Xem: 6359|Trả lời: 0
ASTM 2004- Volume 05.05 Test Methods for Rating Motor, Diesel, and Aviation Fuel
ASTM 2004- Volume 05.05 Test Methods for Rating Motor, Diesel, and Aviation Fuels; Catalysts; Manufactured Carbon and Graphite Products) f3 K: q) N) y" x, B# B
7 H! J8 |8 G$ v  x! TD0613-03B Test Method for Cetane Number of Diesel Fuel Oil# \5 i6 @4 |9 p" d
D0909-01 Test Method for Knock Characteristics of Aviation Gasolines by the Supercharge Method0 K3 ~) f* R: ]8 }2 W. }& \
D2699-04E01 Test Method for Research Octane Number of Spark-Ignition Engine Fuel; |4 J; h9 R* l8 J
D2700-04E01 Test Method for Motor Octane Number of Spark-Ignition Engine Fuel' C- `+ R' V3 Z' f& i+ K+ p
D2885-03 Test Method for Determination of Octane Number of Spark-Ignition Engine Fuels by On-Line Direct Comparison Technique, Z: t- f3 H+ ^
D6890-04 Test Method for Determination of Ignition Delay and Derived Cetane Number (DCN) of Diesel Fuel Oils by Combustion in a Constant Volume Chamber1 l! D1 \( h0 t+ i
C0559-90R00 Test Method for Bulk Density by Physical Measurements of Manufactured Carbon and Graphite Articles
* Q/ Q0 b1 _- d5 n; d3 O2 VC0560-88R98 Test Methods for Chemical Analysis of Graphite$ f5 E0 [, G5 Z3 T8 h
C0561-91R00 Test Method for Ash in a Graphite Sample- _8 a- K( d# w' Q+ y3 l' `
C0562-91R00 Test Method for Moisture in a Graphite Sample
6 h$ v2 e5 {* v% y! OC0565-93R98 Test Methods for Tension Testing of Carbon and Graphite Mechanical Materials# t8 b: e; b1 M1 @3 C, ]0 U
C0611-98 Test Method for Electrical Resistivity of Manufactured Carbon and Graphite Articles at Room Temperature: G9 c3 ^$ s" H  Q6 n- O7 Q% }
C0625-95R00 Practice for Reporting Irradiation Results on Graphite
% K6 _& C1 [# u9 BC0651-91R00 Test Method for Flexural Strength of Manufactured Carbon and Graphite Articles Using Four-Point Loading at Room Temperature( E7 W3 q- E7 \; ?; \$ Z
C0662-70R98 Specification for Impervious Graphite Pipe and Threading
/ o8 _: I8 \2 h) yC0695-91R00 Test Method for Compressive Strength of Carbon and Graphite% c6 E! g* C: a- l  A2 c
C0709-03A Terminology Relating to Manufactured Carbon and Graphite1 H/ S; Z% W- z8 a
C0714-85R00 Test Method for Thermal Diffusivity of Carbon and Graphite by a Thermal Pulse Method
% O& |# p+ b9 ^3 w2 uC0747-93R98 Test Method for Moduli of Elasticity and Fundamental Frequencies of Carbon and Graphite Materials by Sonic Resonance
, N: G$ }% n: t; uC0748-98 Test Method for Rockwell Hardness of Graphite Materials
% Z$ r5 o, @2 i% @  dC0749-92R02 Test Method for Tensile Stress-Strain of Carbon and Graphite% [$ |1 d* U$ J$ E: a/ H1 g& l
C0769-98 Test Method for Sonic Velocity in Manufactured Carbon and Graphite Materials for Use in Obtaining an Approximate Young's Modulus
& C- W) e& \* _# NC0781-02 Practice for Testing Graphite and Boronated Graphite Components for High-Temperature Gas-Cooled Nuclear Reactors& g" l3 `: {9 \! F) O4 W8 W
C0783-85R00 Practice for Core Sampling of Graphite Electrodes7 n# d  `& g2 ~3 c9 |* W- n
C0808-75R00 Guideline for Reporting Friction and Wear Test Results of Manufactured Carbon and Graphite Bearing and Seal Materials* L7 u4 F7 v( w/ T
C0816-85R98E01 Test Method for Sulfur in Graphite by Combustion-Iodometric Titration Method
6 E1 T. n7 \% Z# f5 cC0838-96R01 Test Method for Bulk Density of As-Manufactured Carbon and Graphite Shapes; X& e. |) U5 I% _* W3 x
C0886-98 Test Method for Scleroscope Hardness Testing of Carbon and Graphite Materials* N4 t; s0 y0 y' n
C1025-91R00 Test Method for Modulus of Rupture in Bending of Electrode Graphite1 |$ _# Y8 y' N+ [
C1039-85R00 Test Methods for Apparent Porosity, Apparent Specific Gravity, and Bulk Density of Graphite Electrodes
