MJGTUKVE.pdf
86.54 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3829 – 02 ;RDM4MJK_.pdf
59.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3829 – 93 R98 ;RDM4MJKTOTNSOTG_.pdf
62.63 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3829 – 93 R98 ;RDM4MJKTUKVE.pdf
52.28 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3831 – 01 ;RDM4MZE_.pdf
37.21 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3831 – 98 ;RDM4MZETOTG_.pdf
20.93 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3831 – 98 ;RDM4MZETUKVE.pdf
33.27 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3944 – 88 R00 ;RDM5NDQ_.pdf
51.44 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3944 – 88 R93 ;RDM5NDQTODHSOTNFMQ__.pdf
42.13 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3948 – 99 ;RDM5NDG_.pdf
146.9 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 4006 – 81 R00 ;RDQWMDY_.pdf
130.62 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4007 – 02 ;RDQWMDC_.pdf
138.74 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4007 – 81 R95 ;RDQWMDCTODFSOTVFMQ__.pdf
130 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4007 – 81 R95 ;RDQWMDCTUKVE.pdf
214.25 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4042 – 93 R03 ;RDQWNDI_.pdf
56.79 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4042 – 93 R98 ;RDQWNDITUKVE.pdf
41.36 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4045 – 04 ;RDQWNDU_.pdf
76.95 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4045 – 99 ;RDQWNDUTOTK_.pdf
76.13 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4046 – 91 R00 ;RDQWNDY_.pdf
38.79 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4047 – 00 ;RDQWNDC_.pdf
43.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4047 – 91 R95 ;RDQWNDCTUKVE.pdf
35.79 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4048 – 02 ;RDQWNDG_.pdf
40.81 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4048 – 97 ;RDQWNDGTUKVE.pdf
36.33 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4049 – 99 ;RDQWNDKTOTK_.pdf
67.03 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4049 – 99 R04 ;RDQWNDK_.pdf
73.05 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4051 – 99 ;RDQWNTETOTK_.pdf
56.06 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4051 – 99 R04 ;RDQWNTE_.pdf
55.87 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4052 – 96 ;RDQWNTITOTY_.pdf
31.7 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4052 – 96 R02 ;RDQWNTI_.pdf
50.18 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 4053 – 98 ;RDQWNTMTOTG_.pdf
33.38 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4053 – 98 R03 ;RDQWNTM_.pdf
32.84 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4054 – 93 R03 ;RDQWNTQ_.pdf
D 4054 – 93 R98 ;RDQWNTQTOTNSOTG_.pdf
42.58 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4055 – 01 ;RDQWNTUTMDE_.pdf
23.84 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4055 – 02 ;RDQWNTUTMDI_.pdf
33.72 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4055 – 02 ;RDQWNTUTUKVE.pdf
24.87 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4055 – 04 ;RDQWNTU_.pdf
33.49 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4055 – 97 ;RDQWNTUTOTC_.pdf
22.25 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4056 – 00 ;RDQWNTYTMDA_.pdf
24.08 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4056 – 00 ;RDQWNTYTUKVE.pdf
26.72 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4056 – 01 ;RDQWNTY_.pdf
36.11 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4056 – 92 R97 ;RDQWNTYTOTJSOTDFMQ__.pdf
25.49 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4057 – 95 R00 ;RDQWNTC_.pdf
194.73 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4072 – 98 ;RDQWNZITOTG_.pdf
38.32 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4072 – 98 R03 ;RDQWNZI_.pdf
45.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4170 – 97 ;RDQXNZATOTC_.pdf
151.87 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4170 – 97 R02 ;RDQXNZA_.pdf
103.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4171 – 03 ;RDQXNZE_.pdf
53.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4171 – 98 ;RDQXNZETOTG_.pdf
53.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4171 – 98 ;RDQXNZETUKVE.pdf
36.97 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4172 – 94 R99 ;RDQXNZI_.pdf
69.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4174 – 89 R99 ;RDQXNZQ_.pdf
89.63 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 4175 – 00 ;RDQXNZUTMDBFMQ__.pdf
84.3 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4175 – 01 ;RDQXNZUTMDE_.pdf
83.08 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4175 – 02 ;RDQXNZU_.pdf
270.32 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 4175 – 02 ;RDQXNZUTMDJB.pdf
