CẢNH BÁO và TẨY CHAY WEB filethietke ĂN CẮP files (trên DIỄN ĐÀN XD360) rồi xóa logo, xóa tác giảđăng lên web bán với giá cao. Đừng để bị mất tiền oan bởi hành vi ăn cắp của web filethietke bạn nhé!
ASTM 2004- Volume 06.01 Paint -- Tests for Chemical, Physical, and Optical Properties; Appearance + B* m8 ?5 G9 b) Z' c) _ . t/ [# ^* S) o7 @& z! {D0016-03 Terminology for Paint, Related Coatings, Materials, and Applications % E% w$ ?: W8 O a; S3 W
D0215 Practice for the Chemical Analysis of White Linseed Oil Paints 1 a) m; K7 W" a( e. E
D0281-95R02 Test Method for Oil Absorption of Pigments by Spatula Rub-out + H8 j+ }9 H) l9 @. fD0332-87R04 Test Method for Relative Tinting Strength of White Pigments by Visual Observation 3 T! \& J! x' HD0344-97R04 Test Method for Relative Hiding Power of Paints by the Visual Evaluation of Brushouts : O% X# H6 |) S( B+ d2 @2 GD0387-00 Test Method for Color and Strength of Chromatic Pigments with a Mechanical Muller# M0 d* H1 w2 K$ D5 `' x
D0522-93AR01 Test Methods for Mandrel Bend Test of Attached Organic Coatings ! u) T8 o, s/ wD0523-89R99 Test Method for Specular Gloss! W2 Y5 T4 J2 K
D0562-01 Test Method for Consistency of Paints Measuring Krebs Unit (KU) Viscosity Using a Stormer-Type Viscometer * Q {/ _' Y+ i6 g; ?% ID0564-87R02 Test Methods for Liquid Paint Driers & j( m/ Y* e# X3 \/ qD0609-00 Practice for Preparation of Cold-Rolled Steel Panels for Testing Paint, Varnish, Conversion Coatings, and Related Coating Products ) x: \ c% o4 u! e M/ QD0660-93R05 Test Method for Evaluating Degree of Checking of Exterior Paints / F4 X5 l! B% O, a7 Y9 {: n6 d. jD0661-93R05 Test Method for Evaluating Degree of Cracking of Exterior Paints- m2 M; R9 H6 H/ X. V7 K
D0662-93R05 Test Method for Evaluating Degree of Erosion of Exterior Paints 6 s* N0 E. W0 Y8 @$ UD0714-02 Test Method for Evaluating Degree of Blistering of Paints + F1 D2 v" P$ D8 T- ?; W, d; O$ HD0772-86R05 Test Method for Evaluating Degree of Flaking (Scaling) of Exterior Paints9 d0 r, |$ i+ p, f
D0822-01 Practice for Filtered Open-Flame Carbon-Arc Exposures of Paint and Related Coatings 8 T9 j! G9 Z" R. L0 N& {7 ND0823-95R01 Practices for Producing Films of Uniform Thickness of Paint, Varnish, and Related Products on Test Panels " z( A* A8 J6 L! dD0870-02 Practice for Testing Water Resistance of Coatings Using Water Immersion( Q+ F' u3 j- z( \) O' u2 A
D0968-05 Test Methods for Abrasion Resistance of Organic Coatings by Falling Abrasive) D& K5 p# W2 Z6 |% I
D1005-95R01 Test Method for Measurement of Dry-Film Thickness of Organic Coatings Using Micrometers 2 s7 G/ @' ?7 ]9 C6 hD1006-01 Practice for Conducting Exterior Exposure Tests of Paints on Wood( a- J ^% H n" ^5 P% m
D1014-02 Practice for Conducting Exterior Exposure Tests of Paints and Coatings on Metal Substrates : w2 w8 w2 V, v/ i. s3 }8 X
D1186-01 Test Methods for Nondestructive Measurement of Dry Film Thickness of Nonmagnetic Coatings Applied to a Ferrous Base1 b4 k s& M5 w, h; K: R3 [6 v
D1200-94R05 Test Method for Viscosity by Ford Viscosity Cup& \. X2 F/ a/ b
D1210-05 Test Method for Fineness of Dispersion of Pigment-Vehicle Systems by Hegman-Type Gage7 I* }. N; F' {' U9 C7 K% R, G! o
D1212-91R01 Test Methods for Measurement of Wet Film Thickness of Organic Coatings $ l& R7 L. r) VD1259-85R01 Test Methods for Nonvolatile Content of Resin Solutions N! }" |) x4 e9 ]
D1310-01 Test Method for Flash Point and Fire Point of Liquids by Tag Open-Cup Apparatus 8 x# @6 d @+ L, ?7 U$ l. ~1 aD1360-98R04 Test Method for Fire Retardancy of Paints (Cabinet Method)+ F0 ^" W: J% V% @/ H$ \: @
D1400-00 Test Method for Nondestructive Measurement of Dry Film Thickness of Nonconductive Coatings Applied to a Nonferrous Metal Base3 u! a' h$ {8 z' D( m* [8 H
