Xem: 12078|Trả lời: 0
ASTM 2004- Volume 05.04 Petroleum Products and Lubricants (IV) D 6557 - latest
2 b: ^8 M, u5 \" \% _0 v1 c. e8 W1 n' X* f% m6 b0 K
D6557-04 Test Method for Evaluation of Rust Preventive Characteristics of Automotive Engine Oils" P$ Q- E: G1 l9 d% T- l
D6558-00A Test Method for Determination of TGA CO Reactivity of Baked Carbon Anodes and Cathode Blocks
; m2 q; T$ i5 I2 Q) ]D6559-00A Test Method for Determination of TGA Air Reactivity of Baked Carbon Anodes and Cathode Blocks
, w/ e) T/ e, p/ i; l2 K% s) S+ dD6560-00 Test Method for Determination of Asphaltenes (Heptane Insolubles) in Crude Petroleum and Petroleum Products9 x8 d0 O# U0 W  a
D6584-00 Test Method for Determination of Free and Total Glycerin in B-100 Biodiesel Methyl Esters By Gas Chromatography
  Z; x! i# x8 [- m3 O2 JD6591-00 Test Method for Determination of Aromatic Hydrocarbon Types in Middle Distillates\MHigh Performance Liquid Chromatography Method with Refractive Index Detection& L& X6 }0 f3 ?
D6593-04A Test Method for Evaluation of Automotive Engine Oils for Inhibition of Deposit Formation in a Spark-Ignition Internal Combustion Engine Fueled with Gasoline and Operated Under Low-Temperature, Light-Duty Conditions
! U% `) h9 ?3 O: p% fD6594-04A Test Method for Evaluation of Corrosiveness of Diesel Engine Oil at 135|SDC
7 D# |. S# @. n' a2 e: ZD6595-00 Test Method for Determination of Wear Metals and Contaminants in Used Lubricating Oils or Used Hydraulic Fluids by Rotating Disc Electrode Atomic Emission Spectrometry
) G6 k" R$ e* x* uD6596-00 Practice for Ampulization and Storage of Gasoline and Related Hydrocarbon Materials# S6 F8 S# v' {( X3 I0 A
D6615-04A Specification for Jet B Wide-Cut Aviation Turbine Fuel
2 r: k/ {. ?7 X& W* e( cD6616-01A Test Method for Measuring Viscosity at High Shear Rate by Tapered Bearing Simulator Viscometer At 100|SDC
/ M% o' o( h3 k' \; BD6617-00 Practice for Laboratory Bias Detection Using Single Test Result from Standard Material+ |" T0 A( |: G4 w) K7 }+ @4 |
D6618-04 Test Method for Evaluation of Engine Oils in Diesel Four-Stroke Cycle Supercharged 1M-PC Single Cylinder Oil Test Engine
. R' _& J* E6 T0 s* C( p6 ED6624-01 Practice for Determining a Flow-Proportioned Average Property Value (FPAPV) for a Collected Batch of Process Stream Material Using Stream Analyzer Data! m; E3 K# r7 m5 ~2 u
D6666-04 Guide for Evaluation of Aqueous Polymer Quenchants/ g. m$ Y5 l6 F. P6 b  V, k
D6667-04 Test Method for Determination of Total Volatile Sulfur in Gaseous Hydrocarbons and Liquefied Petroleum Gases by Ultraviolet Fluorescence1 K) I. K! k3 C
D6668-01 Test Method for Discrimination Between Flammability Ratings of F\t=\t0 and F\t=\t1
+ s  [8 m3 M$ r! g; tD6681-04 Test Method for Evaluation of Engine Oils in a High Speed, Single-Cylinder Diesel Engine\MCaterpillar 1P Test Procedure
/ V" I8 t8 [% r/ dD6708-04 Practice for Statistical Assessment and Improvement of the Expected Agreement Between Two Test Methods that Purport to Measure the Same Property of a Material. \/ C: z- ~9 P
D6709-04 Test Method for Evaluation of Automotive Engine Oils in the Sequence VIII Spark-Ignition Engine (CLR Oil Test Engine)0 S, }% i- \4 z1 V3 G* B3 c$ N' w- E
D6710-02 Guide for Evaluation of Hydrocarbon-Based Quench Oil
  J, ]! m  U! f8 XD6728-01 Test Method for Determination of Contaminants in Gas Turbine and Diesel Engine Fuel by Rotating Disc Electrode Atomic Emission Spectrometry6 ~1 O* \  v+ b# n6 j1 [
D6729-04 Test Method for Determination of Individual Components in Spark Ignition Engine Fuels by 100 Meter Capillary High Resolution Gas Chromatography& r& D( |3 u1 K3 k6 m2 C
D6730-01 Test Method for Determination of Individual Components in Spark Ignition Engine Fuels by 100\NMetre Capillary (with Precolumn) High-Resolution Gas Chromatography
