Xem: 7609|Trả lời: 0
ASTM 2004-Volume 05.03 Petroleum Products and Lubricants (III) D 5303 - D 6553
! ~+ m1 g4 X0 V1 k6 l/ X4 }% V! R
: }# F! P, q" F" I! g4 {, M) R2 @D5303-92R02E01 Test Method for Trace Carbonyl Sulfide in Propylene by Gas Chromatography
! y8 O" D$ i) L- q* |D5304-03 Test Method for Assessing Middle Distillate Fuel Storage Stability by Oxygen Overpressure
) U, T) y& r* o0 rD5305-97R02 Test Method for Determination of Ethyl Mercaptan in LP-Gas Vapor5 |  v  |1 [/ J3 N
D5306-92R02E01 Test Method for Linear Flame Propagation Rate of Lubricating Oils and Hydraulic Fluids' l& x8 ^; D$ Z3 Z( P! L) S
D5307-97R02E01 Test Method for Determination of Boiling Range Distribution of Crude Petroleum by Gas Chromatography7 y5 ~) _0 R. B
D5372-04 Guide for Evaluation of Hydrocarbon Heat Transfer Fluids6 S9 D& Q) B! }. w; w
D5384-95R00E01 Test Methods for Chlorine in Used Petroleum Products (Field Test Kit Method)- o1 W) T  V% H5 G+ P" c
D5441-98R03E01 Test Method for Analysis of Methyl Tert-Butyl Ether (MTBE) by Gas Chromatography8 j" M. F, c$ l+ ?% i) ?
D5442-93R03E01 Test Method for Analysis of Petroleum Waxes by Gas Chromatography
) Q0 l! q; @+ ~: d. [D5443-04 Test Method for Paraffin, Naphthene, and Aromatic Hydrocarbon Type Analysis in Petroleum Distillates Through 200|SDC by Multi-Dimensional Gas Chromatography
$ ?2 C$ t7 m/ fD5452-00 Test Method for Particulate Contamination in Aviation Fuels by Laboratory Filtration
& K9 O! C% c! A. VD5453-04 Test Method for Determination of Total Sulfur in Light Hydrocarbons, Spark Ignition Engine Fuel, Diesel Engine Fuel, and Engine Oil by Ultraviolet Fluorescence- s: V8 |: E. x& w# |* l0 u, i
D5480 Test Method for Engine Oil Volatility by Gas Chromatography
& V' H8 O; |; M6 R& v7 RD5481-04 Test Method for Measuring Apparent Viscosity at High-Temperature and High-Shear Rate by Multicell Capillary Viscometer
" q3 T! M/ _) k) t' c2 gD5482-01 Test Method for Vapor Pressure of Petroleum Products (Mini Method\MAtmospheric)5 ?6 x. ]2 L& `
D5483-02 Test Method for Oxidation Induction Time of Lubricating Greases by Pressure Differential Scanning Calorimetry+ U8 S* a6 K, |9 b9 B0 N
D5500-98R03E01 Test Method for Vehicle Evaluation of Unleaded Automotive Spark-Ignition Engine Fuel for Intake Valve Deposit Formation' E1 w% q  p1 |  n+ g! `! I# G
D5501-04 Test Method for Determination of Ethanol Content of Denatured Fuel Ethanol by Gas Chromatography- |; V+ \+ s  L( T9 j& D; S3 H
D5502-00 Test Method for Apparent Density by Physical Measurements of Manufactured Anode and Cathode Carbon Used by the Aluminum Industry5 o& `2 C* {! h1 D: r
D5533 Test Method for Evaluation of Automotive Engine Oils in the Sequence IIIE, Spark-Ignition Engine& u1 z% j* \8 D, O" H8 K: m
D5534-94R99 Test Method for Vapor-Phase Rust-Preventing Characteristics of Hydraulic Fluids
8 h- a- H1 t& N: {* M; S( D' [! D) ?D5579-04 Test Method for Evaluating the Thermal Stability of Manual Transmission Lubricants in a Cyclic Durability Test3 @; C4 H* _' g" {: Z' b
D5580-02 Test Method for Determination of Benzene, Toluene, Ethylbenzene, -Xylene, -Xylene, C and Heavier Aromatics, and Total Aromatics in Finished Gasoline by Gas Chromatography
4 m( D9 e1 T" r3 @D5598-01 Test Method for Evaluating Unleaded Automotive Spark-Ignition Engine Fuel for Electronic Port Fuel Injector Fouling
& d; D$ |/ `3 a" q% X. mD5599-00 Test Method for Determination of Oxygenates in Gasoline by Gas Chromatography and Oxygen Selective Flame Ionization Detection
1 _$ `3 a4 y: D5 YD5600-04 Test Method for Trace Metals in Petroleum Coke by Inductively Coupled Plasma Atomic Emission Spectrometry (ICP-AES)
2 K; R  s8 M7 J3 z! nD5619-00 Test Method for Comparing Metal Removal Fluids Using the Tapping Torque Test Machine* N3 a' \. h1 U8 V
D5620-94R04 Test Method for Evaluating Thin Film Fluid Lubricants in a Drain and Dry Mode Using a Pin and Vee Block Test Machine
4 G( i. j: j; TD5621-01 Test Method for Sonic Shear Stability of Hydraulic Fluids1 v9 i0 C' F* n  f+ B/ n& q2 ^
D5622-95R00 Test Methods for Determination of Total Oxygen in Gasoline and Methanol Fuels by Reductive Pyrolysis0 I3 Y9 R) N( S/ B
D5623-94R04E01 Test Method for Sulfur Compounds in Light Petroleum Liquids by Gas Chromatography and Sulfur Selective Detection
1 F- y3 W9 z. N. [* q# @D5662-99 Test Method for Determining Automotive Gear Oil Compatability with Typical Oil Seal Elastomers3 N' h: M9 [3 t0 ~. v% p1 I  @
D5704-04A Test Method for Evaluation of the Thermal and Oxidative Stability of Lubricating Oils Used for Manual Transmissions and Final Drive Axles
9 u7 @+ @$ M7 [/ H* x7 L1 JD5705-03 Test Method for Measurement of Hydrogen Sulfide in the Vapor Phase Above Residual Fuel Oils/ k9 I; U; n$ b& m1 e; g
D5706-97R02E01 Test Method for Determining Extreme Pressure Properties of Lubricating Greases Using A High-Frequency, Linear-Oscillation (SRV) Test Machine
& B% \( [& z9 G0 f" M/ B  wD5707-98R03E01 Test Method for Measuring Friction and Wear Properties of Lubricating Grease Using a High-Frequency, Linear-Oscillation (SRV) Test Machine3 c7 _4 P6 O+ O2 ]8 F$ T: S
D5708-02 Test Methods for Determination of Nickel, Vanadium, and Iron in Crude Oils and Residual Fuels by Inductively Coupled Plasma (ICP) Atomic Emission Spectrometry0 D  e6 \' J% @4 }' p: d' W5 g
D5709-95R00E01 Test Method for Sieve Analysis of Petroleum Coke% J6 x& t2 Z6 X; e! T9 `" z
D5760-95E01 Specification for Performance of Manual Transmission Gear Lubricants. Y2 m- u( ^& N9 k
D5761-96R01 Practice for Emulsification/Suspension of Multiphase Fluid Waste Materials1 ^: M3 ^6 F. c# t8 Z, y& v
D5762-02 Test Method for Nitrogen in Petroleum and Petroleum Products by Boat-Inlet Chemiluminescence
7 X" ~* Z' l" G# w% H, d( a+ uD5763-95R01 Test Method for Oxidation and Thermal Stability Characteristics of Gear Oils Using Universal Glassware8 m7 I% o: t- C& J/ t
D5769-04 Test Method for Determination of Benzene, Toluene, and Total Aromatics in Finished Gasolines by Gas Chromatography/Mass Spectrometry/ W2 S2 m  z" r+ j/ S2 c1 c5 V  S
D5770-02 Test Method for Semiquantitative Micro Determination of Acid Number of Lubricating Oils During Oxidation Testing" @* ?  {7 K1 B# V$ D$ W
D5771-04 Test Method for Cloud Point of Petroleum Products (Optical Detection Stepped Cooling Method)  t3 R. g- [& ?" |! C6 g