D1474-98R02 Test Methods for Indentation Hardness of Organic Coatings + S, z/ W3 [6 JD1475-98R03 Test Method For Density of Liquid Coatings, Inks, and Related Products, M& Z3 K( _9 K4 [0 Y% I9 X
D1483-95R02 Test Method for Oil Absorption of Pigments by Gardner-Coleman Method) D; I8 j9 n* V4 _# N6 a+ e
D1535-01 Practice for Specifying Color by the Munsell System 4 q: E+ ?+ E0 @ _$ uD1544-04 Test Method for Color of Transparent Liquids (Gardner Color Scale)/ p7 R: J- j1 ?: A
D1640-03 Test Methods for Drying, Curing, or Film Formation of Organic Coatings at Room Temperature 6 ^$ F) M! p, D. zD1644-01 Test Methods for Nonvolatile Content of Varnishes / O8 r+ i/ R, j7 p: g9 }) l- ?* yD1653-03 Test Methods for Water Vapor Transmission of Organic Coating Films/ E9 s l! H) U) t* V
D1654-05 Test Method for Evaluation of Painted or Coated Specimens Subjected to Corrosive Environments . H# Y! X6 }" M' @. c5 U( \% }4 MD1729-96R03 Practice for Visual Appraisal of Colors and Color Differences of Diffusely-Illuminated Opaque Materials / e! _! a3 \& ^- kD1735-04 Practice for Testing Water Resistance of Coatings Using Water Fog Apparatus . P5 b" t) [" {% BD1978-91R02 Guide for Analysis of Electrocoat Bath Samples+ j3 O0 x# o- K) ]
D2134-93R01 Test Method for Determining the Hardness of Organic Coatings with a Sward-Type Hardness Rocker ! i+ k+ n4 c, `, W9 t4 r) _D2196-05 Test Methods for Rheological Properties of Non-Newtonian Materials by Rotational (Brookfield type) Viscometer 1 P% W, f2 B I) z2 aD2197-98R04 Test Method for Adhesion of Organic Coatings by Scrape Adhesion : r$ d9 z$ `2 D- e9 T6 yD2201-99 Practice for Preparation of Zinc-Coated and Zinc-Alloy-Coated Steel Panels for Testing Paint and Related Coating Products, V8 Q: J6 F2 k/ @4 j3 L
D2244-05 Practice for Calculation of Color Tolerances and Color Differences from Instrumentally Measured Color Coordinates 4 h; _$ c$ t% y' Z; i% `
D2245-90R05 Test Method for Identification of Oils and Oil Acids in Solvent-Reducible Paints& z, k2 m& P6 l8 D9 b
D2247-02 Practice for Testing Water Resistance of Coatings in 100 % Relative Humidity ' o1 h1 Z' c2 o' N" UD2248-01A Practice for Detergent Resistance of Organic Finishes , u5 ~! R6 h% iD2348-02 Test Method for Arsenic in Paint0 r Y) w( \4 e2 B
D2349-90R03 Test Method for Qualitative Determination of Nature of Solvent Composition in Solvent-Reducible Paints 8 S9 Q7 I3 X. b( k$ vD2350-90R05 Test Method for Antimony Oxide in White Pigment Separated From Solvent-Reducible Paints 7 D+ p5 w" D0 X; YD2351-90R05 Test Method for Sulfide in White Pigment Separated from Solvent-Reducible Paints0 }" Y# T* X* a' z
D2352-85R05 Test Method for Sulfur Dioxide in White Pigment Separated from Solvent-Reducible Paints , @$ \ v' \$ A2 ^% i" y0 DD2369-04 Test Method for Volatile Content of Coatings ) }& G3 Q" L1 c6 `6 g7 {7 R, {# zD2370-98R02 Test Method for Tensile Properties of Organic Coatings# J1 r6 m G1 Q7 J5 B# w% S& g
D2371-85R05 Test Method for Pigment Content of Solvent-Reducible Paints + l" m8 U E, H5 ~" a' a J, HD2372-85R05 Practice for Separation of Vehicle From Solvent-Reducible Paints % W) ?! S" z! qD2373-05 Test Method for Determination of Cobalt in Paint Driers by EDTA Method7 P% B, ?1 V" c# r7 ]7 r$ W
D2374-05 Test Method for Lead in Paint Driers by EDTA Method $ H2 E6 }; L, ~9 ZD2375-05 Test Method for Manganese in Paint Driers by EDTA Method z6 d$ w4 ^( Z- ^, o( U
D2454-95R02 Practice for Determining the Effect of Overbaking on Organic Coatings" G* C% k6 J( L# o
D2485-91R00 Test Methods for Evaluating Coatings for High Temperature Service( ?/ F( g' [$ P9 f2 \$ u
D2574-00 Test Method for Resistance of Emulsion Paints in the Container to Attack by Microorganisms 3 C7 S. ^! ?8 O/ k- h! q0 vD2613-01 Test Method for Calcium or Zinc in Paint Driers by EDTA Method8 D$ N6 }- i% j
