Volume 14.03, July 20054 U$ d! @9 M) n
Temperature Measurement
- N# `; w1 ]. b2 i# G, ZE0001-03A Specification for ASTM Liquid-in-Glass Thermometers
7 N4 l5 R4 S& Z& ~' qE0077-98R03 Test Method for Inspection and Verification of Thermometers. e2 h+ y3 o- N1 U$ o) X& }1 H4 v
E0100-03 Specification for ASTM Hydrometers
) s' D) V7 p% qE0126-92R98 Test Method for Inspection and Verification of Hydrometers/ M3 U3 d l: j# S3 y4 q1 j W4 u8 q" S
E0207-00 Test Method for Thermal EMF Test of Single Thermoelement Materials by Comparison with a Reference Thermoelement of Similar EMF-Temperature Properties
6 g# O+ m4 k! j" t0 rE0220-02 Test Method for Calibration of Thermocouples By Comparison Techniques O+ W, s2 W( ~) Z& ] q( G' a
E0230-03 Specification and Temperature-Electromotive Force (EMF) Tables for Standardized Thermocouples
5 r7 W3 I9 U- J6 J3 f; _8 ]9 i! @: _E0235-03 Specification for Thermocouples, Sheathed, Type K and Type N, for Nuclear or for Other High-Reliability Applications: t. b2 H% [9 K. s A0 S
E0344-02 Terminology Relating to Thermometry and Hydrometry9 T! y+ }/ Z9 U& l
E0452-02 Test Method for Calibration of Refractory Metal Thermocouples Using a Radiation Thermometer* L, f+ Q: y- x6 e7 P
E0563-02E01 Practice for Preparation and Use of an Ice-Point Bath as a Reference Temperature
1 W- \8 v# k6 }2 ]& ^E0574-00 Specification for Duplex, Base Metal Thermocouple Wire With Glass Fiber or Silica Fiber Insulation$ ? b' J; r# ~9 U
E0585_E0585M-04 Specification for Compacted Mineral-Insulated, Metal-Sheathed, Base Metal Thermocouple Cable) p' l' |# `* R. B8 K1 e
E0601-81R97 Test Method for Comparing EMF Stability of Single-Element Base-Metal Thermocouple Materials in Air& v0 y& `( y9 j
E0608_E0608M-00R04 Specification for Mineral-Insulated, Metal-Sheathed Base Metal Thermocouples
! {1 ]$ ^, ~$ v5 b: z; g+ tE0644-04 Test Methods for Testing Industrial Resistance Thermometers
: g: R; x7 a, _& ?4 [: Z2 lE0667-98R03 Specification for Mercury-in-Glass, Maximum Self-Registering Clinical Thermometers
; H3 Q$ i2 K5 w2 C/ I( ^E0696-00 Specification for Tungsten-Rhenium Alloy Thermocouple Wire" m0 N: R0 ]3 C
E0710-86R97 Test Method for Comparing EMF Stabilities of Base-Metal Thermoelements in Air Using Dual, Simultaneous, Thermal-EMF Indicators
3 F& ~7 N/ E0 _4 tE0780-92R98 Test Method for Measuring the Insulation Resistance of Sheathed Thermocouple Material at Room Temperature
0 d: j$ b1 V s1 VE0825-98R03 Specification for Phase Change-Type Disposable Fever Thermometer for Intermittent Determination of Human Temperature9 j5 l/ z% s) D9 F( d1 {: `
E0839-96 Test Methods for Sheathed Thermocouples and Sheathed Thermocouple Material
# Q. n) L) o# U) H9 h; H& vE0879-01 Specification for Thermistor Sensors for Clinical Laboratory Temperature Measurements
7 N8 z8 Z. T% g5 c/ s7 bE0988-96R02 Temperature-Electromotive Force (EMF) Tables for Tungsten-Rhenium Thermocouples