% M+ N* u/ R' a* lD6731-01 Test Method for Determining the Aerobic, Aquatic Biodegradability of Lubricants or Lubricant Components in a Closed Respirometer
- C( ]% _  [; c; v2 ^: [2 f$ lD6732-04 Test Method for Determination of Copper in Jet Fuels by Graphite Furnace Atomic Absorption Spectrometry2 \; c% U+ H: U
D6733-01 Test Method for Determination of Individual Components in Spark Ignition Engine Fuels by 50\NMeter Capillary High Resolution Gas Chromatography) G: k+ a. j0 A0 P; O
D6743-01E01 Test Method for Thermal Stability of Organic Heat Transfer Fluids
4 H; ~/ I% F' B% bD6744-01 Test Method for Determination of the Thermal Conductivity of Anode Carbons by the Guarded Heat Flow Meter Technique
6 q: U/ _$ V0 O" ?D6745-01 Test Method for Linear Thermal Expansion of Electrode Carbons
% I  \+ U! H5 l: R* ]' ^, F4 A; QD6748-02A Test Method for Determination of Potential Instability of Middle Distillate Fuels Caused by the Presence of Phenalenes and Phenalenones (Rapid Method by Portable Spectrophotometer)! z. p0 K( r) g, ^; J4 o
D6749-02 Test Method for Pour Point of Petroleum Products (Automatic Air Pressure Method)' B3 P7 ^9 k8 n% p- }' Q3 f
D6750-04 Test Methods for Evaluation of Engine Oils in A High-Speed, Single-Cylinder Diesel Engine \M1K Procedure (0.4 \% Fuel Sulfur) and 1N Procedure (0.04 \% Fuel Sulfur)
) U) V1 W  X% n$ z$ @& LD6751-03A Specification for Biodiesel Fuel Blend Stock (B100) for Middle Distillate Fuels
( k9 [2 Q9 B7 ED6756-02 Test Method for Determination of the Red Dye Concentration and Estimation of the ASTM Color of Diesel Fuel and Heating Oil Using a Portable Visible Spectrophotometer- `  I% V+ c# U/ k
D6791-02 Test Method for Determination of Grain Stability of Calcined Petroleum Coke
' w9 ^+ K$ I) C4 V* g/ ~7 vD6792-04A Guide for Quality System in Petroleum Products and Lubricants Testing Laboratories8 Z: K9 Z3 }) l, z$ ^& a, R
D6793-02 Test Method for Determination of Isothermal Secant and Tangent Bulk Modulus
5 f% w, n; c! O) m  H- n9 n$ V) b; fD6794-02 Test Method for Measuring the Effect on Filterability of Engine Oils After Treatment with Various Amounts of Water and a Long (6-h) Heating Time( {7 R6 K: ?# J/ I
D6795-02 Test Method for Measuring the Effect on Filterability of Engine Oils After Treatment with Water and Dry Ice and a Short (30 min) Heating Time
9 q: @2 e) D) n3 C7 ZD6810-02 Test Method for Measurement of Hindered Phenolic Antioxidant Content in HL Turbine Oils by Linear Sweep Voltammetry5 S6 }. i% Q/ o5 ^" K( m
D6811-02 Test Method for Measurement of Thermal Stability of Aviation Turbine Fuels under Turbulent Flow Conditions (HiReTS Method)
# g/ s2 L% E; q( D( }' Z% \D6812-04A Practice for Ground-Based Octane Rating Procedures for Turbocharged/Supercharged Spark Ignition Aircraft Engines7 \3 I+ Q/ j, w* m1 F7 B( Y2 E
D6813-02A Guide for Performance Evaluation of Hydraulic Fluids for Piston Pumps' G5 k3 W8 `& o5 l3 |" a2 N, o
D6821-02 Test Method for Low Temperature Viscosity of Drive Line Lubricants in a Constant Shear Stress Viscometer7 s1 W" |* d2 v$ r. [: _$ t0 H) y
D6822-02 Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermohydrometer Method% d3 K3 F9 b" W; B9 k1 v6 T; i6 s
D6823-02 Specification for Commercial Boiler Fuels With Used Lubricating Oils
4 T+ \; Q& @; M  t# ?6 [/ tD6824-04 Test Method for Determining Filterability of Aviation Turbine Fuel  U$ a4 Q6 ~; v4 `, M' ?5 e
D6837-04A Test Method for Measurement of Effects of Automotive Engine Oils on Fuel Economy of Passenger Cars and Light-Duty Trucks in Sequence VIB Spark Ignition Engine
5 R3 a3 D" P0 LD6838-04 Test Method for Cummins M11 High Soot Test* i# ^! p# P7 ^/ f) h6 n; e
D6839-02 Test Method for Hydrocarbon Types, Oxygenated Compounds and Benzene in Spark Ignition Engine Fuels by Gas Chromatography