D2616-96R03 Test Method for Evaluation of Visual Color Difference With a Gray Scale 6 V3 [2 }5 j" D1 d' iD2621-87R05 Test Method for Infrared Identification of Vehicle Solids From Solvent-Reducible Paints' C; I! G- W% f6 Q
D2697-03 Test Method for Volume Nonvolatile Matter in Clear or Pigmented Coatings, B$ V# z* s9 h' z2 C# e; X
D2698-05 Test Method for Determination of the Pigment Content of Solvent-Reducible Paints by High-Speed Centrifuging $ k+ x" `8 r- T% C# M
D2745-00 Test Method for Relative Tinting Strength of White Pigments by Reflectance Measurements # d Z2 x" ]# m) ?/ L6 S% iD2794-93R04 Test Method for Resistance of Organic Coatings to the Effects of Rapid Deformation (Impact)2 |% _: ^5 R5 g
D2803-03 Guide for Testing Filiform Corrosion Resistance of Organic Coatings on Metal + v' W! W" i, J: n& h3 gD2805-96AR03 Test Method for Hiding Power of Paints by Reflectometry d( R5 v% V' l9 eD2832-92R05 Guide for Determining Volatile and Nonvolatile Content of Paint and Related Coatings) }: N+ W2 {4 _' L# e
D3022-84R05 Test Method for Color and Strength of Color Pigments by Use of a Miniature Sandmill 7 [: S! E* s6 Z+ H2 ]+ jD3134-97R03 Practice for Establishing Color and Gloss Tolerances % D9 ]! b4 S# U, MD3168-85R05 Practice for Qualitative Identification of Polymers in Emulsion Paints/ T D9 ?. g. V1 }7 y, T
D3271-87R01 Practice for Direct Injection of Solvent-Reducible Paints Into a Gas Chromatograph for Solvent Analysis $ D3 ^# w0 W" ]D3272-76R03 Practice for Vacuum Distillation of Solvents From Solvent-Reducible Paints For Analysis" R6 T( d* u* F' X2 N
D3273-00 Test Method for Resistance to Growth of Mold on the Surface of Interior Coatings in an Environmental Chamber4 H; k2 P7 l; o+ |4 k Z- S% m+ X: T* @
D3274-95R02 Test Method for Evaluating Degree of Surface Disfigurement of Paint Films by Microbial (Fungal or Algal) Growth or Soil and Dirt Accumulation' z s! g& Y1 C- }/ m8 P
D3278-96R04E01 Test Methods for Flash Point of Liquids by Small Scale Closed-Cup Apparatus" _" _4 U; S& ]/ [
D3335-85AR05 Test Method for Low Concentrations of Lead, Cadmium, and Cobalt in Paint by Atomic Absorption Spectroscopy; @' H) R- q- _; X- A; u. M; ]
D3359-02 Test Methods for Measuring Adhesion by Tape Test ' E, v8 t( B- v6 m: Z) P; O- H7 qD3361-01 Practice for Unfiltered Open-Flame Carbon-Arc Exposures of Paint and Related Coatings 7 U7 _5 s" |0 I8 |6 Z, f# D+ X+ KD3363-05 Test Method for Film Hardness by Pencil Test2 C+ x& z6 f% u/ D+ c+ f
D3456-86R02 Practice for Determining by Exterior Exposure Tests the Susceptibility of Paint Films to Microbiological Attack ' @* a1 o- p8 Z1 K( y0 b8 }D3539-87R04 Test Methods for Evaporation Rates of Volatile Liquids by Shell Thin-Film Evaporometer & q" t3 s$ E4 @1 y, @+ G
D3618-05 Test Method for Detection of Lead in Paint and Dried Paint Films6 h+ K& y" I" _" _" F; Y
D3624-85AR05 Test Method for Low Concentrations of Mercury in Paint by Atomic Absorption Spectroscopy9 l! C7 M5 y1 o7 k
D3717-85AR05 Test Method for Low Concentrations of Antimony in Paint by Atomic Absorption Spectroscopy ; b) t8 H" N! R: sD3718-85AR05 Test Method for Low Concentrations of Chromium in Paint by Atomic Absorption Spectroscopy 6 t+ @( \2 ^# }% r; p r) O0 ~$ d
D3723-05 Test Method for Pigment Content of Water-Emulsion Paints by Low-Temperature Ashing ' ]1 P8 e* o- r7 S3 g! ZD3792-05 Test Method for Water Content of Coatings by Direct Injection Into a Gas Chromatograph $ D1 h, L: Z5 G0 s, r% [: R& dD3804-02 Test Method for Iron in Paint Driers by EDTA Method 5 z7 K7 k4 R0 r! BD3806-98R04 Test Method of Small-Scale Evaluation of Fire-Retardant Paints (2-Foot Tunnel Method). i& w, p- X7 @. Y3 r8 F0 K