200.79 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4176 – 02 ;RDQXNZY_.pdf
36.59 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4176 – 93 R97 ;RDQXNZYTOTNSOTC_.pdf
22.53 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4176 – 93 R97 ;RDQXNZYTUKVE.pdf
33.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4177 – 95 R00 ;RDQXNZC_.pdf
378.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4178 – 82 R99 ;RDQXNZG_.pdf
32.04 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4241 – 98 ;RDQYNDETOTG_.pdf
48.43 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4241 – 98 R03 ;RDQYNDE_.pdf
49.15 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4248 – 98 ;RDQYNDGTOTG_.pdf
44.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4248 – 98 R03 ;RDQYNDG_.pdf
44.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4289 – 03 ;RDQYODK_.pdf
77.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4289 – 97 ;RDQYODKTOTC_.pdf
76.21 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4290 – 02 ;RDQYOTA_.pdf
118.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4290 – 94 R99 ;RDQYOTATOTRSOTK_.pdf
119.04 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4290 – 94 R99 ;RDQYOTATUKVE.pdf
111.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4291 – 93 R98 ;RDQYOTE_.pdf
37.01 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4292 – 92 R02 ;RDQYOTI_.pdf
52.24 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4293 – 83 R03 ;RDQYOTM_.pdf
27.28 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4293 – 83 R98 ;RDQYOTMTODNSOTG_.pdf
28.23 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4294 – 02 ;RDQYOTQTMDI_.pdf
48.61 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4294 – 02 ;RDQYOTQTUKVE.pdf
37.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4294 – 03 ;RDQYOTQ_.pdf
48.91 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4296 – 83 R99 ;RDQYOTY_.pdf
153.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4304 – 00 ;RDQZMDQ_.pdf
39.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4304 – 99 ;RDQZMDQTOTK_.pdf
29.14 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4304 – 99 ;RDQZMDQTUKVE.pdf
35.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4305 – 98 ;RDQZMDUTOTHB.pdf
57.32 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4305 – 98a R04 ;RDQZMDU_.pdf
66.63 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4306 – 01 ;RDQZMDY_.pdf
45.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4306 – 97 ;RDQZMDYTOTC_.pdf
26.81 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4306 – 97 ;RDQZMDYTUKVE.pdf
45.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4307 – 99 ;RDQZMDCTOTK_.pdf
32.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4307 – 99 R04 ;RDQZMDC_.pdf
32.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4308 – 95 ;RDQZMDGTOTU_.pdf
71.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4308 – 95 R00 ;RDQZMDG_.pdf
95.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4308 – 95 R00 ;RDQZMDGTOTVSMDA_.pdf
71.62 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4310 – 03 ;RDQZMTA_.pdf
141.84 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4310 – 98 ;RDQZMTATOTG_.pdf
183.16 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4310 – 98 ;RDQZMTATUKVE.pdf
175.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4312 – 95 ;RDQZMTITOTVB.pdf
25.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4312 – 95a R00 ;RDQZMTI_.pdf
44.17 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4377 – 00 ;RDQZNZC_.pdf
78.58 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4377 – 00 ;RDQZNZCTMDA_.pdf
53.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4378 – 03 ;RDQZNZG_.pdf
91.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4378 – 97 ;RDQZNZGTOTC_.pdf
82.53 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4378 – 97 ;RDQZNZGTUKVE.pdf
86.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4418 – 00 ;RDQ0MTG_.pdf
90.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4418 – 88 R98 ;RDQ0MTGTODHSOTG_.pdf
67.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4418 – 88 R98 ;RDQ0MTGTUKVE.pdf
73.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4419 – 90 R00 ;RDQ0MTK_.pdf
41.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4419 – 90 R95 ;RDQ0MTKTOTBSOTVFMQ__.pdf
30.43 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4421 – 94 R99 ;RDQ0MJE_.pdf
43.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4422 – 03 ;RDQ0MJI_.pdf
26.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4422 – 94 R98 ;RDQ0MJITOTRSOTG_.pdf
26.09 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4422 – 94 R98 ;RDQ0MJITUKVE.pdf
23.32 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4423 – 00 ;RDQ0MJM_.pdf
40.2 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4423 – 91 R96 ;RDQ0MJMTOTFSOTY_.pdf