) D/ }2 ?. d% I0 S( h& J6 GE1061-01 Specification for Direct-Reading Liquid Crystal Forehead Thermometers
1 x# `; ]7 t/ a+ z; Q eE1104-98R03 Specification for Clinical Thermometer Probe Covers and Sheaths% }! E+ {% F) k: p% p) E
E1112-00 Specification for Electronic Thermometer for Intermittent Determination of Patient Temperature
" ?' A. Y Y: D5 ?% Z9 |( v wE1129_E1129M-98R02 Specification for Thermocouple Connectors& V' j) V' I& n6 A! t, d
E1137_E1137M-04 Specification for Industrial Platinum Resistance Thermometers" Y# H8 Q' Y* W
E1159-98R03 Specification for Thermocouple Materials, Platinum-Rhodium Alloys, and Platinum
1 k4 b, V; i5 @% { Z9 t7 tE1256-95R01 Test Methods for Radiation Thermometers (Single Waveband Type): y# h2 d) \0 l, T
E1299-96R02 Specification for Reusable Phase-Change-Type Fever Thermometer for Intermittent Determination of Human Temperature
7 @* X6 R7 B4 xE1350-97R01 Guide for Testing Sheathed Thermocouples Prior to, During, and After Installation
4 n3 t. J2 F- x2 ]3 JE1502-98R03E01 Guide for Use of Freezing-Point Cells for Reference Temperatures
) H9 b% e K7 Q2 IE1594-99 Guide for Expression of Temperature! u* @# y) K/ `
E1652-03 Specification for Magnesium Oxide and Aluminum Oxide Powder and Crushable Insulators Used in the Manufacture of Metal-Sheathed Platinum Resistance Thermometers, Base Metal Thermocouples, and Noble Metal
7 u, I8 w& m) m; y0 SThermocouples0 w0 Y1 X0 _7 Q$ C6 G# ?' s
E1684-00 Specification for Miniature Thermocouple Connectors% U) ]& n% \' f. @
E1750-02 Guide for Use of Water Triple Point Cells
# r1 q j4 e L+ x! pE1751-00 Guide for Temperature Electromotive Force (EMF) Tables for Non-Letter Designated Thermocouple Combinations
7 c+ P6 e& k, `& t9 _; j- p0 ?E1965-98R03 Specification for Infrared Thermometers for Intermittent Determination of Patient Temperature. t# m: z: `! C1 ], z% `" v: y
E2181_E2181M-01 Specification for Compacted Mineral-Insulated, Metal-Sheathed, Noble Metal Thermocouples and Thermocouple Cable2 W8 y `+ I A
E2251-03A Specification for Liquid-in-Glass ASTM Thermometers with Low-Hazard Precision Liquids
E 2251 - 03 _RTIYNTETUKVE.pdf
(150.6 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
5 w f% E; a3 y+ |6 O1 a" k5 W' W9 P) g" o6 A8 G n0 `- d
E 2251 - 03 _RTIYNTETMDM_.pdf
(186.95 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
& G. ]& B& g( D5 M* i
' |* O1 o1 D& F. v
E 2251 - 03 _RTIYNTE_.pdf
(178.91 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
1 [" \$ r2 [. ]
1 ~. |" l! @: l$ ^! w2 c
E 2181 - E 2181M - 01 _RTIXODEVRTIXODFN.pdf
(101.41 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
5 u7 t" o1 ?* a) J; u
5 ^# B4 d/ j* k* V
E 1965 - 98 R03 _RTE5NJU_.pdf
(237.45 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
/ e2 d: J2 Q. c+ G4 n0 ?