D3891-96R02E01 Practice for Preparation of Glass Panels for Testing Paint, Varnish, Lacquer, and Related Products ; B( h$ |0 i# g7 _- Q( zD3924-80R05 Specification for Standard Environment for Conditioning and Testing Paint, Varnish, Lacquer, and Related Materials7 |% v9 A' D2 n% W- S- Q1 a6 K4 s4 K
D3925-02 Practice for Sampling Liquid Paints and Related Pigmented Coatings( |' F( C1 ?6 Q# d. b9 G% k$ O7 {
D3934-90R01 Test Method for Flash/No Flash Test\MEquilibrium Method by a Closed-Cup Apparatus 7 n+ R. N7 |) t& y% LD3941-90R01 Test Method for Flash Point by the Equilibrium Method With a Closed-Cup Apparatus ; @2 `) B% U8 W6 W' TD3960-05 Practice for Determining Volatile Organic Compound (VOC) Content of Paints and Related Coatings8 l0 }! E: _3 R2 N2 i
D3964-04 Practice for Selection of Coating Specimens for Appearance Measurements , O( s% l! _0 A1 {. YD3969-01 Test Method for Zirconium in Paint Driers by EDTA Method! e, x2 E+ ~' _: I
D3970-05 Test Method for Cerium in Paint Driers by Oxidimetric Determination % F- I+ {2 }& x" j! j4 o5 ?D3988-05 Test Method for Vanadium in Paint Driers by EDTA Method& O2 L) ?0 L: S3 K! V- m
D3989-01 Test Method for Total Rare Earth Metals in Paint Driers by EDTA Method- ]( M* O \ o# w, X+ d
D4017-02 Test Method for Water in Paints and Paint Materials by Karl Fischer Method" ^; X- b* `2 g: k6 A4 S/ Q
D4039-93R04 Test Method for Reflection Haze of High-Gloss Surfaces% f" R& Z5 e: I @3 Z
D4060-01 Test Method for Abrasion Resistance of Organic Coatings by the Taber Abraser t. }% _+ d% T# c8 r
D4061-94R00 Test Method for Retroreflectance of Horizontal Coatings 7 o: L3 [( q, w+ v7 ED4086-92AR03 Practice for Visual Evaluation of Metamerism* R' ], p( D. V1 K( ?! a
D4140-82R02 Guide for Determining Volatile and Nonvolatile Content of Driers, Drying Oils, Naval Stores, and Solvents* O! I1 J* \( D) k+ s+ g$ P
D4141-01 Practice for Conducting Black Box and Solar Concentrating Exposures of Coatings 2 j$ |2 @/ x u! a# U- A- @; g3 ID4144-94R05 Test Method for Estimating Package Stability of Coatings for Ultraviolet Curing ! D! T* t: q v# WD4206-96R01 Test Method for Sustained Burning of Liquid Mixtures Using the Small Scale Open-Cup Apparatus / p4 a# r5 }4 ~# W8 |D4209-82R02 Practice for Determining Volatile and Nonvolatile Content of Cellulosics, Emulsions, Resin Solutions, Shellac, and Varnishes. Y. ?9 W7 R& g! M6 u% Z4 Y
D4212-99R05 Test Method for Viscosity by Dip-Type Viscosity Cups ; P. u/ ^( o% I. @
D4214-98 Test Methods for Evaluating the Degree of Chalking of Exterior Paint FilmsD4287-00R05 Test Method for High-Shear Viscosity Using a Cone/Plate Viscometer ; T$ ? |2 e) R- ~; tD4358-05 Test Method for Lead and Chromium in Air Particulate Filter Samples of Lead Chromate Type Pigment Dusts by Atomic Absorption Spectroscopy$ A7 n' V# Q$ I( G) M1 D' C
D4359-90R00E01 Test Method for Determining Whether a Material is a Liquid or a Solid 5 l) j: u' }1 v- M3 jD4366 Test Methods for Hardness of Organic Coatings by Pendulum Damping Tests # _5 \6 R6 D& v t& c' }D4370-01 Test Methods for Acid and Base Milliequivalent Content of Electrocoat Bath( Q( d* Y2 n; E# ~: G# \( t
D4399-05 Test Method for Measuring Electrical Conductivity of Electrocoat Baths% e0 \6 ]5 l$ A# N" j3 z
D4414-95R01 Practice for Measurement of Wet Film Thickness by Notch Gages - f0 q& c# j, o' d6 d. AD4449-90R04 Test Method for Visual Evaluation of Gloss Differences Between Surfaces of Similar Appearance 7 X6 R1 K% p9 ?. e( o c1 P8 w1 HD4451-02 Test Method for Pigment Content of Paints by Low-Temperature Ashing A& F( ]* h9 M C3 D! b2 z
D4457-02 Test Method for Determination of Dichloromethane and 1,1,1-Trichloroethane in Paints and Coatings by Direct Injection into a Gas Chromatograph5 C( K2 g8 I- N: w