28.05 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4423 – 91 R96 ;RDQ0MJMTUKVE.pdf
35.17 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4424 – 90 R01 ;RDQ0MJQ_.pdf
37.58 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4424 – 90 R95 ;RDQ0MJQTOTBSOTU_.pdf
19.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4425 – 97 ;RDQ0MJUTOTC_.pdf
48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4425 – 97 R02 ;RDQ0MJU_.pdf
66.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4485 – 00 ;RDQ0ODUTMDA_.pdf
88.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4485 – 01 ;RDQ0ODUTMDE_.pdf
101.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4485 – 02 ;RDQ0ODUTMDI_.pdf
179.08 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4485 – 03 ;RDQ0ODUTMDM_.pdf
168.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4485 – 03 ;RDQ0ODUTMDNB.pdf
167.78 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4485 – 03 ;RDQ0ODUTUKVE.pdf
121.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4485 – 04 ;RDQ0ODU_.pdf
167.89 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4486 – 91 R01 ;RDQ0ODY_.pdf
52.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4486 – 91 R96 ;RDQ0ODYTOTFSOTZFMQ__.pdf
39.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4529 – 01 ;RDQ1MJK_.pdf
48.59 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4529 – 95 ;RDQ1MJKTOTU_.pdf
27.78 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4529 – 95 ;RDQ1MJKTUKVE.pdf
36.62 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4530 – 00 ;RDQ1MZATMDA_.pdf
160.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4530 – 00 ;RDQ1MZATUKVE.pdf
140.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4530 – 03 ;RDQ1MZA_.pdf
101.21 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4539 – 02 ;RDQ1MZKTMDI_.pdf
76.75 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4539 – 02 ;RDQ1MZKTUKVE.pdf
61.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4539 – 03 ;RDQ1MZK_.pdf
74.31 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4616 – 95 ;RDQ2MTYTOTU_.pdf
107.46 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4616 – 95 R00 ;RDQ2MTY_.pdf
138.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4625 – 03 ;RDQ2MJU_.pdf
61.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4625 – 92 ;RDQ2MJUTOTJSOTG_.pdf
55.79 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4625 – 92 ;RDQ2MJUTUKVE.pdf
61.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4626 – 95 R00 ;RDQ2MJY_.pdf
35.4 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4627 – 9 R97 ;RDQ2MJCTOTJSOTC_.pdf
31.91 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4627 – 92 R02 ;RDQ2MJC_.pdf
31.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4628 – 02 ;RDQ2MJG_.pdf
51.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4628 – 97 ;RDQ2MJGTOTC_.pdf
47.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4628 – 97 ;RDQ2MJGTUKVE.pdf
45.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4629 – 02 ;RDQ2MJK_.pdf
47.79 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4629 – 96 ;RDQ2MJKTOTY_.pdf
57.8 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4629 – 96 ;RDQ2MJKTUKVE.pdf
53.2 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4636 – 99 ;RDQ2MZYTOTK_.pdf
116.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4636 – 99 R04 ;RDQ2MZY_.pdf
125.14 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4682 – 87 R02 ;RDQ2ODI_.pdf
64.38 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4683 – 04 ;RDQ2ODM_.pdf
85.77 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4683 – 96 ;RDQ2ODMTOTY_.pdf
85.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4683 – 96 ;RDQ2ODMTUKVE.pdf
74.35 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4684 – 02 ;RDQ2ODQ_.pdf
70.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4684 – 02 ;RDQ2ODQTMDI_.pdf
77.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4684 – 02 ;RDQ2ODQTUKVE.pdf
53.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4684 – 99 ;RDQ2ODQTOTLFMQ__.pdf
45.22 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4693 – 03 ;RDQ2OTM_.pdf
103.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4693 – 97 R02 ;RDQ2OTMTOTDSMDJFMQ__.pdf
111.31 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4693 – 97 R02 ;RDQ2OTMTUKVE.pdf
94.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4715 – 98 ;RDQ3MTUTOTG_.pdf
45.36 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4715 – 98 R03 ;RDQ3MTU_.pdf
40.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4737 – 03 ;RDQ3MZC_.pdf
97.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4737 – 96 ;RDQ3MZCTOTZB.pdf
78.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4737 – 96a R01 ;RDQ3MZCTOTZBUJAX.pdf