D5772-04 Test Method for Cloud Point of Petroleum Products (Linear Cooling Rate Method)
% K* w* ?$ N4 S- A4 PD5773-04 Test Method for Cloud Point of Petroleum Products (Constant Cooling Rate Method)
! r! S* v& g/ z1 V7 T; uD5797-96R01 Specification for Fuel Methanol (M70-M85) for Automotive Spark-Ignition Engines. t- S% f8 B. A5 x
D5798-99R04 Specification for Fuel Ethanol (Ed75-Ed85) for Automotive Spark-Ignition Engines
2 `' L( E% X3 T% a0 E0 CD5799-95R04 Test Method for Determination of Peroxides in Butadiene- i% T1 s, d4 q, M# v
D5800-04A Test Method for Evaporation Loss of Lubricating Oils by the Noack Method* x2 R( j7 B/ P4 ^$ `
D5842-95R00 Practice for Sampling and Handling of Fuels for Volatility Measurement* [- u' m. C5 ]: \" x3 M; V
D5844 Test Method for Evaluation of Automotive Engine Oils for Inhibition of Rusting (Sequence IID)8 G7 y$ y: k# q" d. C- E
D5845-01 Test Method for Determination of MTBE, ETBE, TAME, DIPE, Methanol, Ethanol and -Butanol in Gasoline by Infrared Spectroscopy
- C( V& _% G( o/ |D5846-02 Test Method for Universal Oxidation Test for Hydraulic and Turbine Oils Using the Universal Oxidation Test Apparatus
: _- |( _0 g/ i9 J" \3 l& AD5853-95R00E01 Test Method for Pour Point of Crude Oils
7 n' C/ s7 A$ o# |* E: |& C/ ]7 uD5854-96R00 Practice for Mixing and Handling of Liquid Samples of Petroleum and Petroleum Products
" S. b8 w; d: t4 Q1 c. S: I4 ~D5862-03 Test Method for Evaluation of Engine Oils in Two-Stroke Cycle Turbo-Supercharged 6V92TA Diesel Engine
8 R% [% ^' g& P$ G+ oD5863-00A Test Methods for Determination of Nickel, Vanadium, Iron, and Sodium in Crude Oils and Residual Fuels by Flame Atomic Absorption Spectrometry
% |, P- f) x0 O% n1 lD5864-00 Test Method for Determining Aerobic Aquatic Biodegradation of Lubricants or Their Components$ {6 q+ R' @& C1 D7 G( L2 I: q- [
D5901-03 Test Method for Freezing Point of Aviation Fuels (Automated Optical Method)+ Q, H% @6 |) l. A. n2 ~
D5949-01 Test Method for Pour Point of Petroleum Products (Automatic Pressure Pulsing Method)4 W3 H5 `' x) |% z' ~4 a
D5950-02 Test Method for Pour Point of Petroleum Products (Automatic Tilt Method)# I8 V7 P- r% D1 i1 v4 E# b
D5966-02 Test Method for Evaluation of Engine Oils for Roller Follower Wear in Light-Duty Diesel Engine2 C6 I& @* R. I, b1 B; t% ~2 I" x
D5967-04 Test Method for Evaluation of Diesel Engine Oils in T-8 Diesel Engine$ Y( h* t. J- h! i& L; a
D5968-04 Test Method for Evaluation of Corrosiveness of Diesel Engine Oil at 121|SDC
. X& w: x- a# S% @" QD5969-02 Test Method for Corrosion-Preventive Properties of Lubricating Greases in Presence of Dilute Synthetic Sea Water Environments7 [3 d7 P2 k" j# \' ?  N% k
D5972-02 Test Method for Freezing Point of Aviation Fuels (Automatic Phase Transition Method)
) O! R/ f( a1 Y6 V1 U' t6 wD5983-97R02 Specification for Methyl Tertiary-Butyl Ether (MTBE) for Downstream Blending for Use in Automotive Spark-Ignition Engine Fuel* P3 P4 I2 B- }% \# v
D5984-97R02E01 Test Method for Semi-Quantitative Field Test Method for Base Number in New and Used Lubricants by Color-Indicator Titration- H$ C; a8 L# z0 w4 T
D5985-02 Test Method for Pour Point of Petroleum Products (Rotational Method)
" c) `; B6 z8 f7 KD5986-96R01 Test Method for Determination of Oxygenates, Benzene, Toluene, C\NC Aromatics and Total Aromatics in Finished Gasoline by Gas Chromatography/Fourier Transform Infrared Spectroscopy) D8 w+ n7 y4 w& Y. G5 v, C" Q6 d
D6006-97AR03 Guide for Assessing Biodegradability of Hydraulic Fluids
' z" Q/ g  K! S- }! g; KD6021-96R01E01 Test Method for Measurement of Total Hydrogen Sulfide in Residual Fuels by Multiple Headspace Extraction and Sulfur Specific Detection
% J6 Q1 I4 Y' aD6022-01 Practice for Calculation of Permanent Shear Stability Index
5 D4 n+ e& r( {: P+ _5 ?D6045-04 Test Method for Color of Petroleum Products by the Automatic Tristimulus Method
/ D6 h' f  ]  e- y' oD6046-02 Classification of Hydraulic Fluids for Environmental Impact8 }4 i3 I0 L7 D% M/ S8 K& l0 q# k
D6074-99 Guide for Characterizing Hydrocarbon Lubricant Base Oils8 S0 M3 Y7 }$ p0 X) b3 L6 z
D6078-04 Test Method for Evaluating Lubricity of Diesel Fuels by the Scuffing Load Ball-on-Cylinder Lubricity Evaluator (SLBOCLE)
+ |, x/ P4 N8 G% B4 \! W6 l5 a+ B, Y4 ED6079-04 Test Method for Evaluating Lubricity of Diesel Fuels by the High-Frequency Reciprocating Rig (HFRR)+ F3 L1 L) E: R9 ]1 z
D6080-97R02 Practice for Defining the Viscosity Characteristics of Hydraulic Fluids
  h. D' g* l5 ?* H4 a. x, g; b: xD6081-98R04 Practice for Aquatic Toxicity Testing of Lubricants: Sample Preparation and Results Interpretation
: C+ I. s9 h+ w. P, R/ qD6082-01 Test Method for High Temperature Foaming Characteristics of Lubricating Oils8 [( `) ~% x# D
D6120-97R02 Test Method for Electrical Resistivity of Anode and Cathode Carbon Material at Room Temperature8 Y8 U+ e& O3 E
D6121-04 Test Method for Evaluation of Load-Carrying Capacity of Lubricants Under Conditions of Low Speed and High Torque Used for Final Hypoid Drive Axles
% `9 i* v& N4 T9 G" E2 ZD6122-01 Practice for Validation of Multivariate Process Infrared Spectrophotometers
$ [: @; T$ W- w8 s: D1 QD6138-03 Test Method for Determination of Corrosion-Preventive Properties of Lubricating Greases Under Dynamic Wet Conditions (Emcor Test)8 A4 {; e! V* d9 G4 G
D6139-00 Test Method for Determining the Aerobic Aquatic Biodegradation of Lubricants or Their Components Using the Gledhill Shake Flask
6 N' C% y; b% g; b, {& Z5 j8 ~1 ID6158-99 Specification for Mineral Hydraulic Oils4 O6 P. T. y; r
D6159-97R02 Test Method for Determination of Hydrocarbon Impurities in Ethylene by Gas Chromatography  H' c6 n- b. @8 e9 z: E, }
D6160-98R03E01 Test Method for Determination of Polychlorinated Biphenyls (PCBs) in Waste Materials by Gas Chromatography4 D# ^% N! f3 I
D6184-98 Test Method for Oil Separation from Lubricating Grease (Conical Sieve Method)2 X( n; d( C4 n& w
D6185-97R02E01 Practice for Evaluating Compatibility of Binary Mixtures of Lubricating Greases
) Q3 W5 D" V$ I* i, ID6186-98R03E01 Test Method for Oxidation Induction Time of Lubricating Oils by Pressure Differential Scanning Calorimetry (PDSC)( L, p* ^/ N  J- Q$ s* F