( q& S) P' @% A* y0 mC1179-91R00 Test Method for Oxidation Mass Loss of Manufactured Carbon and Graphite Materials in Air% \& r2 E. x7 G3 v
D1977-03 Test Method for Nickel and Vanadium in FCC Equilibrium Catalysts by Hydrofluoric/Sulfuric Acid Decomposition and Atomic Spectroscopic Analysis
& R0 K3 O/ m7 M2 f2 C4 R+ Z" kD3610-00R04 Test Method for Total Cobalt in Alumina-Base Cobalt-Molybdenum Catalyst by Potentiometric Titration Method$ o. P9 g% _4 J* d3 ^
D3663-03 Test Method for Surface Area of Catalysts and Catalyst Carriers
# s" L1 a. Q( ]2 ~! \. j9 ^2 [. c; }( ^D3766-86R02 Terminology Relating to Catalysts and Catalysis
+ E; G+ L4 i3 [) X% b/ B& b1 GD3906-03 Test Method for Determination of Relative X-ray Diffraction Intensities of Faujasite-Type Zeolite-Containing Materials
, \6 `2 |$ @3 }* ^0 Q9 ^D3907-03 Test Method for Testing Fluid Catalytic Cracking (FCC) Catalysts by Microactivity Test
. l5 `0 ~8 S: `/ J. U: cD3908-03 Test Method for Hydrogen Chemisorption on Supported Platinum Catalysts by Volumetric Vacuum Method- A$ X  ?3 p/ _$ T" ]& N# }
D3942-03 Test Method for Determination of the Unit Cell Dimension of a Faujasite-Type Zeolite
2 y$ p8 t* M5 \9 L9 iD3943-04 Test Method for Total Molybdenum in Fresh Alumina-Base Catalysts
# v$ |- f4 t. Y) m0 TD4058-96R01 Test Method for Attrition and Abrasion of Catalysts and Catalyst Carriers" M3 A$ ~. F- }2 q: S
D4164-03 Test Method for Mechanically Tapped Packing Density of Formed Catalyst and Catalyst Carriers
0 C6 Z: E" S9 C4 |: E. AD4179-01 Test Method for Single Pellet Crush Strength of Formed Catalyst Shapes0 g; ~4 u" P/ e1 _+ }* x  f) q
D4180-03 Test Method for Vibratory Packing Density of Formed Catalyst Particles and Catalyst Carriers: l; B! E/ q4 \+ s
D4222-03 Test Method for Determination of Nitrogen Adsorption and Desorption Isotherms of Catalysts and Catalyst Carriers by Static Volumetric Measurements
. o$ C$ {" e- q# k# iD4284-03 Test Method for Determining Pore Volume Distribution of Catalysts by Mercury Intrusion Porosimetry
1 ^& A" z2 c- \' L) r  a$ t3 @D4365-95R01 Test Method for Determining Micropore Volume and Zeolite Area of a Catalyst
$ y- F  R  K9 D+ o, HD4438-85R01E01 Test Method for Particle Size\t Distribution\t of\t Catalytic\t Material\t by\t Electronic\t Counting. W4 \% K& P% _4 t9 }
D4463-96R01 Guide for Metals Free Steam Deactivation of Fresh Fluid Cracking Catalysts
0 b. C' Y8 |7 ^; P8 T8 PD4464-00 Test Method for Particle Size Distribution of Catalytic Material by Laser Light Scattering& H5 _' k8 Q, r5 }
D4481-04 Test Method for Total Nickel in Fresh Alumina-Base Catalysts
; e/ @( {) E3 D# wD4512-03 Test Method for Vibrated Apparent Packing Density of Fine Catalyst and Catalyst Carrier Particles and Powder
% P; S# N- u$ L3 ?  N4 x9 [1 k3 AD4513-97R01E01 Test Method for Particle Size Distribution of Catalytic Materials by Sieving& h7 A* ~* l5 V
D4567-03 Test Method for Single-Point Determination of Specific Surface Area of Catalysts and Catalyst Carriers Using Nitrogen Adsorption by Continuous Flow Method
! ~4 T# P8 e5 Z) wD4641-94R99E01 Practice for Calculation of Pore Size Distributions of Catalysts from Nitrogen Desorption Isotherms
- _9 Z- c9 t8 {+ xD4642-04 Test Method for Platinum in Reforming Catalysts by Wet Chemistry
% V1 N, c7 R6 F& q! q0 VD4699-03 Test Method for Vibratory Packing Density of Large Formed Catalyst and Catalyst Carrier Particles4 G! [( }& v/ @6 V- L
D4780-95R01 Test Method for Determination of Low Surface Area of Catalysts by Multipoint Krypton Adsorption
- Q; R6 d& K# T# }* g% r3 vD4781-03 Test Method for Mechanically Tapped Packing Density of Fine Catalyst Particles and Catalyst Carrier Particles6 x- {4 e+ K2 m7 B* t