91.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4737 – 96a R01 ;RDQ3MZCTUKVE.pdf
107.86 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4739 – 02 ;RDQ3MZK_.pdf
84.04 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 4739 – 96 ;RDQ3MZKTOTY_.pdf
81.66 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4739 – 96 ;RDQ3MZKTUKVE.pdf
73.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4740 – 02 ;RDQ3NDA_.pdf
35.61 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4740 – 95 ;RDQ3NDATOTU_.pdf
24.99 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4740 – 95 R00 ;RDQ3NDATUKVE.pdf
30.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4741 – 00 ;RDQ3NDE_.pdf
58.37 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4741 – 96 ;RDQ3NDETOTY_.pdf
D 4741 – 96 ;RDQ3NDETUKVE.pdf
86.45 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4742 – 02 ;RDQ3NDI_.pdf
140.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4742 – 02 ;RDQ3NDITUKVE.pdf
128.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4742 – 96 ;RDQ3NDITOTY_.pdf
139.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4746 – 98 ;RDQ3NDYTOTG_.pdf
110.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4746 – 98 R03 ;RDQ3NDY_.pdf
118.27 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 01 ;RDQ4MDYTMDE_.pdf
29.46 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 01 ;RDQ4MDYTMDFB.pdf
35.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 02 ;RDQ4MDYTMDI_.pdf
49.55 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 02 ;RDQ4MDYTUKVE.pdf
35.99 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 03 ;RDQ4MDY_.pdf
47.46 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4806 – 99 ;RDQ4MDYTOTK_.pdf
27.81 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4807 – 88 R99 ;RDQ4MDC_.pdf
44.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4808 – 01 ;RDQ4MDG_.pdf
64.54 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4808 – 98 ;RDQ4MDGTOTG_.pdf
47.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4808 – 98 ;RDQ4MDGTUKVE.pdf
54.84 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4809 – 00 ;RDQ4MDK_.pdf
83.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4809 – 95 ;RDQ4MDKTOTU_.pdf
58.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 00 ;RDQ4MTQTMDA_.pdf
401.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 00 ;RDQ4MTQTMDBB.pdf
257.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 01 ;RDQ4MTQTMDE_.pdf
263.58 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 01 ;RDQ4MTQTMDFB.pdf
337.19 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 02 ;RDQ4MTQTMDI_.pdf
459.8 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 03 ;RDQ4MTQ_.pdf
328.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4814 – 03 ;RDQ4MTQTMDM_.pdf
329.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4814 – 03 ;RDQ4MTQTUKVE.pdf
337 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4815 – 03 ;RDQ4MTU_.pdf
117.4 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4815 – 99 ;RDQ4MTUTOTK_.pdf
77.37 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4815 – 99 ;RDQ4MTUTOTLFMQ__.pdf
119 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4815 – 99 ;RDQ4MTUTUKVE.pdf
112.88 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4857 – 00 ;RDQ4NTCTMDA_.pdf
97.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4857 – 01 ;RDQ4NTCTMDE_.pdf
99.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4857 – 01 ;RDQ4NTCTMDFB.pdf
125.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4857 – 02 ;RDQ4NTCTMDI_.pdf
120.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4857 – 02 ;RDQ4NTCTUKVE.pdf
103.83 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4857 – 03 ;RDQ4NTC_.pdf
119.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4858 – 00 ;RDQ4NTGTMDA_.pdf
96.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4858 – 00 ;RDQ4NTGTUKVE.pdf
180.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4858 – 02 ;RDQ4NTG_.pdf
116.2 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4859 – 97 ;RDQ4NTKTOTC_.pdf
39.24 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4859 – 97 R03 ;RDQ4NTK_.pdf
37.57 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4860 – 91 R00 ;RDQ4NJA_.pdf
96.74 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4860 – 91 R95 ;RDQ4NJATOTFSOTU_.pdf
74.25 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4863 – 00 ;RDQ4NJMTMDA_.pdf
118.45 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4863 – 00 ;RDQ4NJMTUKVE.pdf
172.87 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4863 – 02 ;RDQ4NJM_.pdf
117.5 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4864 – 90 R00 ;RDQ4NJQ_.pdf
97.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4865 – 98 ;RDQ4NJUTOTG_.pdf
72.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4865 – 98 R03 ;RDQ4NJU_.pdf