D6200-01 Test Method for Determination of Cooling Characteristics of Quench Oils by Cooling Curve Analysis7 T. \' H1 D" ]5 p- a" U8 r$ b
D6201-04 Test Method for Dynamometer Evaluation of Unleaded Spark-Ignition Engine Fuel for Intake Valve Deposit Formation4 T- }! ^+ v/ X2 J1 l. m
D6202-02 Test Method for Automotive Engine Oils on the Fuel Economy of Passenger Cars and Light-Duty Trucks in the Sequence VIA Spark Ignition Engine% l$ D6 ~6 m8 a3 }7 h
D6203-97R01 Test Method for Thermal Stability of Way Lubricants
( C& x& n6 n! z; GD6217-98R03E01 Test Method for Particulate Contamination in Middle Distillate Fuels by Laboratory Filtration
4 S. v5 v7 q! i0 GD6224-02 Practice for In-Service Monitoring of Lubricating Oil for Auxiliary Power Plant Equipment; }4 }, k: ?6 H
D6227-04A Specification for Grade 82 Unleaded Aviation Gasoline
0 e1 I5 ?7 {% l: h1 ^- C2 x/ cD6258-04 Test Method for Determination of Solvent Red 164 Dye Concentration in Diesel Fuels
' U6 U5 C# y) }: o! H; s: b; ND6259-98R04 Practice for Determination of a Pooled Limit of Quantitation
) k) H0 x4 q+ W4 M0 @: J% w9 U$ JD6277-01 Test Method for Determination of Benzene in Spark-Ignition Engine Fuels Using Mid Infrared Spectroscopy& V6 j2 V: `" Z# ]0 N) F" L4 O
D6278-02 Test Method for Shear Stability of Polymer Containing Fluids Using a European Diesel Injector Apparatus% V8 x% ]( i; T$ R6 X5 n1 }
D6293-98R03E01 Test Method for Oxygenates and Paraffin, Olefin, Naphthene, Aromatic(O-PONA) Hydrocarbon Types in Low-Olefin Spark Ignition Engine Fuels by Gas Chromatography
( Z! R9 f9 p3 X1 _D6296-98R03E01 Test Method for Total Olefins in Spark-ignition Engine Fuels by Multi-dimensional Gas Chromatography
# [. E/ X0 O) P1 [3 [4 D) g2 r6 qD6299-02 Practice for Applying Statistical Quality Assurance Techniques to Evaluate Analytical Measurement System Performance5 G" o4 k1 U# Y2 b- v+ @7 W
D6300-04 Practice for Determination of Precision and Bias Data for Use in Test Methods for Petroleum Products and Lubricants
7 W( k# p+ B, M' OD6304-04A Test Method for Determination of Water in Petroleum Products, Lubricating Oils, and Additives by Coulometric Karl Fischer Titration' V+ d1 ?3 d+ X$ f' r9 G& c6 P
D6334-98R03E01 Test Method for Sulfur in Gasoline by Wavelength Dispersive X-Ray Fluorescence
& k0 T# T$ d/ a2 h$ @  R+ @$ yD6335-03B Test Method for Determination of High Temperature Deposits by Thermo-Oxidation Engine Oil Simulation Test$ S  W- E9 ]/ T0 Q/ A
D6351-99 Test Method for Determination of Low Temperature Fluidity and Appearance of Hydraulic Fluids
! y0 o$ j9 U: _% n2 O: G9 @( ]D6352-04E01 Test Method for Boiling Range Distribution of Petroleum Distillates in Boiling Range from 174 to 700|SDC by Gas Chromatography4 F1 N/ m/ w5 V8 E5 L
D6353-98R03 Guide for Sampling Plan and Core Sampling for Prebaked Anodes Used in Aluminum Production
: h! c& ^; x3 F8 o: y' Y4 w' ED6354-98R03 Guide for Sampling Plan and Core Sampling of Carbon Cathode Blocks Used in Aluminum Production
2 J# T( i  ]3 C; [D6371-99 Test Method for Cold Filter Plugging Point of Diesel and Heating Fuels8 _! @; e( E! K* \0 i
D6374-99R04 Test Method for Volatile Matter in Green Petroleum Coke Quartz Crucible Procedure, h: w2 H* B( J3 N$ Q1 f# M, H
D6375-99A Test Method for Evaporation Loss of Lubricating Oils by Thermogravimetric Analyzer (TGA) Noack Method4 A- _2 K+ ^' b" L' M
D6376-99 Test Method for Determination of Trace Metals in Petroleum Coke by Wavelength Dispersive X-ray Fluorescence Spectroscopy: o5 e5 G) E, T8 K  V
D6377-03 Test Method for Determination of Vapor Pressure of Crude Oil: VPCR (Expansion Method)
* T3 c- B" O: I4 i, h# i5 g7 RD6378-03 Test Method for Determination of Vapor Pressure (VP) of Petroleum Products, Hydrocarbons, and Hydrocarbon-Oxygenate Mixtures (Triple Expansion Method)D6379-04 Test Method for Determination of Aromatic Hydrocarbon Types in Aviation Fuels and Petroleum Distillates\MHigh Performance Liquid Chromatography Method with Refractive Index Detection
9 e; u- w/ M9 e: t. i& tD6384-99AE01 Terminology Relating to Biodegradability and Ecotoxicity of Lubricants
" p5 a* }+ L( P. DD6417-03 Test Method for Estimation of Engine Oil Volatility by Capillary Gas Chromatography7 c; Y! r6 k% U6 @- u# a9 J
D6421-99AR04 Test Method for Evaluating Automotive Spark-Ignition Engine Fuel for Electronic Port Fuel Injector Fouling by Bench Procedure
7 G. q' n- |5 j6 c5 E, Q7 \% Y5 yD6422-99 Test Method for Water Tolerance (Phase Separation) of Gasoline-Alcohol Blends9 l  `1 s# T0 v+ d5 n- A# p
D6423-99R04 Test Method for Determination of pHe of Ethanol, Denatured Fuel Ethanol, and Fuel Ethanol (Ed75-Ed85)
$ \  {( r$ v  K( U* I3 k4 [D6424-04A Practice for Octane Rating Naturally Aspirated Spark Ignition Aircraft Engines  u: ~1 D  o8 W
D6425-02 Test Method for Measuring Friction and Wear Properties of Extreme Pressure (EP) Lubricating Oils Using SRV Test Machine% e! k8 E1 V. G" u% t! N
D6426-04 Test Method for Determining Filterability of Middle Distillate Fuel Oils
8 V6 P3 p9 z4 Z  p! I* QD6439-99 Guide for Cleaning, Flushing, and Purification of Steam, Gas, and Hydroelectric Turbine Lubrication Systems. J, C& Z( `$ p+ H' k& q
D6443-04 Test Method for Determination of Calcium, Chlorine, Copper, Magnesium, Phosphorus, Sulfur, and Zinc in Unused Lubricating Oils and Additives by Wavelength Dispersive X-ray Fluorescence Spectrometry (Mathematical * q2 t# C' }+ @& J9 v
Correction Procedure)( S% O- f8 V- H6 f6 Q# i, |
D6445-99R04E01 Test Method for Sulfur in Gasoline by Energy-Dispersive X-ray Fluorescence Spectrometry
/ V- c; c  V5 vD6446-01 Test Method for Estimation of Net Heat of Combustion (Specific Energy) of Aviation Fuels
+ y+ [: Z. q% uD6447-03 Test Method for Hydroperoxide Number of Aviation Turbine Fuels by Voltammetric Analysis2 D, l9 M0 J  X: L
D6448-99 Specification for Industrial Burner Fuels from Used Lubricating Oils" b0 Z# K. [+ a
D6450-99 Test Method for Flash Point by Continuously Closed Cup (CCCFP) Tester, [( ?3 z: i7 Z. ]5 }- S
D6468-99R04 Test Method for High Temperature Stability of Distillate Fuels( b: `% \. a: M7 }. R* S) C
D6469-04 Guide for Microbial Contamination in Fuels and Fuel Systems& d; P" E" }" ?6 ?& u2 q' d
D6470-99R04 Test Method for Salt in Crude Oils (Potentiometric Method)