, `5 D3 f0 T( ^6 J1 Q: u8 V
E 1965 - 98 _RTE5NJUTOTG_.pdf
(243.43 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
1 [. j, X+ ^8 d
4 [4 w. p+ u* h) l8 \. c6 L/ r, D
E 1751 - 00 _RTE3NTE_.pdf
(4.88 MB, Lượt tải về: 6, Giá: 1 điểmThưởng)
7 `2 h# K, H- f1 p% T* H8 Z) X
# d5 d, B$ G- L- _$ _, u
E 1750 - 95 _RTE3NTATUKVE.pdf
(98.13 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
( F2 s$ ^6 D* f% X8 ?1 z
9 ]0 s" ~5 [8 \- t& }0 ]5 f
E 1750 - 95 _RTE3NTATOTU_.pdf
(90.63 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
. x) g! M* F" ~( ^4 c$ }
& g1 {0 q2 k2 S' v8 ^
E 1750 - 02 _RTE3NTA_.pdf
(108.34 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
3 x4 B2 R7 k$ S, V3 [
# d! I% S! B' b! W
E 1684 - 00 _RTE2ODQ_.pdf
(45.28 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
3 G% \3 B+ Z' D3 m9 T1 d. y' r
% A6 {& L5 p, M& ?/ x) ^
E 1652 - 03 _RTE2NTI_.pdf
(79.26 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
9 r: \! h b3 A. b8 e3 \
+ x3 M. P0 g1 d4 j
E 1652 - 00 _RTE2NTITUKVE.pdf
(63.13 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
# o* d% n% V) o8 M
% i( S$ ?9 P& m" ]
E 1652 - 00 _RTE2NTITMDA_.pdf
(80.62 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
3 i) o: x% m. n% l8 z
& T$ M: t! v8 @: P L: f
E 1594 - 99 _RTE1OTQ_.pdf
(21.56 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
/ ~+ @0 T. u/ n* j% m1 x' v
2 r: o+ x$ @2 I- V" K7 t4 X! X9 G
E 1502 - 98 R03 _RTE1MDI_.pdf
(136.88 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
9 L4 Q( I: b/ [* d! f& o( U+ ~ l. L6 T0 H
E 1502 - 98 _RTE1MDITOTG_.pdf
(131.03 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
7 o4 L5 c3 b; S0 |
+ F; r$ f8 U7 e! r9 t
E 1350 - 97 R01 _RTEZNTA_.pdf
(52.95 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
+ M: T% }& }& _+ I% ]