D4782-04 Test Method for Palladium in Molecular Sieve Catalyst by Wet Chemistry
& N) E8 ?6 p! w: n; N( K' K: QD4824-03 Test Method for Determination of Catalyst Acidity by Ammonia Chemisorption
  ], |/ E2 E& A3 `, M; C6 iD4926-89R01 Test Method for Gamma Alumina Content in Catalysts Containing Silica and Alumina by X-Ray Powder Diffraction: Q& u" n/ Y  }) Y, Y# V
D5153-04 Test Method for Palladium in Molecular Sieve Catalyst by Atomic Absorption
6 v- Z4 b1 u: ?( q3 \% QD5154-03 Test Method for Determining Activity and Selectivity of Fluid Catalytic Cracking (FCC) Catalysts by Microactivity Test$ A1 H" A4 n/ x" g+ c% ]
D5357-03 Test Method for Determination of Relative Crystallinity of Zeolite Sodium A by X-ray Diffraction0 g2 _. {( }3 V! o
D5757-00 Test Method for Determination of Attrition and Abrasion of Powdered Catalysts by Air Jets
5 k5 t$ r5 ]/ F2 x# ]' ED5758-01 Test Method for Determination of Relative Crystallinity of Zeolite ZSM-5 by X-Ray Diffraction! R# Z% |0 C7 _) {7 H5 p
D6175-03 Test Method for Radial Crush Strength of Extruded Catalyst and Catalyst Carrier Particles
$ a% f5 @* Z- \% FD6761-04A Test Method for Determination of the Total Pore Volume of Catalysts and Catalyst Carriers- A$ [' v0 g! i$ z& M+ b7 P
D7084-04 Test Method for Determination of Bulk Crush Strength of Catalysts and Catalyst Carriers% i7 S' _4 q0 x  H
D7085-04 Guide for Determination of Chemical Elements in Fluid Catalytic Cracking Catalysts by X-ray Fluorescence Spectrometry (XRF)" s# d  r5 u* i2 }
C 559 – 90 R00 ;QZU1OQ__.pdf
27.54 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 560 – 88 R98 ;QZU2MA__.pdf
82.33 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
C 561 – 91 R00 ;QZU2MQ__.pdf
26.55 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
C 562 – 91 R00 ;QZU2MG__.pdf
24.57 KB, Lượt tải về: 9, Tải điểm: Thưởng -2 điểm
C 565 – 93 R98 ;QZU2NQ__.pdf
52.78 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 611 – 98 ;QZYXMQ__.pdf
76.76 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 625 – 95 R00 ;QZYYNQ__.pdf
22.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 651 – 91 R00 ;QZY1MQ__.pdf
36.8 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 662 – 70 R98 ;QZY2MG__.pdf
37.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 695 – 91 R00 ;QZY5NQ__.pdf
45.21 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 709 – 03 ;QZCWOQ__.pdf
36.66 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 709 – 03 ;QZCWOS0WMW__.pdf
34.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 709 – 98 ;QZCWOS05OA__.pdf
19.2 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 714 – 85 R00 ;QZCXNA__.pdf
53.61 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 747 – 93 R98 ;QZC0NW__.pdf
116.96 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 748 – 98 ;QZC0OA__.pdf
28.35 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 749 – 92 R02 ;QZC0OQ__.pdf
177.11 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 749 – 92 R96 ;QZC0OS05MLI5NG__.pdf
156.87 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 769 – 98 ;QZC2OQ__.pdf
45.1 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 781 – 02 ;QZC4MQ__.pdf
73 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 781 – 96 ;QZC4MS1SRUQ_.pdf
57.22 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
C 783 – 85 R00 ;QZC4MW__.pdf
27.05 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 808 – 75 R00 ;QZGWOA__.pdf
183.08 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 816 – 85 R98 ;QZGXNG__.pdf
35.43 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
C 838 – 96 ;QZGZOC05NG__.pdf
15.89 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
C 838 – 96 R01 ;QZGZOA__.pdf