79.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4865 – 98 R03 ;RDQ4NJUTUKVE.pdf
58.53 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4868 – 00 ;RDQ4NJG_.pdf
33.57 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4868 – 90 R95 ;RDQ4NJGTOTBSOTVFMQ__.pdf
23.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4868 – 90 R95 ;RDQ4NJGTUKVE.pdf
28.14 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4870 – 04 ;RDQ4NZA_.pdf
76.74 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4870 – 99 ;RDQ4NZATOTK_.pdf
74.5 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4870 – 99 ;RDQ4NZATUKVE.pdf
64.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4871 – 00 ;RDQ4NZE_.pdf
72.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4871 – 88 R95 ;RDQ4NZETUKVE.pdf
67.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4892 – 89 R99 ;RDQ4OTI_.pdf
37.69 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4893 – 94 R99 ;RDQ4OTM_.pdf
118.26 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4898 – 90 R00 ;RDQ4OTG_.pdf
42.29 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4927 – 01 ;RDQ5MJCTMDE_.pdf
51.99 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4927 – 01 ;RDQ5MJCTUKVE.pdf
270.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4927 – 02 ;RDQ5MJC_.pdf
142.08 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4927 – 96 ;RDQ5MJCTOTY_.pdf
43.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4928 – 00 ;RDQ5MJG_.pdf
57.34 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4928 – 00 ;RDQ5MJGTMDA_.pdf
49.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4929 – 99 ;RDQ5MJK_.pdf
70.04 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4930 – 94 R99 ;RDQ5MZA_.pdf
41.87 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4931 – 92 R02 ;RDQ5MZE_.pdf
45.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4931 – 92 R97 ;RDQ5MZETOTJSOTC_.pdf
33.54 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4950 – 01 ;RDQ5NTA_.pdf
53.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4950 – 95 R00 ;RDQ5NTATOTVSMDBFMQ__.pdf
32.98 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4950 – 95 R00 ;RDQ5NTATUKVE.pdf
43.95 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4951 – 00 ;RDQ5NTETMDA_.pdf
39.91 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4951 – 00 ;RDQ5NTETUKVE.pdf
46.35 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4951 – 02 ;RDQ5NTE_.pdf
58.86 KB, Lượt tải về: 12, Tải điểm: Thưởng -2 điểm
D 4952 – 02 ;RDQ5NTI_.pdf
27.48 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4952 – 97 ;RDQ5NTITOTC_.pdf
25.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4952 – 97 ;RDQ5NTITUKVE.pdf
21.49 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4953 – 99 ;RDQ5NTM_.pdf
103.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 4998 – 95 ;RDQ5OTGTOTU_.pdf
65.12 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4998 – 95 R03 ;RDQ5OTG_.pdf
70.25 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 4998 – 95 R03 ;RDQ5OTGTUKVE.pdf
54.7 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5000 – 89 R00 ;RDUWMDA_.pdf
100.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5000 – 89 R95 ;RDUWMDATODLSOTVFMQ__.pdf
87.73 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5001 – 03 ;RDUWMDE_.pdf
88.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5001 – 90a R00 ;RDUWMDETOTBBUJAWRTE_.pdf
95.93 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5001 – 90a R00 ;RDUWMDETUKVE.pdf
82.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5001 – 90a R95 ;RDUWMDETOTBBUJK1RTE_.pdf
70.94 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5002 – 99 ;RDUWMDI_.pdf
51.45 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5003 – 95 R00 ;RDUWMDM_.pdf
34.15 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5004 – 89 R99 ;RDUWMDQ_.pdf
49.42 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5006 – 02 ;RDUWMDYTMDI_.pdf
35.9 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5006 – 02 ;RDUWMDYTUKVE.pdf
27.6 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5006 – 03 ;RDUWMDY_.pdf
36.97 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5006 – 96 ;RDUWMDYTOTY_.pdf
25.1 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5018 – 89 R99 ;RDUWMTG_.pdf
71.59 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5056 – 02 ;RDUWNTY_.pdf
45.1 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5056 – 96 ;RDUWNTYTOTY_.pdf
42.28 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5056 – 96 ;RDUWNTYTUKVE.pdf
34.87 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5059 – 98 ;RDUWNTKTOTG_.pdf
62.22 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5059 – 98 R03 ;RDUWNTK_.pdf
68.7 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5133 – 01 ;RDUXMZM_.pdf