- Z8 @7 Y+ u3 aD6481-99R04 Test Method for Determination of Phosphorus, Sulfur, Calcium, and Zinc in Lubrication Oils by Energy Dispersive X-ray Fluorescence Spectroscopy$ d: D- w9 ]- _# x, D
D6482-01 Test Method for Determination of Cooling Characteristics of Aqueous Polymer Quenchants by Cooling Curve Analysis with Agitation (Tensi Method)
# W) |) G7 a* i. yD6483-04 Test Method for Evaluation of Diesel Engine Oils in T-9 Diesel Engine
7 p0 |( e$ \1 V, T+ M- w. uD6514-03 Test Method for High Temperature Universal Oxidation Test for Turbine Oils
# C9 l& X- M, T! Y  h3 N& u  g* dD6546-00 Test Methods for and Suggested Limits for Determining Compatibility of Elastomer Seals for Industrial Hydraulic Fluid Applications
1 ~) f, t. t; F- Q9 xD6547-00 Test Method for Corrosiveness of Lubricating Fluid to Bimetallic Couple
% ?2 P* ^, B) b3 Y' x1 eD6549-01 Test Method for Determination of Cooling Characteristics of Quenchants by Cooling Curve Analysis with Agitation (Drayton Unit)
6 J* O# t5 c; rD6550-00 Test Method for Determination of Olefin Content of Gasolines by Supercritical-Fluid Chromatography
% A/ m7 g' R# MD6553-00 Test Method for Coolant Compatibility of Way Lubricants8 m; ^' _# T' m/ R! D) [
D 5303 – 92 R02 ;RDUZMDM_.pdf
65.1 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 5304 – 02 ;RDUZMDQTMDI_.pdf
61.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5304 – 02 ;RDUZMDQTMDJB.pdf
73.28 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5304 – 02 ;RDUZMDQTUKVE.pdf
58.48 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5304 – 03 ;RDUZMDQ_.pdf
70.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5305 – 97 ;RDUZMDUTOTC_.pdf
31.59 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5305 – 97 R02 ;RDUZMDU_.pdf
44.81 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5306 – 92 R02 ;RDUZMDY_.pdf
56.72 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5306 – 92 R97 ;RDUZMDYTOTJSOTC_.pdf
50.75 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5307 – 97 ;RDUZMDCTOTC_.pdf
91.33 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5307 – 97 R02 ;RDUZMDC_.pdf
97.53 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5372 – 93 R98 ;RDUZNZI_.pdf
34.66 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5384 – 95 R00 ;RDUZODQ_.pdf
47.5 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5441 – 93 ;RDU0NDETOTM_.pdf
41.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5441 – 98 ;RDU0NDETOTG_.pdf
62.88 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5441 – 98 R03 ;RDU0NDE_.pdf
68.51 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5442 – 93 R03 ;RDU0NDI_.pdf
87.05 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 5442 – 93 R98 ;RDU0NDITOTNSOTG_.pdf
82.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5443 – 93 R03 ;RDU0NDM_.pdf
143.35 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5443 – 93 R98 ;RDU0NDMTOTNSOTG_.pdf
140.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5452 – 00 ;RDU0NTI_.pdf
126.35 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5452 – 99 ;RDU0NTITUKVE.pdf
106.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5453 – 00 ;RDU0NTMTMDA_.pdf
80.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5453 – 00 ;RDU0NTMTMDBFMQ__.pdf
114.07 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5453 – 03 ;RDU0NTM_.pdf
104.19 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5453 – 03 ;RDU0NTMTMDM_.pdf
112.88 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5453 – 03 ;RDU0NTMTUKVE.pdf
90.97 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5481 – 04 ;RDU0ODE_.pdf
61.11 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5481 – 96 ;RDU0ODETOTY_.pdf
37.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5481 – 96 R01 ;RDU0ODETOTZSMDE_.pdf
60.86 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5481 – 96 R01 ;RDU0ODETUKVE.pdf
42.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5482 – 01 ;RDU0ODI_.pdf
58.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5482 – 99 ;RDU0ODITOTK_.pdf
36.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5482 – 99 ;RDU0ODITUKVE.pdf
41.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5483 – 02 ;RDU0ODM_.pdf
57.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5483 – 95 ;RDU0ODMTOTU_.pdf
43.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5483 – 95 ;RDU0ODMTUKVE.pdf
47.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5500 – 98 ;RDU1MDATOTG_.pdf
1.41 MB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5500 – 98 R03 ;RDU1MDA_.pdf
543.77 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5500 – 98 R03 ;RDU1MDATUKVE.pdf
505.1 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5501 – 04 ;RDU1MDE_.pdf
55.69 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
D 5501 – 94 R98 ;RDU1MDETOTRSOTHFMQ__.pdf
61.15 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 5501 – 94 R98 ;RDU1MDETUKVE.pdf
45.09 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 5502 – 00 ;RDU1MDI_.pdf
38.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5502 – 94 R99 ;RDU1MDITUKVE.pdf
34.69 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5534 – 94 R99 ;RDU1MZQ_.pdf
85.06 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5579 – 00 ;RDU1NZKTMDA_.pdf
603.76 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5579 – 03 ;RDU1NZKTMDM_.pdf
598.5 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5579 – 03 ;RDU1NZKTUKVE.pdf
208.14 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5579 – 04 ;RDU1NZK_.pdf
221.82 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5580 – 00 ;RDU1ODATMDA_.pdf
84.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5580 – 00 ;RDU1ODATUKVE.pdf
90.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5580 – 02 ;RDU1ODA_.pdf
116.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5598 – 01 ;RDU1OTG_.pdf
159.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5598 – 95 ;RDU1OTGTOTVB.pdf
132.26 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5598 – 95 ;RDU1OTGTUKVE.pdf
140.15 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5599 – 00 ;RDU1OTK_.pdf
81.36 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5599 – 95 ;RDU1OTKTUKVE.pdf
D 5600 – 98 ;RDU2MDATOTG_.pdf
46.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5600 – 98 R03 ;RDU2MDA_.pdf
44.55 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5600 – 98 R03 ;RDU2MDATUKVE.pdf