+ p' V2 i3 @# A1 B# X! gD6849-02 Practice for Storage and Use of Liquefied Petroleum Gases (LPG) in Sample Cylinders for LPG Test Methods
* [2 I' q0 U& xD6891-03 Test Method for Evaluation of Automotive Engine Oils in the Sequence IVA Spark-Ignition Engine
5 v9 w0 n. K* J8 h6 [D6892-03 Test Method for Pour Point of Petroleum Products (Robotic Tilt Method)- E7 S. Z  e1 I6 v. j
D6894-03 Test Method for Evaluation of Aeration Resistance of Engine Oils in Direct-Injected Turbocharged Automotive Diesel Engine
7 G9 u" s6 X: c2 E9 S+ b( k$ MD6895-03 Test Method for Rotational Viscosity of Heavy Duty Diesel Drain Oils at 100|SDC( Q9 `4 R" o: B
D6896-03E01 Test Method for Determination of Yield Stress and Apparent Viscosity of Used Engine Oils at Low Temperature! h0 c  {  R  t9 s1 O* u
D6897-03A Test Method for Vapor Pressure of Liquefied Petroleum Gases (LPG) (Expansion Method)3 n, g0 R8 z: U3 n6 B$ V
D6898-03 Test Method for Evaluating Diesel Fuel Lubricity by an Injection Pump Rig
) v* g+ {- N0 ~& K" uD6920-03 Test Method for Total Sulfur in Naphthas, Distillates, Reformulated Gasolines, Diesels, Biodiesels, and Motor Fuels by Oxidative Combustion and Electrochemical Detection2 Q# e- p! n, W* ]# P9 l
D6922-03 Test Method for Determination of Homogeneity and Miscibility in Automotive Engine Oils
* |2 t& L2 |+ a1 `D6923-03 Test Method for Evaluation of Engine Oils in a High Speed, Single-Cylinder Diesel Engine\MCaterpillar 1R Test Procedure; V- L7 f$ s* W/ |/ t1 e9 N
D6969-03 Practice for Preparation of Calcined Petroleum Coke Samples for Analysis
" u9 i# ^* c- p9 ]: _6 h# D, M) {D6970-03 Practice for Collection of Calcined Petroleum Coke Samples for Analysis
! \; P1 C' \) U, r+ ~D6971-04 Test Method for Measurement of Hindered Phenolic and Aromatic Amine Antioxidant Content in Non-zinc Turbine Oils by Linear Sweep Voltammetry5 M9 L/ ?5 l' ]! I- R+ \; j
D6973-04 Test Method for Indicating Wear Characteristics of Petroleum Hydraulic Fluids in a High Pressure Constant Volume Vane Pump0 Q" V+ J: Q5 U8 u& n( v
D6974-04 Practice for Enumeration of Viable Bacteria and Fungi in Liquid Fuels\MFiltration and Culture Procedures
, B: l: d  O3 j6 d5 [" \D6975-04 Test Method for Cummins M11 EGR Test1 Q% d  G: F5 M4 k$ L6 y. k
D6984-04 Test Method for Evaluation of Automotive Engine Oils in the Sequence IIIF, Spark-Ignition Engine
8 A) Y* _+ Y7 V8 W4 _+ n1 [1 R: v2 aD6985-04A Specification for Middle Distillate Fuel Oil\MMilitary Marine Applications/ r4 G5 q3 d  A% T7 m, ~
D6986-03 Test Method for Free Water, Particulate and Other Contamination in Aviation Fuels (Visual Inspection Procedures)
2 E0 |9 R7 B7 s" j& V. b( [D6987-04 Test Method for Evaluation of Diesel Engine Oils in T-10 Exhaust Gas Recirculation Diesel Engine
) F1 D4 P- M+ vD7038-04 Test Method for Evaluation of Moisture Corrosion Resistance of Automotive Gear Lubricants
: A2 N- Q1 S* U0 O  h  m6 Q% ^D7039-04 Test Method for Sulfur in Gasoline and Diesel Fuel by Monochromatic Wavelength Dispersive X-ray Fluorescence Spectrometry
( B  {: \. s* e: H. I' UD7040-04 Test Method for Determination of Low Levels of Phosphorus in ILSAC GF 4 and Similar Grade Engine Oils by Inductively Coupled Plasma Atomic Emission Spectrometry7 B, y3 V8 b2 [3 D; z
D7041-04 Test Method for Determination of Total Sulfur in Light Hydrocarbons, Motor Fuels, and Oils by Online Gas Chromatography with Flame Photometric Detection9 }/ m1 _/ V. X4 y. e9 G. @
D7042-04 Test Method for Dynamic Viscosity and Density of Liquids by Stabinger Viscometer (and the Calculation of Kinematic Viscosity)
' K+ [$ d1 e& N6 _0 z$ rD7043-04 Test Method for Indicating Wear Characteristics of Petroleum and Non-Petroleum Hydraulic Fluids in a Constant Volume Vane Pump
3 P8 c' C* Z6 Q1 H! T  wD7044-04A Specification for Biodegradable Fire Resistant Hydraulic Fluids( }: j0 z5 G  h