D4563-02 Test Method for Determination by Atomic Absorption Spectroscopy of Titanium Dioxide Content of Pigments Recovered From Whole Paint 5 E* t* B. l. E! R* KD4584-05 Test Method for Measuring Apparent pH of Electrocoat Baths 2 \) f }6 ^. g0 n* J- {: v( n0 PD4585-99 Practice for Testing Water Resistance of Coatings Using Controlled Condensation( H9 J# m( H y$ X* O2 `
D4587-05 Practice for Fluorescent UV-Condensation Exposures of Paint and Related Coatings / D; S) W+ w0 e9 Q$ RD4610-98R04 Guide for Determining the Presence of and Removing Microbial (Fungal or Algal) Growth on Paint and Related Coatings 6 |- W# b# c- K$ l; @D4708-99R04 Practice for Preparation of Uniform Free Films of Organic Coatings ! S$ l% `# I4 R5 S+ iD4747-02 Test Method for Determining Unreacted Monomer Content of Latexes Using Gas-Liquid Chromatography 7 s- Q) ]7 Q7 F: p; F L! PD4764-01 Test Method for Determination by X-ray Fluorescence Spectroscopy of Titanium Dioxide Content in Paint, [2 P/ {& h2 V9 h) {- S0 U# d
D4827-03 Test Method for Determining the Unreacted Monomer Content of Latexes Using Capillary Column Gas Chromatography $ V- f! h4 y5 L! S* m6 CD4834-03 Test Method for Detection of Lead in Paint by Direct Aspiration Atomic Absorption Spectroscopy 8 S4 i1 C( b* V" X9 sD4948-89R00E01 Test Method for Determination of the Upper Layer Separated from a Viscous Liquid # { l( N5 | j6 Z E, C3 Y- E2 PD5031-01 Practice for Enclosed Carbon-Arc Exposure Tests of Paint and Related Coatings% d/ b9 n$ q+ k# m5 b1 _$ I
D5087-02 Test Method for Determining Amount of Volatile Organic Compound (VOC) Released from Solventborne Automotive Coatings and Available for Removal in a VOC Control Device (Abatement) 1 U# n1 ?4 q& h/ V$ TD5125-97R05 Test Method for Viscosity of Paints and Related Materials by ISO Flow Cups ) S% a5 O8 V6 a: z6 l1 bD5145-03 Test Methods for Nonvolatile and Pigment Content of Electrocoat Baths 4 x4 a% ~) J9 lD5178-98R02 Test Method for Mar Resistance of Organic Coatings , ]" V$ f# E6 L9 _" FD5179-02 Test Method for Measuring Adhesion of Organic Coatings to Plastic Substrates by Direct Tensile Testing; `4 }( T4 {8 Z: A3 Z: E
D5200-03 Test Method for Determination of Weight Percent Volatile Content of Solvent-Borne Paints in Aerosol Cans : a0 ?. o8 X/ j0 b r% a) v3 }
D5201-05 Practice for Calculating Formulation Physical Constants of Paints and Coatings . \( h3 Y* j& B* a+ C) r" B# K
D5325-03 Test Method for Determination of Weight Percent Volatile Content of Water-Borne Aerosol Paints # o3 M! w4 z/ yD5380-93R03 Test Method for Identification of Crystalline Pigments and Extenders in Paint by X-Ray Diffraction Analysis , Z/ \, X6 N# a2 G* \" vD5381-93R03 Guide for X-Ray Fluorescence (XRF) Spectroscopy of Pigments and Extenders4 Y2 S: s, x7 H9 c
D5478-98R03 Test Methods for Viscosity of Materials by a Falling Needle Viscometer ! F% G* Z6 E3 Q: F" R# uD5531-05 Guide for Preparation, Maintenance, and Distribution of Physical Product Standards for Color and Geometric Appearance of Coatings* B7 Y! E x* U" P9 t
D5588-97R02 Test Method for Determination of the Microbial Condition of Paint, Paint Raw Materials, and Plant Areas3 |) c& j0 I9 Q/ y. \
D5589-97R02 Test Method for Determining the Resistance of Paint Films and Related Coatings to Algal Defacement; D$ o6 f3 Q# G6 i" ]
D5590-00 Test Method for Determining the Resistance of Paint Films and Related Coatings to Fungal Defacement by Accelerated Four-Week Agar Plate Assay 5 e, V4 e4 S+ `9 h; o) W; pD5682-95R02 Test Methods for Electrical Resistivity of Liquid Paint and Related Materials( p# N$ D2 x! y1 |. `4 A