33.64 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5619 – 00 ;RDU2MTK_.pdf
74.95 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5619 – 94 ;RDU2MTKTUKVE.pdf
71.41 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5620 – 94 R99 ;RDU2MJA_.pdf
49.02 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5621 – 01 ;RDU2MJE_.pdf
36.34 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5621 – 94 ;RDU2MJETOTQ_.pdf
25.88 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5621 – 94 ;RDU2MJETUKVE.pdf
28.91 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5622 – 95 R00 ;RDU2MJI_.pdf
44.31 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5623 – 94 R99 ;RDU2MJM_.pdf
70.49 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5662 – 99 ;RDU2NJI_.pdf
727.35 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5704 – 00 ;RDU3MDQTMDBB.pdf
2.22 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 5704 – 03 ;RDU3MDQTMDM_.pdf
187.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5704 – 03 ;RDU3MDQTMDNB.pdf
233.84 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5704 – 03 ;RDU3MDQTUKVE.pdf
204.78 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5704 – 04 ;RDU3MDQ_.pdf
237.39 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5705 – 03 ;RDU3MDU_.pdf
91.48 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5705 – 95 R00 ;RDU3MDUTOTVSMDBFMQ__.pdf
98.22 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5705 – 95 R00 ;RDU3MDUTUKVE.pdf
83.84 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5706 – 97 ;RDU3MDYTOTC_.pdf
55.34 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5706 – 97 R02 ;RDU3MDY_.pdf
62.62 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5707 – 98 ;RDU3MDCTOTG_.pdf
96.04 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5707 – 98 R03 ;RDU3MDC_.pdf
73.06 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5707 – 98 R03 ;RDU3MDCTUKVE.pdf
58.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5708 – 00 ;RDU3MDGTMDA_.pdf
52.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5708 – 00 ;RDU3MDGTUKVE.pdf
57.51 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5708 – 02 ;RDU3MDG_.pdf
70.29 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5709 – 95 R00 ;RDU3MDK_.pdf
48.07 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5760 – 95 ;RDU3NJA_.pdf
39.92 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 5761 – 96 ;RDU3NJETOTY_.pdf
24.26 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5761 – 96 R01 ;RDU3NJE_.pdf
36.19 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5762 – 01 ;RDU3NJITMDE_.pdf
50.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5762 – 01 ;RDU3NJITUKVE.pdf
52.66 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5762 – 02 ;RDU3NJI_.pdf
67.05 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5762 – 98 ;RDU3NJITOTG_.pdf
49.31 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5763 – 95 ;RDU3NJMTOTU_.pdf
29.62 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5763 – 95 R01 ;RDU3NJM_.pdf
44.89 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5769 – 98 ;RDU3NJK_.pdf
149.15 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5770 – 02 ;RDU3NZA_.pdf
33.35 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5770 – 96 ;RDU3NZATOTY_.pdf
33.28 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5770 – 96 ;RDU3NZATUKVE.pdf
25.23 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5771 – 02 ;RDU3NZETMDI_.pdf
124.4 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5771 – 03 ;RDU3NZETMDM_.pdf
122.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5771 – 03 ;RDU3NZETUKVE.pdf
104.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5771 – 04 ;RDU3NZE_.pdf
122.08 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5772 – 02 ;RDU3NZITMDI_.pdf
204.74 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5772 – 03 ;RDU3NZITMDM_.pdf
84.45 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5772 – 03 ;RDU3NZITUKVE.pdf
75.08 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5772 – 04 ;RDU3NZI_.pdf
84.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5773 – 02 ;RDU3NZMTMDI_.pdf
193.47 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5773 – 03 ;RDU3NZMTMDM_.pdf
191.4 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5773 – 03 ;RDU3NZMTUKVE.pdf
179.19 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5773 – 04 ;RDU3NZM_.pdf
191 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5797 – 96 ;RDU3OTCTOTY_.pdf
186.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5797 – 96 R01 ;RDU3OTC_.pdf
211.99 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5798 – 99 ;RDU3OTG_.pdf
57.08 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5799 – 95 ;RDU3OTKTOTU_.pdf
21.22 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5799 – 95 R00 ;RDU3OTK_.pdf
39.86 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5800 – 00 ;RDU4MDATMDBB.pdf
267.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5800 – 00 ;RDU4MDATMDBBRTE_.pdf
312.66 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 5800 – 03 ;RDU4MDATMDM_.pdf
284.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5800 – 03 ;RDU4MDATMDNB.pdf
289.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5800 – 03 ;RDU4MDATUKVE.pdf
273.2 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5800 – 04 ;RDU4MDA_.pdf
292.76 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5842 – 95 R00 ;RDU4NDI_.pdf
113.31 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5845 – 01 ;RDU4NDU_.pdf
46.75 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5845 – 95 R00 ;RDU4NDUTOTVSMDBFMQ__.pdf
32.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5845 – 95 R00 ;RDU4NDUTUKVE.pdf
53.55 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5846 – 02 ;RDU4NDY_.pdf
95.45 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5846 – 99 ;RDU4NDYTOTK_.pdf
79.04 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5846 – 99 ;RDU4NDYTUKVE.pdf
86.23 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5853 – 95 ;RDU4NTMTOTU_.pdf
64.29 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5853 – 95 R00 ;RDU4NTM_.pdf
95.92 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5854 – 96 R00 ;RDU4NTQ_.pdf