+ b ~. z- S, d
E 1350 - 97 _RTEZNTATOTC_.pdf
(37.34 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
; P3 o9 j3 D( Q. e4 I
+ b% {( t4 {( V W V+ I
E 1299 - 96 R02 _RTEYOTK_.pdf
(33.72 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
6 o; J: r; Z. i
+ ]9 J- e) Q9 T1 X2 n$ N( b
E 1299 - 96 _RTEYOTKTOTY_.pdf
(22.54 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
1 i7 p# o' c5 L/ R) W) W
2 e/ s8 v% r; k$ e+ o
E 1256 - 95 R01 _RTEYNTY_.pdf
(95.48 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
! Z9 b6 y( { H" ?7 W2 Z* A' ?$ Q1 i. C% {5 A. [, u2 q& Q
E 1256 - 95 _RTEYNTYTOTU_.pdf
(71.1 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
6 I; U3 q/ u$ [/ R; T- y0 R) [. m) T; S5 o- ?
E 1159 - 98 R03 _RTEXNTK_.pdf
(29.5 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
7 A, [$ ?: m k e: {9 D3 }3 V8 j0 I1 K4 W
% X8 a3 n' Q+ N7 }1 ^
E 1137 - 97 _RTEXMZC_.pdf
(69.05 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
8 \2 d" I5 K' @+ s
6 o& q) R) K" r: s7 ^
E 1129 - E 1129M - 98 R02 _RTEXMJKVRTEXMJLN.pdf
(61.74 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
5 d8 f1 \9 \! E# H' b
% Z# u7 p' Z( u- K1 h0 u9 q) V; `
E 1112 - 98 _RTEXMTITUKVE.pdf
(30.18 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
6 W5 i* Q2 ]' W2 k# M2 P% C
2 t! I2 I+ N' J9 v
E 1112 - 00 _RTEXMTI_.pdf
(27.07 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
6 n& S4 b% @2 O1 V
- Y& N( G' Z5 i; i9 p* Y
E 1104 - 98 R03 _RTEXMDQ_.pdf
(27.57 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
$ m! b8 h; d L0 Q$ C9 X0 E; H# w
& Y- z; O) I5 A0 y
E 1104 - 98 _RTEXMDQTOTG_.pdf
(27.91 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
2 d" D. m( r; F+ h& g
, z8 N" a) k( J& t
E 1061 - 94 R00 _RTEWNJETUKVE.pdf
(25.75 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
: l8 q0 [. D, H5 }' `
0 m f& Y0 a: m, `) Y }
E 1061 - 94 R00 _RTEWNJETOTRSMDA_.pdf
(20.05 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
* C2 w5 V4 Y& a7 l. m9 Q7 X
# z) z0 s1 U2 n
E 1061 - 01 _RTEWNJE_.pdf
(29.24 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
9 [3 X. I5 r* g3 j
2 N0 ?* Y- z1 {1 q, g
E 988 - 96 R02 _RTK4OA__.pdf
(1.91 MB, Lượt tải về: 5, Giá: 1 điểmThưởng)
3 }2 v# r+ k: ], z9 v' r4 ?8 b, _/ [1 h8 t: J& k# F
E 988 - 96 _RTK4OC05NG__.pdf
(1.88 MB, Lượt tải về: 5, Giá: 1 điểmThưởng)
4 Q# C% V+ Y) U8 j9 a
! O, [: T3 e# I' G0 R( R
E 879 - 93 _RTG3OS05MW__.pdf
(104.7 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
# {' M3 j$ A7 E5 @( I% W) D |
! V! h( H8 M4 y
E 879 - 93 _RTG3OS1SRUQ_.pdf
(117.84 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
$ z( j! s* j" k0 C7 v
/ p4 X' F: e9 U- \% R
E 879 - 01 _RTG3OQ__.pdf
(135.94 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
/ V8 d" b# _# K' j7 A
0 }3 Y+ g, ]/ G# ^% ^0 W
E 839 - 96 _RTGZOQ__.pdf
(168.08 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
# g1 b9 f* \0 u2 C/ `
: L3 ?5 ?* p4 M
E 825 - 98 R03 _RTGYNQ__.pdf
(38.07 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
1 F: P- J& m: \
6 s& L; ^, N) V; m( t6 C
E 825 - 98 _RTGYNS05OA__.pdf
(37.43 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
. U3 ~2 e5 Q! X$ F( R0 i: Y- f$ e
}1 K9 Z! E' g9 ]$ c) ~( r
E 780 - 92 R98 _RTC4MA__.pdf
(36.42 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
* I' }+ _( T4 d5 h. z
! Y! i X* J$ N