24.91 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 886 – 98 ;QZG4NG__.pdf
26.04 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 1025 – 91 R00 ;QZEWMJU_.pdf
46.37 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 1039 – 85 R00 ;QZEWMZK_.pdf
32.28 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
C 1179 – 91 R00 ;QZEXNZK_.pdf
57.75 KB, Lượt tải về: 8, Tải điểm: Thưởng -2 điểm
D 613 – 01 ;RDYXMY0WMQ__.pdf
535.67 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 613 – 03 ;RDYXMW__.pdf
423.33 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 613 – 03 ;RDYXMY0WM0E_.pdf
536.81 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 613 – 03 ;RDYXMY0WMW__.pdf
537.45 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 613 – 03 ;RDYXMY1SRUQ_.pdf
449.69 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 613 – 95 ;RDYXMY05NQ__.pdf
356.24 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 909 – 00 ;RDKWOS0WMA__.pdf
3.09 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 909 – 00 ;RDKWOS0WMEUX.pdf
3.11 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 909 – 00 ;RDKWOS1SRUQ_.pdf
3.69 MB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 909 – 01 ;RDKWOQ__.pdf
3.22 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 1977 – 03 ;RDE5NZC_.pdf
33.57 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1977 – 98 ;RDE5NZCTOTG_.pdf
34.12 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 1977 – 98 ;RDE5NZCTUKVE.pdf
31.43 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2699 – 01 ;RDI2OTKTMDE_.pdf
458.45 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 2699 – 01 ;RDI2OTKTMDFB.pdf
878.19 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2699 – 02 ;RDI2OTKTMDI_.pdf
1.16 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2699 – 03 ;RDI2OTKTMDM_.pdf
D 2699 – 03 ;RDI2OTKTMDNB.pdf
568.37 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2699 – 03 ;RDI2OTKTUKVE.pdf
855.57 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2699 – 04 ;RDI2OTK_.pdf
569.49 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2699 – 99 ;RDI2OTKTOTK_.pdf
459.77 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2700 – 01 ;RDI3MDATMDE_.pdf
532.21 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2700 – 01 ;RDI3MDATMDFB.pdf
1.23 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2700 – 02 ;RDI3MDATMDI_.pdf
1.57 MB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2700 – 03 ;RDI3MDATMDM_.pdf
D 2700 – 03 ;RDI3MDATMDNB.pdf
655.15 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2700 – 03 ;RDI3MDATMDNC.pdf
654.3 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2700 – 03 ;RDI3MDATUKVE.pdf
556.46 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2700 – 04 ;RDI3MDA_.pdf
659.03 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2700 – 99 ;RDI3MDATOTK_.pdf
533.3 KB, Lượt tải về: 7, Tải điểm: Thưởng -2 điểm
D 2885 – 03 ;RDI4ODU_.pdf
158.13 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2885 – 95 R99 ;RDI4ODUTOTVSOTK_.pdf
146.38 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 2885 – 95 R99 ;RDI4ODUTUKVE.pdf
206.38 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3610 – 00 ;RDM2MTATMDA_.pdf
32.83 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3610 – 00 R04 ;RDM2MTA_.pdf
32.84 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3663 – 03 ;RDM2NJM_.pdf
83.82 KB, Lượt tải về: 6, Tải điểm: Thưởng -2 điểm
D 3663 – 99 ;RDM2NJMTOTK_.pdf
84.04 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3663 – 99 ;RDM2NJMTUKVE.pdf
51.7 KB, Lượt tải về: 5, Tải điểm: Thưởng -2 điểm
D 3766 – 86 R02 ;RDM3NJY_.pdf
23.18 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3766 – 86 R97 ;RDM3NJYTODZSOTC_.pdf