D7058-04 Test Method for Determination of the Red Dye Concentration and Estimation of Saybolt Color of Aviation Turbine Fuels and Kerosine Using a Portable Visible Spectrophotometer
, C- z5 \& d! T0 U( ]0 B7 ?* M6 e1 zD7059-04E01 Test Method for Determination of Methanol in Crude Oils by Multidimensional Gas Chromatography. C+ c& s8 U( X" w6 m: q. ?
D7060-04 Test Method for Determination of the Maximum Flocculation Ratio and Peptizing Power in Residual and Heavy Fuel Oils (Optical Detection Method)
$ R4 z$ r7 [$ l/ YD7061-04 Test Method for Measuring -Heptane Induced Phase Separation of Asphaltene-Containing Heavy Fuel Oils as Separability Number by an Optical Scanning Device
0 ?2 j* P8 R4 W- k! fD7094-04 Test Method for Flash Point by Modified Continuously Closed Cup (MCCCFP) Tester
( f% l) T- S7 A5 H# m1 }9 \) Z) \5 ~D7095-04 Test Method for Rapid Determination of Corrosiveness to Copper from Petroleum Products Using a Disposable Copper Foil Strip
5 f% w# c7 @+ d# ^
D 6557 – 00 ;RDY1NTCTMDA_.pdf
564.74 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6557 – 03 ;RDY1NTCTMDM_.pdf
562.74 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6557 – 03 ;RDY1NTCTUKVE.pdf
516.56 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6557 – 04 ;RDY1NTC_.pdf
562.1 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6558 – 00 ;RDY1NTG_.pdf
69.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6558 – 00 ;RDY1NTGTMDA_.pdf
44.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6558 – 00 ;RDY1NTGTUKVE.pdf
50.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6559 – 00 ;RDY1NTK_.pdf
67.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6559 – 00 ;RDY1NTKTMDA_.pdf
42.98 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6559 – 00 ;RDY1NTKTUKVE.pdf
48.72 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6560 – 00 ;RDY1NJA_.pdf
53.34 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6584 – 00 ;RDY1ODQ_.pdf
57.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6591 – 00 ;RDY1OTE_.pdf
94.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6593 – 00 ;RDY1OTMTMDA_.pdf
1.85 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6593 – 02 ;RDY1OTMTMDI_.pdf
3.19 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6593 – 02 ;RDY1OTMTMDJB.pdf
3.17 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6593 – 03 ;RDY1OTM_.pdf
1.06 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6593 – 03 ;RDY1OTMTMDM_.pdf
1.07 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6593 – 03 ;RDY1OTMTUKVE.pdf
1.01 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6594 – 00 ;RDY1OTQTMDA_.pdf
331.2 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6594 – 01 ;RDY1OTQTMDE_.pdf
286.91 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6594 – 01 ;RDY1OTQTUKVE.pdf
75.16 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6594 – 03 ;RDY1OTQTMDM_.pdf
81.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6594 – 04 ;RDY1OTQ_.pdf
81.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6595 – 00 ;RDY1OTU_.pdf
50.36 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6596 – 00 ;RDY1OTY_.pdf
69.03 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6615 – 00 ;RDY2MTUTMDA_.pdf
46.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6615 – 02 ;RDY2MTU_.pdf
66.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6615 – 02 ;RDY2MTUTUKVE.pdf
47.06 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6616 – 01 ;RDY2MTY_.pdf
184.25 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6616 – 01 ;RDY2MTYTMDE_.pdf
115.19 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6616 – 01 ;RDY2MTYTUKVE.pdf
150.18 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6617 – 00 ;RDY2MTC_.pdf
63.42 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6618 – 00 ;RDY2MTG_.pdf