233.4 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5862 – 03 ;RDU4NJI_.pdf
617.68 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5862 – 99 ;RDU4NJITOTLB.pdf
2.57 MB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5862 – 99 ;RDU4NJITUKVE.pdf
590.54 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 5863 – 00 ;RDU4NJM_.pdf
69.39 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5863 – 00 ;RDU4NJMTMDA_.pdf
56.11 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5863 – 00 ;RDU4NJMTUKVE.pdf
55.72 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 5864 – 00 ;RDU4NJQ_.pdf
97.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5864 – 95 ;RDU4NJQTOTU_.pdf
75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5864 – 95 ;RDU4NJQTUKVE.pdf
74.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5901 – 03 ;RDU5MDE_.pdf
89.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5901 – 99 ;RDU5MDETOTK_.pdf
90.07 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5901 – 99 ;RDU5MDETUKVE.pdf
80.09 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5949 – 01 ;RDU5NDK_.pdf
131.99 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5949 – 96 ;RDU5NDKTOTY_.pdf
114.67 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5949 – 96 ;RDU5NDKTUKVE.pdf
126.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5950 – 02 ;RDU5NTA_.pdf
95.37 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 5950 – 96 ;RDU5NTATOTY_.pdf
79.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5950 – 96 ;RDU5NTATUKVE.pdf
95.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5966 – 02 ;RDU5NJY_.pdf
961.71 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5966 – 99 ;RDU5NJYTOTK_.pdf
925.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5966 – 99 ;RDU5NJYTUKVE.pdf
924.36 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5967 – 03 ;RDU5NJC_.pdf
265.18 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5967 – 99 ;RDU5NJCTOTLB.pdf
3.3 MB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5967 – 99 ;RDU5NJCTUKVE.pdf
249.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5968 – 00 ;RDU5NJGTMDBB.pdf
409.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5968 – 01 ;RDU5NJGTMDE_.pdf
373.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5968 – 01 ;RDU5NJGTUKVE.pdf
75.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5968 – 04 ;RDU5NJG_.pdf
84.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5969 – 02 ;RDU5NJK_.pdf
103.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5969 – 96 ;RDU5NJKTOTY_.pdf
102.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5969 – 96 ;RDU5NJKTUKVE.pdf
94.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5972 – 02 ;RDU5NZI_.pdf
67.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5972 – 99 ;RDU5NZITOTLB.pdf
54.1 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5972 – 99 ;RDU5NZITOTLBRTE_.pdf
75.12 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5972 – 99 ;RDU5NZITUKVE.pdf
64.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5983 – 97 ;RDU5ODM_.pdf
33.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5983 – 97 ;RDU5ODMTOTC_.pdf
22.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5984 – 97 ;RDU5ODQTOTC_.pdf
33.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5984 – 97 R02 ;RDU5ODQ_.pdf
40.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5985 – 02 ;RDU5ODU_.pdf
73.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5985 – 96 ;RDU5ODUTOTZFMQ__.pdf
59.99 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5985 – 96 ;RDU5ODUTUKVE.pdf
69.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5986 – 96 ;RDU5ODYTOTY_.pdf
144.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5986 – 96 R01 ;RDU5ODY_.pdf
174.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6006 – 97 ;RDYWMDYTOTDB.pdf
59.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6006 – 97a R03 ;RDYWMDY_.pdf
56.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6021 – 96 R01 ;RDYWMJE_.pdf
97.7 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6022 – 01 ;RDYWMJI_.pdf
36.93 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6022 – 96 ;RDYWMJITUKVE.pdf
25.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6045 – 02 ;RDYWNDU_.pdf
66.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6045 – 96 ;RDYWNDUTOTY_.pdf
46.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6045 – 96 ;RDYWNDUTUKVE.pdf
49.8 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6046 – 02 ;RDYWNDY_.pdf
75.76 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6046 – 98 ;RDYWNDYTOTHB.pdf
50.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6046 – 98 ;RDYWNDYTUKVE.pdf
54.98 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6074 – 99 ;RDYWNZQ_.pdf
80.02 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6078 – 99 ;RDYWNZG_.pdf
100.94 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6079 – 02 ;RDYWNZK_.pdf
47.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6079 – 99 ;RDYWNZKTOTK_.pdf
34.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6079 – 99 ;RDYWNZKTUKVE.pdf
41.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6080 – 97 ;RDYWODATOTC_.pdf
87.41 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6080 – 97 R02 ;RDYWODA_.pdf
83.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6081 – 98 ;RDYWODE_.pdf
68.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6082 – 00 ;RDYWODITMDA_.pdf
78.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6082 – 00 ;RDYWODITUKVE.pdf
86.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6082 – 01 ;RDYWODI_.pdf
100.69 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6082 – 97 ;RDYWODITOTC_.pdf
77.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6120 – 97 ;RDYXMJATOTC_.pdf
34.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6120 – 97 R02 ;RDYXMJA_.pdf
50.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 00 ;RDYXMJETMDA_.pdf
693.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 01 ;RDYXMJETMDE_.pdf
729.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 02 ;RDYXMJETMDI_.pdf
1.27 MB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 03 ;RDYXMJETMDM_.pdf
143.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 03 ;RDYXMJETMDNB.pdf
145.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 03 ;RDYXMJETUKVE.pdf