D5767-95R04 Test Methods for Instrumental Measurement of Distinctness-of-Image Gloss of Coating Surfaces ' \+ S4 w- b% {- E& ^D5794-95R02 Guide for Determination of Anions in Cathodic Electrocoat Permeates by Ion Chromatography " \( M8 V! N$ d3 t. u. F( E5 gD5894-05 Practice for Cyclic Salt Fog/UV Exposure of Painted Metal, (Alternating Exposures in a Fog/Dry Cabinet and a UV/Condensation Cabinet) $ Y/ q# ~; d/ x( f+ ^3 L) [0 b, tD5895-03 Test Methods for Evaluating Drying or Curing During Film Formation of Organic Coatings Using Mechanical Recorders ) q9 B4 f: w7 ~/ X) i6 O+ J8 g5 MD6037-96R02 Test Methods for Dry Abrasion Mar Resistance of High Gloss Coatings. }* o! ?8 D9 C! r% Z
D6093-97R03 Test Method for Percent Volume Nonvolatile Matter in Clear or Pigmented Coatings Using a Helium Gas Pycnometer R$ w# o" t: S4 @! o
D6131-97R04 Test Method for Evaluating the Relative Tint Undertone of Titanium Dioxide Pigments * z# k$ Q8 T! e3 e; u' d* z4 KD6132-04 Test Method for Nondestructive Measurement of Dry Film Thickness of Applied Organic Coatings Using an Ultrasonic Gage/ s/ \1 a z# ^. g6 e
D6133-02 Test Method for Acetone, -Chlorobenzotrifluoride, Methyl Acetate or -Butyl Acetate Content of Solventborne and Waterborne Paints, Coatings, Resins, and Raw Materials by Direct Injection Into a Gas Chromatograph 0 y8 y3 F/ F5 N5 rD6165-97R03 Guide for the Comparison, Detection, and Identification of the Odors of Paints, Inks, and Related Materials) J$ U g' i' i
D6191-97R03 Test Method for Measurement of Evolved Formaldehyde from Water Reducible Air-Dry Coatings ; {+ `0 h: p9 R* PD6266-00AR05 Test Method for Determining the Amount of Volatile Organic Compound (VOC) Released From Waterborne Automotive Coatings and Available for Removal in a VOC Control Device (Abatement); p9 J' b \( F8 @" s0 b8 s' C- s
D6438-05 Test Method for Acetone, Methyl Acetate, and Parachlorobenzotrifluoride Content of Paints, and Coatings by Solid Phase Microextraction-Gas Chromatography 3 D a& Z+ g' j0 [- ]D6580-00R05 Test Method for The Determination of Metallic Zinc Content in Both Zinc Dust Pigment and in Cured Films of Zinc-Rich Coatings: X' r- r' Z" [0 N
D6619-00 Practice for Incorporating Pigments by High Speed Dispersion 5 o1 L5 q+ N/ v% q5 u' Z0 i4 w5 U6 kD6631-05 Guide for Committee D01 for Conducting an Interlaboratory Study for the Purpose of Determining the Precision of a Test Method* U- ~" H" O& P
D6675-01 Practice for Salt-Accelerated Outdoor Cosmetic Corrosion Testing of Organic Coatings on Automotive Sheet Steel* G( j b# R4 h: ?3 F
D6695-03B Practice for Xenon-Arc Exposures of Paint and Related Coatings* L1 K" Z% _8 p7 C6 O
D6762-02A Test Method for Determining the Hiding Power of Paint by Visual Evaluation of Spray Applied Coatings8 ~ A* i3 p7 M7 x/ C, V/ f
D6886-03 Test Method for Speciation of the Volatile Organic Compounds (VOCs) in Low VOC Content Waterborne Air-Dry Coatings by Gas Chromatograpy 8 _8 R3 r3 f/ [8 ~; V$ t. h2 PD6899-03 Guide for Laboratory Cyclic Corrosion Testing of Automotive Painted Steel ' x; _. n; |6 `, ~4 |D6902-04E01 Test Method for Laboratory Measurement of Formaldehyde Evolved During the Curing of Melamine-Formaldehyde-Based Coatings c1 E$ o, ]9 C0 CD6905-03 Test Method for Impact Flexibility of Organic Coatings+ Y- [* i+ n3 m# Z* x
D6991-05 Test Method for Measurements of Internal Stresses in Organic Coatings by Cantilever (Beam) Method( L: B. ]9 o2 Y2 K- o) D; h8 W
D7087-05A Test Method for An Imaging Technique to Measure Rust Creepage at Scribe on Coated Test Panels Subjected to Corrosive Environments - S5 B8 t" t4 V4 E \- |0 w6 r+ Y, SD7091-05 Practice for Nondestructive Measurement of Dry Film Thickness of Nonmagnetic Coatings Applied to Ferrous Metals and Nonmagnetic, Nonconductive Coatings Applied to Non-Ferrous Metals 6 @, _ I- b' M8 {" V4 fD7187-05 Test Method for Measuring Mechanistic Aspects of Scratch/Mar Behavior of Paint Coatings by Nanoscratching0 V3 p% A9 B* L+ r2 S8 d# S