E 710 - 86 R97 _RTCXMA__.pdf
(66.87 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
8 c' ?0 Y. I# J5 p5 Y# {3 J0 ^! Z( s5 h/ u
E 696 - 95 _RTY5NI1SRUQ_.pdf
(21.98 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
# n: s" w7 S/ d
! g" d6 }6 L$ h2 X2 T2 X0 B
E 696 - 00 _RTY5NG__.pdf
(29.42 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
8 V& l+ w/ D7 g! N6 s$ A
. W* Y$ u7 `% i/ K' {0 b
E 667 - 98 R03 _RTY2NW__.pdf
(74.8 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
7 b& B ^: v) m
* [& m& x4 C- s x8 T* [
E 667 - 98 _RTY2NY05OA__.pdf
(76.34 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
4 e, b1 D. S, S; ]# M, M( A) t- j: y2 m4 e) z- k
E 644 - 98 _RTY0NC05OA__.pdf
(176.58 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
/ T/ Z% r' y8 k! [ ^
" F( Y1 f1 v+ T. X# c# N$ G
E 644 - 04 _RTY0NA__.pdf
(183.22 KB, Lượt tải về: 5, Giá: 1 điểmThưởng)
+ B6 B, M: N$ ]* X: T3 {
+ J5 A' \% g- V2 J6 R! x
E 644 - 02 _RTY0NC1SRUQ_.pdf
(156.75 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
- ?; @2 w; n9 z2 q5 b# c2 b
5 u+ ?8 p" x) k& Y
E 644 - 02 _RTY0NC0WMG__.pdf
(181.1 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
& U. A% f! v0 o. {2 ?5 L4 v
4 c" S' O7 D! ^9 Q5 V' g# A" v
E 608 - E 608M - 00 R04 _RTYWOC9FNJA4TQ__.pdf
(84.62 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
6 u/ w% a3 f. N6 y9 Q3 p$ @9 D+ o0 P; g
E 608 - E 608M - 00 _RTYWOC0WMA__.pdf
(84.92 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
^/ {! G3 n+ K' q0 T
1 R0 M! r* O+ [& Y# z5 Y
E 601 - 81 R97 _RTYWMQ__.pdf
(47.72 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
* c& Q: P" u3 {8 y' W% s0 l4 }
0 Z5 C( ? p" B3 M R
E 585 - E 585M - 99 _RTU4NS05OQ__.pdf
(45.21 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
4 {$ M# }# X1 s' P" o6 }* ?7 f- Q6 o0 ^ D0 P
E 585 - E 585M - 04 _RTU4NS9FNTG1TQ__.pdf
(63.85 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
+ T1 F8 d$ S9 d! p; R$ U3 e
3 K: L- \7 b# a7 }6 j
E 585 - E 585M - 01 _RTU4NS9FNTG1TS1SRUQ_.pdf
(50.38 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
0 U! d/ i* v8 X8 `2 t
' m5 _3 r# C3 U
E 585 - E 585M - 01 _RTU4NS0WMUE_.pdf
(63.78 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
0 G, b0 D, |! |3 [; J/ g0 I$ s
4 F) k/ q5 i0 ^* l3 `
E 585 - E 585M - 01 _RTU4NS0WMQ__.pdf
(46.86 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
7 P3 s! v; i; ?! t0 n$ y3 M
. ^% J4 G6 o& {4 E# I# T3 r5 g
E 574 - 93 _RTU3NC1SRUQ_.pdf
(31.28 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
9 ~+ f( S) I, P' u9 r1 O+ i; \
8 Q/ [# ]; i6 Z4 {; X( G- |
E 574 - 00 _RTU3NA__.pdf
(34.25 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
5 e+ S8 F$ e/ t" C8 w, V3 |
! `: m4 F W2 V- V) i) E$ U0 `
E 563 - 97 _RTU2MY1SRUQ_.pdf
(26.88 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
3 V+ R- h8 _+ j% S* H* l5 e4 _
. l1 J) ]0 T7 j
E 563 - 02 _RTU2MW__.pdf
(35.12 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
- G0 v0 F3 ]- T
. \6 Y/ d% k" U5 E( H
E 452 - 97 _RTQ1MI05NW__.pdf
(183.08 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
7 E9 r% R' f) O$ Y5 Q* C7 o
: t8 p5 d% t# h- f6 t& \8 `
E 452 - 02 _RTQ1MG__.pdf
(212.59 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
?, ?7 L0 U$ }' {' }5 p3 g. _3 c; S- ^0 R/ ?" \
E 344 - 02 _RTM0NA__.pdf