126.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6121 – 04 ;RDYXMJE_.pdf
146.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6122 – 01 ;RDYXMJI_.pdf
459.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6122 – 99 ;RDYXMJITOTK_.pdf
384.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6122 – 99 ;RDYXMJITUKVE.pdf
391.51 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6138 – 03 ;RDYXMZG_.pdf
72.5 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6138 – 97 ;RDYXMZGTOTC_.pdf
74.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6138 – 97 ;RDYXMZGTUKVE.pdf
66.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6139 – 00 ;RDYXMZK_.pdf
81.62 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6139 – 97 ;RDYXMZKTUKVE.pdf
61.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6158 – 99 ;RDYXNTG_.pdf
64.07 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6159 – 97 ;RDYXNTKTOTC_.pdf
64.61 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6159 – 97 R02 ;RDYXNTK_.pdf
74.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6160 – 98 ;RDYXNJATOTG_.pdf
175.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6160 – 98 R03 ;RDYXNJA_.pdf
176.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6160 – 98 R03 ;RDYXNJATUKVE.pdf
143.86 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6184 – 98 ;RDYXODQ_.pdf
39.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6185 – 97 ;RDYXODUTOTC_.pdf
93.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6185 – 97 R02 ;RDYXODU_.pdf
112.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6186 – 98 ;RDYXODYTOTG_.pdf
53.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6186 – 98 R03 ;RDYXODY_.pdf
59.25 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6186 – 98 R03 ;RDYXODYTUKVE.pdf
44.08 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6200 – 00 ;RDYYMDATMDA_.pdf
58.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6200 – 00 ;RDYYMDATUKVE.pdf
63.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6200 – 01 ;RDYYMDA_.pdf
75.07 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6201 – 00 ;RDYYMDETMDA_.pdf
356.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6201 – 01 ;RDYYMDETMDE_.pdf
413.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6201 – 01 ;RDYYMDETUKVE.pdf
397.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6201 – 03 ;RDYYMDE_.pdf
416.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6201 – 99 ;RDYYMDETOTK_.pdf
350.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6202 – 00 ;RDYYMDITMDBB.pdf
2.06 MB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6202 – 01 ;RDYYMDITUKVE.pdf
2.1 MB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6202 – 02 ;RDYYMDI_.pdf
2.17 MB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6203 – 97 ;RDYYMDMTOTC_.pdf
16.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6203 – 97 R01 ;RDYYMDM_.pdf
25.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6217 – 98 ;RDYYMTCTOTG_.pdf
75.98 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6217 – 98 R03 ;RDYYMTC_.pdf
81.37 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6224 – 02 ;RDYYMJQ_.pdf
109.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6224 – 98 ;RDYYMJQTOTG_.pdf
109.43 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6224 – 98 ;RDYYMJQTUKVE.pdf
79.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6227 – 00 ;RDYYMJC_.pdf
56.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6227 – 99 ;RDYYMJCTOTK_.pdf
37.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6227 – 99 ;RDYYMJCTUKVE.pdf
42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6258 – 98 ;RDYYNTGTOTHFMQ__.pdf
57.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6258 – 98 R03 ;RDYYNTG_.pdf
55.69 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6259 – 98 ;RDYYNTK_.pdf
31.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6277 – 01 ;RDYYNZC_.pdf
85.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6277 – 99 ;RDYYNZCTOTK_.pdf
47.3 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6277 – 99 ;RDYYNZCTUKVE.pdf
93.97 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6278 – 02 ;RDYYNZG_.pdf
120.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6278 – 98 ;RDYYNZGTOTG_.pdf
97.84 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6278 – 98 ;RDYYNZGTUKVE.pdf
102.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6293 – 98 ;RDYYOTMTOTG_.pdf
97.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6293 – 98 R03 ;RDYYOTM_.pdf
99.28 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6296 – 98 ;RDYYOTYTOTG_.pdf
94.32 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6296 – 98 R03 ;RDYYOTY_.pdf
98.72 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6299 – 00 ;RDYYOTKTMDA_.pdf
421.56 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6299 – 00 ;RDYYOTKTUKVE.pdf
438.81 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6299 – 02 ;RDYYOTK_.pdf
491.48 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6300 – 02 ;RDYZMDATMDI_.pdf
374.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6300 – 03 ;RDYZMDATMDM_.pdf
300.22 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6300 – 03 ;RDYZMDATUKVE.pdf
218.85 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6300 – 04 ;RDYZMDA_.pdf
301.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6304 – 00 ;RDYZMDQTMDA_.pdf
51.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6304 – 03 ;RDYZMDQTMDM_.pdf
52.54 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6304 – 04 ;RDYZMDQ_.pdf
60.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6304 – 04 ;RDYZMDQTMDQ_.pdf
52.33 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6334 – 98 ;RDYZMZQTOTG_.pdf
59.21 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6334 – 98 R03 ;RDYZMZQ_.pdf
64.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6335 – 03 ;RDYZMZU_.pdf
84.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6335 – 03 ;RDYZMZUTMDM_.pdf
82.98 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6335 – 03 ;RDYZMZUTMDNB.pdf
83.11 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6335 – 03 ;RDYZMZUTUKVE.pdf
72.79 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6335 – 98 ;RDYZMZUTOTG_.pdf
78.46 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6351 – 99 ;RDYZNTE_.pdf