E0167 Practice for Goniophotometry of Objects and Materials' [. i3 q' z4 ?% T
E0179-96R03 Guide for Selection of Geometric Conditions for Measurement of Reflection and Transmission Properties of Materials& E$ d: L, Y# H% k* n4 F* H1 m
E0259-98R03 Practice for Preparation of Pressed Powder White Reflectance Factor Transfer Standards for Hemispherical and Bi-Directional Geometries5 D# H' P& b( p" T" }- x
E0284-05A Terminology of Appearance # d' s$ M) D* s& Q5 S4 P, Y
E0308-01 Practice for Computing the Colors of Objects by Using the CIE System ' U& M. b6 d+ L2 cE0312-02 Practice for Description and Selection of Conditions for Photographing Specimens : x. _2 W: i2 P8 D0 \0 v0 _E0313-05 Practice for Calculating Yellowness and Whiteness Indices from Instrumentally Measured Color Coordinates ) F e4 n D" h# a3 E& e6 UE0430-05 Test Methods for Measurement of Gloss of High-Gloss Surfaces by Abridged Goniophotometry . b1 D- q3 I" oE0805-01A Practice for Identification of Instrumental Methods of Color or Color-Difference Measurement of Materials9 t( R6 n. T, a) M
E0808-01 Practice for Describing Retroreflection / Z8 j1 P9 T' y/ n) d7 V4 T% {E0809-02 Practice for Measuring Photometric Characteristics of Retroreflectors2 V& V! q& ?5 P, }0 [
E0810-03 Test Method for Coefficient of Retroreflection of Retroreflective Sheeting Utilizing the Coplanar Geometry ! x- |( W8 C" FE0811-95R01 Practice for Measuring Colorimetric Characteristics of Retroreflectors Under Nighttime Conditions + x- w- z# d! TE0848-94R00 Guide for Safety and Health Requirements Relating to Occupational Exposure to Water-Insoluble Chromates 0 |2 Y! A# L5 ^. B( q; h. ^' nE0991-98 Practice for Color Measurement of Fluorescent Specimens ]5 g' D; \- s% S7 c- EE1164-02 Practice for Obtaining Spectrometric Data for Object-Color Evaluation' l T& S8 O8 n
E1247-03 Practice for Detecting Fluorescence in Object-Color Specimens by Spectrophotometry 3 F5 p7 E1 ]2 @0 P* e2 AE1331-04 Test Method for Reflectance Factor and Color by Spectrophotometry Using Hemispherical Geometry 5 V" _: O" s R1 e- p0 iE1336-96R03 Test Method for Obtaining Colorimetric Data From a Visual Display Unit by Spectroradiometry & a5 c9 E* k) H' M: K9 g, C3 KE1341-96R01 Practice for Obtaining Spectroradiometric Data from Radiant Sources for Colorimetry( F6 Q' N( a& I; o
E1345-98R03 Practice for Reducing the Effect of Variability of Color Measurement by Use of Multiple Measurements ( | H0 n# ^. N' o9 ZE1347-03 Test Method for Color and Color-Difference Measurement by Tristimulus (Filter) Colorimetry , S4 P5 j" o" g# r# }* P8 _$ sE1348-02 Test Method for Transmittance and Color by Spectrophotometry Using Hemispherical Geometry : f* ~- G' G! y* D! e j) b6 P9 jE1349-90R98 Test Method for Reflectance Factor and Color by Spectrophotometry Using Bidirectional Geometry 8 U& }2 Y, D8 n4 ]% \E1360-05 Practice for Specifying Color by Using the Optical Society of America Uniform Color Scales System( A& n7 S# q6 X
E1455-03 Practice for Obtaining Colorimetric Data from a Visual Display Unit Using Tristimulus Colorimeters : d$ _" m3 g. W3 x, B5 m* I1 m
E1477-98AR03 Test Method for Luminous Reflectance Factor of Acoustical Materials by Use of Integrating-Sphere Reflectometers; g+ p$ N' p% b8 c% g
E1478-97R03 Practice for Visual Color Evaluation of Transparent Sheet Materials3 J* f! N$ h. d- E
E1499-97R03 Guide for Selection, Evaluation, and Training of Observers, O0 ^+ ^( K8 k0 |! V9 U1 b
E1501-99R04 Specification for Nighttime Photometric Performance of Retroreflective Pedestrian Markings for Visibility Enhancement/ g$ h1 J% ]/ h/ |% r