23.88 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3906 – 03 ;RDM5MDY_.pdf
90.85 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3906 – 97 ;RDM5MDYTOTC_.pdf
72.55 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3907 – 03 ;RDM5MDC_.pdf
253.7 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3908 – 03 ;RDM5MDG_.pdf
67.4 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3908 – 99 ;RDM5MDGTOTK_.pdf
67.64 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3908 – 99 ;RDM5MDGTUKVE.pdf
49.88 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3942 – 03 ;RDM5NDI_.pdf
39.97 KB, Lượt tải về: 4, Tải điểm: Thưởng -2 điểm
D 3942 – 97 ;RDM5NDITOTC_.pdf
40.56 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3943 – 00 ;RDM5NDMTMDA_.pdf
38.04 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3943 – 00 ;RDM5NDMTUKVE.pdf
30.45 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 3943 – 04 ;RDM5NDM_.pdf
39.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4058 – 96 ;RDQWNTGTOTY_.pdf
36.72 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4058 – 96 R01 ;RDQWNTG_.pdf
36.15 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4164 – 03 ;RDQXNJQ_.pdf
25.53 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4164 – 99 ;RDQXNJQTOTK_.pdf
26.3 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4164 – 99 ;RDQXNJQTUKVE.pdf
20.49 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4179 – 01 ;RDQXNZK_.pdf
25.96 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4179 – 88a R94 ;RDQXNZKTUKVE.pdf
32.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4180 – 03 ;RDQXODA_.pdf
44.41 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4180 – 99 ;RDQXODATOTK_.pdf
45.98 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4180 – 99 ;RDQXODATUKVE.pdf
40.95 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4222 – 03 ;RDQYMJI_.pdf
93.77 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4222 – 98 ;RDQYMJITOTG_.pdf
95.01 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4222 – 98 ;RDQYMJITUKVE.pdf
59.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4284 – 03 ;RDQYODQ_.pdf
61.39 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4284 – 03 ;RDQYODQTUKVE.pdf
55.61 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 4365 – 95 ;RDQZNJUTOTU_.pdf
53.11 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4365 – 95 R01 ;RDQZNJU_.pdf
54.02 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4438 – 85 R01 ;RDQ0MZG_.pdf
69.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4438 – 85 R97 ;RDQ0MZGTODVSOTC_.pdf
68.09 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4463 – 96 ;RDQ0NJMTOTY_.pdf
25.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4463 – 96 R01 ;RDQ0NJM_.pdf
24.58 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4464 – 00 ;RDQ0NJQ_.pdf
35.05 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4464 – 85 R91 ;RDQ0NJQTUKVE.pdf
41.36 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4481 – 04 ;RDQ0ODE_.pdf
36.66 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4481 – 97 ;RDQ0ODETOTC_.pdf
36.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4481 – 97 ;RDQ0ODETUKVE.pdf
29.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4512 – 03 ;RDQ1MTI_.pdf
44.27 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4512 – 99 ;RDQ1MTITOTK_.pdf
45.03 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4512 – 99 ;RDQ1MTITUKVE.pdf
38.65 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4513 – 97 ;RDQ1MTMTOTC_.pdf
22.04 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4513 – 97 R01 ;RDQ1MTM_.pdf
23.06 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4567 – 03 ;RDQ1NJC_.pdf