2.88 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6624 – 01 ;RDY2MJQ_.pdf
46.34 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6666 – 01 ;RDY2NJY_.pdf
293.49 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6666 – 01 ;RDY2NJYTMDE_.pdf
274.05 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6666 – 01 ;RDY2NJYTUKVE.pdf
274.4 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6667 – 01 ;RDY2NJC_.pdf
112.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6668 – 01 ;RDY2NJG_.pdf
36.52 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6681 – 01 ;RDY2ODE_.pdf
3.06 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6708 – 01 ;RDY3MDG_.pdf
170.37 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6709 – 01 ;RDY3MDKTMDE_.pdf
2.84 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6709 – 03 ;RDY3MDK_.pdf
492.52 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6709 – 03 ;RDY3MDKTMDM_.pdf
1.37 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6709 – 03 ;RDY3MDKTUKVE.pdf
453.17 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6710 – 01 ;RDY3MTATUKVE.pdf
177.46 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6710 – 02 ;RDY3MTA_.pdf
189.42 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6728 – 01 ;RDY3MJG_.pdf
62.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6729 – 01 ;RDY3MJK_.pdf
549.69 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6730 – 01 ;RDY3MZA_.pdf
642.69 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 6731 – 01 ;RDY3MZE_.pdf
89.48 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6732 – 01 ;RDY3MZITMDE_.pdf
33.77 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6732 – 01 ;RDY3MZITUKVE.pdf
54.62 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6732 – 02 ;RDY3MZI_.pdf
66.06 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6733 – 01 ;RDY3MZM_.pdf
285.97 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6743 – 01 ;RDY3NDM_.pdf
52.8 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6743 – 01 ;RDY3NDMTMDE_.pdf
46.68 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6743 – 01 ;RDY3NDMTUKVE.pdf
32.9 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6744 – 01 ;RDY3NDQ_.pdf
81.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6745 – 01 ;RDY3NDU_.pdf
62.67 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6748 – 02 ;RDY3NDG_.pdf
66.23 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6748 – 02 ;RDY3NDGTMDI_.pdf
67.18 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6748 – 02 ;RDY3NDGTUKVE.pdf
55.23 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6749 – 02 ;RDY3NDK_.pdf
56.4 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6750 – 02 ;RDY3NTA_.pdf
3.55 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 6751 – 02 ;RDY3NTETMDI_.pdf
41.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6751 – 02 ;RDY3NTETMDJB.pdf
56.13 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6751 – 03 ;RDY3NTE_.pdf
53.21 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 6751 – 03 ;RDY3NTETMDM_.pdf
54.52 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6751 – 03 ;RDY3NTETUKVE.pdf
39.4 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6756 – 02 ;RDY3NTY_.pdf
76.01 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6791 – 02 ;RDY3OTE_.pdf
112.86 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6792 – 02 ;RDY3OTITMDI_.pdf
72.24 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6792 – 02 ;RDY3OTITUKVE.pdf
50.71 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6792 – 03 ;RDY3OTI_.pdf
72.64 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6793 – 02 ;RDY3OTM_.pdf
54.81 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6794 – 02 ;RDY3OTQ_.pdf
58.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6795 – 02 ;RDY3OTU_.pdf