E1541-98R03 Practice for Specifying and Matching Color Using the Colorcurve System . S. Q4 S+ Q% m& Y% {# J1 n" cE1651 Test Method for Total Luminous Reflectance Factor by Use of 30/t Integrating-Sphere Geometry ; T/ V q4 w+ c) I" c( K
E1682-05 Guide for Modeling the Colorimetric Properties of a Visual Display Unit6 Z/ b2 \" e! c& }5 l0 k6 i
E1696-04 Test Method for Field Measurement of Raised Retroreflective Pavement Markers Using a Portable Retroreflectometer1 W$ {/ N. h3 S; o
E1708-95R01 Practice for Electronic Interchange of Color and Appearance Data - x* M5 J( ?0 `" iE1709-00E01 Test Method for Measurement of Retroreflective Signs Using a Portable Retroreflectometer : N) x6 F; A: q; Y$ UE1710-05 Test Method for Measurement of Retroreflective Pavement Marking Materials with CEN-Prescribed Geometry Using a Portable Retroreflectometer 3 ^* o* {5 s: Q% D/ e. V3 V$ B
E1743 Practice for Selection and Use of Portable Retroreflectometers for the Measurement of Pavement Marking Materials( g3 t9 ?* b0 {! C4 M
E1767-04 Practice for Specifying the Geometries of Observation and Measurement to Characterize the Appearance of Materials 9 m$ @6 u" ~1 n; V( {; Q
E1808-96R03 Guide for Designing and Conducting Visual Experiments ) S/ o9 }4 @4 z4 @3 XE1809-01 Test Method for Measurement of High-Visibility Retroreflective-Clothing Marking Material Using a Portable Retroreflectometer " P( }; k! s# a$ t5 u, i4 z* rE2022-01 Practice for Calculation of Weighting Factors for Tristimulus Integration( \' k3 S. V& M8 ?0 \( w8 ^' X3 s
E2030-04 Guide for Recommended Uses of Photoluminescent (Phosphorescent) Safety Markings$ J: [$ U: }1 I6 j
E2072-04 Specification for Photoluminescent (Phosphorescent) Safety Markings6 y) b/ m( K8 i! @1 r
E2073-02 Test Method for Photopic Luminance of Photoluminescent (Phosphorescent) Markings $ ^- g. [5 n: e5 _/ J8 ~& r, |E2152-01 Practice for Computing the Colors of Fluorescent Objects from Bispectral Photometric Data* i, i- F. h/ y2 r- q
E2153-01 Practice for Obtaining Bispectral Photometric Data for Evaluation of Fluorescent Color 7 ]( l9 p" N, B+ M* p3 C$ @& eE2175-01 Practice for Specifying the Geometry of Multiangle Spectrophotometers % z7 h) S5 t3 N
E2176-01 Test Method for Measuring the Coefficient of Retroreflected Luminance (R) of Pavement Markings in a Standard Condition of Continuous Wetting # j) {8 f2 R/ _- E
E2177-01 Test Method for Measuring the Coefficient of Retroreflected Luminance (R) of Pavement Markings in a Standard Condition of Wetness 0 Y: ^ ]3 I0 [1 L! zE2194-03 Practice for Multiangle Color Measurement of Metal Flake Pigmented Materials / L4 ^5 i# W5 x2 DE2214-02 Practice for Specifying and Verifying the Performance of Color-Measuring Instruments + }8 |$ n2 G5 x2 F, U8 I' V, OE2222-02 Practice for Host Computer Communication with Spectrometers for Color Measurements : \: A5 f& s; k8 @
E2301-03 Test Method for Daytime Colorimetric Properties of Fluorescent Retroreflective Sheeting and Marking Materials for High Visibility Traffic Control and Personal Safety Applications Using 45|SD:Normal Geometry$ O1 j) A, l9 N' s6 _! ]1 j
E2302-03A Test Method for Measurement of the Luminance Coefficient Under Diffuse Illumination of Pavement Marking Materials Using a Portable Reflectometer! S) k; a4 ?" B" [& ?9 J
E2366-05 Test Method for Measurement of Daytime Chromaticity of Pavement Marking Materials Using a Portable Reflection Colorimeter 3 N7 b8 x' z y5 V; aE2367-05 Test Method for Measurement of Nighttime Chromaticity of Pavement Marking Materials Using a Portable Retroreflection Colorimeter * }# W+ V+ X$ v7 o6 w# JE2387-05 Practice for Goniometric Optical Scatter Measurements # J4 W$ K' A- f# aF0923-00 Guide to Properties of High Visibility Materials Used to Improve Individual Safety ; W+ a3 M( q- w6 k( V