26.04 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6352 – 02 ;RDYZNTITMDI_.pdf
134.89 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6352 – 02 ;RDYZNTITUKVE.pdf
142.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6352 – 03 ;RDYZNTI_.pdf
157.55 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6352 – 98 ;RDYZNTITOTG_.pdf
135.73 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6353 – 98 ;RDYZNTMTOTG_.pdf
65.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6353 – 98 R03 ;RDYZNTM_.pdf
63.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6354 – 98 ;RDYZNTQTOTG_.pdf
52.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6354 – 98 R03 ;RDYZNTQ_.pdf
51.06 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6371 – 99 ;RDYZNZE_.pdf
109.74 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6374 – 99 ;RDYZNZQ_.pdf
36.95 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6375 – 99 ;RDYZNZU_.pdf
61.54 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6376 – 99 ;RDYZNZY_.pdf
44.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6377 – 03 ;RDYZNZC_.pdf
53.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6377 – 99 ;RDYZNZCTOTK_.pdf
53.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6377 – 99 ;RDYZNZCTUKVE.pdf
41.9 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6378 – 03 ;RDYZNZG_.pdf
63.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6378 – 99 ;RDYZNZGTOTLFMQ__.pdf
71.58 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6378 – 99 ;RDYZNZGTUKVE.pdf
53.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6379 – 99 ;RDYZNZK_.pdf
63.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6384 – 99 ;RDYZODQ_.pdf
36.39 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6417 – 02 ;RDY0MTCTMDI_.pdf
222.88 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6417 – 02 ;RDY0MTCTUKVE.pdf
81.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6417 – 03 ;RDY0MTC_.pdf
97.93 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6417 – 99 ;RDY0MTCTOTK_.pdf
95.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6421 – 99 ;RDY0MJE_.pdf
98.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6422 – 99 ;RDY0MJI_.pdf
46.67 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6423 – 99 ;RDY0MJM_.pdf
33.44 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6424 – 03 ;RDY0MJQ_.pdf
194.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6424 – 99 ;RDY0MJQTOTK_.pdf
194.26 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6424 – 99 ;RDY0MJQTUKVE.pdf
179.34 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6425 – 02 ;RDY0MJU_.pdf
107.92 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6425 – 99 ;RDY0MJUTOTK_.pdf
87.96 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6425 – 99 ;RDY0MJUTUKVE.pdf
94.33 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6426 – 02 ;RDY0MJY_.pdf
89.68 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6426 – 02 ;RDY0MJYTMDI_.pdf
240.31 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6426 – 02 ;RDY0MJYTUKVE.pdf
76.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6426 – 99 ;RDY0MJYTOTK_.pdf
56.66 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6439 – 99 ;RDY0MZK_.pdf
123.78 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6443 – 99 ;RDY0NDM_.pdf
59.38 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6445 – 99 ;RDY0NDU_.pdf
48.15 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6446 – 01 ;RDY0NDY_.pdf
33.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6446 – 99 ;RDY0NDYTOTK_.pdf
20.53 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6446 – 99 ;RDY0NDYTUKVE.pdf
26.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6447 – 03 ;RDY0NDC_.pdf
47.17 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6447 – 99 ;RDY0NDCTOTK_.pdf
45.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6447 – 99 ;RDY0NDCTUKVE.pdf
40.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6448 – 99 ;RDY0NDG_.pdf
49 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6450 – 99 ;RDY0NTA_.pdf
66.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6468 – 99 ;RDY0NJG_.pdf
50.42 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6469 – 04 ;RDY0NJK_.pdf
110.4 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6469 – 99 ;RDY0NJKTOTK_.pdf
111.05 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6469 – 99 ;RDY0NJKTUKVE.pdf
83.24 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6470 – 99 ;RDY0NZATOTK_.pdf
68.58 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6470 – 99 R04 ;RDY0NZA_.pdf
68.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6481 – 99 ;RDY0ODETOTK_.pdf
41.56 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6481 – 99 R04 ;RDY0ODE_.pdf
43.03 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6482 – 01 ;RDY0ODI_.pdf
141.6 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6482 – 99 ;RDY0ODITOTK_.pdf
128.29 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6482 – 99 ;RDY0ODITUKVE.pdf
128.13 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6483 – 03 ;RDY0ODM_.pdf
178.01 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6483 – 99 ;RDY0ODMTOTK_.pdf
4.24 MB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6483 – 99 ;RDY0ODMTUKVE.pdf
158.74 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6514 – 00 ;RDY1MTQTMDA_.pdf
73.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6514 – 02 ;RDY1MTQTMDI_.pdf
93.16 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6514 – 02 ;RDY1MTQTUKVE.pdf
87.75 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6514 – 03 ;RDY1MTQ_.pdf
93.96 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
D 6546 – 00 ;RDY1NDY_.pdf
82.01 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6547 – 00 ;RDY1NDC_.pdf
40.2 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6549 – 00 ;RDY1NDKTMDA_.pdf
117.45 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6549 – 00 ;RDY1NDKTUKVE.pdf
117.23 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6549 – 01 ;RDY1NDK_.pdf
130.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6550 – 00 ;RDY1NTA_.pdf
85.09 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6553 – 00 ;RDY1NTM_.pdf
35.77 KB, Lượt tải về: 1, Tải điểm: Thưởng -2 điểm
GMT+7, 17/11/2026 12:24 , Processed in 0.113643 second(s), 20 queries .