58.95 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6810 – 02 ;RDY4MTA_.pdf
143.53 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6811 – 02 ;RDY4MTE_.pdf
117.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6812 – 02 ;RDY4MTITMDI_.pdf
158.22 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6812 – 02 ;RDY4MTITUKVE.pdf
138.62 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6812 – 03 ;RDY4MTI_.pdf
159.79 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6813 – 02 ;RDY4MTM_.pdf
296.52 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6813 – 02 ;RDY4MTMTMDI_.pdf
603.36 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6813 – 02 ;RDY4MTMTUKVE.pdf
234.66 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6821 – 02 ;RDY4MJE_.pdf
46.96 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6822 – 02 ;RDY4MJI_.pdf
81.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6823 – 02 ;RDY4MJM_.pdf
56.55 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6824 – 02 ;RDY4MJQTMDI_.pdf
261.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6824 – 02 ;RDY4MJQTUKVE.pdf
218.62 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6824 – 03 ;RDY4MJQ_.pdf
128.97 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6837 – 02 ;RDY4MZCTMDI_.pdf
1023.97 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6837 – 02 ;RDY4MZCTUKVE.pdf
949.67 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6837 – 03 ;RDY4MZCTMDM_.pdf
1016.8 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6837 – 04 ;RDY4MZC_.pdf
1016.84 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 6838 – 02 ;RDY4MZGTMDI_.pdf
355.92 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6838 – 02 ;RDY4MZGTUKVE.pdf
316.31 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6838 – 04 ;RDY4MZG_.pdf
356.15 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6839 – 02 ;RDY4MZK_.pdf
110.22 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6849 – 02 ;RDY4NDK_.pdf
50.26 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6891 – 03 ;RDY4OTE_.pdf
745.39 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6892 – 03 ;RDY4OTI_.pdf
117.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6894 – 03 ;RDY4OTQ_.pdf
201.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6895 – 03 ;RDY4OTU_.pdf
55.71 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6896 – 03 ;RDY4OTY_.pdf
67.19 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6897 – 03 ;RDY4OTC_.pdf
48.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6897 – 03 ;RDY4OTCTMDM_.pdf
47.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6897 – 03 ;RDY4OTCTUKVE.pdf
37.74 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6898 – 03 ;RDY4OTG_.pdf
230.26 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6920 – 03 ;RDY5MJA_.pdf
48.88 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6922 – 03 ;RDY5MJI_.pdf
38.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6923 – 03 ;RDY5MJM_.pdf
986.26 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6969 – 03 ;RDY5NJK_.pdf
48.68 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6970 – 03 ;RDY5NZA_.pdf
33.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6973 – 03 ;RDY5NZM_.pdf
209.87 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6974 – 03 ;RDY5NZQ_.pdf
57.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6975 – 03 ;RDY5NZU_.pdf
594.97 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6984 – 03 ;RDY5ODQ_.pdf
723.95 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6985 – 04 ;RDY5ODU_.pdf
35.8 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6986 – 03 ;RDY5ODY_.pdf
45.36 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6987 – 03 ;RDY5ODC_.pdf
827.6 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
GMT+7, 17/11/2026 12:23 , Processed in 0.088027 second(s), 20 queries .