46.18 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4567 – 99 ;RDQ1NJCTOTK_.pdf
47.89 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4567 – 99 ;RDQ1NJCTUKVE.pdf
36.33 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4641 – 94 R99 ;RDQ2NDE_.pdf
91.85 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4642 – 04 ;RDQ2NDI_.pdf
35.82 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4642 – 92 R98 ;RDQ2NDITOTJSOTG_.pdf
35.37 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4642 – 92 R98 ;RDQ2NDITUKVE.pdf
31.29 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4699 – 03 ;RDQ2OTK_.pdf
38.6 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4699 – 99 ;RDQ2OTKTOTK_.pdf
39.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4699 – 99 ;RDQ2OTKTUKVE.pdf
33.56 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4780 – 95 ;RDQ3ODATOTU_.pdf
45.18 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4780 – 95 R01 ;RDQ3ODA_.pdf
44.63 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4781 – 03 ;RDQ3ODE_.pdf
25.46 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4781 – 99 ;RDQ3ODETOTK_.pdf
26.21 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4781 – 99 ;RDQ3ODETUKVE.pdf
20.43 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4782 – 04 ;RDQ3ODI_.pdf
49.63 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4782 – 91 R97 ;RDQ3ODITOTFSOTC_.pdf
50.08 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4782 – 91 R97 ;RDQ3ODITUKVE.pdf
44.25 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4824 – 03 ;RDQ4MJQ_.pdf
64.87 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4824 – 94 R99 ;RDQ4MJQTOTRSOTK_.pdf
50.43 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4824 – 94 R99 ;RDQ4MJQTUKVE.pdf
51.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4926 – 89 R01 ;RDQ5MJY_.pdf
18.67 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 4926 – 89 R94 ;RDQ5MJYTODLSOTRFMQ__.pdf
20.93 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5153 – 04 ;RDUXNTM_.pdf
42.92 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5153 – 91 R97 ;RDUXNTMTOTFSOTC_.pdf
42.73 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5153 – 91 R97 ;RDUXNTMTUKVE.pdf
31.16 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5154 – 03 ;RDUXNTQ_.pdf
324.34 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5154 – 03 ;RDUXNTQTUKVE.pdf
311.83 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5357 – 03 ;RDUZNTC_.pdf
37.47 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5357 – 98 ;RDUZNTCTOTG_.pdf
37.81 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5757 – 00 ;RDU3NTC_.pdf
42.22 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5757 – 95 ;RDU3NTCTUKVE.pdf
24.99 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 5758 – 01 ;RDU3NTG_.pdf
43.65 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 5758 – 95 ;RDU3NTGTUKVE.pdf
35.64 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6175 – 03 ;RDYXNZU_.pdf
43.14 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6175 – 98 ;RDYXNZUTOTG_.pdf
35.24 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6175 – 98 ;RDYXNZUTUKVE.pdf
31.02 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6761 – 02 ;RDY3NJE_.pdf
62.76 KB, Lượt tải về: 0, Tải điểm: Thưởng -2 điểm
D 6890 – 03 ;RDY4OTATMDM_.pdf
438.31 KB, Lượt tải về: 3, Tải điểm: Thưởng -2 điểm
D 6890 – 03 ;RDY4OTATMDNB.pdf
229.52 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6890 – 03 ;RDY4OTATUKVE.pdf
206.78 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
D 6890 – 04 ;RDY4OTA_.pdf
230.45 KB, Lượt tải về: 2, Tải điểm: Thưởng -2 điểm
GMT+7, 17/11/2026 12:33 , Processed in 0.086285 second(s), 20 queries .