(99.81 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
' [3 H- q' ~2 H7 o- W5 {! S- d7 B+ A. `
E 344 - 01 _RTM0NC1SRUQ_.pdf
(83.51 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
* m# t+ p8 B7 r* j. `7 r1 q. i8 w% P
8 j) z: c8 N' w# v0 `
E 344 - 01 _RTM0NC0WMQ__.pdf
(78.36 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
2 f3 C) v8 H! c% ?1 f" M8 G4 A! _/ p
E 344 - 00 _RTM0NC0WMA__.pdf
(75.14 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
7 W8 P5 H. C) p+ l- [
) l# o$ B. ?5 L3 k B3 }4 `) p) ?7 X
E 235 - 88 R96 _RTIZNS04OFI5NKUX.pdf
(65.65 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
* U: G6 J/ D1 l- y7 F1 A) ?0 \$ `- h# q
E 235 - 88 R96 _RTIZNS1SRUQ_.pdf
(53.95 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
Z. U* |3 {9 N# l
( E0 k$ W4 k* B
E 235 - 03 _RTIZNQ__.pdf
(53.08 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
3 ^+ y5 l) X3 T: J+ H5 Z, j5 @
8 V- ?- w& V, O& x
E 230 - 98 _RTIZMC05OA__.pdf
(7.27 MB, Lượt tải về: 5, Giá: 1 điểmThưởng)
2 j$ g* m. w4 v( s/ P8 p& q: o3 S% N! h5 `8 p' }8 F8 k
E 220 - 86 R96 _RTIYMC1SRUQ_.pdf
(196.12 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
; ~5 c5 I' p8 i: }, J
' q4 u, e4 s8 U6 O/ q
E 220 - 02 _RTIYMA__.pdf
(208.12 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
' g# N* T8 O4 T% o# S v6 A
6 N& W9 O7 z# _7 b
E 207 - 96 _RTIWNY1SRUQ_.pdf
(61.41 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
^& P& R: r# ~8 E ?+ Y; q# ? Q9 d0 [+ ?6 [' _# L* j
E 207 - 00 _RTIWNW__.pdf
(46.41 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
1 g8 W, o& t( L& e* C( s
8 g1 V9 Y% M2 q$ T/ e1 i* m2 b. k
E 126 - 92 R98 _RTEYNG__.pdf
(63.04 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
6 f9 G# Y' G3 D. r! O
5 W) J1 a2 m: g- \
E 100 - 95 R01 _RTEWMC1SRUQ_.pdf
(63.07 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
0 z, e T0 Q" A$ ] G8 f g
9 \ ^1 k5 R1 l8 I
E 100 - 95 _RTEWMC05NQ__.pdf
(48.92 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
, ?; l: t# D/ i3 h4 S& H
4 R4 D0 B: _% ]
E 100 - 03 _RTEWMA__.pdf
(71.41 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
1 u* q3 i: m/ i" O! o9 _
- ~5 K/ f _' v5 J9 f. Z( g
E 77 - 98 R03 _RTC3LVJFRA__.pdf
(174.23 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
V5 r) k5 P. Q/ e, N/ A: F- [3 u! P' Y, J
E 77 - 98 R03 _RTC3.pdf
(197.11 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
6 L4 |6 S; f. ^( a* I7 [* S
' N M0 P& H7 J2 l# f' `( V' Y
E 1 - 98 _RTETOTHFMQ__.pdf
(232.73 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
5 v6 d% U: E/ m1 H
! L' R: P5 P3 R. ^
E 1 - 98 _RTETOTG_.pdf
(226.07 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
; t0 H D! y. W! `. G. \
: |+ l* ?+ C* u- Q! ?
E 1 - 03 _RTETUKVE.pdf
(273.13 KB, Lượt tải về: 2, Giá: 1 điểmThưởng)
& W! r( n- ?, E% ^ n4 ~5 F8 _4 ~
5 c/ h. ?) [* V) x0 h- l
E 1 - 03 _RTETMDM_.pdf
(392.52 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
# Q z/ r0 {. O. x& Q7 _ m
( n, Q3 b( E {% v/ ]
E 1 - 03 _RTE_.pdf
(342.44 KB, Lượt tải về: 3, Giá: 1 điểmThưởng)
8 g8 r+ V& P3 O2 v
r6 b/ F3 W# s$ l6 a: |# ?' X+ ?- u
E 1 - 01 _RTETMDE_.pdf
(354.41 KB, Lượt tải về: 4, Giá: 1 điểmThưởng)
; z. t1 u0 q Y+ D3 u
- X" H9 F# \9 O% G8 Q
ASTM-2004_full index.pdf
(861.79 KB, Lượt tải về: 6, Giá: 1 điểmThưởng)
+ o' Q5 Y m6 D8 y) t/ J
f, L& C5 b6 Y* o7 p0 _9 P
4 k6 O! i6 q1 a |