166.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5133 – 99 ;RDUXMZMTOTK_.pdf
110.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5133 – 99 ;RDUXMZMTUKVE.pdf
141.16 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5134 – 98 ;RDUXMZQTOTG_.pdf
157.46 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5134 – 98 R03 ;RDUXMZQ_.pdf
153.44 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5182 – 97 ;RDUXODITOTDFMQ__.pdf
306.62 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5182 – 97 R02 ;RDUXODI_.pdf
129.53 KB, Lượt tải về: 11, Tải điểm: Thưởng -2 điểm
D 5183 – 95 R99 ;RDUXODM_.pdf
100.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5184 – 00 ;RDUXODQTMDA_.pdf
38.61 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5184 – 00 ;RDUXODQTUKVE.pdf
42.61 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5184 – 01 ;RDUXODQ_.pdf
56.47 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5185 – 02 ;RDUXODU_.pdf
71.22 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5185 – 02 ;RDUXODUTMDI_.pdf
66.27 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5185 – 02 ;RDUXODUTUKVE.pdf
48.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5185 – 97 ;RDUXODUTOTC_.pdf
42.52 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5186 – 03 ;RDUXODY_.pdf
64.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5186 – 99 ;RDUXODYTOTK_.pdf
64.3 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5187 – 91 R02 ;RDUXODC_.pdf
46.41 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5187 – 91 R97 ;RDUXODCTOTFSOTC_.pdf
34.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5188 – 04 ;RDUXODG_.pdf
46.65 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5188 – 04 ;RDUXODGTMDQ_.pdf
D 5188 – 04 ;RDUXODGTUKVE.pdf
D 5188 – 99 ;RDUXODGTOTK_.pdf
47.37 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5190 – 01 ;RDUXOTA_.pdf
79.61 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5190 – 99 ;RDUXOTATOTK_.pdf
64.15 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5190 – 99 ;RDUXOTATUKVE.pdf
72.36 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5191 – 01 ;RDUXOTETMDE_.pdf
51.89 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5191 – 02 ;RDUXOTETMDI_.pdf
50.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5191 – 03 ;RDUXOTETMDM_.pdf
50.91 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5191 – 03 ;RDUXOTETUKVE.pdf
41.73 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5191 – 04 ;RDUXOTE_.pdf
51.91 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5191 – 99 ;RDUXOTETOTK_.pdf
36.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5234 – 92 R02 ;RDUYMZQ_.pdf
27.43 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5234 – 92 R97 ;RDUYMZQTOTJSOTC_.pdf
28.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5236 – 02 ;RDUYMZYTMDI_.pdf
685.75 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5236 – 02 ;RDUYMZYTUKVE.pdf
571.74 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5236 – 03 ;RDUYMZY_.pdf
378.82 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5236 – 99 ;RDUYMZYTOTLBRTE_.pdf
334.71 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5273 – 92 R02 ;RDUYNZM_.pdf
32.64 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5273 – 92 R97 ;RDUYNZMTOTJSOTC_.pdf
32.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5274 – 00 ;RDUYNZQ_.pdf
31.13 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5274 – 92 R97 ;RDUYNZQTOTJSOTC_.pdf
20.29 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5274 – 92 R97 ;RDUYNZQTUKVE.pdf
26.58 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5275 – 03 ;RDUYNZU_.pdf
89.03 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5275 – 92 R98 ;RDUYNZUTOTJSOTHFMQ__.pdf
95.48 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5275 – 92 R98 ;RDUYNZUTUKVE.pdf
80.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5291 – 01 ;RDUYOTETUKVE.pdf
51 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5291 – 02 ;RDUYOTE_.pdf
61.86 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5291 – 96 ;RDUYOTETOTY_.pdf
37.85 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5292 – 99 ;RDUYOTI_.pdf
66.6 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5293 – 02 ;RDUYOTMTMDI_.pdf
566.81 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5293 – 02 ;RDUYOTMTUKVE.pdf
548.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5293 – 04 ;RDUYOTM_.pdf
566.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5293 – 99 ;RDUYOTMTOTLBRTE_.pdf
573.51 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5302 – 00 ;RDUZMDITMDBB.pdf
2.69 MB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5302 – 01 ;RDUZMDITMDE_.pdf
2.71 MB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
GMT+7, 17/11/2026 12:23 , Processed in 0.140106 second(s), 20 queries .
